AMD Radeon RX 590 8GB
Hello from Northern Germany,
I am new to this board and kind of new to folding and a little bit overwhelmed by this forum, so I am sorry if this was asked before. (Actually I did'nt find RX 590 in the search)
I want to give my full power to this, but my GPU has nothing to do. At the beginning I had a slot error, but now there is just nothing to do and no notification
Grafik-Chipsatz
Radeon RX 590 Series
GDDR5 2000Mhz
Can I do something about it?
Thank you, stay healthy
Kammarah
Grafik-Chipsatz
GDDR5 2000Mhz
Kammarah
Re: AMD Radeon RX 590 8GB
There are some posts here on the RX 590 - viewtopic.php?f=83&t=33058&hilit=radeon+590 & viewtopic.php?f=106&t=33150&hilit=radeon+590 - and it has been mentioned in a few other topics.
Currently there are some shortages of WUs for GPUs, so it may take a bit before your folding cling downloads a WU.
If you post your log using the directions in the Welcome topic - viewtopic.php?f=106&t=26036 - we can look it over to see if there is anything particular that might be an issue.
Thank you for your reply.
Here is my log. I followed Method 1 from your help topic.
*********************** Log Started 2020-04-14T18:58:54Z ***********************
18:58:54:************************* Folding@home Client *************************
18:58:54: Website: https://foldingathome.org/
18:58:54: Copyright: (c) 2009-2018 foldingathome.org
18:58:54: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:58:54: Args:
18:58:54: Config: C:\Users\User\AppData\Roaming\FAHClient\config.xml
18:58:54:******************************** Build ********************************
18:58:54: Version: 7.5.1
18:58:54: Date: May 11 2018
18:58:54: Time: 13:06:32
18:58:54: Repository: Git
18:58:54: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:58:54: Branch: master
18:58:54: Compiler: Visual C++ 2008
18:58:54: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:58:54: Platform: win32 10
18:58:54: Bits: 32
18:58:54: Mode: Release
18:58:54:******************************* System ********************************
18:58:54: CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
18:58:54: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:58:54: CPUs: 8
18:58:54: Memory: 31.94GiB
18:58:54: Free Memory: 29.12GiB
18:58:54: Threads: WINDOWS_THREADS
18:58:54: OS Version: 6.2
18:58:54: Has Battery: false
18:58:54: On Battery: false
18:58:54: UTC Offset: 2
18:58:54: PID: 11056
18:58:54: CWD: C:\Users\User\AppData\Roaming\FAHClient
18:58:54: OS: Windows 10 Enterprise
18:58:54: OS Arch: AMD64
18:58:54: GPUs: 1
18:58:54: GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
18:58:54: 470/480/570/580/590]
18:58:54: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
18:58:54: angegebene Modul wurde nicht gefunden.
18:58:54:
18:58:54:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
18:58:54: Win32 Service: false
18:58:54:***********************************************************************
18:58:54:<config>
18:58:54: <!-- Slot Control -->
18:58:54: <power v='MEDIUM'/>
18:58:54:
18:58:54: <!-- User Information -->
18:58:54: <user v='KammarahPro'/>
18:58:54:
18:58:54: <!-- Folding Slots -->
18:58:54: <slot id='0' type='CPU'/>
18:58:54: <slot id='1' type='GPU'/>
18:58:54:</config>
18:58:54:Trying to access database...
