Can't Upload - Has the work passed the timeout?
KimboJ
Post by KimboJ »
*********************** Log Started 2020-04-12T23:48:47Z ***********************
23:48:47:************************* Folding@home Client *************************
23:48:47:        Website: https://foldingathome.org/
23:48:47:      Copyright: (c) 2009-2018 foldingathome.org
23:48:47:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:48:47:           Args:
23:48:47:         Config: C:\Users\Kimberley\AppData\Roaming\FAHClient\config.xml
23:48:47:******************************** Build ********************************
23:48:47:        Version: 7.5.1
23:48:47:           Date: May 11 2018
23:48:47:           Time: 13:06:32
23:48:47:     Repository: Git
23:48:47:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
23:48:47:         Branch: master
23:48:47:       Compiler: Visual C++ 2008
23:48:47:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:48:47:       Platform: win32 10
23:48:47:           Bits: 32
23:48:47:           Mode: Release
23:48:47:******************************* System ********************************
23:48:47:            CPU: Intel(R) Core(TM) i5 CPU M 480 @ 2.67GHz
23:48:47:         CPU ID: GenuineIntel Family 6 Model 37 Stepping 5
23:48:47:           CPUs: 4
23:48:47:         Memory: 5.86GiB
23:48:47:    Free Memory: 3.07GiB
23:48:47:        Threads: WINDOWS_THREADS
23:48:47:     OS Version: 6.2
23:48:47:    Has Battery: true
23:48:47:     On Battery: false
23:48:47:     UTC Offset: 1
23:48:47:            PID: 12072
23:48:47:            CWD: C:\Users\Kimberley\AppData\Roaming\FAHClient
23:48:47:             OS: Windows 10 Home
23:48:47:        OS Arch: AMD64
23:48:47:           GPUs: 1
23:48:47:          GPU 0: Bus:1 Slot:0 Func:0 AMD:4 Manhattan [Mobility Radeon HD 5000
23:48:47:                 Series]
23:48:47:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
23:48:47:                 specified module could not be found.
23:48:47:
23:48:47:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:1800.11
23:48:47:  Win32 Service: false
23:48:47:***********************************************************************
23:48:47:<config>
23:48:47:  <!-- Network -->
23:48:47:  <proxy v=':8080'/>
23:48:47:
23:48:47:  <!-- Slot Control -->
23:48:47:  <power v='full'/>
23:48:47:
23:48:47:  <!-- User Information -->
23:48:47:  <team v='247707'/>
23:48:47:  <user v='KimboJ'/>
23:48:47:
23:48:47:  <!-- Folding Slots -->
23:48:47:  <slot id='0' type='CPU'/>
23:48:47:  <slot id='1' type='GPU'/>
23:48:47:</config>
23:48:47:Trying to access database...
23:48:47:Successfully acquired database lock
23:48:47:Enabled folding slot 00: READY cpu:3
23:48:47:Enabled folding slot 01: READY gpu:0:Manhattan [Mobility Radeon HD 5000 Series]
23:48:47:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14409 run:0 clone:909 gen:37 core:0xa7 unit:0x0000002e80fccb095e6e41715fdb286c
23:48:47:WU00:FS00:Uploading 9.13MiB to 128.252.203.9
23:48:47:WU02:FS00:Starting
23:48:47:WU00:FS00:Connecting to 128.252.203.9:8080
23:48:47:WARNING:WU02:FS00:AS lowered CPUs from 3 to 1
23:48:48:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Kimberley\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 12072 -checkpoint 15 -np 1
23:48:53:WU00:FS00:Upload 41.06%
23:48:53:WU02:FS00:Started FahCore on PID 10216
23:48:59:WU00:FS00:Upload 76.65%
23:49:01:WU00:FS00:Upload complete
23:49:04:WU02:FS00:Core PID:12804
23:49:04:WU02:FS00:FahCore 0xa7 started
23:49:09:WU02:FS00:0xa7:*********************** Log Started 2020-04-12T23:49:09Z ***********************
23:49:09:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:49:09:WU02:FS00:0xa7:       Type: 0xa7
23:49:09:WU02:FS00:0xa7:       Core: Gromacs
