Hi,
Most probably this is not the correct place for a wishlist, but can the support of logging machine temperature be considered for a future version please? While a client is generating log, it will be great if every X minutes, it also logs the machine cpu/gpu temperatures. This will be very helpful when I am consolidating logs from various machines in a single place, and I can perhaps have the tool parse the logs to quickly show me temperatures of all my cpu/gpus across all machines, and react manually where temperature are going beyond what I like. Once logged, hopefully fuure versions of HFM.NET can also start reading it and displaying on the dashboard.
Client machine temperature
Re: Client machine temperature
What about existing tools like openhardwaremonitor?
If this request is considered, it will take a while since there are other items that have a higher priority. I would suggest that you look at already available hardware monitoring tools like:
HWiNFO: https://www.hwinfo.com/download/
HWMonitor: https://www.cpuid.com/softwares/hwmonitor.html
GPU-Z: https://www.techpowerup.com/download/techpowerup-gpu-z/
@foldy, does it allow us to see temp of individual CPU, GPU across multiple machines? I will explore it then.
Even if it does, I am using HFM.NET to consolidate my folding machines, and view/manage from a single dashboard, so it will be great if while viewing the status of my various slots and clients, i can see the temperature there itself too within WFM.NET, or even via the FAHcontrol visual interface.
With https://www.aida64.com/compare-aida64-features you can configure your own set of sensors and monitor them remotely. And much more.