18:58:54:Successfully acquired database lock
18:58:54:Enabled folding slot 00: READY cpu:6
18:58:54:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
18:58:54:WU01:FS00:Starting
18:58:54:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 11056 -checkpoint 15 -np 6
18:58:55:WU01:FS00:Started FahCore on PID 11152
18:58:55:WU01:FS00:Core PID:6304
18:58:55:WU01:FS00:FahCore 0xa7 started
18:58:55:WU00:FS01:Connecting to 65.254.110.245:8080
18:58:56:WU01:FS00:0xa7:*********************** Log Started 2020-04-14T18:58:55Z ***********************
18:58:56:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:58:56:WU01:FS00:0xa7: Type: 0xa7
18:58:56:WU01:FS00:0xa7: Core: Gromacs
18:58:56:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 11152 -checkpoint 15 -np
18:58:56:WU01:FS00:0xa7: 6
18:58:56:WU01:FS00:0xa7:************************************ CBang *************************************
18:58:56:WU01:FS00:0xa7: Date: Oct 26 2019
18:58:56:WU01:FS00:0xa7: Time: 01:38:25
18:58:56:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:58:56:WU01:FS00:0xa7: Branch: master
18:58:56:WU01:FS00:0xa7: Compiler: Visual C++ 2008
18:58:56:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:58:56:WU01:FS00:0xa7: Platform: win32 10
18:58:56:WU01:FS00:0xa7: Bits: 64
18:58:56:WU01:FS00:0xa7: Mode: Release
18:58:56:WU01:FS00:0xa7:************************************ System ************************************
18:58:56:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
18:58:56:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:58:56:WU01:FS00:0xa7: CPUs: 8
18:58:56:WU01:FS00:0xa7: Memory: 31.94GiB
18:58:56:WU01:FS00:0xa7:Free Memory: 29.03GiB
18:58:56:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
18:58:56:WU01:FS00:0xa7: OS Version: 6.2
18:58:56:WU01:FS00:0xa7:Has Battery: false
18:58:56:WU01:FS00:0xa7: On Battery: false
18:58:56:WU01:FS00:0xa7: UTC Offset: 2
18:58:56:WU01:FS00:0xa7: PID: 6304
18:58:56:WU01:FS00:0xa7: CWD: C:\Users\User\AppData\Roaming\FAHClient\work
18:58:56:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
18:58:56:WU01:FS00:0xa7: Version: 0.0.18
18:58:56:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:58:56:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
18:58:56:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
18:58:56:WU01:FS00:0xa7: Time: 01:52:30
18:58:56:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:58:56:WU01:FS00:0xa7:************************************ Build *************************************
18:58:56:WU01:FS00:0xa7: SIMD: avx_256
18:58:56:WU01:FS00:0xa7:********************************************************************************
18:58:56:WU01:FS00:0xa7:Project: 16420 (Run 1041, Clone 1, Gen 15)
18:58:56:WU01:FS00:0xa7:Unit: 0x00000012a8f5c67d5e8a611a03b25462
18:58:56:WU01:FS00:0xa7:Digital signatures verified
18:58:56:WU01:FS00:0xa7:Calling: mdrun -s frame15.tpr -o frame15.trr -x frame15.xtc -cpi state.cpt -cpt 15 -nt 6
18:58:56:WU01:FS00:0xa7:Steps: first=3750000 total=250000
18:58:56:WU01:FS00:0xa7:Completed 112061 out of 250000 steps (44%)
18:58:58:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:58:58:WU00:FS01:Connecting to 18.218.241.186:80
18:59:00:WU00:FS01:Assigned to work server 140.163.4.241
18:59:00:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 140.163.4.241
18:59:00:WU00:FS01:Connecting to 140.163.4.241:8080
18:59:11:WU00:FS01:Downloading 7.92MiB
18:59:12:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
18:59:17:WU00:FS01:Download 6.31%
18:59:23:WU00:FS01:Download 22.87%
18:59:29:WU00:FS01:Download 52.84%
18:59:35:WU00:FS01:Download 86.76%
18:59:39:WU00:FS01:Download complete
18:59:39:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11745 run:0 clone:2726 gen:61 core:0x22 unit:0x0000005a8ca304f15e6a04f3219e2e48
18:59:39:WU00:FS01:Starting
18:59:39:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 11056 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:59:39:WU00:FS01:Started FahCore on PID 500
18:59:40:WU00:FS01:Core PID:11996
18:59:40:WU00:FS01:FahCore 0x22 started
18:59:40:WU00:FS01:0x22:*********************** Log Started 2020-04-14T18:59:40Z ***********************
18:59:40:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:59:40:WU00:FS01:0x22: Type: 0x22
18:59:40:WU00:FS01:0x22: Core: Core22
18:59:40:WU00:FS01:0x22: Website: https://foldingathome.org/
18:59:40:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
18:59:40:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:59:40:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
18:59:40:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 500 -checkpoint 15
18:59:40:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:59:40:WU00:FS01:0x22: Config: <none>
18:59:40:WU00:FS01:0x22:************************************ Build *************************************
18:59:40:WU00:FS01:0x22: Version: 0.0.2
