Work Units Crashing
joeljose
Work Units Crashing
Post by joeljose »
Mod note - Moved topic from GPU projects forum as this is CPU only problem, no usable GPU
I've been having a lot of issues with Folding@Home lately. The work units keep crashing and I haven't been able to fold for a few days now.
Here's the log:
*********************** Log Started 2020-04-10T06:33:34Z ***********************
06:33:35:WU00:FS00:Connecting to 65.254.110.245:8080
06:33:36:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:33:36:WU00:FS00:Connecting to 18.218.241.186:80
06:33:40:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:33:40:ERROR:WU00:FS00:Exception: Could not get an assignment
06:33:40:WU00:FS00:Connecting to 65.254.110.245:8080
06:33:41:WU00:FS00:Assigned to work server 13.90.152.57
06:33:41:WU00:FS00:Requesting new work unit for slot 00: READY cpu:4 from 13.90.152.57
06:33:41:WU00:FS00:Connecting to 13.90.152.57:8080
06:33:42:WU00:FS00:Downloading 4.50MiB
06:33:53:WU00:FS00:Download 4.17%
06:34:00:WU00:FS00:Download 6.95%
06:34:08:WU00:FS00:Download 9.73%
06:34:14:WU00:FS00:Download 12.51%
06:34:20:WU00:FS00:Download 15.29%
06:34:27:WU00:FS00:Download 18.08%
06:34:36:WU00:FS00:Download 20.86%
06:34:42:WU00:FS00:Download 22.25%
06:34:49:WU00:FS00:Download 25.03%
06:34:56:WU00:FS00:Download 29.20%
06:35:10:WU00:FS00:Download 33.37%
06:35:16:WU00:FS00:Download 37.54%
06:35:22:WU00:FS00:Download 40.32%
06:35:30:WU00:FS00:Download 43.10%
06:36:05:WU00:FS00:Download 45.88%
06:36:14:WU00:FS00:Download 48.66%
06:36:20:WU00:FS00:Download 51.44%
06:36:26:WU00:FS00:Download 54.23%
06:37:02:WU00:FS00:Download 57.01%
06:37:08:WU00:FS00:Download 65.35%
06:37:14:WU00:FS00:Download 75.08%
06:37:20:WU00:FS00:Download 83.42%
06:37:26:WU00:FS00:Download 94.55%
06:37:27:WU00:FS00:Download complete
06:37:27:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13860 run:0 clone:6933 gen:34 core:0xa7 unit:0x000000290d5a98395e731361acaf27c0
06:37:28:WU00:FS00:Starting
06:37:28:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
06:37:28:WU00:FS00:Started FahCore on PID 8912
06:37:28:WU00:FS00:FahCore 0xa7 started
06:37:28:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:37:28:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (7858526 = 0x77e95e)
06:37:28:WU00:FS00:Started FahCore on PID 10688
Re: Work Units Crashing
Welcome to the F@H Forum joeljose,
Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file (viewtopic.php?f=74&t=26036).
joeljose
Post by joeljose »
Thanks for the quick reply PantherX.
06:33:34:************************* Folding@home Client *************************
06:33:34:        Website: https://foldingathome.org/
06:33:34:      Copyright: (c) 2009-2018 foldingathome.org
06:33:34:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:33:34:           Args: --open-web-control
06:33:34:         Config: C:\Users\Joel\AppData\Roaming\FAHClient\config.xml
06:33:34:******************************** Build ********************************
06:33:34:        Version: 7.5.1
06:33:34:           Date: May 11 2018
06:33:34:           Time: 13:06:32
06:33:34:     Repository: Git
06:33:34:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
06:33:34:         Branch: master
06:33:34:       Compiler: Visual C++ 2008
06:33:34:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:33:34:       Platform: win32 10
06:33:34:           Bits: 32
06:33:34:           Mode: Release
06:33:34:******************************* System ********************************
06:33:34:            CPU: Intel(R) Core(TM) i3-8145U CPU @ 2.10GHz
06:33:34:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
06:33:34:           CPUs: 4
06:33:34:         Memory: 3.86GiB
06:33:34:    Free Memory: 1.36GiB
06:33:34:        Threads: WINDOWS_THREADS
06:33:34:     OS Version: 6.2
06:33:34:    Has Battery: true
06:33:34:     On Battery: false
06:33:34:     UTC Offset: 5
06:33:34:            PID: 9436
06:33:34:            CWD: C:\Users\Joel\AppData\Roaming\FAHClient
06:33:34:             OS: Windows 10 Home
06:33:34:        OS Arch: AMD64
06:33:34:           GPUs: 0
06:33:34:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
06:33:34:                 specified module could not be found.
