GPU stays "Ready"
vaterfa
GPU stays "Ready"
Post by vaterfa »
Hi firstly. I have 2 machines. One is new and its working perfectly. The other one is kind of old but i want to fold from it also anyway but i have a problem with my old device. Cpu working fine but gpu stays "ready" state. Currently using new installed W10 pro and fully updated, gpu drivers also updated. Here is the my log, thank you!
*********************** Log Started 2020-04-12T17:03:36Z ***********************
17:03:36:************************* Folding@home Client *************************
17:03:36:        Website: https://foldingathome.org/
17:03:36:      Copyright: (c) 2009-2018 foldingathome.org
17:03:36:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:03:36:           Args:
17:03:36:         Config: C:\Users\G45\AppData\Roaming\FAHClient\config.xml
17:03:36:******************************** Build ********************************
17:03:36:        Version: 7.5.1
17:03:36:           Date: May 11 2018
17:03:36:           Time: 13:06:32
17:03:36:     Repository: Git
17:03:36:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
17:03:36:         Branch: master
17:03:36:       Compiler: Visual C++ 2008
17:03:36:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:03:36:       Platform: win32 10
17:03:36:           Bits: 32
17:03:36:           Mode: Release
17:03:36:******************************* System ********************************
17:03:36:            CPU: Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz
17:03:36:         CPU ID: GenuineIntel Family 6 Model 15 Stepping 13
17:03:36:           CPUs: 2
17:03:36:         Memory: 3.00GiB
17:03:36:    Free Memory: 1.69GiB
17:03:36:        Threads: WINDOWS_THREADS
17:03:36:     OS Version: 6.2
17:03:36:    Has Battery: false
17:03:36:     On Battery: false
17:03:36:     UTC Offset: 3
17:03:36:            PID: 4268
17:03:36:            CWD: C:\Users\G45\AppData\Roaming\FAHClient
17:03:36:             OS: Windows 10 Enterprise
17:03:36:        OS Arch: AMD64
17:03:36:           GPUs: 1
17:03:36:          GPU 0: Bus:4 Slot:0 Func:0 AMD:4 ManhattanP [Radeon HD
17:03:36:                 5400/6200/7300/8300]
17:03:36:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
17:03:36:                 Belirtilen modül bulunamadı.
17:03:36:
17:03:36:OpenCL Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:1.2 Driver:1800.8
17:03:36:  Win32 Service: false
17:03:36:***********************************************************************
17:03:36:<config>
17:03:36:  <!-- Network -->
17:03:36:  <proxy v=':8080'/>
17:03:36:
17:03:36:  <!-- Slot Control -->
17:03:36:  <power v='FULL'/>
17:03:36:
17:03:36:  <!-- User Information -->
17:03:36:  <passkey v='********************************'/>
17:03:36:  <user v='vaterfa'/>
17:03:36:
17:03:36:  <!-- Folding Slots -->
17:03:36:  <slot id='0' type='CPU'/>
17:03:36:  <slot id='1' type='GPU'/>
17:03:36:</config>
17:03:36:Trying to access database...