18:59:40:WU00:FS01:0x22: Date: Dec 6 2019
18:59:40:WU00:FS01:0x22: Time: 21:30:31
18:59:40:WU00:FS01:0x22: Repository: Git
18:59:40:WU00:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
18:59:40:WU00:FS01:0x22: Branch: HEAD
18:59:40:WU00:FS01:0x22: Compiler: Visual C++ 2008
18:59:40:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:59:40:WU00:FS01:0x22: Platform: win32 10
18:59:40:WU00:FS01:0x22: Bits: 64
18:59:40:WU00:FS01:0x22: Mode: Release
18:59:40:WU00:FS01:0x22:************************************ System ************************************
18:59:40:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
18:59:40:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:59:40:WU00:FS01:0x22: CPUs: 8
18:59:40:WU00:FS01:0x22: Memory: 31.94GiB
18:59:40:WU00:FS01:0x22:Free Memory: 28.21GiB
18:59:40:WU00:FS01:0x22: Threads: WINDOWS_THREADS
18:59:40:WU00:FS01:0x22: OS Version: 6.2
18:59:40:WU00:FS01:0x22:Has Battery: false
18:59:40:WU00:FS01:0x22: On Battery: false
18:59:40:WU00:FS01:0x22: UTC Offset: 2
18:59:40:WU00:FS01:0x22: PID: 11996
18:59:40:WU00:FS01:0x22: CWD: C:\Users\User\AppData\Roaming\FAHClient\work
18:59:40:WU00:FS01:0x22: OS: Windows 10 Pro
18:59:40:WU00:FS01:0x22: OS Arch: AMD64
18:59:40:WU00:FS01:0x22:********************************************************************************
18:59:40:WU00:FS01:0x22:Project: 11745 (Run 0, Clone 2726, Gen 61)
18:59:40:WU00:FS01:0x22:Unit: 0x0000005a8ca304f15e6a04f3219e2e48
18:59:40:WU00:FS01:0x22:Reading tar file core.xml
18:59:40:WU00:FS01:0x22:Reading tar file integrator.xml
18:59:40:WU00:FS01:0x22:Reading tar file state.xml
18:59:41:WU00:FS01:0x22:Reading tar file system.xml
18:59:41:WU00:FS01:0x22:Digital signatures verified
18:59:41:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:59:41:WU00:FS01:0x22:Version 0.0.2
18:59:52:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
18:59:52:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:00:34:WU01:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
19:01:25:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
19:01:54:WU01:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
19:02:59:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
19:03:15:WU01:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
19:04:32:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
19:04:35:WU01:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
19:04:51:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
19:04:51:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
19:04:56:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
19:04:56:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
19:05:00:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
19:05:00:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
19:05:00:WU00:FS01:0x22:ERROR:114: Max Retries Reached
19:05:00:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
19:05:00:WU00:FS01:0x22:Saving result file badstate-0.xml
19:05:02:WU00:FS01:0x22:Saving result file badstate-1.xml
19:05:04:WU00:FS01:0x22:Saving result file badstate-2.xml
19:05:06:WU00:FS01:0x22:Saving result file checkpt.crc
19:05:06:WU00:FS01:0x22:Saving result file science.log
19:05:06:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
19:05:07:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:05:07:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11745 run:0 clone:2726 gen:61 core:0x22 unit:0x0000005a8ca304f15e6a04f3219e2e48
19:05:07:WU00:FS01:Uploading 20.50MiB to 140.163.4.241
19:05:07:WU00:FS01:Connecting to 140.163.4.241:8080
19:05:07:WU02:FS01:Connecting to 65.254.110.245:8080
19:05:08:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:05:08:WU02:FS01:Connecting to 18.218.241.186:80
19:05:09:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:05:09:ERROR:WU02:FS01:Exception: Could not get an assignment
19:05:09:WU02:FS01:Connecting to 65.254.110.245:8080
19:05:10:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:05:10:WU02:FS01:Connecting to 18.218.241.186:80
19:05:11:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:05:11:ERROR:WU02:FS01:Exception: Could not get an assignment
19:05:13:WU00:FS01:Upload 4.27%
19:05:19:WU00:FS01:Upload 7.62%
19:05:25:WU00:FS01:Upload 9.45%
19:05:31:WU00:FS01:Upload 11.89%
19:05:37:WU00:FS01:Upload 16.16%
19:05:43:WU00:FS01:Upload 20.42%
19:05:49:WU00:FS01:Upload 23.47%
19:05:55:WU00:FS01:Upload 27.43%
19:05:55:WU01:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
19:06:01:WU00:FS01:Upload 32.01%
19:06:07:WU00:FS01:Upload 36.27%
19:06:09:WU02:FS01:Connecting to 65.254.110.245:8080
19:06:10:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:06:10:WU02:FS01:Connecting to 18.218.241.186:80
19:06:11:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:06:11:ERROR:WU02:FS01:Exception: Could not get an assignment
19:06:13:WU00:FS01:Upload 40.54%
