how to do temperature control
scm2000
Post by scm2000 »
the log says "temperature control disabled" when it gets a work unit.
How can I enable temperature control on a GPU core?
09:18:08:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
Re: how to do temperature control
It was a feature few FahCores back that wasn't implemented. It's a leftover message that will eventually be cleaned up.
