Particle coordinate nan project:14545 run:0 clone:1728 gen:1
Nuitari
Hardware configuration: 1x Nvidia 1050ti
1x Nvidia 1660Super
1x Nvidia GTX 660
1x Nvidia 1060 3gb
1x AMD rx570
2x AMD rx560
1x AMD Ryzen 7 PRO 1700
1x AMD Ryzen 7 3700X
1x AMD Phenom II
1x AMD A8-9600
1x Intel i5-4590S
Post by Nuitari »
Running on a stock RX570
01:26:31:WU04:FS03:0x22:Version 0.0.2
01:27:24:WU04:FS03:0x22:Completed 0 out of 5000000 steps (0%)
01:27:24:WU04:FS03:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
01:29:34:WU04:FS03:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
01:29:34:WU04:FS03:0x22:Following exception occured: Particle coordinate is nan
01:40:24:WU04:FS03:0x22:Completed 50000 out of 5000000 steps (1%)
01:51:26:WU04:FS03:0x22:Completed 100000 out of 5000000 steps (2%)
02:02:06:WU04:FS03:0x22:Completed 150000 out of 5000000 steps (3%)
02:13:26:WU04:FS03:0x22:Completed 200000 out of 5000000 steps (4%)
02:24:04:WU04:FS03:0x22:Completed 250000 out of 5000000 steps (5%)
02:34:51:WU04:FS03:0x22:Completed 300000 out of 5000000 steps (6%)
02:46:00:WU04:FS03:0x22:Completed 350000 out of 5000000 steps (7%)
02:56:58:WU04:FS03:0x22:Completed 400000 out of 5000000 steps (8%)
03:08:02:WU04:FS03:0x22:Completed 450000 out of 5000000 steps (9%)
03:19:08:WU04:FS03:0x22:Completed 500000 out of 5000000 steps (10%)
03:30:08:WU04:FS03:0x22:Completed 550000 out of 5000000 steps (11%)
03:41:15:WU04:FS03:0x22:Completed 600000 out of 5000000 steps (12%)
03:50:12:WU04:FS03:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
03:50:12:WU04:FS03:0x22:Following exception occured: Particle coordinate is nan
******************************* Date: 2020-04-13 *******************************
04:01:06:WU04:FS03:0x22:Completed 650000 out of 5000000 steps (13%)
04:12:45:WU04:FS03:0x22:Completed 700000 out of 5000000 steps (14%)
04:26:25:WU04:FS03:0x22:Completed 750000 out of 5000000 steps (15%)
04:40:20:WU04:FS03:0x22:Completed 800000 out of 5000000 steps (16%)
04:54:10:WU04:FS03:0x22:Completed 850000 out of 5000000 steps (17%)
05:08:07:WU04:FS03:0x22:Completed 900000 out of 5000000 steps (18%)
05:21:50:WU04:FS03:0x22:Completed 950000 out of 5000000 steps (19%)
First time I see this error on that computer, and searching the logs show no other occurrence.
In the WU stats, it does show 1 FAULTY and one OK for this WU already. Bit strange that an error popped up after 2 minutes though.
Re: Particle coordinate nan project:14545 run:0 clone:1728 g
Could be a WU that is borderline stable, or one that stresses your GPU a bit differently than other WUs that have run on it.
If it turns out to be a one-off, then it is probably the first. If you see a pattern of WUs from some projects doing this, then if you have your GPU overclocked, consider reducing it by a bit. Or if factory overclocked, reduce the clock closer to reference card values.
EduardoCZ
Post by EduardoCZ »
Hello, same here.
14545 (Run 0, Clone 718, Gen 10)
GPU AMD RX580 Ellesmere XT
Plus I have also this error:
06:45:00:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
06:45:00:WU01:FS01:0x22:Following exception occured: Force RMSE error of 6.29986 with threshold of 5
But in the end WU finished sucesfully and uploded, however PPD wos somehow lower than usual (about 320k PPD, other projects ~410k-450k PPD) and it took longer to fold.