23:49:09:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 10216 -checkpoint 15 -np
23:49:09:WU02:FS00:0xa7:             1
23:49:09:WU02:FS00:0xa7:************************************ CBang *************************************
23:49:09:WU02:FS00:0xa7:       Date: Oct 26 2019
23:49:09:WU02:FS00:0xa7:       Time: 01:38:35
23:49:09:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:49:09:WU02:FS00:0xa7:     Branch: master
23:49:09:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
23:49:09:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:49:09:WU02:FS00:0xa7:   Platform: win32 10
23:49:09:WU02:FS00:0xa7:       Bits: 64
23:49:09:WU02:FS00:0xa7:       Mode: Release
23:49:09:WU02:FS00:0xa7:************************************ System ************************************
23:49:10:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5 CPU M 480 @ 2.67GHz
23:49:10:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 37 Stepping 5
23:49:10:WU02:FS00:0xa7:       CPUs: 4
23:49:10:WU02:FS00:0xa7:     Memory: 5.86GiB
23:49:10:WU02:FS00:0xa7:Free Memory: 2.61GiB
23:49:10:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
23:49:10:WU02:FS00:0xa7: OS Version: 6.2
23:49:10:WU02:FS00:0xa7:Has Battery: true
23:49:10:WU02:FS00:0xa7: On Battery: false
23:49:10:WU02:FS00:0xa7: UTC Offset: 1
23:49:10:WU02:FS00:0xa7:        PID: 12804
23:49:10:WU02:FS00:0xa7:        CWD: C:\Users\Kimberley\AppData\Roaming\FAHClient\work
23:49:10:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
23:49:10:WU02:FS00:0xa7:    Version: 0.0.18
23:49:10:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:49:10:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:49:10:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
23:49:10:WU02:FS00:0xa7:       Date: Oct 26 2019
23:49:10:WU02:FS00:0xa7:       Time: 01:52:44
23:49:10:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:49:10:WU02:FS00:0xa7:     Branch: master
23:49:10:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
23:49:10:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:49:10:WU02:FS00:0xa7:   Platform: win32 10
23:49:10:WU02:FS00:0xa7:       Bits: 64
23:49:10:WU02:FS00:0xa7:       Mode: Release
23:49:10:WU02:FS00:0xa7:************************************ Build *************************************
23:49:10:WU02:FS00:0xa7:       SIMD: sse2
23:49:10:WU02:FS00:0xa7:********************************************************************************
23:49:10:WU02:FS00:0xa7:Project: 14401 (Run 0, Clone 255, Gen 91)
23:49:10:WU02:FS00:0xa7:Unit: 0x0000006980fccb095dcb30e6adee51bf
23:49:10:WU02:FS00:0xa7:Digital signatures verified
23:49:10:WU02:FS00:0xa7:Calling: mdrun -s frame91.tpr -o frame91.trr -x frame91.xtc -cpi state.cpt -cpt 15 -nt 1
23:49:32:WU02:FS00:0xa7:Steps: first=11375000 total=125000
23:49:36:WU02:FS00:0xa7:Completed 58481 out of 125000 steps (46%)
23:50:29:WARNING:WU02:FS00:Detected clock skew (1 mins 20 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
23:50:29:WU01:FS01:Connecting to 65.254.110.245:8080
23:50:30:WU00:FS00:Server responded PLEASE_WAIT (464)
23:50:30:WARNING:WU00:FS00:Failed to send results, will try again later
23:50:30:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14409 run:0 clone:909 gen:37 core:0xa7 unit:0x0000002e80fccb095e6e41715fdb286c
23:50:30:WU00:FS00:Uploading 9.13MiB to 128.252.203.9
23:50:30:WU00:FS00:Connecting to 128.252.203.9:8080
23:50:30:WU01:FS01:Assigned to work server 192.0.2.1
23:50:30:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Manhattan [Mobility Radeon HD 5000 Series] from 192.0.2.1
23:50:30:WU01:FS01:Connecting to 192.0.2.1:8080
23:50:36:WU00:FS00:Upload 38.33%
23:50:42:WU00:FS00:Upload 56.12%
23:50:48:WU00:FS00:Upload 91.02%
23:50:49:WU00:FS00:Upload complete