17:03:36:Successfully acquired database lock
17:03:36:Enabled folding slot 00: READY cpu:1
17:03:36:Enabled folding slot 01: READY gpu:0:ManhattanP [Radeon HD 5400/6200/7300/8300]
17:03:36:WU00:FS00:Starting
17:03:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\G45\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4268 -checkpoint 15 -np 1
17:03:37:WU00:FS00:Started FahCore on PID 4724
17:03:40:WU00:FS00:Core PID:4068
17:03:40:WU00:FS00:FahCore 0xa7 started
17:03:41:WU01:FS01:Connecting to 65.254.110.245:8080
17:03:42:WU00:FS00:0xa7:*********************** Log Started 2020-04-12T17:03:42Z ***********************
17:03:42:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:03:42:WU00:FS00:0xa7:       Type: 0xa7
17:03:42:WU00:FS00:0xa7:       Core: Gromacs
17:03:42:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 4724 -checkpoint 15 -np 1
17:03:42:WU00:FS00:0xa7:************************************ CBang *************************************
17:03:42:WU00:FS00:0xa7:       Date: Oct 26 2019
17:03:42:WU00:FS00:0xa7:       Time: 01:38:35
17:03:42:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:03:42:WU00:FS00:0xa7:     Branch: master
17:03:42:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:03:42:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:03:42:WU00:FS00:0xa7:   Platform: win32 10
17:03:42:WU00:FS00:0xa7:       Bits: 64
17:03:42:WU00:FS00:0xa7:       Mode: Release
17:03:42:WU00:FS00:0xa7:************************************ System ************************************
17:03:42:WU00:FS00:0xa7:        CPU: Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz
17:03:42:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 13
17:03:42:WU00:FS00:0xa7:       CPUs: 2
17:03:42:WU00:FS00:0xa7:     Memory: 3.00GiB
17:03:42:WU00:FS00:0xa7:Free Memory: 1.67GiB
17:03:42:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
17:03:42:WU00:FS00:0xa7: OS Version: 6.2
17:03:42:WU00:FS00:0xa7:Has Battery: false
17:03:42:WU00:FS00:0xa7: On Battery: false
17:03:42:WU00:FS00:0xa7: UTC Offset: 3
17:03:42:WU00:FS00:0xa7:        PID: 4068
17:03:42:WU00:FS00:0xa7:        CWD: C:\Users\G45\AppData\Roaming\FAHClient\work
17:03:42:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:03:42:WU00:FS00:0xa7:    Version: 0.0.18
17:03:42:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:03:42:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:03:42:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:03:42:WU00:FS00:0xa7:       Time: 01:52:44
17:03:42:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:03:42:WU00:FS00:0xa7:************************************ Build *************************************
17:03:42:WU00:FS00:0xa7:       SIMD: sse2
17:03:42:WU00:FS00:0xa7:********************************************************************************
17:03:42:WU00:FS00:0xa7:Project: 14304 (Run 9, Clone 3, Gen 81)
17:03:42:WU00:FS00:0xa7:Unit: 0x0000005e9bf7a4d55e655f5227000dd5
17:03:42:WU00:FS00:0xa7:Digital signatures verified
17:03:42:WU00:FS00:0xa7:Calling: mdrun -s frame81.tpr -o frame81.trr -cpi state.cpt -cpt 15 -nt 1
17:03:42:WU00:FS00:0xa7:ERROR:Guru Meditation #64f63fdf1db40cef.1060e351da65c77b (593040.1186080) '00/01/frame81.trr'
17:03:42:WU00:FS00:0xa7:WARNING:Unexpected exit() call
17:03:43:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
17:03:43:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
17:03:43:WU00:FS00:0xa7:Saving result file frame81.trr
17:03:43:WU00:FS00:0xa7:ERROR:Guru Meditation #64f63fdf1db40cef.1060e351da65c77b (593040.1186080) '00/01/frame81.trr'
17:03:43:WU01:FS01:Assigned to work server 192.0.2.1
17:03:43:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:ManhattanP [Radeon HD 5400/6200/7300/8300] from 192.0.2.1
17:03:43:WU01:FS01:Connecting to 192.0.2.1:8080
17:03:49:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:03:49:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
17:03:49:WU00:FS00:Starting
17:03:49:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\G45\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4268 -checkpoint 15 -np 1