06:33:34:
06:33:34:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
06:33:34:  Win32 Service: false
06:33:34:***********************************************************************
06:33:34:<config>
06:33:34:  <service-description v='Folding@home Client'/>
06:33:34:  <service-restart v='true'/>
06:33:34:  <service-restart-delay v='5000'/>
06:33:34:
06:33:34:  <!-- Client Control -->
06:33:34:  <client-threads v='6'/>
06:33:34:  <cycle-rate v='4'/>
06:33:34:  <cycles v='-1'/>
06:33:34:  <data-directory v='.'/>
06:33:34:  <disable-sleep-when-active v='true'/>
06:33:34:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
06:33:34:  <exit-when-done v='false'/>
06:33:34:  <fold-anon v='false'/>
06:33:34:  <open-web-control v='true'/>
06:33:34:
06:33:34:  <!-- Configuration -->
06:33:34:  <config-rotate v='true'/>
06:33:34:  <config-rotate-dir v='configs'/>
06:33:34:  <config-rotate-max v='16'/>
06:33:34:
06:33:34:  <!-- Debugging -->
06:33:34:  <assignment-servers>
06:33:34:    assign1.foldingathome.org:8080 assign2.foldingathome.org:80
06:33:34:  </assignment-servers>
06:33:34:  <auth-as v='true'/>
06:33:34:  <capture-directory v='capture'/>
06:33:34:  <capture-on-error v='false'/>
06:33:34:  <capture-packets v='false'/>
06:33:34:  <capture-requests v='false'/>
06:33:34:  <capture-responses v='false'/>
06:33:34:  <capture-sockets v='false'/>
06:33:34:  <core-exec v='FahCore_$type'/>
06:33:34:  <core-wrapper-exec v='FAHCoreWrapper'/>
06:33:34:  <debug-sockets v='false'/>
06:33:34:  <exception-locations v='true'/>
06:33:34:  <stack-traces v='false'/>
06:33:34:
06:33:34:  <!-- Error Handling -->
06:33:34:  <max-slot-errors v='10'/>
06:33:34:  <max-unit-errors v='5'/>
06:33:34:
06:33:34:  <!-- Folding Core -->
06:33:34:  <checkpoint v='15'/>
06:33:34:  <core-dir v='cores'/>
06:33:34:  <core-priority v='idle'/>
06:33:34:  <cpu-affinity v='false'/>
06:33:34:  <cpu-usage v='100'/>
06:33:34:  <gpu-usage v='100'/>
06:33:34:  <no-assembly v='false'/>
06:33:34:
06:33:34:  <!-- Folding Slot Configuration -->
06:33:34:  <cause v='ANY'/>
06:33:34:  <client-subtype v='STDCLI'/>
06:33:34:  <client-type v='normal'/>
06:33:34:  <cpu-species v='X86_PENTIUM_II'/>
06:33:34:  <cpu-type v='AMD64'/>
06:33:34:  <cpus v='-1'/>
06:33:34:  <disable-viz v='false'/>
06:33:34:  <gpu v='true'/>
06:33:34:  <max-packet-size v='normal'/>
06:33:34:  <os-species v='WIN_8'/>
06:33:34:  <os-type v='WIN32'/>
06:33:34:  <project-key v='0'/>
06:33:34:  <smp v='true'/>
06:33:34:
06:33:34:  <!-- GUI -->
06:33:34:  <gui-enabled v='true'/>
06:33:34:
06:33:34:  <!-- HTTP Server -->
06:33:34:  <allow v='127.0.0.1'/>
06:33:34:  <connection-timeout v='60'/>
06:33:34:  <deny v='0/0'/>
06:33:34:  <http-addresses v='0:7396'/>
06:33:34:  <https-addresses v=''/>
06:33:34:  <max-connect-time v='900'/>