23:50:49:WU00:FS00:Server responded PLEASE_WAIT (464)
23:50:49:WARNING:WU00:FS00:Failed to send results, will try again later
23:50:51:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:50:51:WU01:FS01:Connecting to 192.0.2.1:80
23:51:13:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:51:13:WU01:FS01:Connecting to 65.254.110.245:8080
23:51:13:WU01:FS01:Assigned to work server 192.0.2.1
23:51:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Manhattan [Mobility Radeon HD 5000 Series] from 192.0.2.1
23:51:13:WU01:FS01:Connecting to 192.0.2.1:8080
23:51:30:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14409 run:0 clone:909 gen:37 core:0xa7 unit:0x0000002e80fccb095e6e41715fdb286c
23:51:30:WU00:FS00:Uploading 9.13MiB to 128.252.203.9
23:51:30:WU00:FS00:Connecting to 128.252.203.9:8080
23:51:34:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:51:34:WU01:FS01:Connecting to 192.0.2.1:80
23:51:36:WU00:FS00:Upload 41.75%
23:51:42:WU00:FS00:Upload 89.65%
23:51:43:WU00:FS00:Upload complete
23:51:43:WU00:FS00:Server responded PLEASE_WAIT (464)
23:51:43:WARNING:WU00:FS00:Failed to send results, will try again later
23:51:55:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:52:13:WU01:FS01:Connecting to 65.254.110.245:8080
23:52:13:WU01:FS01:Assigned to work server 192.0.2.1
23:52:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Manhattan [Mobility Radeon HD 5000 Series] from 192.0.2.1
23:52:13:WU01:FS01:Connecting to 192.0.2.1:8080
23:52:34:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:52:34:WU01:FS01:Connecting to 192.0.2.1:80
23:52:56:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:53:10:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14409 run:0 clone:909 gen:37 core:0xa7 unit:0x0000002e80fccb095e6e41715fdb286c
23:53:10:WU00:FS00:Uploading 9.13MiB to 128.252.203.9
23:53:10:WU00:FS00:Connecting to 128.252.203.9:8080
23:53:16:WU00:FS00:Upload 57.49%
23:53:22:WU00:FS00:Upload complete
23:53:22:WU00:FS00:Server responded PLEASE_WAIT (464)
23:53:22:WARNING:WU00:FS00:Failed to send results, will try again later
23:53:50:WU01:FS01:Connecting to 65.254.110.245:8080
23:53:51:WU01:FS01:Assigned to work server 192.0.2.1
23:53:51:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Manhattan [Mobility Radeon HD 5000 Series] from 192.0.2.1
23:53:51:WU01:FS01:Connecting to 192.0.2.1:8080
23:54:12:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:54:12:WU01:FS01:Connecting to 192.0.2.1:80
23:54:33:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:54:43:WU02:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
23:55:47:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14409 run:0 clone:909 gen:37 core:0xa7 unit:0x0000002e80fccb095e6e41715fdb286c
23:55:47:WU00:FS00:Uploading 9.13MiB to 128.252.203.9
23:55:47:WU00:FS00:Connecting to 128.252.203.9:8080
23:55:53:WU00:FS00:Upload 54.07%
23:55:59:WU00:FS00:Upload 89.65%
23:56:00:WU00:FS00:Upload complete
23:56:00:WU00:FS00:Server responded PLEASE_WAIT (464)
23:56:00:WARNING:WU00:FS00:Failed to send results, will try again later
23:56:27:WU01:FS01:Connecting to 65.254.110.245:8080
23:56:28:WU01:FS01:Assigned to work server 192.0.2.1
23:56:28:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Manhattan [Mobility Radeon HD 5000 Series] from 192.0.2.1
23:56:28:WU01:FS01:Connecting to 192.0.2.1:8080
23:56:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:56:49:WU01:FS01:Connecting to 192.0.2.1:80
23:57:10:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:00:01:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14409 run:0 clone:909 gen:37 core:0xa7 unit:0x0000002e80fccb095e6e41715fdb286c
00:00:01:WU00:FS00:Uploading 9.13MiB to 128.252.203.9