17:03:49:WU00:FS00:Started FahCore on PID 1268
17:03:49:WU00:FS00:Core PID:4936
17:03:49:WU00:FS00:FahCore 0xa7 started
17:03:50:WU00:FS00:0xa7:*********************** Log Started 2020-04-12T17:03:49Z ***********************
17:03:50:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:03:50:WU00:FS00:0xa7:       Type: 0xa7
17:03:50:WU00:FS00:0xa7:       Core: Gromacs
17:03:50:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 1268 -checkpoint 15 -np 1
17:03:50:WU00:FS00:0xa7:************************************ CBang *************************************
17:03:50:WU00:FS00:0xa7:       Date: Oct 26 2019
17:03:50:WU00:FS00:0xa7:       Time: 01:38:35
17:03:50:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:03:50:WU00:FS00:0xa7:     Branch: master
17:03:50:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:03:50:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:03:50:WU00:FS00:0xa7:   Platform: win32 10
17:03:50:WU00:FS00:0xa7:       Bits: 64
17:03:50:WU00:FS00:0xa7:       Mode: Release
17:03:50:WU00:FS00:0xa7:************************************ System ************************************
17:03:50:WU00:FS00:0xa7:        CPU: Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz
17:03:50:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 13
17:03:50:WU00:FS00:0xa7:       CPUs: 2
17:03:50:WU00:FS00:0xa7:     Memory: 3.00GiB
17:03:50:WU00:FS00:0xa7:Free Memory: 1.64GiB
17:03:50:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
17:03:50:WU00:FS00:0xa7: OS Version: 6.2
17:03:50:WU00:FS00:0xa7:Has Battery: false
17:03:50:WU00:FS00:0xa7: On Battery: false
17:03:50:WU00:FS00:0xa7: UTC Offset: 3
17:03:50:WU00:FS00:0xa7:        PID: 4936
17:03:50:WU00:FS00:0xa7:        CWD: C:\Users\G45\AppData\Roaming\FAHClient\work
17:03:50:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:03:50:WU00:FS00:0xa7:    Version: 0.0.18
17:03:50:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:03:50:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:03:50:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:03:50:WU00:FS00:0xa7:       Time: 01:52:44
17:03:50:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:03:50:WU00:FS00:0xa7:************************************ Build *************************************
17:03:50:WU00:FS00:0xa7:       SIMD: sse2
17:03:50:WU00:FS00:0xa7:********************************************************************************
17:03:50:WU00:FS00:0xa7:Project: 14304 (Run 9, Clone 3, Gen 81)
17:03:50:WU00:FS00:0xa7:Unit: 0x0000005e9bf7a4d55e655f5227000dd5
17:03:50:WU00:FS00:0xa7:Digital signatures verified
17:03:50:WU00:FS00:0xa7:Calling: mdrun -s frame81.tpr -o frame81.trr -cpi state.cpt -cpt 15 -nt 1
17:03:50:WU00:FS00:0xa7:ERROR:Guru Meditation #64f63fdf1db40cef.1060e351da65c77b (593040.1186080) '00/01/frame81.trr'
17:03:50:WU00:FS00:0xa7:WARNING:Unexpected exit() call
17:03:50:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
17:03:50:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
17:03:50:WU00:FS00:0xa7:Saving result file frame81.trr
17:03:53:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:03:53:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
17:04:04:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:04:04:WU01:FS01:Connecting to 192.0.2.1:80
17:04:25:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Bağlanılan uygun olarak belli bir süre içinde yanıt vermediğinden veya kurulan
17:04:25:ERROR:WU01:FS01:bağlantı bağlanılan ana bilgisayar yanıt vermediğinden bir bağlantı kurulamadı.
17:04:25:WU01:FS01:Connecting to 65.254.110.245:8080
17:04:26:WU01:FS01:Assigned to work server 192.0.2.1
17:04:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:ManhattanP [Radeon HD 5400/6200/7300/8300] from 192.0.2.1
17:04:26:WU01:FS01:Connecting to 192.0.2.1:8080
17:04:47:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:04:47:WU01:FS01:Connecting to 192.0.2.1:80
17:04:49:WU00:FS00:Starting
17:04:49:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\G45\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4268 -checkpoint 15 -np 1
