Hlafordles
Posts: 6 Joined: Sun Apr 12, 2020 10:23 am
Post
by Hlafordles » Sun Apr 12, 2020 3:23 pm
I know the servers are under heavy load, but since my best folding component (1080 Ti) is getting no work, and I found an excellent deal on a Titan Xp that is on the way, I thought I would follow the instructions for posting my log, and see if others can clue me in as to any problem settings etc.
Thanks in advance for any hints you can provide.
I'm in the fight, and just want to land more blows, is all. So far, I'm up to 1.7 million points (4 regular PCs folding), but all on on CPU and daytime residential power.
*********************** Log Started 2020-04-12T07:21:17Z ***********************
07:21:17:************************* Folding@home Client *************************
07:21:17: Website: https://foldingathome.org/
07:21:17: Copyright: (c) 2009-2018 foldingathome.org
07:21:17: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:21:17: Args: --open-web-control
07:21:17: Config: C:\Users\William\AppData\Roaming\FAHClient\config.xml
07:21:17:******************************** Build ********************************
07:21:17: Version: 7.5.1
07:21:17: Date: May 11 2018
07:21:17: Time: 13:06:32
07:21:17: Repository: Git
07:21:17: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
07:21:17: Branch: master
07:21:17: Compiler: Visual C++ 2008
07:21:17: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:21:17: Platform: win32 10
07:21:17: Bits: 32
07:21:17: Mode: Release
07:21:17:******************************* System ********************************
07:21:17: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
07:21:17: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
07:21:17: CPUs: 16
07:21:17: Memory: 31.94GiB
07:21:17: Free Memory: 26.17GiB
07:21:17: Threads: WINDOWS_THREADS
07:21:17: OS Version: 6.2
07:21:17: Has Battery: false
07:21:17: On Battery: false
07:21:17: UTC Offset: 2
07:21:17: PID: 12156
07:21:17: CWD: C:\Users\William\AppData\Roaming\FAHClient
07:21:17: OS: Windows 10 Enterprise
07:21:17: OS Arch: AMD64
07:21:17: GPUs: 1
07:21:17: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti] 11380
07:21:17:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.1
07:21:17:Win32 Service: false
07:21:17:***********************************************************************
07:21:17:<config>
07:21:17: <service-description v='Folding@home Client'/>
07:21:17: <service-restart v='true'/>
07:21:17: <service-restart-delay v='5000'/>
07:21:17:
07:21:17: <!-- Client Control -->
07:21:17: <client-threads v='6'/>
07:21:17: <cycle-rate v='4'/>
07:21:17: <cycles v='-1'/>
07:21:17: <data-directory v='.'/>
07:21:17: <disable-sleep-when-active v='true'/>
07:21:17: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
07:21:17: <exit-when-done v='false'/>
07:21:17: <fold-anon v='false'/>
07:21:17: <open-web-control v='true'/>
07:21:17:
07:21:17: <!-- Configuration -->
07:21:17: <config-rotate v='true'/>
07:21:17: <config-rotate-dir v='configs'/>
07:21:17: <config-rotate-max v='16'/>
07:21:17:
07:21:17: <!-- Debugging -->
07:21:17: <assignment-servers>
07:21:17: assign1.foldingathome.org:8080 assign2.foldingathome.org:80
07:21:17: </assignment-servers>
07:21:17: <auth-as v='true'/>
07:21:17: <capture-directory v='capture'/>
07:21:17: <capture-on-error v='false'/>
07:21:17: <capture-packets v='false'/>
07:21:17: <capture-requests v='false'/>
07:21:17: <capture-responses v='false'/>
07:21:17: <capture-sockets v='false'/>
07:21:17: <core-exec v='FahCore_$type'/>
07:21:17: <core-wrapper-exec v='FAHCoreWrapper'/>
07:21:17: <debug-sockets v='false'/>
07:21:17: <exception-locations v='true'/>
07:21:17: <stack-traces v='false'/>
07:21:17:
07:21:17: <!-- Error Handling -->
07:21:17: <max-slot-errors v='10'/>
07:21:17: <max-unit-errors v='5'/>
07:21:17:
07:21:17: <!-- Folding Core -->
07:21:17: <checkpoint v='15'/>
07:21:17: <core-dir v='cores'/>