06:33:34:  <max-connections v='800'/>
06:33:34:  <max-request-length v='52428800'/>
06:33:34:  <min-connect-time v='300'/>
06:33:34:
06:33:34:  <!-- Logging -->
06:33:34:  <log v='log.txt'/>
06:33:34:  <log-color v='false'/>
06:33:34:  <log-crlf v='true'/>
06:33:34:  <log-date v='false'/>
06:33:34:  <log-date-periodically v='21600'/>
06:33:34:  <log-domain v='false'/>
06:33:34:  <log-header v='true'/>
06:33:34:  <log-level v='true'/>
06:33:34:  <log-no-info-header v='true'/>
06:33:34:  <log-redirect v='false'/>
06:33:34:  <log-rotate v='true'/>
06:33:34:  <log-rotate-dir v='logs'/>
06:33:34:  <log-rotate-max v='16'/>
06:33:34:  <log-short-level v='false'/>
06:33:34:  <log-simple-domains v='true'/>
06:33:34:  <log-thread-id v='false'/>
06:33:34:  <log-thread-prefix v='true'/>
06:33:34:  <log-time v='true'/>
06:33:34:  <log-to-screen v='true'/>
06:33:34:  <log-truncate v='false'/>
06:33:34:  <verbosity v='5'/>
06:33:34:
06:33:34:  <!-- Network -->
06:33:34:  <proxy v=':8080'/>
06:33:34:  <proxy-enable v='false'/>
06:33:34:  <proxy-pass v=''/>
06:33:34:  <proxy-user v=''/>
06:33:34:
06:33:34:  <!-- Process Control -->
06:33:34:  <child v='false'/>
06:33:34:  <daemon v='false'/>
06:33:34:  <pid v='false'/>
06:33:34:  <pid-file v='Folding@home Client.pid'/>
06:33:34:  <respawn v='false'/>
06:33:34:  <service v='false'/>
06:33:34:
06:33:34:  <!-- Remote Command Server -->
06:33:34:  <command-address v='0.0.0.0'/>
06:33:34:  <command-allow-no-pass v='127.0.0.1'/>
06:33:34:  <command-deny-no-pass v='0/0'/>
06:33:34:  <command-enable v='true'/>
06:33:34:  <command-port v='36330'/>
06:33:34:
06:33:34:  <!-- Slot Control -->
06:33:34:  <idle v='false'/>
06:33:34:  <max-shutdown-wait v='60'/>
06:33:34:  <pause-on-battery v='false'/>
06:33:34:  <pause-on-start v='false'/>
06:33:34:  <paused v='false'/>
06:33:34:  <power v='full'/>
06:33:34:
06:33:34:  <!-- User Information -->
06:33:34:  <machine-id v='0'/>
06:33:34:  <passkey v='********************************'/>
06:33:34:  <team v='223518'/>
06:33:34:  <user v='joeljose'/>
06:33:34:
06:33:34:  <!-- Web Server -->
06:33:34:  <web-allow v='127.0.0.1'/>
06:33:34:  <web-deny v='0/0'/>
06:33:34:  <web-enable v='true'/>
06:33:34:
06:33:34:  <!-- Web Server Sessions -->
06:33:34:  <session-cookie v='sid'/>
06:33:34:  <session-lifetime v='86400'/>
06:33:34:  <session-timeout v='3600'/>
06:33:34:
06:33:34:  <!-- Work Unit Control -->
06:33:34:  <dump-after-deadline v='true'/>
06:33:34:  <max-queue v='16'/>
06:33:34:  <max-units v='0'/>
06:33:34:  <next-unit-percentage v='99'/>
06:33:34:  <stall-detection-enabled v='false'/>
06:33:34:  <stall-percent v='5'/>
06:33:34:  <stall-timeout v='1800'/>
06:33:34:
06:33:34:  <!-- Folding Slots -->
06:33:34:  <slot id='0' type='CPU'/>
06:33:34:</config>
06:33:34:Trying to access database...