17:04:49:WU00:FS00:Started FahCore on PID 844
17:04:50:WU00:FS00:Core PID:1268
17:04:50:WU00:FS00:FahCore 0xa7 started
17:04:50:WU00:FS00:0xa7:*********************** Log Started 2020-04-12T17:04:50Z ***********************
17:04:50:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:04:50:WU00:FS00:0xa7:       Type: 0xa7
17:04:50:WU00:FS00:0xa7:       Core: Gromacs
17:04:50:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 844 -checkpoint 15 -np 1
17:04:50:WU00:FS00:0xa7:************************************ CBang *************************************
17:04:50:WU00:FS00:0xa7:       Date: Oct 26 2019
17:04:50:WU00:FS00:0xa7:       Time: 01:38:35
17:04:50:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:04:50:WU00:FS00:0xa7:     Branch: master
17:04:50:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:04:50:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:04:50:WU00:FS00:0xa7:   Platform: win32 10
17:04:50:WU00:FS00:0xa7:       Bits: 64
17:04:50:WU00:FS00:0xa7:       Mode: Release
17:04:50:WU00:FS00:0xa7:************************************ System ************************************
17:04:50:WU00:FS00:0xa7:        CPU: Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz
17:04:50:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 13
17:04:50:WU00:FS00:0xa7:       CPUs: 2
17:04:50:WU00:FS00:0xa7:     Memory: 3.00GiB
17:04:50:WU00:FS00:0xa7:Free Memory: 1.63GiB
17:04:50:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
17:04:50:WU00:FS00:0xa7: OS Version: 6.2
17:04:50:WU00:FS00:0xa7:Has Battery: false
17:04:50:WU00:FS00:0xa7: On Battery: false
17:04:50:WU00:FS00:0xa7: UTC Offset: 3
17:04:50:WU00:FS00:0xa7:        PID: 1268
17:04:50:WU00:FS00:0xa7:        CWD: C:\Users\G45\AppData\Roaming\FAHClient\work
17:04:50:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:04:50:WU00:FS00:0xa7:    Version: 0.0.18
17:04:50:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:04:50:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:04:50:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:04:50:WU00:FS00:0xa7:       Time: 01:52:44
17:04:50:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:04:50:WU00:FS00:0xa7:************************************ Build *************************************
17:04:50:WU00:FS00:0xa7:       SIMD: sse2
17:04:50:WU00:FS00:0xa7:********************************************************************************
17:04:50:WU00:FS00:0xa7:Project: 14304 (Run 9, Clone 3, Gen 81)
17:04:50:WU00:FS00:0xa7:Unit: 0x0000005e9bf7a4d55e655f5227000dd5
17:04:50:WU00:FS00:0xa7:Digital signatures verified
17:04:50:WU00:FS00:0xa7:Calling: mdrun -s frame81.tpr -o frame81.trr -cpi state.cpt -cpt 15 -nt 1
17:04:50:WU00:FS00:0xa7:ERROR:Guru Meditation #64f63fdf1db40cef.1060e351da65c77b (593040.1186080) '00/01/frame81.trr'
17:04:50:WU00:FS00:0xa7:WARNING:Unexpected exit() call
17:04:50:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
17:04:50:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
17:04:50:WU00:FS00:0xa7:Saving result file frame81.trr
17:04:52:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:04:52:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
17:04:52:WARNING:WU00:FS00:Too many errors, failing
17:04:52:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:14304 run:9 clone:3 gen:81 core:0xa7 unit:0x0000005e9bf7a4d55e655f5227000dd5
17:04:52:WU00:FS00:Connecting to 155.247.164.213:8080
17:04:53:WU02:FS00:Connecting to 65.254.110.245:8080
17:04:53:WU00:FS00:Server responded WORK_ACK (400)
17:04:53:WU00:FS00:Cleaning up
17:04:54:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:04:54:WU02:FS00:Connecting to 18.218.241.186:80
17:04:54:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:04:54:ERROR:WU02:FS00:Exception: Could not get an assignment
17:04:55:WU02:FS00:Connecting to 65.254.110.245:8080
17:04:55:WU02:FS00:Assigned to work server 150.136.14.110
17:04:55:WU02:FS00:Requesting new work unit for slot 00: READY cpu:1 from 150.136.14.110
17:04:55:WU02:FS00:Connecting to 150.136.14.110:8080
17:04:56:WU02:FS00:Downloading 3.11MiB
17:04:58:WU02:FS00:Download complete
