GPU is stuck on "Ready" with 10 attempts for a WU
hormelspam552
Post by hormelspam552 »
Hey there. I just installed F@H today, so sorry if this question is obvious or has already been answered.
My CPU is getting WUs and is running wonderfully, but my GPU is still idle with no WU assigned to it. Is this normal?
I attached the logs below.
*********************** Log Started 2020-04-12T19:54:06Z ***********************
19:54:06:************************* Folding@home Client *************************
19:54:06:        Website: https://foldingathome.org/
19:54:06:      Copyright: (c) 2009-2018 foldingathome.org
19:54:06:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:54:06:           Args: --open-web-control
19:54:06:         Config: <none>
19:54:06:******************************** Build ********************************
19:54:06:        Version: 7.5.1
19:54:06:           Date: May 11 2018
19:54:06:           Time: 13:06:32
19:54:06:     Repository: Git
19:54:06:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
19:54:06:         Branch: master
19:54:06:       Compiler: Visual C++ 2008
19:54:06:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:54:06:       Platform: win32 10
19:54:06:           Bits: 32
19:54:06:           Mode: Release
19:54:06:******************************* System ********************************
19:54:06:            CPU: Intel(R) Xeon(R) W-2145 CPU @ 3.70GHz
19:54:06:         CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
19:54:06:           CPUs: 16
19:54:06:         Memory: 31.72GiB
19:54:06:    Free Memory: 8.96GiB
19:54:06:        Threads: WINDOWS_THREADS
19:54:06:     OS Version: 6.2
19:54:06:    Has Battery: false
19:54:06:     On Battery: false
19:54:06:     UTC Offset: -7
19:54:06:            PID: 278536
19:54:06:            CWD: C:\Users\Administrator\AppData\Roaming\FAHClient
19:54:06:             OS: Windows 10 Enterprise
19:54:06:        OS Arch: AMD64
19:54:06:           GPUs: 0
19:54:06:  CUDA Device 0: Platform:0 Device:0 Bus:33 Slot:0 Compute:7.5 Driver:10.2
19:54:06:OpenCL Device 0: Platform:0 Device:0 Bus:33 Slot:0 Compute:1.2 Driver:441.41
19:54:06:  Win32 Service: false
19:54:06:***********************************************************************
19:54:06:<config>
19:54:06:  <!-- Folding Slots -->
19:54:06:</config>
19:54:06:Connecting to assign1.foldingathome.org:8080
19:54:06:Updated GPUs.txt
19:54:06:Read GPUs.txt
19:54:06:Trying to access database...
19:54:06:Successfully acquired database lock
19:54:06:Enabled folding slot 00: PAUSED cpu:14 (not configured)
19:54:06:Enabled folding slot 01: PAUSED gpu:0:TU106 [GeForce RTX 2070 Rev. A] M 7465 (not configured)
19:54:08:10:127.0.0.1:New Web connection
19:55:07:Saving configuration to config.xml
19:55:07:<config>
19:55:07:  <!-- Folding Slots -->
19:55:07:  <slot id='0' type='CPU'/>
19:55:07:  <slot id='1' type='GPU'/>
19:55:07:</config>
19:55:07:Set client configured
19:55:07:WU00:FS00:Connecting to 65.254.110.245:8080
19:55:07:WU01:FS01:Connecting to 65.254.110.245:8080
19:55:08:WU01:FS01:Connecting to 65.254.110.245:8080
19:55:08:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:55:08:WU00:FS00:Connecting to 18.218.241.186:80
19:55:08:WU01:FS01:Assigned to work server 128.252.203.10
19:55:08:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU106 [GeForce RTX 2070 Rev. A] M 7465 from 128.252.203.10
19:55:08:WU01:FS01:Connecting to 128.252.203.10:8080
19:55:08:WU00:FS00:Assigned to work server 13.90.152.57
19:55:08:WU00:FS00:Requesting new work unit for slot 00: READY cpu:14 from 13.90.152.57
19:55:08:WU00:FS00:Connecting to 13.90.152.57:8080
19:55:08:WU00:FS00:Downloading 4.19MiB
19:55:14:WU00:FS00:Download 99.91%
19:55:14:WU00:FS00:Download complete
19:55:14:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13861 run:0 clone:19465 gen:43 core:0xa7 unit:0x0000002f0d5a98395e730ad95afcaa20
19:55:14:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
19:55:14:WU00:FS00:Connecting to cores.foldingathome.org:80
19:55:14:WU00:FS00:FahCore a7: Downloading 6.71MiB
19:55:20:WU00:FS00:FahCore a7: 47.49%
19:55:24:WU00:FS00:FahCore a7: Download complete
19:55:24:WU00:FS00:Valid core signature
19:55:24:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
19:55:25:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
19:55:25:WU00:FS00:Starting
19:55:25:WU00:FS00:Running FahCore: "M:\Folding At Home/FAHCoreWrapper.exe" C:\Users\Administrator\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 278536 -checkpoint 15 -np 14
19:55:26:WU00:FS00:Started FahCore on PID 292032
19:55:26:WU00:FS00:Core PID:288300
19:55:26:WU00:FS00:FahCore 0xa7 started
19:55:27:WU00:FS00:0xa7:*********************** Log Started 2020-04-12T19:55:27Z ***********************