00:00:01:WU00:FS00:Connecting to 128.252.203.9:8080
00:00:07:WU00:FS00:Upload 58.86%
00:00:10:WU00:FS00:Upload complete
00:00:10:WU00:FS00:Server responded PLEASE_WAIT (464)
00:00:10:WARNING:WU00:FS00:Failed to send results, will try again later
00:00:42:WU01:FS01:Connecting to 65.254.110.245:8080
00:00:42:WU01:FS01:Assigned to work server 192.0.2.1
00:00:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Manhattan [Mobility Radeon HD 5000 Series] from 192.0.2.1
00:00:42:WU01:FS01:Connecting to 192.0.2.1:8080
00:01:03:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
00:01:03:WU01:FS01:Connecting to 192.0.2.1:80
00:01:25:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:03:14:11:127.0.0.1:New Web connection
00:06:52:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14409 run:0 clone:909 gen:37 core:0xa7 unit:0x0000002e80fccb095e6e41715fdb286c
00:06:53:WU00:FS00:Uploading 9.13MiB to 128.252.203.9
00:06:53:WU00:FS00:Connecting to 128.252.203.9:8080
00:06:59:WU00:FS00:Upload 58.86%
00:07:02:WU00:FS00:Upload complete
00:07:02:WU00:FS00:Server responded PLEASE_WAIT (464)
00:07:02:WARNING:WU00:FS00:Failed to send results, will try again later
00:07:33:WU01:FS01:Connecting to 65.254.110.245:8080
00:07:33:WU01:FS01:Assigned to work server 192.0.2.1
00:07:33:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Manhattan [Mobility Radeon HD 5000 Series] from 192.0.2.1
00:07:33:WU01:FS01:Connecting to 192.0.2.1:8080
00:07:54:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
00:07:54:WU01:FS01:Connecting to 192.0.2.1:80
00:08:16:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:11:28:FS00:Paused
00:11:28:FS01:Paused
00:11:28:FS00:Shutting core down
00:11:29:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 12804
00:11:29:WU02:FS00:0xa7:Exiting, please wait. . .
00:11:38:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
00:11:38:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:11:51:Saving configuration to config.xml
00:11:51:<config>
00:11:51:  <!-- Network -->
00:11:51:  <proxy v=':8080'/>
00:11:51:
00:11:51:  <!-- Slot Control -->
00:11:51:  <power v='full'/>
00:11:51:
00:11:51:  <!-- User Information -->
00:11:51:  <team v='247707'/>
00:11:51:  <user v='KimboJ'/>
00:11:51:
00:11:51:  <!-- Folding Slots -->
00:11:51:  <slot id='0' type='CPU'>
00:11:51:    <paused v='true'/>
00:11:51:  </slot>
00:11:51:  <slot id='1' type='GPU'>
00:11:51:  </slot>
00:11:51:</config>
00:17:58:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14409 run:0 clone:909 gen:37 core:0xa7 unit:0x0000002e80fccb095e6e41715fdb286c
00:17:58:WU00:FS00:Uploading 9.13MiB to 128.252.203.9
00:17:58:WU00:FS00:Connecting to 128.252.203.9:8080
00:18:04:WU00:FS00:Upload 47.91%
00:18:08:WU00:FS00:Upload complete
00:18:08:WU00:FS00:Server responded PLEASE_WAIT (464)
00:18:08:WARNING:WU00:FS00:Failed to send results, will try again later
00:20:33:FS00:Unpaused
00:20:33:FS01:Unpaused
00:20:33:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14409 run:0 clone:909 gen:37 core:0xa7 unit:0x0000002e80fccb095e6e41715fdb286c
00:20:33:WU00:FS00:Uploading 9.13MiB to 128.252.203.9
00:20:33:WU00:FS00:Connecting to 128.252.203.9:8080
00:20:33:WU02:FS00:Starting
00:20:33:WARNING:WU02:FS00:AS lowered CPUs from 3 to 1
00:20:33:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Kimberley\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 12072 -checkpoint 15 -np 1
00:20:33:WU02:FS00:Started FahCore on PID 7020
00:20:33:WU02:FS00:Core PID:12736
00:20:34:WU02:FS00:FahCore 0xa7 started
00:20:34:WU02:FS00:0xa7:*********************** Log Started 2020-04-13T00:20:34Z ***********************
00:20:34:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:20:34:WU02:FS00:0xa7:       Type: 0xa7