06:33:34:Successfully acquired database lock
06:33:34:Enabled folding slot 00: READY cpu:4
06:33:34:Started thread 9 on PID 9436
06:33:34:Started thread 6 on PID 9436
06:33:34:Started thread 4 on PID 9436
06:33:34:Started thread 8 on PID 9436
06:33:34:Started thread 7 on PID 9436
06:33:34:Started thread 5 on PID 9436
06:33:44:Started thread 10 on PID 9436
06:37:28:Started thread 11 on PID 9436
06:37:28:Started thread 12 on PID 9436
06:38:28:WU00:FS00:Starting
06:38:28:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
06:38:28:WU00:FS00:Started FahCore on PID 9000
06:38:28:Started thread 13 on PID 9436
06:38:28:WU00:FS00:FahCore 0xa7 started
06:38:28:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:38:28:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (7858526 = 0x77e95e)
06:39:28:WU00:FS00:Starting
06:39:28:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
06:39:28:WU00:FS00:Started FahCore on PID 9660
06:39:28:Started thread 14 on PID 9436
06:39:28:WU00:FS00:FahCore 0xa7 started
06:39:29:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:39:29:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (7858526 = 0x77e95e)
06:40:29:WU00:FS00:Starting
06:40:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
06:40:29:WU00:FS00:Started FahCore on PID 7484
06:40:29:Started thread 15 on PID 9436
06:40:29:WU00:FS00:FahCore 0xa7 started
06:40:29:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:40:29:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (3074398 = 0x2ee95e)
06:40:29:WARNING:WU00:FS00:Too many errors, failing
06:40:29:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:13860 run:0 clone:6933 gen:34 core:0xa7 unit:0x000000290d5a98395e731361acaf27c0
06:40:29:WU00:FS00:Connecting to 13.90.152.57:8080
06:40:29:WU01:FS00:Connecting to 65.254.110.245:8080
06:40:30:WU00:FS00:Server responded WORK_ACK (400)
06:40:30:WU00:FS00:Cleaning up
06:41:02:WU01:FS00:Assigned to work server 40.114.52.201
06:41:02:WU01:FS00:Requesting new work unit for slot 00: READY cpu:4 from 40.114.52.201
06:41:02:WU01:FS00:Connecting to 40.114.52.201:8080
06:41:03:WU01:FS00:Downloading 1.23MiB
06:41:10:WU01:FS00:Download 15.26%
06:44:54:WU01:FS00:Download 30.51%
06:44:54:ERROR:WU01:FS00:Exception: Transfer failed
06:44:54:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: No such host is known.
06:44:54:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: No such host is known.
06:44:54:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
06:44:54:ERROR:WU01:FS00:Exception: Could not get an assignment
06:45:54:WU01:FS00:Connecting to 65.254.110.245:8080
06:45:55:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:45:55:WU01:FS00:Connecting to 18.218.241.186:80
06:45:56:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:45:56:ERROR:WU01:FS00:Exception: Could not get an assignment
06:47:31:WU01:FS00:Connecting to 65.254.110.245:8080
06:47:33:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:47:33:WU01:FS00:Connecting to 18.218.241.186:80
06:47:34:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:47:34:ERROR:WU01:FS00:Exception: Could not get an assignment
06:50:09:WU01:FS00:Connecting to 65.254.110.245:8080
06:50:10:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:50:10:WU01:FS00:Connecting to 18.218.241.186:80
06:50:10:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:50:10:ERROR:WU01:FS00:Exception: Could not get an assignment
06:50:16:FS00:Paused
06:50:18:FS00:Unpaused
06:51:09:WU01:FS00:Connecting to 65.254.110.245:8080
06:51:10:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:51:10:WU01:FS00:Connecting to 18.218.241.186:80
06:51:11:WU01:FS00:Assigned to work server 13.90.152.57
06:51:11:WU01:FS00:Requesting new work unit for slot 00: READY cpu:4 from 13.90.152.57
06:51:11:WU01:FS00:Connecting to 13.90.152.57:8080
06:51:12:WU01:FS00:Downloading 4.50MiB
06:51:18:WU01:FS00:Download 11.12%
06:51:24:WU01:FS00:Download 26.42%
06:51:30:WU01:FS00:Download 41.71%
06:51:36:WU01:FS00:Download 52.84%
06:51:42:WU01:FS00:Download 65.35%
06:51:48:WU01:FS00:Download 82.03%
06:51:54:WU01:FS00:Download 100.00%
06:51:54:WU01:FS00:Download complete
06:51:54:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13860 run:0 clone:8894 gen:33 core:0xa7 unit:0x000000280d5a98395e7312be0604a5eb
06:51:54:WU01:FS00:Starting
06:51:54:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