07:21:17: <core-priority v='idle'/>
07:21:17: <cpu-affinity v='false'/>
07:21:17: <cpu-usage v='100'/>
07:21:17: <gpu-usage v='100'/>
07:21:17: <no-assembly v='false'/>
07:21:17:
07:21:17: <!-- Folding Slot Configuration -->
07:21:17: <cause v='ANY'/>
07:21:17: <client-subtype v='STDCLI'/>
07:21:17: <client-type v='advanced'/>
07:21:17: <cpu-species v='X86_PENTIUM_II'/>
07:21:17: <cpu-type v='AMD64'/>
07:21:17: <cpus v='-1'/>
07:21:17: <disable-viz v='false'/>
07:21:17: <gpu v='true'/>
07:21:17: <max-packet-size v='normal'/>
07:21:17: <os-species v='WIN_8'/>
07:21:17: <os-type v='WIN32'/>
07:21:17: <project-key v='0'/>
07:21:17: <smp v='true'/>
07:21:17:
07:21:17: <!-- GUI -->
07:21:17: <gui-enabled v='true'/>
07:21:17:
07:21:17: <!-- HTTP Server -->
07:21:17: <allow v='127.0.0.1, 192.168.1.1-192.168.1.100'/>
07:21:17: <connection-timeout v='60'/>
07:21:17: <deny v='0/0'/>
07:21:17: <http-addresses v='0:7396'/>
07:21:17: <https-addresses v=''/>
07:21:17: <max-connect-time v='900'/>
07:21:17: <max-connections v='800'/>
07:21:17: <max-request-length v='52428800'/>
07:21:17: <min-connect-time v='300'/>
07:21:17:
07:21:17: <!-- Logging -->
07:21:17: <log v='log.txt'/>
07:21:17: <log-color v='false'/>
07:21:17: <log-crlf v='true'/>
07:21:17: <log-date v='false'/>
07:21:17: <log-date-periodically v='21600'/>
07:21:17: <log-domain v='false'/>
07:21:17: <log-header v='true'/>
07:21:17: <log-level v='true'/>
07:21:17: <log-no-info-header v='true'/>
07:21:17: <log-redirect v='false'/>
07:21:17: <log-rotate v='true'/>
07:21:17: <log-rotate-dir v='logs'/>
07:21:17: <log-rotate-max v='16'/>
07:21:17: <log-short-level v='false'/>
07:21:17: <log-simple-domains v='true'/>
07:21:17: <log-thread-id v='false'/>
07:21:17: <log-thread-prefix v='true'/>
07:21:17: <log-time v='true'/>
07:21:17: <log-to-screen v='true'/>
07:21:17: <log-truncate v='false'/>
07:21:17: <verbosity v='5'/>
07:21:17:
07:21:17: <!-- Network -->
07:21:17: <proxy v=':8080'/>
07:21:17: <proxy-enable v='false'/>
07:21:17: <proxy-pass v=''/>
07:21:17: <proxy-user v=''/>
07:21:17:
07:21:17: <!-- Process Control -->
07:21:17: <child v='false'/>
07:21:17: <daemon v='false'/>
07:21:17: <pid v='false'/>
07:21:17: <pid-file v='Folding@home Client.pid'/>
07:21:17: <respawn v='false'/>
07:21:17: <service v='false'/>
07:21:17:
07:21:17: <!-- Remote Command Server -->
07:21:17: <command-address v='0.0.0.0'/>
07:21:17: <command-allow-no-pass v='127.0.0.1, 192.168.1.1-192.168.1.100'/>
07:21:17: <command-deny-no-pass v='0/0'/>
07:21:17: <command-enable v='true'/>
07:21:17: <command-port v='36330'/>
07:21:17:
07:21:17: <!-- Slot Control -->
07:21:17: <idle v='false'/>
07:21:17: <max-shutdown-wait v='60'/>
07:21:17: <pause-on-battery v='true'/>
07:21:17: <pause-on-start v='false'/>
07:21:17: <paused v='false'/>
07:21:17: <power v='FULL'/>
07:21:17:
07:21:17: <!-- User Information -->
07:21:17: <machine-id v='0'/>
07:21:17: <passkey v='********************************'/>
07:21:17: <team v='234771'/>
07:21:17: <user v='Hlafordlaes'/>
07:21:17:
07:21:17: <!-- Web Server -->
07:21:17: <web-allow v='127.0.0.1'/>
07:21:17: <web-deny v='0/0'/>
07:21:17: <web-enable v='true'/>
07:21:17:
07:21:17: <!-- Web Server Sessions -->
07:21:17: <session-cookie v='sid'/>
07:21:17: <session-lifetime v='86400'/>
07:21:17: <session-timeout v='3600'/>
07:21:17:
07:21:17: <!-- Work Unit Control -->
07:21:17: <dump-after-deadline v='true'/>
07:21:17: <max-queue v='16'/>
07:21:17: <max-units v='0'/>
07:21:17: <next-unit-percentage v='99'/>
07:21:17: <stall-detection-enabled v='false'/>
07:21:17: <stall-percent v='5'/>
07:21:17: <stall-timeout v='1800'/>
07:21:17:
07:21:17: <!-- Folding Slots -->
07:21:17: <slot id='0' type='CPU'/>
07:21:17: <slot id='1' type='GPU'/>
07:21:17:</config>
Posts: 2522 Joined: Mon Feb 16, 2009 4:12 am
Post
by JimboPalmer » Sun Apr 12, 2020 3:41 pm
Welcome to Folding@Home!