00:20:34:WU02:FS00:0xa7:       Core: Gromacs
00:20:34:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 7020 -checkpoint 15 -np 1
00:20:34:WU02:FS00:0xa7:************************************ CBang *************************************
00:20:34:WU02:FS00:0xa7:       Date: Oct 26 2019
00:20:34:WU02:FS00:0xa7:       Time: 01:38:35
00:20:34:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
00:20:34:WU02:FS00:0xa7:     Branch: master
00:20:34:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
00:20:34:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:20:34:WU02:FS00:0xa7:   Platform: win32 10
00:20:34:WU02:FS00:0xa7:       Bits: 64
00:20:34:WU02:FS00:0xa7:       Mode: Release
00:20:34:WU02:FS00:0xa7:************************************ System ************************************
00:20:34:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5 CPU M 480 @ 2.67GHz
00:20:34:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 37 Stepping 5
00:20:34:WU02:FS00:0xa7:       CPUs: 4
00:20:34:WU02:FS00:0xa7:     Memory: 5.86GiB
00:20:34:WU02:FS00:0xa7:Free Memory: 1.96GiB
00:20:34:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
00:20:34:WU01:FS01:Connecting to 65.254.110.245:8080
00:20:34:WU02:FS00:0xa7: OS Version: 6.2
00:20:34:WU02:FS00:0xa7:Has Battery: true
00:20:34:WU02:FS00:0xa7: On Battery: false
00:20:34:WU02:FS00:0xa7: UTC Offset: 1
00:20:34:WU02:FS00:0xa7:        PID: 12736
00:20:34:WU02:FS00:0xa7:        CWD: C:\Users\Kimberley\AppData\Roaming\FAHClient\work
00:20:34:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
00:20:34:WU02:FS00:0xa7:    Version: 0.0.18
00:20:34:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:20:34:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
00:20:34:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
00:20:34:WU02:FS00:0xa7:       Time: 01:52:44
00:20:34:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
00:20:34:WU02:FS00:0xa7:************************************ Build *************************************
00:20:34:WU02:FS00:0xa7:       SIMD: sse2
00:20:34:WU02:FS00:0xa7:********************************************************************************
00:20:34:WU02:FS00:0xa7:Project: 14401 (Run 0, Clone 255, Gen 91)
00:20:34:WU02:FS00:0xa7:Unit: 0x0000006980fccb095dcb30e6adee51bf
00:20:34:WU02:FS00:0xa7:Digital signatures verified
00:20:34:WU02:FS00:0xa7:Calling: mdrun -s frame91.tpr -o frame91.trr -x frame91.xtc -cpi state.cpt -cpt 15 -nt 1
00:20:34:WU02:FS00:0xa7:Steps: first=11375000 total=125000
00:20:39:WU00:FS00:Upload 52.70%
00:20:39:WU02:FS00:0xa7:Completed 59652 out of 125000 steps (47%)
00:20:43:WU00:FS00:Upload complete
00:20:45:WU01:FS01:Assigned to work server 192.0.2.1
00:20:45:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Manhattan [Mobility Radeon HD 5000 Series] from 192.0.2.1
00:20:45:WU01:FS01:Connecting to 192.0.2.1:8080
00:20:45:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:20:45:WU00:FS00:Server responded PLEASE_WAIT (464)
00:20:45:WARNING:WU00:FS00:Failed to send results, will try again later
00:21:00:Saving configuration to config.xml
00:21:00:<config>
00:21:00:  <!-- Network -->
00:21:00:  <proxy v=':8080'/>
00:21:00:
00:21:00:  <!-- Slot Control -->
00:21:00:  <power v='full'/>
00:21:00:
00:21:00:  <!-- User Information -->
00:21:00:  <team v='247707'/>
00:21:00:  <user v='KimboJ'/>
00:21:00:
00:21:00:  <!-- Folding Slots -->
00:21:00:  <slot id='0' type='CPU'/>
00:21:00:  <slot id='1' type='GPU'/>
00:21:00:</config>
00:21:06:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
00:21:06:WU01:FS01:Connecting to 192.0.2.1:80
00:21:27:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:22:10:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14409 run:0 clone:909 gen:37 core:0xa7 unit:0x0000002e80fccb095e6e41715fdb286c