19:06:19:WU00:FS01:Upload 45.42%
19:06:25:WU00:FS01:Upload 48.77%
19:06:31:WU00:FS01:Upload 50.90%
19:06:37:WU00:FS01:Upload 55.17%
19:06:43:WU00:FS01:Upload 59.74%
19:06:49:WU00:FS01:Upload 64.32%
19:06:55:WU00:FS01:Upload 68.89%
19:07:01:WU00:FS01:Upload 73.16%
19:07:07:WU00:FS01:Upload 78.03%
19:07:13:WU00:FS01:Upload 82.00%
19:07:13:WU01:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
19:07:19:WU00:FS01:Upload 86.87%
19:07:25:WU00:FS01:Upload 91.44%
19:07:31:WU00:FS01:Upload 95.71%
19:07:41:WU00:FS01:Upload complete
19:07:41:WU00:FS01:Server responded WORK_ACK (400)
19:07:41:WU00:FS01:Cleaning up
19:07:46:WU02:FS01:Connecting to 65.254.110.245:8080
19:07:47:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:07:47:WU02:FS01:Connecting to 18.218.241.186:80
19:07:48:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:07:48:ERROR:WU02:FS01:Exception: Could not get an assignment
19:08:31:WU01:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
19:09:50:WU01:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
19:10:23:WU02:FS01:Connecting to 65.254.110.245:8080
19:10:25:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:10:25:WU02:FS01:Connecting to 18.218.241.186:80
19:10:26:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:10:26:ERROR:WU02:FS01:Exception: Could not get an assignment
19:11:08:WU01:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
19:12:27:WU01:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
19:13:46:WU01:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
19:14:38:WU02:FS01:Connecting to 65.254.110.245:8080
19:14:39:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:14:39:WU02:FS01:Connecting to 18.218.241.186:80
19:14:39:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:14:39:ERROR:WU02:FS01:Exception: Could not get an assignment
19:15:05:WU01:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
19:16:24:WU01:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
19:17:42:WU01:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
19:19:01:WU01:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
19:20:20:WU01:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
19:21:29:WU02:FS01:Connecting to 65.254.110.245:8080
19:21:30:WU02:FS01:Assigned to work server 140.163.4.241
19:21:30:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 140.163.4.241
19:21:30:WU02:FS01:Connecting to 140.163.4.241:8080
19:21:38:WU01:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
19:21:39:WU02:FS01:Downloading 4.53MiB
19:21:45:WU02:FS01:Download 8.28%
19:21:51:WU02:FS01:Download 34.49%
19:21:57:WU02:FS01:Download 84.16%
19:21:59:WU02:FS01:Download complete
19:21:59:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11742 run:0 clone:5656 gen:17 core:0x22 unit:0x0000001f8ca304f15e6bc529dd2dd19e
19:21:59:WU02:FS01:Starting
19:21:59:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 11056 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:21:59:WU02:FS01:Started FahCore on PID 9940
19:21:59:WU02:FS01:Core PID:7264
19:21:59:WU02:FS01:FahCore 0x22 started
19:21:59:WU02:FS01:0x22:*********************** Log Started 2020-04-14T19:21:59Z ***********************
19:21:59:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:21:59:WU02:FS01:0x22: Type: 0x22
19:21:59:WU02:FS01:0x22: Core: Core22
19:21:59:WU02:FS01:0x22: Website: https://foldingathome.org/
19:21:59:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
19:21:59:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:21:59:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
19:21:59:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 705 -lifeline 9940 -checkpoint 15
19:21:59:WU02:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:21:59:WU02:FS01:0x22: Config: <none>
19:21:59:WU02:FS01:0x22:************************************ Build *************************************
19:21:59:WU02:FS01:0x22: Version: 0.0.2
19:21:59:WU02:FS01:0x22: Date: Dec 6 2019
19:21:59:WU02:FS01:0x22: Time: 21:30:31
19:21:59:WU02:FS01:0x22: Repository: Git
19:21:59:WU02:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
19:21:59:WU02:FS01:0x22: Branch: HEAD
19:21:59:WU02:FS01:0x22: Compiler: Visual C++ 2008
19:21:59:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:21:59:WU02:FS01:0x22: Platform: win32 10
19:21:59:WU02:FS01:0x22: Bits: 64
19:21:59:WU02:FS01:0x22: Mode: Release
19:21:59:WU02:FS01:0x22:************************************ System ************************************
19:21:59:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
19:21:59:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:21:59:WU02:FS01:0x22: CPUs: 8
19:21:59:WU02:FS01:0x22: Memory: 31.94GiB
19:21:59:WU02:FS01:0x22:Free Memory: 28.32GiB
19:21:59:WU02:FS01:0x22: Threads: WINDOWS_THREADS
19:21:59:WU02:FS01:0x22: OS Version: 6.2
19:21:59:WU02:FS01:0x22:Has Battery: false
19:21:59:WU02:FS01:0x22: On Battery: false
