My laptop has two GPU's.
GPU0: Intel HD Graphics 520
GPU1: AMD Radeon R/ M360
Folding@Home Client shows a configured and running folding slot called gpu:0:Mars [Radeon R7 M260/M265/M270]. The strange thing is that the Windows Task manager Performance view shows that the Intel HD Graphics GPU is active while the AMD Radeon GPU is doing nothing.
Is there a way to get the more powerful GPU1 up and running?
GPU identified incorrectly
Re: GPU identified incorrectly
The description field for your AMD Radeon GPU is based on the initial report of the device ID given to us. AMD has reused the device ID and GPU chip in your R7 M360, the description field does not affect how folding run on the GPU.
As for Task Manager, its default displays for the GPU are misleading for seeing GPU utilization for computing as opposed to video. Click on the down arrow of one of the GPU displays and change to Compute 0 or Compute 1. One of them will read in the 90+% range.
The graphics activity on the Intel iGPU is probably related to your screen usage.
You can also post the first 200 or so lines of your log file here, we can look at to see if there are any configuration issues.
A more accurate test would be GPU-Z it should allow you to switch and see the GPU Load on each on the sensor screen
I adjusted the GPU displays of the AMD gpu to Compute 0 and Compute 1 but still see no activity at all.
GPU-Z sensors for the AMD show 0% GPU Load, even if I start a game or a video. The Intel gpu seems to always get all of the load.
*********************** Log Started 2020-04-12T19:21:43Z ***********************
19:37:37:WU01:FS01:Connecting to 65.254.110.245:8080
19:37:37:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:37:37:WU01:FS01:Connecting to 18.218.241.186:80
19:37:38:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:37:38:ERROR:WU01:FS01:Exception: Could not get an assignment
19:37:38:WU01:FS01:Connecting to 65.254.110.245:8080
19:37:39:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:37:39:WU01:FS01:Connecting to 18.218.241.186:80
19:37:40:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:37:40:ERROR:WU01:FS01:Exception: Could not get an assignment
19:38:38:WU01:FS01:Connecting to 65.254.110.245:8080
19:38:39:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:38:39:WU01:FS01:Connecting to 18.218.241.186:80
19:38:40:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:38:40:ERROR:WU01:FS01:Exception: Could not get an assignment
19:40:16:WU01:FS01:Connecting to 65.254.110.245:8080
19:40:16:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:40:16:WU01:FS01:Connecting to 18.218.241.186:80
19:40:17:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:40:17:ERROR:WU01:FS01:Exception: Could not get an assignment
19:42:53:WU01:FS01:Connecting to 65.254.110.245:8080
19:42:53:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:42:53:WU01:FS01:Connecting to 18.218.241.186:80
19:42:54:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:42:54:ERROR:WU01:FS01:Exception: Could not get an assignment
19:47:07:WU01:FS01:Connecting to 65.254.110.245:8080
19:47:08:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:47:08:WU01:FS01:Connecting to 18.218.241.186:80
19:47:08:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:47:08:ERROR:WU01:FS01:Exception: Could not get an assignment
19:53:58:WU01:FS01:Connecting to 65.254.110.245:8080
19:53:59:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:53:59:WU01:FS01:Connecting to 18.218.241.186:80
19:53:59:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:53:59:ERROR:WU01:FS01:Exception: Could not get an assignment
20:05:04:WU01:FS01:Connecting to 65.254.110.245:8080
20:05:04:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:05:04:WU01:FS01:Connecting to 18.218.241.186:80
20:05:05:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:05:05:ERROR:WU01:FS01:Exception: Could not get an assignment
20:23:01:WU01:FS01:Connecting to 65.254.110.245:8080
20:23:01:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:23:01:WU01:FS01:Connecting to 18.218.241.186:80
20:23:02:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:23:02:ERROR:WU01:FS01:Exception: Could not get an assignment
20:52:03:WU01:FS01:Connecting to 65.254.110.245:8080
20:52:03:WU01:FS01:Assigned to work server 140.163.4.231
20:52:03:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Mars [Radeon R7 M260/M265/M270] from 140.163.4.231
20:52:03:WU01:FS01:Connecting to 140.163.4.231:8080
20:54:03:WU01:FS01:Downloading 7.93MiB
20:54:09:WU01:FS01:Download 58.36%
20:54:15:WU01:FS01:Download 80.44%
20:54:16:WU01:FS01:Download complete
20:54:16:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11751 run:0 clone:6074 gen:1 core:0x22 unit:0x000000068ca304e75e6bbb72c61a4ac8
20:54:16:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
20:54:16:WU01:FS01:Connecting to cores.foldingathome.org:80
20:54:16:WU01:FS01:FahCore 22: Downloading 4.04MiB
20:54:18:WU01:FS01:FahCore 22: Download complete
20:54:19:WU01:FS01:Valid core signature