00:22:10:WU00:FS00:Uploading 9.13MiB to 128.252.203.9
00:22:10:WU00:FS00:Connecting to 128.252.203.9:8080
00:22:11:WU01:FS01:Connecting to 65.254.110.245:8080
00:22:12:WU01:FS01:Assigned to work server 192.0.2.1
00:22:16:WU00:FS00:Upload 29.43%
00:22:22:WU00:FS00:Upload 67.75%
00:22:22:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Manhattan [Mobility Radeon HD 5000 Series] from 192.0.2.1
00:22:22:WU01:FS01:Connecting to 192.0.2.1:8080
00:22:25:WU00:FS00:Upload complete
00:22:25:WU00:FS00:Server responded PLEASE_WAIT (464)
00:22:25:WARNING:WU00:FS00:Failed to send results, will try again later
00:22:43:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
00:22:43:WU01:FS01:Connecting to 192.0.2.1:80
00:23:04:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
This is the entire log. I am not sure what to post.
I have FAH on both my laptop and desktop, because I am using my laptop more recently for the webcam etc. However, it is much slower than my desktop.
I have 1 WU that is stuck on my laptop and won't upload. Has it passed the timeout or expiration date? I don't know the difference between these. Why won't it send?
Assisgned 2020-04-07T21:08:41Z
Timeout 2020-04-08T21:08:41Z
Expiration 2020-04-14T21:08:41Z
Work Server 128.252.203.9
Collection Server 52.224.109.74
Thanks
Re: Can't Upload - Has the work passed the timeout?
Welcome to the F@H Forum KimboJ,
Please note that due to a significant increase in Donors, the F@H Servers have under load: viewtopic.php?f=18&t=33193
Thus, the behavior of a completed WU not being able to upload to the F@H Servers is expected. Things are improving slow but there's still additional work in the pipeline to hopefully address this issue. If your completed WU is not uploaded by the Expiration date, it will automatically be deleted so for now, you can leave it as it as the client will take care of it automatically.
Once thing I noticed from your log is that you're not using a passkey. While it is optional to use a passkey, it is recommended by F@H. You can read more information here and decide accordingly: https://foldingathome.org/support/faq/points/passkey/
You can also remove the GPU folding slot for the HD 5000 series GPU in the laptop. The GPU does not support Double Proecision calculations, and is no longer able to be used. Projects that could use it finished up last year.
I will check with the person managing the server about the upload getting a Please_Wait response.
sonick_rnd
Looks like 40.114.52.201 out of disk space. Waiting
Post by sonick_rnd »
06:19:22:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13851 run:0 clone:601 gen:27 core:0xa7 unit:0x00000028287234c95e7258b8758398f3
06:19:22:WU01:FS00:Uploading 2.53MiB to 40.114.52.201
06:19:22:WU01:FS00:Connecting to 40.114.52.201:8080
06:19:28:WU01:FS00:Upload 34.64%
06:19:34:WU01:FS00:Upload 69.28%
06:19:40:WU01:FS00:Upload 91.55%
06:19:42:WU01:FS00:Upload complete
06:19:42:WU01:FS00:Server responded PLEASE_WAIT (464)
06:19:42:WARNING:WU01:FS00:Failed to send results, will try again later
KimboJ
Post by KimboJ »
Thanks. I've deleted the GPU. I am surprised it was supported at all really, my laptop is pretty old and I haven't used it for years, although it was high middle range when I bought it like 8 years ago. I have only started using it recently because of group zoom calls. My desktop completes the work about 4 times faster and hasn't had any issues uploading.
The work is still here, so hopefully the server clears before it expires.
I have added a passkey now. I thought that I had done, but it must not have saved/not clicked save.
sonick_rnd
Okay, looks like mine WU passed to server okay.