19:21:59:WU02:FS01:0x22: UTC Offset: 2
19:21:59:WU02:FS01:0x22: PID: 7264
19:21:59:WU02:FS01:0x22: CWD: C:\Users\User\AppData\Roaming\FAHClient\work
19:21:59:WU02:FS01:0x22: OS: Windows 10 Pro
19:21:59:WU02:FS01:0x22: OS Arch: AMD64
19:21:59:WU02:FS01:0x22:********************************************************************************
19:21:59:WU02:FS01:0x22:Project: 11742 (Run 0, Clone 5656, Gen 17)
19:21:59:WU02:FS01:0x22:Unit: 0x0000001f8ca304f15e6bc529dd2dd19e
19:21:59:WU02:FS01:0x22:Reading tar file core.xml
19:21:59:WU02:FS01:0x22:Reading tar file integrator.xml
19:21:59:WU02:FS01:0x22:Reading tar file state.xml
19:22:00:WU02:FS01:0x22:Reading tar file system.xml
19:22:00:WU02:FS01:0x22:Digital signatures verified
19:22:00:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:22:00:WU02:FS01:0x22:Version 0.0.2
19:22:07:WU02:FS01:0x22:Completed 0 out of 2000000 steps (0%)
19:22:07:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:22:58:WU01:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
19:24:00:WU02:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
19:24:18:WU01:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
19:25:37:WU01:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
19:25:51:WU02:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
19:26:33:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
19:26:33:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
19:26:45:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
19:26:45:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
19:26:56:WU01:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
19:26:57:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
19:26:57:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
19:26:57:WU02:FS01:0x22:ERROR:114: Max Retries Reached
19:26:57:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
19:26:57:WU02:FS01:0x22:Saving result file badstate-0.xml
19:26:59:WU02:FS01:0x22:Saving result file badstate-1.xml
19:27:01:WU02:FS01:0x22:Saving result file badstate-2.xml
19:27:03:WU02:FS01:0x22:Saving result file checkpt.crc
19:27:03:WU02:FS01:0x22:Saving result file science.log
19:27:03:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
19:27:03:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:27:03:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11742 run:0 clone:5656 gen:17 core:0x22 unit:0x0000001f8ca304f15e6bc529dd2dd19e
19:27:04:WU02:FS01:Uploading 2.82MiB to 140.163.4.241
19:27:04:WU02:FS01:Connecting to 140.163.4.241:8080
19:27:04:WU00:FS01:Connecting to 65.254.110.245:8080
19:27:05:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:27:05:WU00:FS01:Connecting to 18.218.241.186:80
19:27:05:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:27:05:ERROR:WU00:FS01:Exception: Could not get an assignment
19:27:06:WU00:FS01:Connecting to 65.254.110.245:8080
19:27:06:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:27:06:WU00:FS01:Connecting to 18.218.241.186:80
19:27:07:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:27:07:ERROR:WU00:FS01:Exception: Could not get an assignment
19:27:10:WU02:FS01:Upload 28.83%
19:27:16:WU02:FS01:Upload 59.88%
19:27:22:WU02:FS01:Upload 82.06%
19:27:27:WU02:FS01:Upload complete
19:27:27:WU02:FS01:Server responded WORK_ACK (400)
19:27:28:WU02:FS01:Cleaning up
19:28:06:WU00:FS01:Connecting to 65.254.110.245:8080
19:28:07:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:28:07:WU00:FS01:Connecting to 18.218.241.186:80
19:28:08:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:28:08:ERROR:WU00:FS01:Exception: Could not get an assignment
19:28:15:WU01:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
19:29:35:WU01:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
19:29:43:WU00:FS01:Connecting to 65.254.110.245:8080
19:29:44:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:29:44:WU00:FS01:Connecting to 18.218.241.186:80
19:29:45:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:29:45:ERROR:WU00:FS01:Exception: Could not get an assignment
19:30:53:WU01:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
19:32:12:WU01:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
19:32:20:WU00:FS01:Connecting to 65.254.110.245:8080
19:32:21:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:32:21:WU00:FS01:Connecting to 18.218.241.186:80
19:32:22:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:32:22:ERROR:WU00:FS01:Exception: Could not get an assignment
19:33:31:WU01:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
19:34:49:WU01:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
19:36:08:WU01:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
19:36:35:WU00:FS01:Connecting to 65.254.110.245:8080
19:36:36:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:36:36:WU00:FS01:Connecting to 18.218.241.186:80
