MUST READ! Research Reveals That COVID-19 Attacks Hemoglobin In Red Blood Cells, Rendering It Incapable Of Transporting Oxygen. Current Medical Protocols Could All Be Wrong!
Source: COVID-19 Research Apr 09, 2020 3 days ago
COVID-19 Research: Findings from a new study released by Chinese researchers , Dr Wenzhong Liu from Sichuan University and Dr Hualan Li from Yibin University has revealed that the Sars-CoV-2 coronavirus attacks hemoglobin in the the red blood cells through a series of cellular actions, that ultimately renders the red blood cells incapable of transporting oxygen. https://chemrxiv.org/articles/COVID-19_ ... n/11938173
Though the virus is able to attack the ACE2 receptors in the lung tissues and cause damage and also while cytokine storms are creating more damage, it is most probability of the body’s inability get enough oxygen along with carbon dioxide build up that is creating the so called ARDS symptoms and stress and current protocols could be all wrong including the usage of ventilators in a non-proper manner way that could actually aggravate already ‘injured’ and inflamed lungs.
Red blood cells are critical oxygen carriers to the various cells in the body. Inside the red blood cells is a molecule called hemoglobin that contains heme groups. Each of these heme groups is molecular “ring” (porphyrin) that holds an Iron ion or FE ion. It is the FE ions that helps to transport oxygen in the bloodstream depending on states of oxidation.
Typically the red blood cells pick up oxygen from the lungs to transport to other parts of the bodies.
Once inside a human host cell, the virus’s RNA also codes for a number of non-structural proteins that are created during the replication process. These proteins are not part of the virus itself but helps the virus to ‘hijack” other cellularpath ways or actions to facilate its survival in the host.
The research discovered that some of these proteins are to hijack the red blood cells and remove the Iron ions from the heme groups (HBB) and replace themselves with it. This makes the hemoglobin unable to transport oxygen.
As a result the lungs are stressed out and inflamed while the rest of the organs are also being affected. The so called ARDS and subsequent organ failure could be attributed to this.
It was also suggested by another virologists that perhaps the coronavirus does not produce these proteins in the early stages of infection but will do so as a certain threshold is reached and only then the proteins ORF8,ORF1ab, ORF10, and ORF3a are produced.
This could explains the observation made by various ER docs (incl this one in New Orleans) that patients tend to have elevated ferritin. Typically ferritin is used to store excess iron. If a lot of iron is 'pushed' out of heme groups and circulating around, the body produces more ferritin.
https://www.thailandmedical.news/news/m ... al-protoco
COVID-19 Attacks Hemoglobin In Red Blood Cells?
Re: COVID-19 Attacks Hemoglobin In Red Blood Cells?
very interesting, before that I haven’t read such information anywhere, thanks.
I'm so old that I still play cs 1.6 =/
Interesting information I just hope we can win this war, Thank you very much