*********************** Log Started 2020-04-15T00:13:19Z ***********************
00:13:19:************************* Folding@home Client *************************
00:13:19:        Website: https://foldingathome.org/
00:13:19:      Copyright: (c) 2009-2018 foldingathome.org
00:13:19:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:13:19:           Args:
00:13:19:         Config: C:\Users\Kiklouni\AppData\Roaming\FAHClient\config.xml
00:13:19:******************************** Build ********************************
00:13:19:        Version: 7.5.1
00:13:19:           Date: May 11 2018
00:13:19:           Time: 13:06:32
00:13:19:     Repository: Git
00:13:19:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:13:19:         Branch: master
00:13:19:       Compiler: Visual C++ 2008
00:13:19:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:13:19:       Platform: win32 10
00:13:19:           Bits: 32
00:13:19:           Mode: Release
00:13:19:******************************* System ********************************
00:13:19:            CPU: Intel(R) Core(TM) i3-4170 CPU @ 3.70GHz
00:13:19:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:13:19:           CPUs: 4
00:13:19:         Memory: 7.94GiB
00:13:19:    Free Memory: 5.78GiB
00:13:19:        Threads: WINDOWS_THREADS
00:13:19:     OS Version: 6.2
00:13:19:    Has Battery: false
00:13:19:     On Battery: false
00:13:19:     UTC Offset: 2
00:13:19:            PID: 1696
00:13:19:            CWD: C:\Users\Kiklouni\AppData\Roaming\FAHClient
00:13:19:             OS: Windows 10 Home
00:13:19:        OS Arch: AMD64
00:13:19:           GPUs: 1
00:13:19:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
00:13:19:                 470/480/570/580/590]
00:13:19:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
00:13:19:                 Uvedený modul nebyl nalezen.
00:13:19:
00:13:19:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
00:13:19:  Win32 Service: false
00:13:19:***********************************************************************
00:13:19:<config>
00:13:19:  <!-- Folding Core -->
00:13:19:  <checkpoint v='10'/>
00:13:19:
00:13:19:  <!-- HTTP Server -->
00:13:19:  <allow v='127.0.0.1 192.168.0.0/24'/>
00:13:19:
00:13:19:  <!-- Network -->
00:13:19:  <proxy v=':8080'/>
00:13:19:
00:13:19:  <!-- Remote Command Server -->
00:13:19:  <command-allow-no-pass v='127.0.0.1 192.168.0.0/24'/>
00:13:19:
00:13:19:  <!-- User Information -->
00:13:19:  <passkey v='********************************'/>
00:13:19:  <team v='236157'/>
00:13:19:  <user v='EduardoCZ'/>
00:13:19:
00:13:19:  <!-- Folding Slots -->
00:13:19:  <slot id='1' type='GPU'>
00:13:19:    <gpu-index v='0'/>
00:13:19:  </slot>
00:13:19:</config>
00:13:19:Trying to access database...
00:13:19:Successfully acquired database lock
00:13:19:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
00:13:19:WU00:FS01:Starting
00:13:19:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Kiklouni\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 1696 -checkpoint 10 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
00:13:20:WU00:FS01:Started FahCore on PID 3820
00:13:20:WU00:FS01:Core PID:3924
00:13:20:WU00:FS01:FahCore 0x22 started
00:13:21:WU00:FS01:0x22:*********************** Log Started 2020-04-15T00:13:20Z ***********************
00:13:21:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:13:21:WU00:FS01:0x22:       Type: 0x22
00:13:21:WU00:FS01:0x22:       Core: Core22
00:13:21:WU00:FS01:0x22:    Website: https://foldingathome.org/
00:13:21:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
00:13:21:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
00:13:21:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
00:13:21:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 3820 -checkpoint 10
00:13:21:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
00:13:21:WU00:FS01:0x22:     Config: <none>
00:13:21:WU00:FS01:0x22:************************************ Build *************************************
00:13:21:WU00:FS01:0x22:    Version: 0.0.2
00:13:21:WU00:FS01:0x22:       Date: Dec 6 2019
00:13:21:WU00:FS01:0x22:       Time: 21:30:31
00:13:21:WU00:FS01:0x22: Repository: Git
00:13:21:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
00:13:21:WU00:FS01:0x22:     Branch: HEAD
00:13:21:WU00:FS01:0x22:   Compiler: Visual C++ 2008
00:13:21:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:13:21:WU00:FS01:0x22:   Platform: win32 10
00:13:21:WU00:FS01:0x22:       Bits: 64
00:13:21:WU00:FS01:0x22:       Mode: Release
00:13:21:WU00:FS01:0x22:************************************ System ************************************
00:13:21:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i3-4170 CPU @ 3.70GHz
00:13:21:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:13:21:WU00:FS01:0x22:       CPUs: 4
00:13:21:WU00:FS01:0x22:     Memory: 7.94GiB
00:13:21:WU00:FS01:0x22:Free Memory: 5.57GiB
00:13:21:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
00:13:21:WU00:FS01:0x22: OS Version: 6.2
00:13:21:WU00:FS01:0x22:Has Battery: false
00:13:21:WU00:FS01:0x22: On Battery: false
00:13:21:WU00:FS01:0x22: UTC Offset: 2
00:13:21:WU00:FS01:0x22:        PID: 3924
00:13:21:WU00:FS01:0x22:        CWD: C:\Users\Kiklouni\AppData\Roaming\FAHClient\work
00:13:21:WU00:FS01:0x22:         OS: Windows 10 Home
00:13:21:WU00:FS01:0x22:    OS Arch: AMD64
00:13:21:WU00:FS01:0x22:********************************************************************************
00:13:21:WU00:FS01:0x22:Project: 11743 (Run 0, Clone 10347, Gen 16)
00:13:21:WU00:FS01:0x22:Unit: 0x000000188ca304f15e6d7cc1af405e88
00:13:21:WU00:FS01:0x22:Digital signatures verified
00:13:21:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:13:21:WU00:FS01:0x22:Version 0.0.2
00:13:21:WU00:FS01:0x22:  Found a checkpoint file
00:13:37:WU00:FS01:0x22:Completed 550000 out of 2000000 steps (27%)