19:55:27:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:55:27:WU00:FS00:0xa7:       Type: 0xa7
19:55:27:WU00:FS00:0xa7:       Core: Gromacs
19:55:27:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 292032 -checkpoint 15 -np
19:55:27:WU00:FS00:0xa7:             14
19:55:27:WU00:FS00:0xa7:************************************ CBang *************************************
19:55:27:WU00:FS00:0xa7:       Date: Oct 26 2019
19:55:27:WU00:FS00:0xa7:       Time: 01:38:25
19:55:27:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:55:27:WU00:FS00:0xa7:     Branch: master
19:55:27:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
19:55:27:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:55:27:WU00:FS00:0xa7:   Platform: win32 10
19:55:27:WU00:FS00:0xa7:       Bits: 64
19:55:27:WU00:FS00:0xa7:       Mode: Release
19:55:27:WU00:FS00:0xa7:************************************ System ************************************
19:55:27:WU00:FS00:0xa7:        CPU: Intel(R) Xeon(R) W-2145 CPU @ 3.70GHz
19:55:27:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
19:55:27:WU00:FS00:0xa7:       CPUs: 16
19:55:27:WU00:FS00:0xa7:     Memory: 31.72GiB
19:55:27:WU00:FS00:0xa7:Free Memory: 8.97GiB
19:55:27:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
19:55:27:WU00:FS00:0xa7: OS Version: 6.2
19:55:27:WU00:FS00:0xa7:Has Battery: false
19:55:27:WU00:FS00:0xa7: On Battery: false
19:55:27:WU00:FS00:0xa7: UTC Offset: -7
19:55:27:WU00:FS00:0xa7:        PID: 288300
19:55:27:WU00:FS00:0xa7:        CWD: C:\Users\Administrator\AppData\Roaming\FAHClient\work
19:55:27:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
19:55:27:WU00:FS00:0xa7:    Version: 0.0.18
19:55:27:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:55:27:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
19:55:27:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
19:55:27:WU00:FS00:0xa7:       Time: 01:52:30
19:55:27:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:55:27:WU00:FS00:0xa7:************************************ Build *************************************
19:55:27:WU00:FS00:0xa7:       SIMD: avx_256
19:55:27:WU00:FS00:0xa7:********************************************************************************
19:55:27:WU00:FS00:0xa7:Project: 13861 (Run 0, Clone 19465, Gen 43)
19:55:27:WU00:FS00:0xa7:Unit: 0x0000002f0d5a98395e730ad95afcaa20
19:55:27:WU00:FS00:0xa7:Reading tar file core.xml
19:55:27:WU00:FS00:0xa7:Reading tar file frame43.tpr
19:55:27:WU00:FS00:0xa7:Digital signatures verified
19:55:27:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
19:55:27:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
19:55:27:WU00:FS00:0xa7:Calling: mdrun -s frame43.tpr -o frame43.trr -x frame43.xtc -e frame43.edr -cpt 15 -nt 12
19:55:27:WU00:FS00:0xa7:Steps: first=5375000 total=125000
19:55:28:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
19:55:29:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:55:29:WU01:FS01:Connecting to 128.252.203.10:80
19:55:50:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:55:50:WU01:FS01:Connecting to 65.254.110.245:8080
19:55:50:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:55:50:WU01:FS01:Connecting to 18.218.241.186:80
19:55:51:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:55:51:ERROR:WU01:FS01:Exception: Could not get an assignment
19:55:52:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
19:56:16:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
19:56:41:WU00:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
19:56:50:WU01:FS01:Connecting to 65.254.110.245:8080
19:56:51:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:56:51:WU01:FS01:Connecting to 18.218.241.186:80
19:56:51:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:56:51:ERROR:WU01:FS01:Exception: Could not get an assignment
19:57:05:WU00:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
19:57:29:WU00:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
19:57:53:WU00:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
19:58:18:WU00:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
19:58:28:WU01:FS01:Connecting to 65.254.110.245:8080
19:58:28:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:58:28:WU01:FS01:Connecting to 18.218.241.186:80
19:58:29:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:58:29:ERROR:WU01:FS01:Exception: Could not get an assignment
19:58:43:WU00:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
19:59:07:WU00:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
19:59:32:WU00:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
19:59:57:WU00:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
20:00:21:WU00:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
20:00:46:WU00:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
