Hi,
I'm so happy to be able to help FAH and it seems to be working fine on my laptop.
I'd like to share the project but was wondering if you have a few lines I could add about the risks of over heating, cost and liability etc - so people know what might happen and don't sign up if they can't deal with the risks.
Thanks
AFAIK, you're more than welcome to spread the word about F@H. You can also share your experience. However, I would like to point out few aspects based on your post:
1) Over heating - That's a system issue, not F@H issue. If your system is not being cooled properly, or is overclocked, then it isn't the software's fault for surfacing those issues.
2) Power - The system will use more power when it is in use than when it is idle or turned off. Power consumption will vary on few factors; PSU efficiency, CPU/GPU models, etc.
3) Cost - If you use more power, you would need to pay for it unless you have your own renewable energy source.
4) System - Do note that as per the EULA, if you own the system, you can install F@H Software on it. If you do not own the system, you will nee to have permission (generally written) from the system owner.
I'd add that the vast majority of laptops are not designed for prolonged heavy workloads like FAH, and will likely run at their designed thermal limits which may have some impact on overall hardware life span, but will at least most likely cause fans to run at 100% which is often somewhat annoying.
For Intel based laptops running Windows, here are some workarounds to limit heat generated (by limiting the CPU, which in turn may negatively impact the user experience on the laptop): https://www.geeks3d.com/20170213/how-to ... -notebook/
