One bad GPU WU Project: 11748 (Run 0, Clone 1993, Gen 13)
Post by foldy »
Got one bad GPU WU Project: 11748 (Run 0, Clone 1993, Gen 13).
09:36:59:WU00:FS01:Assigned to work server 140.163.4.231
09:36:59:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 140.163.4.231
09:36:59:WU00:FS01:Connecting to 140.163.4.231:8080
09:37:55:WU00:FS01:Downloading 4.53MiB
09:38:00:WU00:FS01:Download complete
09:38:00:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11748 run:0 clone:1993 gen:13 core:0x22 unit:0x0000001d8ca304e75e6a7fea2b07b6f9
09:38:00:WU00:FS01:Starting
09:38:00:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 6688 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:38:00:WU00:FS01:Started FahCore on PID 10636
09:38:00:WU00:FS01:Core PID:12612
09:38:00:WU00:FS01:FahCore 0x22 started
09:38:00:WU00:FS01:0x22:*********************** Log Started 2020-04-11T09:38:00Z ***********************
09:38:00:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
09:38:00:WU00:FS01:0x22:       Type: 0x22
09:38:00:WU00:FS01:0x22:       Core: Core22
09:38:00:WU00:FS01:0x22:    Website: https://foldingathome.org/
09:38:00:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
09:38:00:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
09:38:00:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
09:38:00:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 10636 -checkpoint 15
09:38:00:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
09:38:00:WU00:FS01:0x22:             0 -gpu 0
09:38:00:WU00:FS01:0x22:     Config: <none>
09:38:00:WU00:FS01:0x22:************************************ Build *************************************
09:38:00:WU00:FS01:0x22:    Version: 0.0.2
09:38:00:WU00:FS01:0x22:       Date: Dec 6 2019
09:38:00:WU00:FS01:0x22:       Time: 21:30:31
09:38:00:WU00:FS01:0x22: Repository: Git
09:38:00:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
09:38:00:WU00:FS01:0x22:     Branch: HEAD
09:38:00:WU00:FS01:0x22:   Compiler: Visual C++ 2008
09:38:00:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:38:00:WU00:FS01:0x22:   Platform: win32 10
09:38:00:WU00:FS01:0x22:       Bits: 64
09:38:00:WU00:FS01:0x22:       Mode: Release
09:38:00:WU00:FS01:0x22:************************************ System ************************************
09:38:00:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
09:38:00:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
09:38:00:WU00:FS01:0x22:       CPUs: 4
09:38:00:WU00:FS01:0x22:     Memory: 15.98GiB
09:38:00:WU00:FS01:0x22:Free Memory: 10.80GiB
09:38:00:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
09:38:00:WU00:FS01:0x22: OS Version: 6.1
09:38:00:WU00:FS01:0x22:Has Battery: false
09:38:00:WU00:FS01:0x22: On Battery: false
09:38:00:WU00:FS01:0x22: UTC Offset: 2
09:38:00:WU00:FS01:0x22:        PID: 12612
09:38:00:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
09:38:00:WU00:FS01:0x22:         OS: Windows 7 Professional Service Pack 1
09:38:00:WU00:FS01:0x22:    OS Arch: AMD64
09:38:00:WU00:FS01:0x22:********************************************************************************
09:38:00:WU00:FS01:0x22:Project: 11748 (Run 0, Clone 1993, Gen 13)
09:38:00:WU00:FS01:0x22:Unit: 0x0000001d8ca304e75e6a7fea2b07b6f9
09:38:00:WU00:FS01:0x22:Reading tar file core.xml
09:38:00:WU00:FS01:0x22:Reading tar file integrator.xml
09:38:00:WU00:FS01:0x22:Reading tar file state.xml
09:38:01:WU00:FS01:0x22:Reading tar file system.xml
09:38:01:WU00:FS01:0x22:Digital signatures verified
09:38:01:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
09:38:01:WU00:FS01:0x22:Version 0.0.2
09:38:07:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
09:38:07:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:39:04:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
09:39:58:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
09:40:55:WU00:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
09:41:11:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
09:41:11:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
09:41:16:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
09:41:16:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
09:41:21:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
09:41:21:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
09:41:21:WU00:FS01:0x22:ERROR:114: Max Retries Reached
09:41:21:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
09:41:21:WU00:FS01:0x22:Saving result file badstate-0.xml
09:41:23:WU00:FS01:0x22:Saving result file badstate-1.xml
09:41:24:WU00:FS01:0x22:Saving result file badstate-2.xml
09:41:27:WU00:FS01:0x22:Saving result file checkpointState.xml
09:41:28:WU00:FS01:0x22:Saving result file checkpt.crc
09:41:28:WU00:FS01:0x22:Saving result file positions.xtc
09:41:28:WU00:FS01:0x22:Saving result file science.log
09:41:28:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
09:41:29:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:41:29:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11748 run:0 clone:1993 gen:13 core:0x22 unit:0x0000001d8ca304e75e6a7fea2b07b6f9
09:41:29:WU00:FS01:Uploading 4.10MiB to 140.163.4.231
09:41:29:WU00:FS01:Connecting to 140.163.4.231:8080
09:41:29:WU01:FS01:Connecting to 65.254.110.245:8080
09:41:30:WU01:FS01:Assigned to work server 13.82.98.119
09:41:30:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 13.82.98.119
09:41:30:WU01:FS01:Connecting to 13.82.98.119:8080
09:41:32:WU01:FS01:Downloading 68.56MiB
09:41:38:WU01:FS01:Download 16.23%
09:41:42:WU00:FS01:Upload complete
09:41:42:WU00:FS01:Server responded WORK_ACK (400)
Other work units folding fine.
Re: One bad GPU WU Project: 11748 (Run 0, Clone 1993, Gen 13
Post by muziqaz »
hey foldy, thanks for that.
There are two people who uploaded this as faulty, but one other person managed to complete this very WU :)
FAH Omega tester