19:36:36:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:36:36:ERROR:WU00:FS01:Exception: Could not get an assignment
19:37:26:WU01:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
19:38:45:WU01:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
19:40:04:WU01:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
19:41:23:WU01:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
19:42:41:WU01:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
19:43:26:WU00:FS01:Connecting to 65.254.110.245:8080
19:43:27:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:43:27:WU00:FS01:Connecting to 18.218.241.186:80
19:43:28:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:43:28:ERROR:WU00:FS01:Exception: Could not get an assignment
19:44:01:WU01:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
19:45:19:WU01:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
19:46:38:WU01:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
19:47:56:WU01:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
19:49:15:WU01:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
19:50:34:WU01:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
19:51:52:WU01:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
19:53:11:WU01:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
19:54:29:WU01:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
19:54:31:WU00:FS01:Connecting to 65.254.110.245:8080
19:54:33:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:54:33:WU00:FS01:Connecting to 18.218.241.186:80
19:54:33:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:54:33:ERROR:WU00:FS01:Exception: Could not get an assignment
19:55:48:WU01:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
19:57:07:WU01:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
19:58:25:WU01:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
19:59:45:WU01:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
20:01:03:WU01:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
20:02:22:WU01:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
20:03:40:WU01:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
20:04:59:WU01:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
20:06:18:WU01:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
20:07:36:WU01:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
20:08:55:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
20:10:14:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
20:10:14:WU02:FS00:Connecting to 65.254.110.245:8080
20:10:16:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:10:16:WU02:FS00:Connecting to 18.218.241.186:80
20:10:17:WU02:FS00:Assigned to work server 128.252.203.9
20:10:17:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 128.252.203.9
20:10:17:WU02:FS00:Connecting to 128.252.203.9:8080
20:10:19:ERROR:WU02:FS00:Exception: Server did not assign work unit
20:10:19:WU02:FS00:Connecting to 65.254.110.245:8080
20:10:21:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:10:21:WU02:FS00:Connecting to 18.218.241.186:80
20:10:22:WU02:FS00:Assigned to work server 168.245.198.125
20:10:22:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 168.245.198.125
20:10:22:WU02:FS00:Connecting to 168.245.198.125:8080
20:10:23:WU02:FS00:Downloading 13.97MiB
20:10:29:WU02:FS00:Download 19.24%
20:10:35:WU02:FS00:Download 46.99%
20:10:41:WU02:FS00:Download 78.76%
20:10:46:WU02:FS00:Download complete
20:10:46:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16408 run:0 clone:1778 gen:16 core:0xa7 unit:0x00000015a8f5c67d5e801d421fa338b8
20:11:32:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
20:11:34:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
20:11:34:WU01:FS00:0xa7:Saving result file frame15.trr
20:11:34:WU01:FS00:0xa7:Saving result file frame15.xtc
20:11:34:WU01:FS00:0xa7:Saving result file md.log
20:11:34:WU01:FS00:0xa7:Saving result file science.log
20:11:34:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
20:11:34:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:11:34:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16420 run:1041 clone:1 gen:15 core:0xa7 unit:0x00000012a8f5c67d5e8a611a03b25462
20:11:34:WU01:FS00:Uploading 4.75MiB to 168.245.198.125
20:11:34:WU01:FS00:Connecting to 168.245.198.125:8080
20:11:35:WU02:FS00:Starting
20:11:35:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 11056 -checkpoint 15 -np 6
20:11:35:WU02:FS00:Started FahCore on PID 8868
20:11:35:WU02:FS00:Core PID:6216
20:11:35:WU02:FS00:FahCore 0xa7 started
20:11:35:WU02:FS00:0xa7:*********************** Log Started 2020-04-14T20:11:35Z ***********************
20:11:35:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:11:35:WU02:FS00:0xa7: Type: 0xa7
20:11:35:WU02:FS00:0xa7: Core: Gromacs
20:11:35:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 8868 -checkpoint 15 -np 6
20:11:35:WU02:FS00:0xa7:************************************ CBang *************************************