00:13:38:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:14:42:WU00:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
00:16:48:WU00:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
00:18:54:WU00:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
00:21:03:WU00:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
00:23:10:WU00:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
00:25:18:WU00:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
00:27:24:WU00:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
00:29:30:WU00:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
00:31:39:WU00:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
00:33:45:WU00:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
00:35:54:WU00:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
00:38:00:WU00:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
00:40:07:WU00:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
00:42:15:WU00:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
00:44:22:WU00:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
00:46:30:WU00:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
00:48:36:WU00:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
00:50:43:WU00:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
00:52:51:WU00:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
00:54:57:WU00:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
00:57:05:WU00:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
00:59:12:WU00:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
01:01:18:WU00:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
01:03:27:WU00:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
01:05:33:WU00:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
01:07:41:WU00:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
01:09:48:WU00:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
01:11:54:WU00:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
01:14:03:WU00:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
01:16:09:WU00:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
01:18:17:WU00:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
01:20:24:WU00:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
01:22:30:WU00:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
01:24:38:WU00:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
01:26:45:WU00:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
01:28:53:WU00:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
01:30:59:WU00:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
01:33:06:WU00:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
01:35:14:WU00:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
01:37:21:WU00:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
01:39:29:WU00:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
01:41:35:WU00:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
01:43:42:WU00:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
01:45:50:WU00:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
01:47:56:WU00:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
01:50:05:WU00:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
01:52:11:WU00:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
01:54:18:WU00:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
01:56:26:WU00:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
01:58:32:WU00:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
02:00:41:WU00:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
02:02:47:WU00:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
02:04:53:WU00:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
02:07:02:WU00:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
02:09:08:WU00:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
02:11:17:WU00:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
02:13:22:WU00:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
02:15:30:WU00:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
02:17:38:WU00:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
02:19:45:WU00:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
02:21:53:WU00:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
02:23:59:WU00:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
02:26:06:WU00:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
02:28:14:WU00:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
02:30:20:WU00:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
02:32:29:WU00:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
02:34:35:WU00:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
02:36:42:WU00:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
02:38:50:WU00:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
02:40:56:WU00:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
02:43:05:WU00:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
02:45:11:WU00:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
02:45:12:WU01:FS01:Connecting to 65.254.110.245:8080
02:45:13:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:45:13:WU01:FS01:Connecting to 18.218.241.186:80
02:45:13:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:45:13:ERROR:WU01:FS01:Exception: Could not get an assignment
02:45:13:WU01:FS01:Connecting to 65.254.110.245:8080
02:45:14:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:45:14:WU01:FS01:Connecting to 18.218.241.186:80
02:45:15:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:45:15:ERROR:WU01:FS01:Exception: Could not get an assignment
02:46:14:WU01:FS01:Connecting to 65.254.110.245:8080
02:46:14:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:46:14:WU01:FS01:Connecting to 18.218.241.186:80
02:46:15:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:46:15:ERROR:WU01:FS01:Exception: Could not get an assignment
02:47:18:WU00:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
02:47:20:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