Right here you should have a line about OpenCL, and you don't.
Lets have you re-install the latest driver direct from Nvidia
https://www.geforce.com/drivers/results/159091
Once that installs, please post your log again so we can see if OpenCL took.
Post
by JimboPalmer » Sun Apr 12, 2020 3:50 pm
Not as important, but if you set verbosity to 3, it will be much easier to read your log.
Posts: 1996 Joined: Sun Mar 22, 2020 5:52 pm
Hardware configuration: 1: 2x Xeon E5-2697v3@2.60GHz, 512GB DDR4 LRDIMM, SSD Raid, Win10 Ent 20H2, Quadro K420 1GB, FAH 7.6.21 2: Xeon E3-1505Mv5@2.80GHz, 32GB DDR4, NVME, Win10 Pro 20H2, Quadro M1000M 2GB, FAH 7.6.21 (actually have two of these) 3: i7-960@3.20GHz, 12GB DDR3, SSD, Win10 Pro 20H2, GTX 750Ti 2GB, GTX 1080Ti 11GB, FAH 7.6.21
Post
by Neil-B » Sun Apr 12, 2020 3:57 pm
Hlafordles wrote: … but all on on CPU and daytime residential power.
I hear you !! … my own fault really for just running CPU slots … and tbh I am just ignoring my electricity bill and hoping it will go away!!
My Xeons are nice and solid get me 250k ppd, but do require a fair bit of juice to run - I pretend I just have a somewhat noisy heater with no off switch.
Fingers crossed the GPU community gets a flow of WUs soon.
Hlafordles
Post
by Hlafordles » Sun Apr 12, 2020 4:04 pm
Good-bye NVidia 3D Vision, which is what had me clinging to an old driver. My bad. Relegated to dual booting in Win7, then.
Back to business: As I understand it, log looks good, though no magical instant GPU WU, which is what I knew not to expect and was nonetheless, like,
totally rooting for.
