CPU/Memory problems on 2019 Macbook Air
wauserfriendly
Post by wauserfriendly »
I installed FAH about a month ago, and I'm finding it is slowing down my 2019 Macbook Air. Recently, I've had some freezing problems. Activity Manager and Etrecheck told me it was using up a lot of memory/cpu.
I couldn't find any info on how to address, but as a newbie here, I may not know where to go.
I want to stay involved, but to prevent more freeze ups, had to change the extensions on FAH app so it wouldn't load. I've learned to use the right uninstaller and I didn't see.
1) Is there technical support that can help me to get this to work? I know enough to know I can do real damage. ;)
2) If not, what's the correct way to remove this from Mac OS? (Latest version of everything).
Thanks. I accept I'm the tail trying to wag the dog. :lol: Forgive me if I'm posting it in the wrong section.
Re: CPU/Memory problems on 2019 Macbook Air
Welcome to the F@H Forum wauserfriendly,
If you still have the F@H Software installed, Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file (viewtopic.php?f=106&t=26036). I am sure we can work with you to optimize your contribution towards F@H :)
As for an uninstaller, look in the Folding@home folder in Applications.
wauserfriendly
this is going to take a little time for me. :)