20:00:51:FS00:Shutting core down
20:00:51:WU01:FS01:Connecting to 65.254.110.245:8080
20:00:51:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 288300
20:00:51:WU00:FS00:0xa7:Exiting, please wait. . .
20:00:51:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:00:51:WU01:FS01:Connecting to 18.218.241.186:80
20:00:51:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:00:51:ERROR:WU01:FS01:Exception: Could not get an assignment
20:00:52:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:00:52:WU00:FS00:Starting
20:00:52:WARNING:WU00:FS00:Changed SMP threads from 14 to 15 this can cause some work units to fail
20:00:52:WARNING:WU00:FS00:AS lowered CPUs from 15 to 14
20:00:52:WU00:FS00:Running FahCore: "M:\Folding At Home/FAHCoreWrapper.exe" C:\Users\Administrator\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 278536 -checkpoint 15 -np 14
20:00:52:WU00:FS00:Started FahCore on PID 287948
20:00:53:WU00:FS00:Core PID:283840
20:00:53:WU00:FS00:FahCore 0xa7 started
20:00:53:WU00:FS00:0xa7:*********************** Log Started 2020-04-12T20:00:53Z ***********************
20:00:53:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:00:53:WU00:FS00:0xa7:       Type: 0xa7
20:00:53:WU00:FS00:0xa7:       Core: Gromacs
20:00:53:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 287948 -checkpoint 15 -np
20:00:53:WU00:FS00:0xa7:             14
20:00:53:WU00:FS00:0xa7:************************************ CBang *************************************
20:00:53:WU00:FS00:0xa7:       Date: Oct 26 2019
20:00:53:WU00:FS00:0xa7:       Time: 01:38:25
20:00:53:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:00:53:WU00:FS00:0xa7:     Branch: master
20:00:53:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:00:53:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:00:53:WU00:FS00:0xa7:   Platform: win32 10
20:00:53:WU00:FS00:0xa7:       Bits: 64
20:00:53:WU00:FS00:0xa7:       Mode: Release
20:00:53:WU00:FS00:0xa7:************************************ System ************************************
20:00:53:WU00:FS00:0xa7:        CPU: Intel(R) Xeon(R) W-2145 CPU @ 3.70GHz
20:00:53:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
20:00:53:WU00:FS00:0xa7:       CPUs: 16
20:00:53:WU00:FS00:0xa7:     Memory: 31.72GiB
20:00:53:WU00:FS00:0xa7:Free Memory: 8.95GiB
20:00:53:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
20:00:53:WU00:FS00:0xa7: OS Version: 6.2
20:00:53:WU00:FS00:0xa7:Has Battery: false
20:00:53:WU00:FS00:0xa7: On Battery: false
20:00:53:WU00:FS00:0xa7: UTC Offset: -7
20:00:53:WU00:FS00:0xa7:        PID: 283840
20:00:53:WU00:FS00:0xa7:        CWD: C:\Users\Administrator\AppData\Roaming\FAHClient\work
20:00:53:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:00:53:WU00:FS00:0xa7:    Version: 0.0.18
20:00:53:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:00:53:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:00:53:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:00:53:WU00:FS00:0xa7:       Time: 01:52:30
20:00:53:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:00:53:WU00:FS00:0xa7:************************************ Build *************************************
20:00:53:WU00:FS00:0xa7:       SIMD: avx_256
20:00:53:WU00:FS00:0xa7:********************************************************************************
20:00:53:WU00:FS00:0xa7:Project: 13861 (Run 0, Clone 19465, Gen 43)
20:00:53:WU00:FS00:0xa7:Unit: 0x0000002f0d5a98395e730ad95afcaa20
20:00:53:WU00:FS00:0xa7:Digital signatures verified
20:00:53:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
20:00:53:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
20:00:53:WU00:FS00:0xa7:Calling: mdrun -s frame43.tpr -o frame43.trr -x frame43.xtc -e frame43.edr -cpi state.cpt -cpt 15 -nt 12
20:00:53:WU00:FS00:0xa7:Steps: first=5375000 total=125000
20:00:55:WU00:FS00:0xa7:Completed 16502 out of 125000 steps (13%)
20:01:13:Saving configuration to config.xml
20:01:13:<config>
20:01:13:  <!-- Slot Control -->
20:01:13:  <power v='FULL'/>
20:01:13:
20:01:13:  <!-- User Information -->
20:01:13:  <passkey v='********************************'/>
20:01:13:  <team v='260844'/>
20:01:13:  <user v='Andrew123Shi'/>
20:01:13:
20:01:13:  <!-- Folding Slots -->
20:01:13:  <slot id='0' type='CPU'/>
20:01:13:  <slot id='1' type='GPU'/>
20:01:13:</config>
20:01:15:WU00:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
20:01:40:WU00:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
20:02:05:WU00:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
20:02:28:WU01:FS01:Connecting to 65.254.110.245:8080
20:02:28:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:02:28:WU01:FS01:Connecting to 18.218.241.186:80
20:02:29:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:02:29:ERROR:WU01:FS01:Exception: Could not get an assignment