*********************** Log Started 2020-04-12T15:55:41Z ***********************
15:55:41:************************* Folding@home Client *************************
15:55:41: Website: https://foldingathome.org/
15:55:41: Copyright: (c) 2009-2018 foldingathome.org
15:55:41: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:55:41: Args:
15:55:41: Config: C:\Users\William\AppData\Roaming\FAHClient\config.xml
15:55:41:******************************** Build ********************************
15:55:41: Version: 7.5.1
15:55:41: Date: May 11 2018
15:55:41: Time: 13:06:32
15:55:41: Repository: Git
15:55:41: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
15:55:41: Branch: master
15:55:41: Compiler: Visual C++ 2008
15:55:41: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:55:41: Platform: win32 10
15:55:41: Bits: 32
15:55:41: Mode: Release
15:55:41:******************************* System ********************************
15:55:41: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
15:55:41: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
15:55:41: CPUs: 16
15:55:41: Memory: 31.94GiB
15:55:41: Free Memory: 27.74GiB
15:55:41: Threads: WINDOWS_THREADS
15:55:41: OS Version: 6.2
15:55:41: Has Battery: false
15:55:41: On Battery: false
15:55:41: UTC Offset: 2
15:55:41: PID: 12332
15:55:41: CWD: C:\Users\William\AppData\Roaming\FAHClient
15:55:41: OS: Windows 10 Enterprise
15:55:41: OS Arch: AMD64
15:55:41: GPUs: 1
15:55:41: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti] 11380
15:55:41: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.0
15:55:41:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.75
15:55:41: Win32 Service: false
15:55:41:***********************************************************************
15:55:41:<config>
15:55:41: <!-- Folding Slot Configuration -->
15:55:41: <client-type v='advanced'/>
15:55:41:
15:55:41: <!-- HTTP Server -->
15:55:41: <allow v='127.0.0.1, 192.168.1.1-192.168.1.100'/>
15:55:41:
15:55:41: <!-- Network -->
15:55:41: <proxy v=':8080'/>
15:55:41:
15:55:41: <!-- Remote Command Server -->
15:55:41: <command-allow-no-pass v='127.0.0.1, 192.168.1.1-192.168.1.100'/>
15:55:41:
15:55:41: <!-- Slot Control -->
15:55:41: <power v='FULL'/>
15:55:41:
15:55:41: <!-- User Information -->
15:55:41: <passkey v='********************************'/>
15:55:41: <team v='234771'/>
15:55:41: <user v='Hlafordlaes'/>
15:55:41:
15:55:41: <!-- Folding Slots -->
15:55:41: <slot id='0' type='CPU'>
15:55:41: <paused v='true'/>
15:55:41: </slot>
15:55:41: <slot id='1' type='GPU'>
15:55:41: </slot>
15:55:41:</config>
15:55:41:Trying to access database...
15:55:41:Successfully acquired database lock
15:55:41:Enabled folding slot 00: PAUSED cpu:15 (by user)
15:55:41:Enabled folding slot 01: PAUSED gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 (by user)
15:56:00:FS00:Unpaused
15:56:00:FS01:Unpaused
15:56:00:WU00:FS00:Starting
15:56:00:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\William\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 12332 -checkpoint 15 -np 15
15:56:00:WU00:FS00:Started FahCore on PID 14860
15:56:00:WU00:FS00:Core PID:14888
15:56:00:WU00:FS00:FahCore 0xa7 started
15:56:00:WU00:FS00:0xa7:*********************** Log Started 2020-04-12T15:56:00Z ***********************
15:56:00:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:56:00:WU00:FS00:0xa7: Type: 0xa7
15:56:00:WU00:FS00:0xa7: Core: Gromacs
15:56:00:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 14860 -checkpoint 15 -np
15:56:00:WU00:FS00:0xa7: 15
15:56:00:WU00:FS00:0xa7:************************************ CBang *************************************
15:56:00:WU00:FS00:0xa7: Date: Oct 26 2019
15:56:00:WU00:FS00:0xa7: Time: 01:38:25
15:56:00:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:56:00:WU00:FS00:0xa7: Branch: master
15:56:00:WU00:FS00:0xa7: Compiler: Visual C++ 2008
15:56:00:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:56:00:WU00:FS00:0xa7: Platform: win32 10
15:56:00:WU00:FS00:0xa7: Bits: 64
