Please add Radeon Pro Vega 64
heyheiho
Post by heyheiho »
Radeon Pro Vega 64
FAHClient --lspci:
0x1022:0x1470:241:0:0:Advanced Micro Devices, Inc. [AMD]:EGP0
0x1022:0x1471:242:0:0:Advanced Micro Devices, Inc. [AMD]:EGP1
Log:
*********************** Log Started 2020-04-13T20:22:05Z ***********************
20:22:05:************************* Folding@home Client *************************
20:22:05:    Website: https://foldingathome.org/
20:22:05:  Copyright: (c) 2009-2018 foldingathome.org
20:22:05:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:22:05:       Args:
20:22:05:     Config: /Library/Application Support/FAHClient/config.xml
20:22:05:******************************** Build ********************************
20:22:05:    Version: 7.5.1
20:22:05:       Date: May 11 2018
20:22:05:       Time: 12:57:01
20:22:05: Repository: Git
20:22:05:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:22:05:     Branch: master
20:22:05:   Compiler: GNU 4.2.1 Compatible Apple LLVM 7.3.0 (clang-703.0.31)
20:22:05:    Options: -std=gnu++98 -O3 -funroll-loops -mmacosx-version-min=10.6
20:22:05:             -Wno-unused-local-typedefs
20:22:05:   Platform: darwin 15.6.0
20:22:05:       Bits: 64
20:22:05:       Mode: Release
20:22:05:******************************* System ********************************
20:22:05:        CPU: Intel(R) Xeon(R) W-2150B CPU @ 3.00GHz
20:22:05:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
20:22:05:       CPUs: 20
20:22:05:     Memory: 64.00GiB
20:22:05:Free Memory: 60.40GiB
20:22:05:    Threads: POSIX_THREADS
20:22:05: OS Version: 10.14
20:22:05:Has Battery: false
20:22:05: On Battery: false
20:22:05: UTC Offset: -7
20:22:05:        PID: 47
20:22:05:        CWD: /Library/Application Support/FAHClient
20:22:05:         OS: Darwin 18.7.0 x86_64
20:22:05:    OS Arch: AMD64
20:22:05:       GPUs: 0
20:22:05:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
20:22:05:             dlopen(libcuda.dylib, 1): image not found
20:22:05:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
20:22:05:             dlopen(libOpenCL.dylib, 1): image not found
20:22:05:***********************************************************************
Re: Please add Radeon Pro Vega 64
Welcome to the F@H Forum heyheiho,
Please note that GPU folding isn't supported on macOS :( Currently, there's no plans due to uncertainty given that Apple has deprecated support of OpenCL on the OS.
heyheiho
Post by heyheiho »
Thanks for quick reply, oh I didn't notice it is not supported :o . Thanks!
However others have successfully folded on their Mac's after booting into an install of Linux or Windows.