20:02:29:WU00:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
20:02:53:WU00:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
20:03:17:WU00:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
20:03:40:WU00:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
20:04:05:WU00:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
20:04:29:WU00:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
20:04:53:WU00:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
20:05:05:WU01:FS01:Connecting to 65.254.110.245:8080
20:05:05:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:05:05:WU01:FS01:Connecting to 18.218.241.186:80
20:05:06:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:05:06:ERROR:WU01:FS01:Exception: Could not get an assignment
20:05:17:WU00:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
20:05:42:WU00:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
20:06:06:WU00:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
20:06:30:WU00:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
20:06:54:WU00:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
20:07:18:WU00:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
20:07:42:WU00:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
20:08:06:WU00:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
20:08:30:WU00:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
20:08:55:WU00:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
20:09:19:WU00:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
20:09:19:WU01:FS01:Connecting to 65.254.110.245:8080
20:09:20:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:09:20:WU01:FS01:Connecting to 18.218.241.186:80
20:09:20:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:09:20:ERROR:WU01:FS01:Exception: Could not get an assignment
20:09:43:WU00:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
20:10:07:WU00:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
20:10:35:WU00:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
20:11:00:WU00:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
20:11:25:WU00:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
20:11:49:WU00:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
20:12:13:WU00:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
20:12:38:WU00:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
20:13:02:WU00:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
20:13:26:WU00:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
20:13:50:WU00:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
20:14:14:WU00:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
20:14:38:WU00:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
20:15:03:WU00:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
20:15:28:WU00:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
20:15:52:WU00:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
20:16:11:WU01:FS01:Connecting to 65.254.110.245:8080
20:16:11:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:16:11:WU01:FS01:Connecting to 18.218.241.186:80
20:16:12:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:16:12:ERROR:WU01:FS01:Exception: Could not get an assignment
20:16:18:WU00:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
20:16:42:WU00:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
20:17:06:WU00:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
20:17:31:WU00:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
20:17:55:WU00:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
20:18:19:WU00:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
20:18:43:WU00:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
20:19:07:WU00:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
20:19:32:WU00:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
20:19:56:WU00:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
20:20:20:WU00:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
20:20:45:WU00:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
20:21:09:WU00:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
20:21:33:WU00:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
20:21:57:WU00:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
20:22:22:WU00:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
20:22:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:22:46:WU00:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
20:22:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:23:10:WU00:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
20:23:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:23:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:23:34:WU00:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