02:47:20:WU00:FS01:0x22:Saving result file checkpointState.xml
02:47:21:WU00:FS01:0x22:Saving result file checkpt.crc
02:47:21:WU00:FS01:0x22:Saving result file positions.xtc
02:47:22:WU00:FS01:0x22:Saving result file science.log
02:47:22:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
02:47:23:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:47:23:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11743 run:0 clone:10347 gen:16 core:0x22 unit:0x000000188ca304f15e6d7cc1af405e88
02:47:23:WU00:FS01:Uploading 12.65MiB to 140.163.4.241
02:47:23:WU00:FS01:Connecting to 140.163.4.241:8080
02:47:29:WU00:FS01:Upload 10.38%
02:47:35:WU00:FS01:Upload 22.24%
02:47:41:WU00:FS01:Upload 33.60%
02:47:47:WU00:FS01:Upload 45.46%
02:47:51:WU01:FS01:Connecting to 65.254.110.245:8080
02:47:51:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:47:51:WU01:FS01:Connecting to 18.218.241.186:80
02:47:52:WU01:FS01:Assigned to work server 13.82.98.119
02:47:52:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 13.82.98.119
02:47:52:WU01:FS01:Connecting to 13.82.98.119:8080
02:47:54:WU00:FS01:Upload 51.89%
02:47:55:WU01:FS01:Downloading 22.03MiB
02:48:00:WU00:FS01:Upload 61.77%
02:48:01:WU01:FS01:Download 7.38%
02:48:06:WU00:FS01:Upload 73.13%
02:48:07:WU01:FS01:Download 15.32%
02:48:12:WU00:FS01:Upload 84.50%
02:48:13:WU01:FS01:Download 26.67%
02:48:18:WU00:FS01:Upload 95.37%
02:48:19:WU01:FS01:Download 39.44%
02:48:22:WU00:FS01:Upload complete
02:48:22:WU00:FS01:Server responded WORK_ACK (400)
02:48:22:WU00:FS01:Final credit estimate, 59339.00 points
02:48:22:WU00:FS01:Cleaning up
02:48:25:WU01:FS01:Download 53.35%
02:48:31:WU01:FS01:Download 76.33%
02:48:37:WU01:FS01:Download 96.48%
02:48:38:WU01:FS01:Download complete
02:48:38:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14545 run:0 clone:718 gen:10 core:0x22 unit:0x0000000c0d5262775e80e22421f13e8c
02:48:38:WU01:FS01:Starting
02:48:38:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Kiklouni\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 1696 -checkpoint 10 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
02:48:38:WU01:FS01:Started FahCore on PID 6164
02:48:38:WU01:FS01:Core PID:2212
02:48:38:WU01:FS01:FahCore 0x22 started
02:48:38:WU01:FS01:0x22:*********************** Log Started 2020-04-15T02:48:38Z ***********************
02:48:38:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
02:48:38:WU01:FS01:0x22:       Type: 0x22
02:48:38:WU01:FS01:0x22:       Core: Core22
02:48:38:WU01:FS01:0x22:    Website: https://foldingathome.org/
02:48:38:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
02:48:38:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
02:48:38:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
02:48:38:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 6164 -checkpoint 10
02:48:38:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
02:48:38:WU01:FS01:0x22:     Config: <none>
02:48:38:WU01:FS01:0x22:************************************ Build *************************************
02:48:38:WU01:FS01:0x22:    Version: 0.0.2
02:48:38:WU01:FS01:0x22:       Date: Dec 6 2019
02:48:38:WU01:FS01:0x22:       Time: 21:30:31
02:48:38:WU01:FS01:0x22: Repository: Git
02:48:38:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
02:48:38:WU01:FS01:0x22:     Branch: HEAD
02:48:38:WU01:FS01:0x22:   Compiler: Visual C++ 2008
02:48:38:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:48:38:WU01:FS01:0x22:   Platform: win32 10
02:48:38:WU01:FS01:0x22:       Bits: 64
02:48:38:WU01:FS01:0x22:       Mode: Release
02:48:38:WU01:FS01:0x22:************************************ System ************************************
02:48:38:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i3-4170 CPU @ 3.70GHz
02:48:38:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
02:48:38:WU01:FS01:0x22:       CPUs: 4
02:48:38:WU01:FS01:0x22:     Memory: 7.94GiB
02:48:38:WU01:FS01:0x22:Free Memory: 4.90GiB
02:48:38:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
02:48:38:WU01:FS01:0x22: OS Version: 6.2
02:48:38:WU01:FS01:0x22:Has Battery: false
02:48:38:WU01:FS01:0x22: On Battery: false
02:48:38:WU01:FS01:0x22: UTC Offset: 2
02:48:38:WU01:FS01:0x22:        PID: 2212
02:48:38:WU01:FS01:0x22:        CWD: C:\Users\Kiklouni\AppData\Roaming\FAHClient\work
02:48:38:WU01:FS01:0x22:         OS: Windows 10 Home
02:48:38:WU01:FS01:0x22:    OS Arch: AMD64
02:48:38:WU01:FS01:0x22:********************************************************************************
02:48:38:WU01:FS01:0x22:Project: 14545 (Run 0, Clone 718, Gen 10)
02:48:38:WU01:FS01:0x22:Unit: 0x0000000c0d5262775e80e22421f13e8c
02:48:38:WU01:FS01:0x22:Reading tar file core.xml
02:48:38:WU01:FS01:0x22:Reading tar file integrator.xml
02:48:38:WU01:FS01:0x22:Reading tar file state.xml
02:48:38:WU01:FS01:0x22:Reading tar file system.xml
02:48:38:WU01:FS01:0x22:Digital signatures verified
02:48:38:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
02:48:38:WU01:FS01:0x22:Version 0.0.2
02:48:46:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
02:48:46:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:52:00:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
02:55:14:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
02:58:28:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
03:01:42:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
03:04:56:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
03:08:10:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
03:11:25:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
03:14:39:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
03:17:53:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
03:21:07:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
03:24:21:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
03:27:35:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
03:30:49:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