17:04:58:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16422 run:1202 clone:2 gen:20 core:0xa7 unit:0x0000001696880e6e5e8be01933a980ef
17:04:58:WU02:FS00:Starting
17:04:58:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\G45\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 4268 -checkpoint 15 -np 1
17:04:58:WU02:FS00:Started FahCore on PID 948
17:04:58:WU02:FS00:Core PID:3432
17:04:58:WU02:FS00:FahCore 0xa7 started
17:04:59:WU02:FS00:0xa7:*********************** Log Started 2020-04-12T17:04:59Z ***********************
17:04:59:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:04:59:WU02:FS00:0xa7:       Type: 0xa7
17:04:59:WU02:FS00:0xa7:       Core: Gromacs
17:04:59:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 948 -checkpoint 15 -np 1
17:04:59:WU02:FS00:0xa7:************************************ CBang *************************************
17:04:59:WU02:FS00:0xa7:       Date: Oct 26 2019
17:04:59:WU02:FS00:0xa7:       Time: 01:38:35
17:04:59:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:04:59:WU02:FS00:0xa7:     Branch: master
17:04:59:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
17:04:59:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:04:59:WU02:FS00:0xa7:   Platform: win32 10
17:04:59:WU02:FS00:0xa7:       Bits: 64
17:04:59:WU02:FS00:0xa7:       Mode: Release
17:04:59:WU02:FS00:0xa7:************************************ System ************************************
17:04:59:WU02:FS00:0xa7:        CPU: Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz
17:04:59:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 13
17:04:59:WU02:FS00:0xa7:       CPUs: 2
17:04:59:WU02:FS00:0xa7:     Memory: 3.00GiB
17:04:59:WU02:FS00:0xa7:Free Memory: 1.62GiB
17:04:59:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
17:04:59:WU02:FS00:0xa7: OS Version: 6.2
17:04:59:WU02:FS00:0xa7:Has Battery: false
17:04:59:WU02:FS00:0xa7: On Battery: false
17:04:59:WU02:FS00:0xa7: UTC Offset: 3
17:04:59:WU02:FS00:0xa7:        PID: 3432
17:04:59:WU02:FS00:0xa7:        CWD: C:\Users\G45\AppData\Roaming\FAHClient\work
17:04:59:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
17:04:59:WU02:FS00:0xa7:    Version: 0.0.18
17:04:59:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:04:59:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:04:59:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
17:04:59:WU02:FS00:0xa7:       Time: 01:52:44
17:04:59:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:04:59:WU02:FS00:0xa7:************************************ Build *************************************
17:04:59:WU02:FS00:0xa7:       SIMD: sse2
17:04:59:WU02:FS00:0xa7:********************************************************************************
17:04:59:WU02:FS00:0xa7:Project: 16422 (Run 1202, Clone 2, Gen 20)
17:04:59:WU02:FS00:0xa7:Unit: 0x0000001696880e6e5e8be01933a980ef
17:04:59:WU02:FS00:0xa7:Reading tar file core.xml
17:04:59:WU02:FS00:0xa7:Reading tar file frame20.tpr
17:04:59:WU02:FS00:0xa7:Digital signatures verified
17:04:59:WU02:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpt 15 -nt 1
17:05:00:WU02:FS00:0xa7:Steps: first=5000000 total=250000
17:05:02:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
17:05:08:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Bağlanılan uygun olarak belli bir süre içinde yanıt vermediğinden veya kurulan
17:05:08:ERROR:WU01:FS01:bağlantı bağlanılan ana bilgisayar yanıt vermediğinden bir bağlantı kurulamadı.
17:05:25:WU01:FS01:Connecting to 65.254.110.245:8080
17:05:26:WU01:FS01:Assigned to work server 192.0.2.1
17:05:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:ManhattanP [Radeon HD 5400/6200/7300/8300] from 192.0.2.1
17:05:26:WU01:FS01:Connecting to 192.0.2.1:8080
17:05:47:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:05:47:WU01:FS01:Connecting to 192.0.2.1:80
17:06:09:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Bağlanılan uygun olarak belli bir süre içinde yanıt vermediğinden veya kurulan
17:06:09:ERROR:WU01:FS01:bağlantı bağlanılan ana bilgisayar yanıt vermediğinden bir bağlantı kurulamadı.
