slow slots vs fast slots
sk69
Post by sk69 »
I have 4 laptops at home which are folding. I have set the same userid, passkey and team for all these laptops. One of my laptop is a gaming laptop, with has a fast CPU and RTX 2060, and hence has a much higher PPD. The other laptops are relatively slower. If my gaming laptop's CPU slot has 33000 PPD, my other laptop's CPU slot might be 4000 PPD. Due to the slow laptops in my mix, will the bonus points of my gaming laptop's slots will be impacted too? Should i stop using my slower laptops?
Re: slow slots vs fast slots
No
The Quick Return Bonus is determined from when you start the download to when you finish the same Work Unit's upload. So the PC's do not effect each other unless they are all uploading at the same time, which is unlikely.
All the science is good science! (Unless it times out)
sk69
Post by sk69 »
ok, but with the same username and passkey... my gaming laptop's CPU slot almost always completes and uploads at full speed and uninterrupted.... on the other hand one of my laptop is my daughters, and she may turn it off and turn on next day...which means that laptop would be completing and sending back WUs slower... so is the QRB able to differentiate based on slots....or when my daughter takes more time to complete....then it impacts my gaming cpu slot too?
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
The QRB is based on the workunit. Each workunit has Base Credit and the timer starts from when you download the workunit to when you finish uploading it. So your gaming laptop will complete its workunit quickly and get a significant amount of bonus points. Your daughter's machine will take longer and won't get as much bonus points as a result.
In addition to what's been already told, there's a possibility that you may loose the QRB if the return rate of WUs falls under 80% i.e. out of 10 WUs assigned to your identity (username+passkey), 4 have never been returned (those WUs reached the expiration date).
sk69
Post by sk69 »
Wishlist: There should be a way to join multiple teams :) This will help a lot in different tracking goals... e.g. one main team similar to current team, but then, perhaps in my home I would have split faster machines in one team and slower machines in different teams to see how they are performing, and so that slower machines do not hurt faster machines.
You can join multiple teams, for each machine, change the Team ID :)
Slower machines don't hurt the faster ones. Each machine functionally stands alone.
sk69
Post by sk69 »
PantherX wrote:You can join multiple teams, for each machine, change the Team ID :)
Are you saying that the same machine, user and passkey can join more than one teams? That is what I was suggesting. If this is already possible, then that is cool!
jrweiss
Post by jrweiss »
Yes. Just pick a different team on each machine. If you are counting points, though, be aware that points accumulate and are posted by the user+team combination, so you will have to add up your total points yourself.
Technically, you can change team numbers on a machine at any time, and it will take effect on the next download. It's probably too much of a bother to do on a regular basis...
HaloJones
Post by HaloJones »
the user and passkey are for you. the team id at the time of submitting the unit is where the points for that unit go as a team contribution.
you can't have one slot for one team and another slot on the same machine going to different teams as the team id is set for the client not the slot.
two different machines can contribute to a single user and two teams.
single 1070
JimTheoHome
Post by JimTheoHome »
Seems to me the best way to differentiate between machines would be to have different Machine names that all belong to the same Team name/number. That way you could track which machine is doing what and how may points are awarded per WU. In the grand scheme of things, it don't mean much but it can help you keep track of your own contributions to the cause.
I.E. TeamName: Jimxxxx ID#99999 Computer1Name: Jimxxxx1, Computer2Name: Jimxxxx2, etc.
I think of all of my PCs as one farm. JimboPalmer has 21 active clients in the last 7 days and that is all the detail I need. (CPU slots and GPU slots count as a client each)
iceman1992
Post by iceman1992 »
JimTheoHome wrote:Seems to me the best way to differentiate between machines would be to have different Machine names that all belong to the same Team name/number. That way you could track which machine is doing what and how may points are awarded per WU. In the grand scheme of things, it don't mean much but it can help you keep track of your own contributions to the cause.
I think it's also possible for 1 username to have multiple passkeys, and to search the credits based on the passkeys, but I might be wrong.
uyaem
Post by uyaem »
iceman1992 wrote:I think it's also possible for 1 username to have multiple passkeys, and to search the credits based on the passkeys, but I might be wrong.
Should be possible if you use different email addresses to request passkeys for the same user.