20:54:19:WU01:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
20:54:19:WU01:FS01:Starting
20:54:19:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jim\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 16652 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
20:54:19:WU01:FS01:Started FahCore on PID 9796
20:54:19:WU01:FS01:Core PID:19728
20:54:19:WU01:FS01:FahCore 0x22 started
20:54:20:WU01:FS01:0x22:*********************** Log Started 2020-04-12T20:54:19Z ***********************
20:54:20:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:54:20:WU01:FS01:0x22: Type: 0x22
20:54:20:WU01:FS01:0x22: Core: Core22
20:54:20:WU01:FS01:0x22: Website: https://foldingathome.org/
20:54:20:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:54:20:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:54:20:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:54:20:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 9796 -checkpoint 15
20:54:20:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
20:54:20:WU01:FS01:0x22: Config: <none>
20:54:20:WU01:FS01:0x22:************************************ Build *************************************
20:54:20:WU01:FS01:0x22: Version: 0.0.2
20:54:20:WU01:FS01:0x22: Date: Dec 6 2019
20:54:20:WU01:FS01:0x22: Time: 21:30:31
20:54:20:WU01:FS01:0x22: Repository: Git
20:54:20:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:54:20:WU01:FS01:0x22: Branch: HEAD
20:54:20:WU01:FS01:0x22: Compiler: Visual C++ 2008
20:54:20:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:54:20:WU01:FS01:0x22: Platform: win32 10
20:54:20:WU01:FS01:0x22: Bits: 64
20:54:20:WU01:FS01:0x22: Mode: Release
20:54:20:WU01:FS01:0x22:************************************ System ************************************
20:54:20:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz
20:54:20:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
20:54:20:WU01:FS01:0x22: CPUs: 4
20:54:20:WU01:FS01:0x22: Memory: 7.89GiB
20:54:20:WU01:FS01:0x22:Free Memory: 2.22GiB
20:54:20:WU01:FS01:0x22: Threads: WINDOWS_THREADS
20:54:20:WU01:FS01:0x22: OS Version: 6.2
20:54:20:WU01:FS01:0x22:Has Battery: true
20:54:20:WU01:FS01:0x22: On Battery: false
20:54:20:WU01:FS01:0x22: UTC Offset: 2
20:54:20:WU01:FS01:0x22: PID: 19728
20:54:20:WU01:FS01:0x22: CWD: C:\Users\Jim\AppData\Roaming\FAHClient\work
20:54:20:WU01:FS01:0x22: OS: Windows 10 Pro
20:54:20:WU01:FS01:0x22: OS Arch: AMD64
20:54:20:WU01:FS01:0x22:********************************************************************************
20:54:20:WU01:FS01:0x22:Project: 11751 (Run 0, Clone 6074, Gen 1)
20:54:20:WU01:FS01:0x22:Unit: 0x000000068ca304e75e6bbb72c61a4ac8
20:54:20:WU01:FS01:0x22:Reading tar file core.xml
20:54:20:WU01:FS01:0x22:Reading tar file integrator.xml
20:54:20:WU01:FS01:0x22:Reading tar file state.xml
20:54:22:WU01:FS01:0x22:Reading tar file system.xml
20:54:23:WU01:FS01:0x22:Digital signatures verified
20:54:23:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:54:23:WU01:FS01:0x22:Version 0.0.2
20:54:44:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
20:54:45:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:12:51:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
21:30:58:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
21:49:07:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
22:07:16:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
22:25:24:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
22:43:38:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
23:01:48:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
23:19:57:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
23:38:04:WU01:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
23:56:13:WU01:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
00:14:27:WU01:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
00:32:35:WU01:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
00:50:45:WU01:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
01:08:55:WU01:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
******************************* Date: 2020-04-13 *******************************
01:27:04:WU01:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
01:45:19:WU01:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
02:03:28:WU01:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
02:21:43:WU01:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
02:39:56:WU01:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
02:58:10:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
03:16:33:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
03:34:47:WU01:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
03:53:00:WU01:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
04:11:14:WU01:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
04:29:27:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
04:44:40:FS01:Shutting core down
04:44:40:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 19728
04:44:40:WU01:FS01:0x22:Exiting, please wait. . .