03:34:03:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
03:37:17:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
03:40:31:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
03:43:46:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
03:47:00:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
03:50:14:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
03:53:28:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
03:56:42:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
03:59:56:WU01:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
04:03:10:WU01:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
04:06:25:WU01:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
04:09:39:WU01:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
04:12:53:WU01:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
04:16:07:WU01:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
04:19:20:WU01:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
04:22:34:WU01:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
04:25:48:WU01:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
04:29:01:WU01:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
04:32:16:WU01:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
04:35:31:WU01:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
04:38:45:WU01:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
04:41:59:WU01:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
04:45:13:WU01:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
04:48:27:WU01:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
04:51:41:WU01:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
04:54:55:WU01:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
04:58:10:WU01:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
05:01:24:WU01:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
05:04:39:WU01:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
05:07:53:WU01:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
05:11:07:WU01:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
05:14:22:WU01:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
05:17:36:WU01:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
05:20:50:WU01:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
05:24:04:WU01:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
05:27:18:WU01:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
05:30:32:WU01:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
05:33:46:WU01:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
05:37:01:WU01:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
05:40:15:WU01:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
05:43:29:WU01:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
05:46:44:WU01:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
05:49:58:WU01:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
05:53:12:WU01:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
05:56:27:WU01:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
05:59:41:WU01:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
06:02:55:WU01:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
06:06:09:WU01:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
06:09:23:WU01:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
06:12:37:WU01:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
******************************* Date: 2020-04-15 *******************************
06:15:51:WU01:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
06:19:05:WU01:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
06:22:20:WU01:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
06:25:34:WU01:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
06:28:48:WU01:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
06:32:02:WU01:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
06:35:16:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
06:38:30:WU01:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
06:41:44:WU01:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
06:44:59:WU01:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
06:51:27:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
06:54:41:WU01:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
06:57:56:WU01:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
07:01:10:WU01:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
07:04:24:WU01:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
07:07:38:WU01:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
07:10:52:WU01:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
07:14:06:WU01:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
07:15:52:22:127.0.0.1:New Web connection
07:17:25:WU01:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
07:20:40:WU01:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
07:23:56:WU01:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
07:27:11:WU01:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
07:30:26:WU01:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
07:33:42:WU01:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
07:36:57:WU01:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
07:38:43:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
07:38:43:WU01:FS01:0x22:Following exception occured: Particle coordinate is nan
07:41:57:WU01:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
07:45:13:WU01:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
07:48:29:WU01:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
07:51:44:WU01:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
07:55:00:WU01:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
07:58:16:WU01:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
08:01:33:WU01:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
08:04:50:WU01:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
08:08:04:WU01:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