20:23:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:23:59:WU00:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
20:24:23:WU00:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
20:24:46:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
20:24:48:WU00:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
20:25:13:WU00:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
20:25:15:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
20:25:33:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
20:25:38:WU00:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
20:26:03:WU00:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
20:26:29:WU00:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
20:26:54:WU00:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
20:27:16:WU01:FS01:Connecting to 65.254.110.245:8080
20:27:17:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:27:17:WU01:FS01:Connecting to 18.218.241.186:80
20:27:17:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:27:17:ERROR:WU01:FS01:Exception: Could not get an assignment
20:27:19:WU00:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
20:27:43:WU00:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
20:28:08:WU00:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
20:28:32:WU00:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
20:28:56:WU00:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
20:29:20:WU00:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
20:29:44:WU00:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
20:30:08:WU00:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
20:30:32:WU00:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
20:30:57:WU00:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
20:31:22:WU00:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
20:31:46:WU00:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
20:32:10:WU00:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
20:32:35:WU00:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
20:33:00:WU00:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
20:33:24:WU00:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
20:33:48:WU00:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
20:34:12:WU00:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
20:34:36:WU00:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
20:35:01:WU00:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
20:35:25:WU00:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
20:35:37:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:35:50:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
20:35:50:WU02:FS00:Connecting to 65.254.110.245:8080
20:35:50:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:35:50:WU02:FS00:Connecting to 18.218.241.186:80
20:35:51:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:35:51:ERROR:WU02:FS00:Exception: Could not get an assignment
20:35:51:WU02:FS00:Connecting to 65.254.110.245:8080
20:35:51:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:35:51:WU02:FS00:Connecting to 18.218.241.186:80
20:36:14:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
20:36:15:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
20:36:15:WU00:FS00:0xa7:Saving result file frame43.edr
20:36:15:WU00:FS00:0xa7:Saving result file frame43.trr
20:36:15:WU00:FS00:0xa7:Saving result file frame43.xtc
20:36:15:WU00:FS00:0xa7:Saving result file md.log
20:36:15:WU00:FS00:0xa7:Saving result file science.log
20:36:15:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
20:36:16:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:36:16:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13861 run:0 clone:19465 gen:43 core:0xa7 unit:0x0000002f0d5a98395e730ad95afcaa20
20:36:16:WU00:FS00:Uploading 5.27MiB to 13.90.152.57
20:36:16:WU00:FS00:Connecting to 13.90.152.57:8080
20:36:22:WU00:FS00:Upload 58.11%
20:36:25:WU00:FS00:Upload complete
20:36:25:WU00:FS00:Server responded WORK_ACK (400)
20:36:25:WU00:FS00:Final credit estimate, 3289.00 points
20:36:25:WU00:FS00:Cleaning up
20:36:51:WU02:FS00:Connecting to 65.254.110.245:8080
20:36:51:WU02:FS00:Assigned to work server 168.245.198.125
20:36:51:WU02:FS00:Requesting new work unit for slot 00: READY cpu:15 from 168.245.198.125
20:36:51:WU02:FS00:Connecting to 168.245.198.125:8080
20:36:52:WU02:FS00:Downloading 2.85MiB
20:36:52:WU02:FS00:Download complete
20:36:53:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16411 run:3105 clone:2 gen:23 core:0xa7 unit:0x00000019a8f5c67d5e8772612936942e
20:36:53:WU02:FS00:Starting
20:36:53:WARNING:WU02:FS00:AS lowered CPUs from 15 to 14
20:36:53:WU02:FS00:Running FahCore: "M:\Folding At Home/FAHCoreWrapper.exe" C:\Users\Administrator\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 278536 -checkpoint 15 -np 14
20:36:53:WU02:FS00:Started FahCore on PID 290508
