It's designed to run hot, and allegedly survive, but I'm a cautious person and don't like fans at maximum speed.
I've upgraded to a Ryzen 3900X myself yesterday. Using the stock cooler, FAH easily got it to 92°C, clock speeds capping out at around 4MHz, fan(s) maximized.
I've not done any overclocking since a Pentium 200MMX was the bee's knees, but with the recent UI-based tools that make the process much simpler, I thought I'd start tinkering with the settings a bit
Alas, I thought I'd share my findings, which are limited to my FAH experience only.
- Because of the constant 100% load across most cores, the temperature hits the ceiling of 95°C so quickly, that the maximum boost clock speed of 4.6 GHz is only reached for split seconds. It then stabilizes at 4GHz for me.
- According to many reports on the web, as well as my own experience, the board chooses a voltage by default that is way too high. In idle, mine sat at around 1.35 volts. (Yes, it'll regulate down a bit when it runs hot, but I've not seen it go under 1.17 volts.)
- Because of the high temperatures, the fans spin up to maximum, but it's still not enough to prevent CPU throttling
I've tested the stability of each setting. First with Ryzen Master, then running FAH for 15 minutes each. And before anybody's wondering: All finished work units were uploaded with a result of WORK_ACK.
With the specific use case of FAH in mind, I also looked at the projected PPD, to estimate the performance hit. With surprising results.
stock settings: 92°C, ~103W, 110k + 70k = 180k PPD
3800 MHz, 1.175 V: 78°C, ~78W, 104k + 68k = 172k PPD
3800 MHz, 1.150 V: 74°C, ~73W, 106k + 64k = 170k PPD
3800 MHz, 1.075 V: 68°C, ~61W, 106k + 66k = 172k PPD (= Fan not maxed!)
As a result, I've decided that I'll stick with the 1.075 V setting, as it offers a significant power saving (40W * 24h = approx 1 kWh = 30 Eurocents/day) and keeps the computer quiet.
Sources: I'll add more sources to this posting once I found them in my browser history... I've looked at a lot of sites.