17:07:03:WU01:FS01:Connecting to 65.254.110.245:8080
17:07:03:WU01:FS01:Assigned to work server 192.0.2.1
17:07:03:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:ManhattanP [Radeon HD 5400/6200/7300/8300] from 192.0.2.1
17:07:03:WU01:FS01:Connecting to 192.0.2.1:8080
17:07:24:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:07:24:WU01:FS01:Connecting to 192.0.2.1:80
17:07:46:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Bağlanılan uygun olarak belli bir süre içinde yanıt vermediğinden veya kurulan
17:07:46:ERROR:WU01:FS01:bağlantı bağlanılan ana bilgisayar yanıt vermediğinden bir bağlantı kurulamadı.
17:09:40:WU01:FS01:Connecting to 65.254.110.245:8080
17:09:40:WU01:FS01:Assigned to work server 192.0.2.1
17:09:41:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:ManhattanP [Radeon HD 5400/6200/7300/8300] from 192.0.2.1
17:09:41:WU01:FS01:Connecting to 192.0.2.1:8080
17:10:02:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:10:02:WU01:FS01:Connecting to 192.0.2.1:80
17:10:23:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Bağlanılan uygun olarak belli bir süre içinde yanıt vermediğinden veya kurulan
17:10:23:ERROR:WU01:FS01:bağlantı bağlanılan ana bilgisayar yanıt vermediğinden bir bağlantı kurulamadı.
17:13:54:WU01:FS01:Connecting to 65.254.110.245:8080
17:13:55:WU01:FS01:Assigned to work server 192.0.2.1
17:13:55:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:ManhattanP [Radeon HD 5400/6200/7300/8300] from 192.0.2.1
17:13:55:WU01:FS01:Connecting to 192.0.2.1:8080
17:14:16:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:14:16:WU01:FS01:Connecting to 192.0.2.1:80
17:14:37:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Bağlanılan uygun olarak belli bir süre içinde yanıt vermediğinden veya kurulan
17:14:37:ERROR:WU01:FS01:bağlantı bağlanılan ana bilgisayar yanıt vermediğinden bir bağlantı kurulamadı.
17:20:45:WU01:FS01:Connecting to 65.254.110.245:8080
17:20:46:WU01:FS01:Assigned to work server 192.0.2.1
17:20:46:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:ManhattanP [Radeon HD 5400/6200/7300/8300] from 192.0.2.1
17:20:46:WU01:FS01:Connecting to 192.0.2.1:8080
17:21:07:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:21:07:WU01:FS01:Connecting to 192.0.2.1:80
17:21:28:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Bağlanılan uygun olarak belli bir süre içinde yanıt vermediğinden veya kurulan
17:21:28:ERROR:WU01:FS01:bağlantı bağlanılan ana bilgisayar yanıt vermediğinden bir bağlantı kurulamadı.
Re: GPU stays "Ready"
Post by foldy »
CPU also has issues:
Guess it is too old for FAH
In the Radeon HD 5000 series only the 5800 cards are currently usable for GPU folding. So the one shown in the log will not get an assignment now. The projects that could use it finished last year, the list needs updating to remove some of the formerly usable cards.
The CPU should be okay, it is a dual core processor supporting SSE2.
The Guru Meditation error is pointing towards a problem accessing one of the work files, not an error calculating for the folding core. The file may have been corrupted or locked from being used. I would try rebooting and see if that clears up the error. Otherwise, dump the WU and let the client cleanup and see if it processes on another WU okay.
vaterfa
Post by vaterfa »
Here is the new log after reboot and manual start folding.
