How to keep FAH from running when I'm working (OS X)
I have two Mac Pros with a total of 18 cores between them that I use for audio work. I would like to install FAH on them as I'm not working a lot right now due to the virus. But when I do my audio work I don't want anything running in the background. Can I make a new User Account (running OS X High Sierra) and install FAH from that account? If I did that, would it only run when that account is logged in?
Re: How to keep FAH from running when I'm working (OS X)
Welcome to the F@H Forum Smashprod,
First option would be you install the F@H Software as normal and it will fold on your CPU. When you're doing audio work, you can use Advanced Control (AKA FAHControl) to pause the CPU slot and it will stop within a minute. After that, you are free to do audio work. Once done, you can then unpause the CPU Slot and it will resume from the last checkpoint.
Second option would be similar to the above but instead of pausing and unpausing the CPU slot, you ensure that the CPU slot only folds when the system is idle.
Please note that the folding process for CPU is at a low priority so most of the time, you can use your system as normal and it won't make a difference. You may want to experiment with allowing the CPU to fold in the background and process the audio to see if there is any measurable impact or not.
TomJohnson
- Hardware configuration: F@H Info – V8.4.9 – 12 Machines – 123 CPUs - 1,000K+ PPD; 1/5/2025
Mac Pro 14,8, 24 CPUs, 256K PPD;
Mac Pro 5,1, 24 CPUs, 496K PPD;
Mac Studio 13,1, 10 CPUs, 146K PPD;
iMac Pro 1,1, 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD;
iMac 14,1, 4 CPUs, 40K PPD;
Mac Book Pro 17,1, 8 CPUs, 166K PPD;
Mac Book Pro 13,3, 8 CPUs, 57K PPD;
Mac Book Air 5,2, 4 CPUs, 23K PPD;
Mac Mini 7,1, 4 CPUs, 9K PPD;
HP Pavilion, 12 CPUs, 105K PPD;
SONY VAIO, 8 CPUs, 44K PPD. - Location: Oak Harbor, WA
Use Activity Monitor to check CPU usage - keep this app visible on Desktop to see Audio app usage vs FahCore_a7 CPU usage.
Mac Pro 14,8, 24 CPUs, 226K PPD;
iMac Pro 1,1. 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD; + 7 more CPUs
Thanks PantherX-- I tried pausing and it indeed works perfectly. Activity Monitor showed the CPU usage dropped down to insignificant. I'm going to set up my audio computers.