04:44:40:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
04:44:41:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
04:53:05:WU01:FS01:Starting
04:53:05:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jim\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 16652 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
04:53:05:WU01:FS01:Started FahCore on PID 20380
04:53:05:WU01:FS01:Core PID:13400
04:53:05:WU01:FS01:FahCore 0x22 started
04:53:06:WU01:FS01:0x22:*********************** Log Started 2020-04-13T04:53:05Z ***********************
04:53:06:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:53:06:WU01:FS01:0x22: Type: 0x22
04:53:06:WU01:FS01:0x22: Core: Core22
04:53:06:WU01:FS01:0x22: Website: https://foldingathome.org/
04:53:06:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
04:53:06:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:53:06:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
04:53:06:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 20380 -checkpoint 15
04:53:06:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
04:53:06:WU01:FS01:0x22: Config: <none>
04:53:06:WU01:FS01:0x22:************************************ Build *************************************
04:53:06:WU01:FS01:0x22: Version: 0.0.2
04:53:06:WU01:FS01:0x22: Date: Dec 6 2019
04:53:06:WU01:FS01:0x22: Time: 21:30:31
04:53:06:WU01:FS01:0x22: Repository: Git
04:53:06:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
04:53:06:WU01:FS01:0x22: Branch: HEAD
04:53:06:WU01:FS01:0x22: Compiler: Visual C++ 2008
04:53:06:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:53:06:WU01:FS01:0x22: Platform: win32 10
04:53:06:WU01:FS01:0x22: Bits: 64
04:53:06:WU01:FS01:0x22: Mode: Release
04:53:06:WU01:FS01:0x22:************************************ System ************************************
04:53:06:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz
04:53:06:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
04:53:06:WU01:FS01:0x22: CPUs: 4
04:53:06:WU01:FS01:0x22: Memory: 7.89GiB
04:53:06:WU01:FS01:0x22:Free Memory: 1.86GiB
04:53:06:WU01:FS01:0x22: Threads: WINDOWS_THREADS
04:53:06:WU01:FS01:0x22: OS Version: 6.2
04:53:06:WU01:FS01:0x22:Has Battery: true
04:53:06:WU01:FS01:0x22: On Battery: false
04:53:06:WU01:FS01:0x22: UTC Offset: 2
04:53:06:WU01:FS01:0x22: PID: 13400
04:53:06:WU01:FS01:0x22: CWD: C:\Users\Jim\AppData\Roaming\FAHClient\work
04:53:06:WU01:FS01:0x22: OS: Windows 10 Pro
04:53:06:WU01:FS01:0x22: OS Arch: AMD64
04:53:06:WU01:FS01:0x22:********************************************************************************
04:53:06:WU01:FS01:0x22:Project: 11751 (Run 0, Clone 6074, Gen 1)
04:53:06:WU01:FS01:0x22:Unit: 0x000000068ca304e75e6bbb72c61a4ac8
04:53:06:WU01:FS01:0x22:Digital signatures verified
04:53:06:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:53:06:WU01:FS01:0x22:Version 0.0.2
04:53:06:WU01:FS01:0x22: Found a checkpoint file
04:53:15:FS01:Shutting core down
04:53:15:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 13400
04:53:15:WU01:FS01:0x22:Exiting, please wait. . .