20:11:35:WU02:FS00:0xa7: Date: Oct 26 2019
20:11:35:WU02:FS00:0xa7: Time: 01:38:25
20:11:35:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:11:35:WU02:FS00:0xa7: Branch: master
20:11:35:WU02:FS00:0xa7: Compiler: Visual C++ 2008
20:11:35:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:11:35:WU02:FS00:0xa7: Platform: win32 10
20:11:35:WU02:FS00:0xa7: Bits: 64
20:11:35:WU02:FS00:0xa7: Mode: Release
20:11:35:WU02:FS00:0xa7:************************************ System ************************************
20:11:35:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
20:11:35:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
20:11:35:WU02:FS00:0xa7: CPUs: 8
20:11:35:WU02:FS00:0xa7: Memory: 31.94GiB
20:11:35:WU02:FS00:0xa7:Free Memory: 28.46GiB
20:11:35:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
20:11:35:WU02:FS00:0xa7: OS Version: 6.2
20:11:35:WU02:FS00:0xa7:Has Battery: false
20:11:35:WU02:FS00:0xa7: On Battery: false
20:11:35:WU02:FS00:0xa7: UTC Offset: 2
20:11:35:WU02:FS00:0xa7: PID: 6216
20:11:35:WU02:FS00:0xa7: CWD: C:\Users\User\AppData\Roaming\FAHClient\work
20:11:35:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
20:11:35:WU02:FS00:0xa7: Version: 0.0.18
20:11:35:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:11:35:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
20:11:35:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
20:11:35:WU02:FS00:0xa7: Time: 01:52:30
20:11:35:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:11:35:WU02:FS00:0xa7:************************************ Build *************************************
20:11:35:WU02:FS00:0xa7: SIMD: avx_256
20:11:35:WU02:FS00:0xa7:********************************************************************************
20:11:35:WU02:FS00:0xa7:Project: 16408 (Run 0, Clone 1778, Gen 16)
20:11:35:WU02:FS00:0xa7:Unit: 0x00000015a8f5c67d5e801d421fa338b8
20:11:35:WU02:FS00:0xa7:Reading tar file core.xml
20:11:35:WU02:FS00:0xa7:Reading tar file frame16.tpr
20:11:35:WU02:FS00:0xa7:Digital signatures verified
20:11:35:WU02:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -x frame16.xtc -cpt 15 -nt 6
20:11:35:WU02:FS00:0xa7:Steps: first=4000000 total=250000
20:11:37:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
20:11:40:WU01:FS00:Upload 11.84%
20:11:46:WU01:FS00:Upload 27.63%
20:11:52:WU01:FS00:Upload 42.11%
20:11:58:WU01:FS00:Upload 59.22%
20:12:04:WU01:FS00:Upload 76.32%
20:12:10:WU01:FS00:Upload 93.43%
20:12:13:WU01:FS00:Upload complete
20:12:13:WU01:FS00:Server responded WORK_ACK (400)
20:12:13:WU01:FS00:Final credit estimate, 10385.00 points
20:12:13:WU01:FS00:Cleaning up
20:12:28:WU00:FS01:Connecting to 65.254.110.245:8080
20:12:29:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:12:29:WU00:FS01:Connecting to 18.218.241.186:80
20:12:30:WU00:FS01:Assigned to work server 128.252.203.10
20:12:30:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 128.252.203.10
20:12:30:WU00:FS01:Connecting to 128.252.203.10:8080
20:12:51:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
20:12:51:WU00:FS01:Connecting to 128.252.203.10:80
20:13:13:ERROR:WU00:FS01:Exception: Failed to connect to 128.252.203.10:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
20:14:14:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
20:16:52:WU02:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
20:19:30:WU02:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
20:22:08:WU02:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
20:24:45:WU02:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
20:27:24:WU02:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
20:30:02:WU02:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
20:32:39:WU02:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
20:35:17:WU02:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
20:37:54:WU02:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
20:39:12:19:127.0.0.1:New Web connection
20:40:36:WU02:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
20:41:31:WU00:FS01:Connecting to 65.254.110.245:8080
20:41:31:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:41:31:WU00:FS01:Connecting to 18.218.241.186:80
20:41:32:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:41:32:ERROR:WU00:FS01:Exception: Could not get an assignment
I will let someone more familiar with AMD drivers to comment, the version appears to be recent. Some recent versions did have a problem with F@h and other video activity going on at the same time, a few topics covered that within the last few weeks.
Running into the same problem with two different WUs, does lead to the question on whether your RX 590 is overclocked, factory or otherwise. If so, try reducing the clock closer to the reference speed of 1469. Or use a GPU utility to set power or temperature limits.
Ok, thanks.