20:36:53:WU02:FS00:Core PID:292464
20:36:53:WU02:FS00:FahCore 0xa7 started
20:36:54:WU02:FS00:0xa7:*********************** Log Started 2020-04-12T20:36:53Z ***********************
20:36:54:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:36:54:WU02:FS00:0xa7:       Type: 0xa7
20:36:54:WU02:FS00:0xa7:       Core: Gromacs
20:36:54:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 290508 -checkpoint 15 -np
20:36:54:WU02:FS00:0xa7:             14
20:36:54:WU02:FS00:0xa7:************************************ CBang *************************************
20:36:54:WU02:FS00:0xa7:       Date: Oct 26 2019
20:36:54:WU02:FS00:0xa7:       Time: 01:38:25
20:36:54:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:36:54:WU02:FS00:0xa7:     Branch: master
20:36:54:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
20:36:54:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:36:54:WU02:FS00:0xa7:   Platform: win32 10
20:36:54:WU02:FS00:0xa7:       Bits: 64
20:36:54:WU02:FS00:0xa7:       Mode: Release
20:36:54:WU02:FS00:0xa7:************************************ System ************************************
20:36:54:WU02:FS00:0xa7:        CPU: Intel(R) Xeon(R) W-2145 CPU @ 3.70GHz
20:36:54:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
20:36:54:WU02:FS00:0xa7:       CPUs: 16
20:36:54:WU02:FS00:0xa7:     Memory: 31.72GiB
20:36:54:WU02:FS00:0xa7:Free Memory: 10.86GiB
20:36:54:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
20:36:54:WU02:FS00:0xa7: OS Version: 6.2
20:36:54:WU02:FS00:0xa7:Has Battery: false
20:36:54:WU02:FS00:0xa7: On Battery: false
20:36:54:WU02:FS00:0xa7: UTC Offset: -7
20:36:54:WU02:FS00:0xa7:        PID: 292464
20:36:54:WU02:FS00:0xa7:        CWD: C:\Users\Administrator\AppData\Roaming\FAHClient\work
20:36:54:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
20:36:54:WU02:FS00:0xa7:    Version: 0.0.18
20:36:54:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:36:54:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:36:54:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
20:36:54:WU02:FS00:0xa7:       Time: 01:52:30
20:36:54:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:36:54:WU02:FS00:0xa7:************************************ Build *************************************
20:36:54:WU02:FS00:0xa7:       SIMD: avx_256
20:36:54:WU02:FS00:0xa7:********************************************************************************
20:36:54:WU02:FS00:0xa7:Project: 16411 (Run 3105, Clone 2, Gen 23)
20:36:54:WU02:FS00:0xa7:Unit: 0x00000019a8f5c67d5e8772612936942e
20:36:54:WU02:FS00:0xa7:Reading tar file core.xml
20:36:54:WU02:FS00:0xa7:Reading tar file frame23.tpr
20:36:54:WU02:FS00:0xa7:Digital signatures verified
20:36:54:WU02:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
20:36:54:WU02:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
20:36:54:WU02:FS00:0xa7:Calling: mdrun -s frame23.tpr -o frame23.trr -x frame23.xtc -cpt 15 -nt 12
20:36:54:WU02:FS00:0xa7:Steps: first=5750000 total=250000
20:36:54:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
20:37:33:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
20:38:12:WU02:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
20:38:52:WU02:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
20:39:32:WU02:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
20:40:12:WU02:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
20:40:51:WU02:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
20:41:31:WU02:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
20:42:10:WU02:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
20:42:50:WU02:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
20:43:29:WU02:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
20:44:08:WU02:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
20:44:47:WU02:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
20:45:13:WU01:FS01:Connecting to 65.254.110.245:8080
20:45:13:WU01:FS01:Assigned to work server 52.224.109.74
20:45:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU106 [GeForce RTX 2070 Rev. A] M 7465 from 52.224.109.74
20:45:13:WU01:FS01:Connecting to 52.224.109.74:8080
20:45:16:ERROR:WU01:FS01:Exception: Server did not assign work unit
20:45:28:WU02:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
HaloJones
Re: GPU is stuck on "Ready" with 10 attempts for a WU
Post by HaloJones »
there's a little shortage right now. I've had gpus stuck at various times today and after a while they've all picked up units eventually. Nothing you can do although rebooting sometimes speeds up the process.
single 1070
Welcome to the F@H Forum hormelspam552,
You can also reset the timer by pausing/unpausing the GPU Slot. However, we recommend that you do that if the next attempt is in few hours.
