foldinghomealone is maintaining a database of user submitted PPD using the HFM.NET. The current database can be seen here https://docs.google.com/spreadsheets/d/ ... sp=sharing. If you would like to contribute, I wrote a guide on setting up HFM.NET and submitting to the database viewtopic.php?f=16&t=34516
Additionally, I created a graphing and comparison tool that pulls from the database: viewtopic.php?f=14&t=35071
(The following is the old post, will update later)
Looking to upgrade your computer or building a new one? I spent a stupid amount of time compiling this short ordered list of theoretically top performing CPUs for each price point. I did this by taking the average CPU benchmark scores from https://www.cpubenchmark.net/power_performance.html eliminated any embedded, server, or OEM CPUs from the list; added the price from Amazon or Newegg (whichever was lower); sorted by performance; and finally went down the list and removed any processor that was more expensive than the previous one. You can see the performance/watt and performance/dollar in the last two columns.
Hopefully you guys find this useful. I'm planning on doing the same thing for GPUs eventually, but I'm a little burned out after this
I have done the same for GPUs, see here: viewtopic.php?f=38&t=34240