06:51:54:WU01:FS00:Started FahCore on PID 5824
06:51:54:Started thread 16 on PID 9436
06:51:54:WU01:FS00:FahCore 0xa7 started
06:51:54:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:51:54:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (6089054 = 0x5ce95e)
06:51:54:WU01:FS00:Started FahCore on PID 13052
06:51:54:Started thread 17 on PID 9436
06:51:55:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:51:55:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (6089054 = 0x5ce95e)
06:52:54:WU01:FS00:Starting
06:52:54:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
06:52:54:WU01:FS00:Started FahCore on PID 12616
06:52:54:Started thread 18 on PID 9436
06:52:54:WU01:FS00:FahCore 0xa7 started
06:52:55:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:52:55:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (6089054 = 0x5ce95e)
06:53:54:WU01:FS00:Starting
06:53:54:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
06:53:54:WU01:FS00:Started FahCore on PID 7284
06:53:54:Started thread 19 on PID 9436
06:53:54:WU01:FS00:FahCore 0xa7 started
06:53:55:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:53:55:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (6089054 = 0x5ce95e)
06:54:55:WU01:FS00:Starting
06:54:55:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
06:54:55:WU01:FS00:Started FahCore on PID 9468
06:54:55:Started thread 20 on PID 9436
06:54:55:WU01:FS00:FahCore 0xa7 started
06:54:55:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:54:55:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (12839262 = 0xc3e95e)
06:54:55:WARNING:WU01:FS00:Too many errors, failing
06:54:55:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:13860 run:0 clone:8894 gen:33 core:0xa7 unit:0x000000280d5a98395e7312be0604a5eb
06:54:55:WU01:FS00:Connecting to 13.90.152.57:8080
06:54:55:WU00:FS00:Connecting to 65.254.110.245:8080
06:54:56:WU01:FS00:Server responded WORK_ACK (400)
06:54:56:WU01:FS00:Cleaning up
06:54:56:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:54:56:WU00:FS00:Connecting to 18.218.241.186:80
06:54:57:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:54:57:ERROR:WU00:FS00:Exception: Could not get an assignment
06:54:57:WU00:FS00:Connecting to 65.254.110.245:8080
06:55:01:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:55:01:WU00:FS00:Connecting to 18.218.241.186:80
06:55:01:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:55:01:ERROR:WU00:FS00:Exception: Could not get an assignment
06:55:57:WU00:FS00:Connecting to 65.254.110.245:8080
06:55:58:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:55:58:WU00:FS00:Connecting to 18.218.241.186:80
06:56:00:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:56:00:ERROR:WU00:FS00:Exception: Could not get an assignment
06:57:35:WU00:FS00:Connecting to 65.254.110.245:8080
06:57:36:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:57:36:WU00:FS00:Connecting to 18.218.241.186:80
06:57:54:WU00:FS00:Assigned to work server 128.252.203.9
06:57:54:WU00:FS00:Requesting new work unit for slot 00: READY cpu:4 from 128.252.203.9
06:57:54:WU00:FS00:Connecting to 128.252.203.9:8080
06:58:01:ERROR:WU00:FS00:Exception: Server did not assign work unit
07:00:12:WU00:FS00:Connecting to 65.254.110.245:8080
07:00:13:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:00:13:WU00:FS00:Connecting to 18.218.241.186:80
07:00:14:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:00:14:ERROR:WU00:FS00:Exception: Could not get an assignment
07:00:21:FS00:Paused
07:00:22:FS00:Unpaused
07:01:12:WU00:FS00:Connecting to 65.254.110.245:8080
07:01:25:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: A socket operation was attempted to an unreachable network.
07:01:25:WU00:FS00:Connecting to 18.218.241.186:80
07:01:25:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': Failed to connect to 18.218.241.186:80: A socket operation was attempted to an unreachable network.
07:01:25:ERROR:WU00:FS00:Exception: Could not get an assignment
07:02:50:WU00:FS00:Connecting to 65.254.110.245:8080
07:02:51:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:02:51:WU00:FS00:Connecting to 18.218.241.186:80
07:02:51:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:02:51:ERROR:WU00:FS00:Exception: Could not get an assignment
07:05:27:WU00:FS00:Connecting to 65.254.110.245:8080