*********************** Log Started 2020-04-12T19:29:46Z ***********************
19:29:46:************************* Folding@home Client *************************
19:29:46:        Website: https://foldingathome.org/
19:29:46:      Copyright: (c) 2009-2018 foldingathome.org
19:29:46:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:29:46:           Args:
19:29:46:         Config: C:\Users\G45\AppData\Roaming\FAHClient\config.xml
19:29:46:******************************** Build ********************************
19:29:46:        Version: 7.5.1
19:29:46:           Date: May 11 2018
19:29:46:           Time: 13:06:32
19:29:46:     Repository: Git
19:29:46:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
19:29:46:         Branch: master
19:29:46:       Compiler: Visual C++ 2008
19:29:46:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:29:46:       Platform: win32 10
19:29:46:           Bits: 32
19:29:46:           Mode: Release
19:29:46:******************************* System ********************************
19:29:46:            CPU: Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz
19:29:46:         CPU ID: GenuineIntel Family 6 Model 15 Stepping 13
19:29:46:           CPUs: 2
19:29:46:         Memory: 3.00GiB
19:29:46:    Free Memory: 1.64GiB
19:29:46:        Threads: WINDOWS_THREADS
19:29:46:     OS Version: 6.2
19:29:46:    Has Battery: false
19:29:46:     On Battery: false
19:29:46:     UTC Offset: 3
19:29:46:            PID: 1352
19:29:46:            CWD: C:\Users\G45\AppData\Roaming\FAHClient
19:29:46:             OS: Windows 10 Enterprise
19:29:46:        OS Arch: AMD64
19:29:46:           GPUs: 1
19:29:46:          GPU 0: Bus:4 Slot:0 Func:0 AMD:4 ManhattanP [Radeon HD
19:29:46:                 5400/6200/7300/8300]
19:29:46:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
19:29:46:                 Belirtilen modül bulunamadı.
19:29:46:
19:29:46:OpenCL Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:1.2 Driver:1800.8
19:29:46:  Win32 Service: false
19:29:46:***********************************************************************
19:29:46:<config>
19:29:46:  <!-- Network -->
19:29:46:  <proxy v=':8080'/>
19:29:46:
19:29:46:  <!-- Slot Control -->
19:29:46:  <power v='FULL'/>
19:29:46:
19:29:46:  <!-- User Information -->
19:29:46:  <passkey v='********************************'/>
19:29:46:  <user v='vaterfa'/>
19:29:46:
19:29:46:  <!-- Folding Slots -->
19:29:46:  <slot id='0' type='CPU'>
19:29:46:    <paused v='true'/>
19:29:46:  </slot>
19:29:46:  <slot id='1' type='GPU'>
19:29:46:  </slot>
19:29:46:</config>
19:29:46:Trying to access database...
19:29:46:Successfully acquired database lock
19:29:46:Enabled folding slot 00: PAUSED cpu:1 (by user)
19:29:46:Enabled folding slot 01: PAUSED gpu:0:ManhattanP [Radeon HD 5400/6200/7300/8300] (by user)
19:30:25:FS00:Unpaused
19:30:25:FS01:Unpaused
19:30:25:WU02:FS00:Starting
19:30:25:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\G45\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 1352 -checkpoint 15 -np 1
19:30:26:WU02:FS00:Started FahCore on PID 2880
19:30:29:WU02:FS00:Core PID:3784
19:30:29:WU02:FS00:FahCore 0xa7 started
19:30:30:WU02:FS00:0xa7:*********************** Log Started 2020-04-12T19:30:30Z ***********************
19:30:30:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:30:30:WU02:FS00:0xa7:       Type: 0xa7
19:30:30:WU02:FS00:0xa7:       Core: Gromacs
19:30:30:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 2880 -checkpoint 15 -np 1
19:30:30:WU02:FS00:0xa7:************************************ CBang *************************************
19:30:30:WU02:FS00:0xa7:       Date: Oct 26 2019
19:30:30:WU02:FS00:0xa7:       Time: 01:38:35
19:30:30:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:30:30:WU02:FS00:0xa7:     Branch: master
19:30:30:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
19:30:30:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:30:30:WU02:FS00:0xa7:   Platform: win32 10
19:30:31:WU02:FS00:0xa7:       Bits: 64
19:30:31:WU02:FS00:0xa7:       Mode: Release