All the time I only used basic apps like firefox or MS Office. Nothing with special video activity needs. The Radeon Software settings are in "automatic", I could choose the button "overclocking" but all the time the setting "standard" is chosen. Temperature 50°C at the moment. It looks like that the kernelclocking ?(Speichertaktfrequenz) is set to 1545MHz.
Welcome to the F@H Forum Kammarah,
From your configuration, I noticed that you're not using a passkey. Using a passkey is recommended for security and bonus points. You can learn more about it here: https://foldingathome.org/support/faq/points/passkey/
The AMD Ellesmere XT [Radeon RX 470/480/570/580/590] are all the same GPU, as far as the drivers are concerned, so you can search for any of those numbers for related information.
There is a known driver problem which has not been resolved yet. The symptoms reported elsewhere have been different, however, so this may not be the issue at all.
Two WUs have failed in that portion of the log:
Both were reassigned and successfully completed by someone else, which suggests the problem is local. A problem with NaNs is commonly a result of GPU instability so overclocking is suspected, as suggested by the error message. Just to be certain, though, I'd suggest UNDERCLOCKING and see if the problem goes away. You were able to complete oher WUs, so it's not clear whether it will be easy or difficult to diagnose.
Thank you!
I think your good intentions worked. So I started my PC to change the clocking settings and I see this:
After a week with nothing to do for my GPU and the error I told, right NOW my GPU is contributing to Project 14416.
I changed nothing.
Thank you and stay healthy!
Kammarah
I changed nothing.
Kammarah
bignerdguy
Just an FYI if you have your GPU core clocked above 1500 MHz it might fail to process WU's. I have the XFX 590 Fatboy and its factory default of 1545 MHz causes WU's to fail. I under clocked it to 1500 MHz and it runs WU's just fine now. Try either using the AMD driver utility or something like MSI afterburner to change the settings. You can always setup a game mode on either utility to return the clock settings back to defaults when you run a game.
Hello.
I do not want to create a new topic.
The video card cannot receive a task to complete.
I want to clarify if I understand correctly that the problem is now in the server?
Screenshot:
https://ibb.co/p1GHGwc
Log:
10:33:37:WU00:FS01:Connecting to 65.254.110.245:8080
10:33:37:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:33:37:WU00:FS01:Connecting to 18.218.241.186:80
10:33:38:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:33:38:ERROR:WU00:FS01:Exception: Could not get an assignment
10:34:37:WU00:FS01:Connecting to 65.254.110.245:8080
10:34:37:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:34:37:WU00:FS01:Connecting to 18.218.241.186:80
10:34:38:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:34:38:ERROR:WU00:FS01:Exception: Could not get an assignment
10:36:14:WU00:FS01:Connecting to 65.254.110.245:8080
10:36:14:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:36:14:WU00:FS01:Connecting to 18.218.241.186:80
10:36:15:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:36:15:ERROR:WU00:FS01:Exception: Could not get an assignment
10:38:51:WU00:FS01:Connecting to 65.254.110.245:8080
10:38:52:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:38:52:WU00:FS01:Connecting to 18.218.241.186:80
10:38:52:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:38:52:ERROR:WU00:FS01:Exception: Could not get an assignment
10:43:06:WU00:FS01:Connecting to 65.254.110.245:8080
10:43:06:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:43:06:WU00:FS01:Connecting to 18.218.241.186:80
10:43:06:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:43:06:ERROR:WU00:FS01:Exception: Could not get an assignment
Ok.
So the project wasn't stable anyway.
I have the Radeon Software and hope that I found the right spot to lower the clock settings. First step I will try the 1469MHz whick John_H recommended.
(Performance - Configuration - Tuning manually - minimum acoustic limit -> 1469MHz) My software is in german, so the translation may be kind of incorrect.
Leistung - Konfiguration - Manuell - GPU Tuning (aktiviert) - Max. Frequenz. Thats where you limit the clock. Reset the acoustic limit before, its not what you want in that case.
Grüße aus dem Thüringer Wald.
Welcome to the F@H Forum BabyRoot,BabyRoot wrote:Hello.
I want to clarify if I understand correctly that the problem is now in the server?...
Yes, that's correct. The demand for GPU WUs is massive when compared to the supply. Work is being done to resolve this.
NoMoreQuarantine
I have been running a 590 at 1545MHz for a couple weeks now with no issues. Same driver as you on Win 10 64bit Home.
Then you are probably on the lucky end, having a chip of higher quality. Every product is unique in its properties - some can handle more clock speed, some less. The finetuning is up to everyone on their own.
Sorry @BabyRoot, completely missed your post.