15:56:00:WU00:FS00:0xa7: Mode: Release
15:56:00:WU00:FS00:0xa7:************************************ System ************************************
15:56:00:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
15:56:00:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
15:56:00:WU00:FS00:0xa7: CPUs: 16
15:56:00:WU00:FS00:0xa7: Memory: 31.94GiB
15:56:00:WU00:FS00:0xa7:Free Memory: 27.04GiB
15:56:00:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
15:56:00:WU00:FS00:0xa7: OS Version: 6.2
15:56:00:WU00:FS00:0xa7:Has Battery: false
15:56:00:WU00:FS00:0xa7: On Battery: false
15:56:00:WU00:FS00:0xa7: UTC Offset: 2
15:56:00:WU00:FS00:0xa7: PID: 14888
15:56:00:WU00:FS00:0xa7: CWD: C:\Users\William\AppData\Roaming\FAHClient\work
15:56:00:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
15:56:00:WU00:FS00:0xa7: Version: 0.0.18
15:56:00:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:56:00:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
15:56:00:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
15:56:00:WU00:FS00:0xa7: Time: 01:52:30
15:56:00:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:56:00:WU00:FS00:0xa7:************************************ Build *************************************
15:56:00:WU00:FS00:0xa7: SIMD: avx_256
15:56:00:WU00:FS00:0xa7:********************************************************************************
15:56:00:WU00:FS00:0xa7:Project: 14583 (Run 0, Clone 1412, Gen 15)
15:56:00:WU00:FS00:0xa7:Unit: 0x0000000f80fccb025e8bc95bf247f6a2
15:56:00:WU00:FS00:0xa7:Digital signatures verified
15:56:00:WU00:FS00:0xa7:Calling: mdrun -s frame15.tpr -o frame15.trr -x frame15.xtc -cpi state.cpt -cpt 15 -nt 15
15:56:00:WU01:FS01:Connecting to 65.254.110.245:8080
15:56:01:WU00:FS00:0xa7:Steps: first=937500 total=62500
15:56:06:WU00:FS00:0xa7:Completed 48112 out of 62500 steps (76%)
15:56:09:WU00:FS00:0xa7:Completed 48125 out of 62500 steps (77%)
15:56:29:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:56:29:WU01:FS01:Connecting to 18.218.241.186:80
15:56:30:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:56:30:ERROR:WU01:FS01:Exception: Could not get an assignment
15:56:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
15:56:30:WU01:FS01:Connecting to 65.254.110.245:8080
15:56:31:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:56:31:WU01:FS01:Connecting to 18.218.241.186:80
15:56:32:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:56:32:ERROR:WU01:FS01:Exception: Could not get an assignment
15:56:42:Removing old file 'configs/config-20200412-070828.xml'
15:56:42:Saving configuration to config.xml
15:56:42:<config>
15:56:42: <!-- Folding Slot Configuration -->
15:56:42: <client-type v='advanced'/>
15:56:42:
15:56:42: <!-- HTTP Server -->
15:56:42: <allow v='127.0.0.1, 192.168.1.1-192.168.1.100'/>
15:56:42:
15:56:42: <!-- Network -->
15:56:42: <proxy v=':8080'/>
15:56:42:
15:56:42: <!-- Remote Command Server -->
15:56:42: <command-allow-no-pass v='127.0.0.1, 192.168.1.1-192.168.1.100'/>
15:56:42:
15:56:42: <!-- Slot Control -->
15:56:42: <power v='FULL'/>
15:56:42:
15:56:42: <!-- User Information -->
15:56:42: <passkey v='********************************'/>
15:56:42: <team v='234771'/>
15:56:42: <user v='Hlafordlaes'/>
15:56:42:
15:56:42: <!-- Folding Slots -->
15:56:42: <slot id='0' type='CPU'/>
15:56:42: <slot id='1' type='GPU'/>
15:56:42:</config>
Hlafordles
Post
by Hlafordles » Sun Apr 12, 2020 4:19 pm
Neil-B wrote: Hlafordles wrote: … but all on on CPU and daytime residential power.
Nice to have company in the,
ahem , insanely folding category.
Post
by JimboPalmer » Sun Apr 12, 2020 4:33 pm
Yes!
That is what I was not seeing. I hope that GPU WUs are forthcoming!
Hlafordles
Post
by Hlafordles » Mon Apr 13, 2020 6:25 am
Applied same fix to all machines and now have my GTX 980 folding this morning. The GTX 1080 Ti flirted with a WU and dropped it, but at least there is some action.
Gonna take this here virus head on!!
Thanks again for the help.
ETA: Just had a WU fail and here is the code.
"Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900"
06:28:48:WU02:FS01:Starting
06:28:48:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\William\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 12804 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
06:28:48:WU02:FS01:Started FahCore on PID 1496
06:28:48:WU02:FS01:Core PID:16772
06:28:48:WU02:FS01:FahCore 0x22 started
06:28:49:WU02:FS01:0x22:*********************** Log Started 2020-04-13T06:28:48Z ***********************
06:28:49:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
06:28:49:WU02:FS01:0x22: Type: 0x22
06:28:49:WU02:FS01:0x22: Core: Core22
06:28:49:WU02:FS01:0x22: Website: https://foldingathome.org/
06:28:49:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
06:28:49:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
06:28:49:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
06:28:49:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 705 -lifeline 1496 -checkpoint 15
06:28:49:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
06:28:49:WU02:FS01:0x22: 0 -gpu 0
06:28:49:WU02:FS01:0x22: Config: <none>
06:28:49:WU02:FS01:0x22:************************************ Build *************************************
06:28:49:WU02:FS01:0x22: Version: 0.0.2
06:28:49:WU02:FS01:0x22: Date: Dec 6 2019
06:28:49:WU02:FS01:0x22: Time: 21:30:31
06:28:49:WU02:FS01:0x22: Repository: Git
06:28:49:WU02:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
06:28:49:WU02:FS01:0x22: Branch: HEAD
06:28:49:WU02:FS01:0x22: Compiler: Visual C++ 2008
06:28:49:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:28:49:WU02:FS01:0x22: Platform: win32 10
06:28:49:WU02:FS01:0x22: Bits: 64
06:28:49:WU02:FS01:0x22: Mode: Release
06:28:49:WU02:FS01:0x22:************************************ System ************************************
06:28:49:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
06:28:49:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
06:28:49:WU02:FS01:0x22: CPUs: 16
06:28:49:WU02:FS01:0x22: Memory: 31.94GiB
06:28:49:WU02:FS01:0x22:Free Memory: 25.83GiB
06:28:49:WU02:FS01:0x22: Threads: WINDOWS_THREADS
06:28:49:WU02:FS01:0x22: OS Version: 6.2
06:28:49:WU02:FS01:0x22:Has Battery: false
06:28:49:WU02:FS01:0x22: On Battery: false
06:28:49:WU02:FS01:0x22: UTC Offset: 2
06:28:49:WU02:FS01:0x22: PID: 16772
06:28:49:WU02:FS01:0x22: CWD: C:\Users\William\AppData\Roaming\FAHClient\work
06:28:49:WU02:FS01:0x22: OS: Windows 10 Pro
06:28:49:WU02:FS01:0x22: OS Arch: AMD64
06:28:49:WU02:FS01:0x22:********************************************************************************
06:28:49:WU02:FS01:0x22:Project: 11743 (Run 0, Clone 695, Gen 49)
06:28:49:WU02:FS01:0x22:Unit: 0x000000558ca304f15e67e045b79d5086
06:28:49:WU02:FS01:0x22:Reading tar file core.xml
06:28:49:WU02:FS01:0x22:Reading tar file integrator.xml
06:28:49:WU02:FS01:0x22:Reading tar file state.xml
06:28:49:WU02:FS01:0x22:Reading tar file system.xml
06:28:50:WU02:FS01:0x22:Digital signatures verified
06:28:50:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
06:28:50:WU02:FS01:0x22:Version 0.0.2
06:29:01:WU02:FS01:0x22:Completed 0 out of 2000000 steps (0%)
06:29:01:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:29:11:WU02:FS01:0x22:ERROR:exception: Error downloading array energySum: clEnqueueReadBuffer (-5)
06:29:11:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
06:29:11:WU02:FS01:0x22:Saving result file checkpt.crc
06:29:11:WU02:FS01:0x22:Saving result file science.log
06:29:11:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
06:29:12:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:29:12:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11743 run:0 clone:695 gen:49 core:0x22 unit:0x000000558ca304f15e67e045b79d5086
Posts: 6986 Joined: Wed Dec 23, 2009 9:33 am
Hardware configuration: V7.6.21 -> Multi-purpose 24/7 Windows 10 64-bit CPU:2/3/4/6 -> Intel i7-6700K GPU:1 -> Nvidia GTX 1080 Ti § Retired: 2x Nvidia GTX 1070 Nvidia GTX 675M Nvidia GTX 660 Ti Nvidia GTX 650 SC Nvidia GTX 260 896 MB SOC Nvidia 9600GT 1 GB OC Nvidia 9500M GS Nvidia 8800GTS 320 MB Intel Core i7-860 Intel Core i7-3840QM Intel i3-3240 Intel Core 2 Duo E8200 Intel Core 2 Duo E6550 Intel Core 2 Duo T8300 Intel Pentium E5500 Intel Pentium E5400
Post
by PantherX » Mon Apr 13, 2020 7:33 am
Hlafordles wrote: ...ETA: Just had a WU fail and here is the code.
The failure of the WU and the message are two different events and not at all co-related.
The failure of the WU could be due to hardware issues, it being a bad WU or a random glitch.
The message printed as an attempt from an earlier FahCore to ensure that a single Nvidia GPU would not exceed a certain temperature. However, it wasn't fully deployed in production and that message wasn't removed.