07:05:28:WU00:FS00:Assigned to work server 155.247.164.214
07:05:28:WU00:FS00:Requesting new work unit for slot 00: READY cpu:4 from 155.247.164.214
07:05:28:WU00:FS00:Connecting to 155.247.164.214:8080
07:05:29:WU00:FS00:Downloading 140.00KiB
07:05:30:WU00:FS00:Download complete
07:05:30:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14364 run:25 clone:4 gen:38 core:0xa7 unit:0x000000279bf7a4d65e7cbfc8afcde01b
07:05:30:WU00:FS00:Starting
07:05:30:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
07:05:30:WU00:FS00:Started FahCore on PID 6592
07:05:30:Started thread 21 on PID 9436
07:05:30:WU00:FS00:FahCore 0xa7 started
07:05:30:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:05:30:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (4974942 = 0x4be95e)
07:05:30:WU00:FS00:Started FahCore on PID 11592
07:05:30:Started thread 22 on PID 9436
07:05:31:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:05:31:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (4974942 = 0x4be95e)
07:06:31:WU00:FS00:Starting
07:06:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
07:06:31:WU00:FS00:Started FahCore on PID 11260
07:06:31:Started thread 23 on PID 9436
07:06:31:WU00:FS00:FahCore 0xa7 started
07:06:31:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:06:31:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (4974942 = 0x4be95e)
07:07:31:WU00:FS00:Starting
07:07:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
07:07:31:WU00:FS00:Started FahCore on PID 7324
07:07:31:Started thread 24 on PID 9436
07:07:31:WU00:FS00:FahCore 0xa7 started
07:07:31:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:07:31:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (4974942 = 0x4be95e)
07:08:31:WU00:FS00:Starting
07:08:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
07:08:31:WU00:FS00:Started FahCore on PID 756
07:08:31:Started thread 25 on PID 9436
07:08:31:WU00:FS00:FahCore 0xa7 started
07:08:31:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:08:31:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (4974942 = 0x4be95e)
07:08:31:WARNING:WU00:FS00:Too many errors, failing
07:08:31:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:14364 run:25 clone:4 gen:38 core:0xa7 unit:0x000000279bf7a4d65e7cbfc8afcde01b
07:08:31:WU00:FS00:Connecting to 155.247.164.214:8080
07:08:32:WU01:FS00:Connecting to 65.254.110.245:8080
07:08:32:WU00:FS00:Server responded WORK_ACK (400)
07:08:32:WU00:FS00:Cleaning up
07:08:33:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:08:33:WU01:FS00:Connecting to 18.218.241.186:80
07:08:34:WU01:FS00:Assigned to work server 168.245.198.125
07:08:34:WU01:FS00:Requesting new work unit for slot 00: READY cpu:4 from 168.245.198.125
07:08:34:WU01:FS00:Connecting to 168.245.198.125:8080
07:08:35:WU01:FS00:Downloading 2.85MiB
07:08:41:WU01:FS00:Download 21.93%
07:08:47:WU01:FS00:Download 50.45%
07:08:53:WU01:FS00:Download 65.80%
07:08:59:WU01:FS00:Download 89.92%
07:09:01:WU01:FS00:Download complete
07:09:01:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16411 run:1673 clone:4 gen:12 core:0xa7 unit:0x0000000da8f5c67d5e87749740c4966b
07:09:01:WU01:FS00:Starting
07:09:01:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
07:09:01:WU01:FS00:Started FahCore on PID 7580
07:09:01:Started thread 26 on PID 9436
07:09:01:WU01:FS00:FahCore 0xa7 started
07:09:01:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:09:01:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (4974942 = 0x4be95e)
07:09:01:WU01:FS00:Started FahCore on PID 3084
07:09:01:Started thread 27 on PID 9436
07:09:02:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:09:02:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (4974942 = 0x4be95e)
07:10:02:WU01:FS00:Starting
07:10:02:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
07:10:02:WU01:FS00:Started FahCore on PID 6544
07:10:02:Started thread 28 on PID 9436
07:10:02:WU01:FS00:FahCore 0xa7 started
07:10:02:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:10:02:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (4974942 = 0x4be95e)
07:11:02:WU01:FS00:Starting
07:11:02:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
07:11:02:WU01:FS00:Started FahCore on PID 7924
07:11:02:Started thread 29 on PID 9436
07:11:02:WU01:FS00:FahCore 0xa7 started