19:30:31:WU02:FS00:0xa7:************************************ System ************************************
19:30:31:WU02:FS00:0xa7:        CPU: Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz
19:30:31:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 13
19:30:31:WU02:FS00:0xa7:       CPUs: 2
19:30:31:WU02:FS00:0xa7:     Memory: 3.00GiB
19:30:31:WU02:FS00:0xa7:Free Memory: 1.60GiB
19:30:31:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
19:30:31:WU02:FS00:0xa7: OS Version: 6.2
19:30:31:WU02:FS00:0xa7:Has Battery: false
19:30:31:WU02:FS00:0xa7: On Battery: false
19:30:31:WU02:FS00:0xa7: UTC Offset: 3
19:30:31:WU02:FS00:0xa7:        PID: 3784
19:30:31:WU02:FS00:0xa7:        CWD: C:\Users\G45\AppData\Roaming\FAHClient\work
19:30:31:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
19:30:31:WU02:FS00:0xa7:    Version: 0.0.18
19:30:31:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:30:31:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
19:30:31:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
19:30:31:WU02:FS00:0xa7:       Date: Oct 26 2019
19:30:31:WU02:FS00:0xa7:       Time: 01:52:44
19:30:31:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:30:31:WU02:FS00:0xa7:     Branch: master
19:30:31:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
19:30:31:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:30:31:WU02:FS00:0xa7:   Platform: win32 10
19:30:31:WU02:FS00:0xa7:************************************ Build *************************************
19:30:31:WU02:FS00:0xa7:       SIMD: sse2
19:30:31:WU02:FS00:0xa7:********************************************************************************
19:30:31:WU02:FS00:0xa7:Project: 16422 (Run 1202, Clone 2, Gen 20)
19:30:31:WU02:FS00:0xa7:Unit: 0x0000001696880e6e5e8be01933a980ef
19:30:31:WU02:FS00:0xa7:Digital signatures verified
19:30:31:WU02:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpi state.cpt -cpt 15 -nt 1
19:30:32:WU00:FS01:Connecting to 65.254.110.245:8080
19:30:33:WU00:FS01:Assigned to work server 192.0.2.1
19:30:33:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:ManhattanP [Radeon HD 5400/6200/7300/8300] from 192.0.2.1
19:30:33:WU00:FS01:Connecting to 192.0.2.1:8080
19:30:33:WU02:FS00:0xa7:Steps: first=5000000 total=250000
19:30:37:WU02:FS00:0xa7:Completed 10582 out of 250000 steps (4%)
19:30:47:Saving configuration to config.xml
19:30:47:<config>
19:30:47:  <!-- Network -->
19:30:47:  <proxy v=':8080'/>
19:30:47:
19:30:47:  <!-- Slot Control -->
19:30:47:  <power v='FULL'/>
19:30:47:
19:30:47:  <!-- User Information -->
19:30:47:  <passkey v='********************************'/>
19:30:47:  <user v='vaterfa'/>
19:30:47:
19:30:47:  <!-- Folding Slots -->
19:30:47:  <slot id='0' type='CPU'/>
19:30:47:  <slot id='1' type='GPU'/>
19:30:47:</config>
19:30:54:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
19:30:54:WU00:FS01:Connecting to 192.0.2.1:80
19:31:15:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Bağlanılan uygun olarak belli bir süre içinde yanıt vermediğinden veya kurulan
19:31:15:ERROR:WU00:FS01:bağlantı bağlanılan ana bilgisayar yanıt vermediğinden bir bağlantı kurulamadı.
19:31:16:WU00:FS01:Connecting to 65.254.110.245:8080
19:31:16:WU00:FS01:Assigned to work server 192.0.2.1
19:31:16:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:ManhattanP [Radeon HD 5400/6200/7300/8300] from 192.0.2.1
19:31:16:WU00:FS01:Connecting to 192.0.2.1:8080
19:31:37:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
19:31:37:WU00:FS01:Connecting to 192.0.2.1:80
19:31:58:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Bağlanılan uygun olarak belli bir süre içinde yanıt vermediğinden veya kurulan
19:31:58:ERROR:WU00:FS01:bağlantı bağlanılan ana bilgisayar yanıt vermediğinden bir bağlantı kurulamadı.
19:32:16:WU00:FS01:Connecting to 65.254.110.245:8080
Looks like the CPU is folding okay, at least as far as the log shows. Either pause the GPU slot, or just remove it entirely, it is not going to get a WU assigned to it.
vaterfa
Post by vaterfa »
Okay, i removed gpu from configure menu. Thank you for help.