04:53:26:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
04:53:26:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:53:26:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
04:53:26:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
04:54:06:WU01:FS01:Starting
04:54:06:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jim\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 16652 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
04:54:06:WU01:FS01:Started FahCore on PID 19896
04:54:06:WU01:FS01:Core PID:20008
04:54:06:WU01:FS01:FahCore 0x22 started
04:54:06:WU01:FS01:0x22:*********************** Log Started 2020-04-13T04:54:06Z ***********************
04:54:06:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:54:06:WU01:FS01:0x22: Type: 0x22
04:54:06:WU01:FS01:0x22: Core: Core22
04:54:06:WU01:FS01:0x22: Website: https://foldingathome.org/
04:54:06:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
04:54:06:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:54:06:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
04:54:06:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 19896 -checkpoint 15
04:54:06:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
04:54:06:WU01:FS01:0x22: Config: <none>
04:54:06:WU01:FS01:0x22:************************************ Build *************************************
04:54:06:WU01:FS01:0x22: Version: 0.0.2
04:54:06:WU01:FS01:0x22: Date: Dec 6 2019
04:54:06:WU01:FS01:0x22: Time: 21:30:31
04:54:06:WU01:FS01:0x22: Repository: Git
04:54:06:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
04:54:06:WU01:FS01:0x22: Branch: HEAD
04:54:06:WU01:FS01:0x22: Compiler: Visual C++ 2008
04:54:06:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:54:06:WU01:FS01:0x22: Platform: win32 10
04:54:06:WU01:FS01:0x22: Bits: 64
04:54:06:WU01:FS01:0x22: Mode: Release
04:54:06:WU01:FS01:0x22:************************************ System ************************************
04:54:06:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz
04:54:06:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
04:54:06:WU01:FS01:0x22: CPUs: 4
04:54:06:WU01:FS01:0x22: Memory: 7.89GiB
04:54:06:WU01:FS01:0x22:Free Memory: 1.92GiB
04:54:06:WU01:FS01:0x22: Threads: WINDOWS_THREADS
04:54:06:WU01:FS01:0x22: OS Version: 6.2
04:54:06:WU01:FS01:0x22:Has Battery: true
04:54:06:WU01:FS01:0x22: On Battery: false
04:54:06:WU01:FS01:0x22: UTC Offset: 2
04:54:06:WU01:FS01:0x22: PID: 20008
04:54:06:WU01:FS01:0x22: CWD: C:\Users\Jim\AppData\Roaming\FAHClient\work
04:54:06:WU01:FS01:0x22: OS: Windows 10 Pro
04:54:06:WU01:FS01:0x22: OS Arch: AMD64
04:54:06:WU01:FS01:0x22:********************************************************************************
04:54:06:WU01:FS01:0x22:Project: 11751 (Run 0, Clone 6074, Gen 1)
04:54:06:WU01:FS01:0x22:Unit: 0x000000068ca304e75e6bbb72c61a4ac8
04:54:06:WU01:FS01:0x22:Digital signatures verified
04:54:06:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:54:06:WU01:FS01:0x22:Version 0.0.2
04:54:06:WU01:FS01:0x22: Found a checkpoint file
04:54:31:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
04:54:31:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:12:42:WU01:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
05:30:50:WU01:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
05:45:53:FS01:Shutting core down
05:45:53:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 20008
05:45:53:WU01:FS01:0x22:Exiting, please wait. . .
05:45:53:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
05:45:53:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)Re: GPU identified incorrectly
Your Intel iGP is successfully being used to display images on your desktop. It should see heightened graphics activity when you're playing a game.
Your assigned FAH Wu is running FAHCore22 using -opencl-platform 1 which is your AMD Radeon GPU.
It's working like it's supposed to.