07:11:02:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:11:02:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (11790686 = 0xb3e95e)
07:12:02:WU01:FS00:Starting
07:12:02:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 9436 -checkpoint 15 -np 4
07:12:02:WU01:FS00:Started FahCore on PID 4196
07:12:02:Started thread 30 on PID 9436
07:12:02:WU01:FS00:FahCore 0xa7 started
07:12:02:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:12:02:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (11790686 = 0xb3e95e)
07:12:02:WARNING:WU01:FS00:Too many errors, failing
07:12:02:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:16411 run:1673 clone:4 gen:12 core:0xa7 unit:0x0000000da8f5c67d5e87749740c4966b
07:12:02:WU01:FS00:Connecting to 168.245.198.125:8080
07:12:02:WU00:FS00:Connecting to 65.254.110.245:8080
07:12:03:WU01:FS00:Server responded WORK_ACK (400)
07:12:03:WU01:FS00:Cleaning up
07:12:04:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:12:04:WU00:FS00:Connecting to 18.218.241.186:80
07:12:04:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:12:04:ERROR:WU00:FS00:Exception: Could not get an assignment
07:12:05:WU00:FS00:Connecting to 65.254.110.245:8080
07:12:06:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:12:06:WU00:FS00:Connecting to 18.218.241.186:80
07:12:07:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:12:07:ERROR:WU00:FS00:Exception: Could not get an assignment
07:13:05:WU00:FS00:Connecting to 65.254.110.245:8080
Can you please reset the verbosity level to 3 so that it excludes all the default values and excessive messages which makes it difficult to troubleshoot? Do note that you may need to restart your system/client after changing the verbosity level to the default (3)
joeljose
Post by joeljose »
I'm running Folding@Home on a laptop with a Core i3-8145U and it does not have a discrete graphics card. I've also tried reinstalling Folding@Home but it still shows that
*********************** Log Started 2020-04-10T07:30:57Z ***********************
07:30:57:************************* Folding@home Client *************************
07:30:57:        Website: https://foldingathome.org/
07:30:57:      Copyright: (c) 2009-2018 foldingathome.org
07:30:57:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:30:57:           Args: --open-web-control
07:30:57:         Config: C:\Users\Joel\AppData\Roaming\FAHClient\config.xml
07:30:57:******************************** Build ********************************
07:30:57:        Version: 7.5.1
07:30:57:           Date: May 11 2018
07:30:57:           Time: 13:06:32
07:30:57:     Repository: Git
07:30:57:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
07:30:57:         Branch: master
07:30:57:       Compiler: Visual C++ 2008
07:30:57:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:30:57:       Platform: win32 10
07:30:57:           Bits: 32
07:30:57:           Mode: Release
07:30:57:******************************* System ********************************
07:30:57:            CPU: Intel(R) Core(TM) i3-8145U CPU @ 2.10GHz
07:30:57:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
07:30:57:           CPUs: 4
07:30:57:         Memory: 3.86GiB
07:30:57:    Free Memory: 793.12MiB
07:30:57:        Threads: WINDOWS_THREADS
07:30:57:     OS Version: 6.2
07:30:57:    Has Battery: true
07:30:57:     On Battery: false
07:30:57:     UTC Offset: 5
07:30:57:            PID: 10432
07:30:57:            CWD: C:\Users\Joel\AppData\Roaming\FAHClient
07:30:57:             OS: Windows 10 Home
07:30:57:        OS Arch: AMD64
07:30:57:           GPUs: 0
07:30:57:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
07:30:57:                 specified module could not be found.
07:30:57:
07:30:57:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
07:30:57:  Win32 Service: false
07:30:57:***********************************************************************
07:30:57:<config>
07:30:57:  <!-- Network -->
07:30:57:  <proxy v=':8080'/>
07:30:57:
07:30:57:  <!-- Slot Control -->
07:30:57:  <pause-on-battery v='false'/>
07:30:57:  <power v='full'/>
07:30:57:
07:30:57:  <!-- User Information -->
07:30:57:  <passkey v='********************************'/>
07:30:57:  <team v='223518'/>
07:30:57:  <user v='joeljose'/>
07:30:57:
07:30:57:  <!-- Folding Slots -->
07:30:57:  <slot id='0' type='CPU'/>
07:30:57:</config>
07:30:57:Trying to access database...
07:30:57:Successfully acquired database lock
07:30:57:Enabled folding slot 00: READY cpu:4
07:30:58:WU00:FS00:Connecting to 65.254.110.245:8080
07:30:59:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:30:59:WU00:FS00:Connecting to 18.218.241.186:80
07:30:59:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:30:59:ERROR:WU00:FS00:Exception: Could not get an assignment
07:31:00:WU00:FS00:Connecting to 65.254.110.245:8080
07:31:00:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:31:00:WU00:FS00:Connecting to 18.218.241.186:80
07:31:02:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:31:02:ERROR:WU00:FS00:Exception: Could not get an assignment
07:32:00:WU00:FS00:Connecting to 65.254.110.245:8080
07:32:01:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:32:01:WU00:FS00:Connecting to 18.218.241.186:80
07:32:03:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:32:03:ERROR:WU00:FS00:Exception: Could not get an assignment
07:33:37:WU00:FS00:Connecting to 65.254.110.245:8080
07:33:38:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:33:38:WU00:FS00:Connecting to 18.218.241.186:80
07:33:40:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:33:40:ERROR:WU00:FS00:Exception: Could not get an assignment
07:36:14:WU00:FS00:Connecting to 65.254.110.245:8080
07:36:15:WU00:FS00:Assigned to work server 168.245.198.125
07:36:15:WU00:FS00:Requesting new work unit for slot 00: READY cpu:4 from 168.245.198.125
07:36:15:WU00:FS00:Connecting to 168.245.198.125:8080
07:36:18:WU00:FS00:Downloading 13.97MiB
07:36:26:WU00:FS00:Download 3.13%
07:36:32:WU00:FS00:Download 5.37%
07:36:38:WU00:FS00:Download 10.74%
07:36:44:WU00:FS00:Download 16.56%
07:36:50:WU00:FS00:Download 24.17%
07:36:56:WU00:FS00:Download 29.54%
07:37:02:WU00:FS00:Download 32.22%
07:37:08:WU00:FS00:Download 36.25%
07:37:14:WU00:FS00:Download 40.72%
07:37:20:WU00:FS00:Download 45.20%
07:37:26:WU00:FS00:Download 50.57%
07:37:32:WU00:FS00:Download 57.28%
07:37:38:WU00:FS00:Download 62.65%
07:37:44:WU00:FS00:Download 67.13%
07:37:50:WU00:FS00:Download 71.60%
07:37:56:WU00:FS00:Download 75.63%
07:38:02:WU00:FS00:Download 79.66%
07:38:08:WU00:FS00:Download 89.50%
07:38:12:WU00:FS00:Download complete
07:38:12:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16408 run:0 clone:415 gen:26 core:0xa7 unit:0x0000001ba8f5c67d5e801dfb82bbfb5d
07:38:12:WU00:FS00:Starting
07:38:12:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 10432 -checkpoint 15 -np 4
07:38:12:WU00:FS00:Started FahCore on PID 7516
07:38:13:WU00:FS00:FahCore 0xa7 started
07:38:13:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:38:13:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (7137630 = 0x6ce95e)
07:38:13:WU00:FS00:Starting
07:38:13:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Joel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 10432 -checkpoint 15 -np 4
07:38:13:WU00:FS00:Started FahCore on PID 1096
Thanks for the swift reply!
I have few suggestions for you:
1) Ensure that folding pauses when the laptop is on battery since it can drain the battery very quickly:
07:30:57: <pause-on-battery v='false'/> this should be 07:30:57: <pause-on-battery v='true'/>
2) If you're using this laptop while folding, you may find that setting the CPU to 3 via the FAHControl would give you a good balance between usability and folding.
3) Ensure that your laptop is well ventilated.
The current messages about "No WUs available for this configuration" is due to the excessive load on the F@H Servers: viewtopic.php?f=74&t=33193
It will automatically be assigned a new WU over the next few hours.
joeljose
Post by joeljose »
Alright but do you know what is causing "07:38:13:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed" to occur?
joeljose
Post by joeljose »
Also this happens when I've been folding a work unit and I turn off the laptop. I've also tried pausing it and then shutting down but when I try to resume my work the next day, the work unit disappears and almost all the work units I get after that crashes.
Humm... I have seen very few occurrences of error on a CPU only folding system. The general causes were:
1) No AVX support - Your CPU is new and supports AVX2
2) CPU overheating - I suggest that you ensure your laptop is properly ventilated
3) Anti-virus/anti-malware interference - Check to see if any software is messing up with the files
Just so I understand correctly, you were previously folding a WU fine and it was making progress. You turned off your laptop and now it simply refuses to fold even after a reboot. Is that correct?
joeljose
Post by joeljose »
Yes and I'm pretty sure it's not overheating. I don't know if Windows Defender can cause problems but I don't have any other anti-virus programs installed on this laptop.
That's rather unusual... is your Windows 10 fully up-to-date? While I don't think it causes an issue, I am running out of ideas to explain why that would happen :(
joeljose
Post by joeljose »
Yeah I have the latest version of Windows 10 installed. I also have a desktop PC with a Pentium E5200 which also runs on integrated graphics and it is able to fold without any issues.
Rel25917
Post by Rel25917 »
You could try running some stress tests and memory test.
I can not find that specific error code, but that type of report is usually a Windows error code being passed through to the folding log file. The Windows system log may give more information on the error, or there may be a crash log to check out.
As for Defender, check to see if it has quarantined or modified any files in the directory shown as CWD:
We recommend excluding that directory from scans, random binary data in some of the work files can trigger false positives on being scanned.
