AMD:5 Cypress Pro [Radeon HD 5800/6850] not getting wu
peterjammo
Post by peterjammo »
This is a win 10 box, been live for about 10 days. Cpu is folding, but I don't think the GPU has picked up any wu. Any time I check FAHcontrol it says that the GPU is waiting for idle.
*********************** Log Started 2020-04-09T13:13:37Z ***********************
13:13:37:************************* Folding@home Client *************************
13:13:37:        Website: https://foldingathome.org/
13:13:37:      Copyright: (c) 2009-2018 foldingathome.org
13:13:37:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:13:37:           Args:
13:13:37:         Config: C:\Users\Ryan\AppData\Roaming\FAHClient\config.xml
13:13:37:******************************** Build ********************************
13:13:37:        Version: 7.5.1
13:13:37:           Date: May 11 2018
13:13:37:           Time: 13:06:32
13:13:37:     Repository: Git
13:13:37:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
13:13:37:         Branch: master
13:13:37:       Compiler: Visual C++ 2008
13:13:37:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:13:37:       Platform: win32 10
13:13:37:           Bits: 32
13:13:37:           Mode: Release
13:13:37:******************************* System ********************************
13:13:37:            CPU: AMD Phenom(tm) II X4 955 Processor
13:13:37:         CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
13:13:37:           CPUs: 4
13:13:37:         Memory: 8.00GiB
13:13:37:    Free Memory: 5.75GiB
13:13:37:        Threads: WINDOWS_THREADS
13:13:37:     OS Version: 6.2
13:13:37:    Has Battery: false
13:13:37:     On Battery: false
13:13:37:     UTC Offset: 1
13:13:37:            PID: 11320
13:13:37:            CWD: C:\Users\Ryan\AppData\Roaming\FAHClient
13:13:37:             OS: Windows 10 Home
13:13:37:        OS Arch: AMD64
13:13:37:           GPUs: 1
13:13:37:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Cypress Pro [Radeon HD 5800/6850]
13:13:37:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
13:13:37:                 specified module could not be found.
13:13:37:
13:13:37:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:1800.12
13:13:37:  Win32 Service: false
13:13:37:***********************************************************************
13:13:37:<config>
13:13:37:  <!-- Folding Core -->
13:13:37:  <core-priority v='low'/>
13:13:37:
13:13:37:  <!-- Network -->
13:13:37:  <proxy v=':8080'/>
13:13:37:
13:13:37:  <!-- Slot Control -->
13:13:37:  <power v='LIGHT'/>
13:13:37:
13:13:37:  <!-- User Information -->
13:13:37:  <user v='PeterJammo'/>
13:13:37:
13:13:37:  <!-- Folding Slots -->
13:13:37:  <slot id='0' type='CPU'/>
13:13:37:  <slot id='1' type='GPU'/>
13:13:37:</config>
13:13:37:Trying to access database...
13:13:37:Successfully acquired database lock
13:13:37:Enabled folding slot 00: READY cpu:1
13:13:37:Enabled folding slot 01: PAUSED gpu:0:Cypress Pro [Radeon HD 5800/6850] (waiting for idle)
13:13:38:WU02:FS00:Starting
13:13:38:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Ryan\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 11320 -checkpoint 15 -np 1
13:13:38:WU02:FS00:Started FahCore on PID 11780
13:13:41:WU02:FS00:Core PID:11164
13:13:41:WU02:FS00:FahCore 0xa7 started
13:13:42:WU02:FS00:0xa7:*********************** Log Started 2020-04-09T13:13:42Z ***********************
13:13:42:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:13:42:WU02:FS00:0xa7:       Type: 0xa7
13:13:42:WU02:FS00:0xa7:       Core: Gromacs
13:13:42:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 11780 -checkpoint 15 -np
13:13:42:WU02:FS00:0xa7:             1
13:13:42:WU02:FS00:0xa7:************************************ CBang *************************************
13:13:42:WU02:FS00:0xa7:       Date: Oct 26 2019
13:13:42:WU02:FS00:0xa7:       Time: 01:38:35
13:13:42:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
13:13:42:WU02:FS00:0xa7:     Branch: master
13:13:42:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
13:13:42:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:13:42:WU02:FS00:0xa7:   Platform: win32 10
13:13:42:WU02:FS00:0xa7:       Bits: 64
13:13:42:WU02:FS00:0xa7:       Mode: Release
13:13:42:WU02:FS00:0xa7:************************************ System ************************************
13:13:42:WU02:FS00:0xa7:        CPU: AMD Phenom(tm) II X4 955 Processor
13:13:42:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
13:13:42:WU02:FS00:0xa7:       CPUs: 4
13:13:42:WU02:FS00:0xa7:     Memory: 8.00GiB
13:13:42:WU02:FS00:0xa7:Free Memory: 5.40GiB
13:13:42:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
13:13:42:WU02:FS00:0xa7: OS Version: 6.2
13:13:42:WU02:FS00:0xa7:Has Battery: false
13:13:42:WU02:FS00:0xa7: On Battery: false
13:13:42:WU02:FS00:0xa7: UTC Offset: 1
13:13:42:WU02:FS00:0xa7:        PID: 11164
13:13:42:WU02:FS00:0xa7:        CWD: C:\Users\Ryan\AppData\Roaming\FAHClient\work
13:13:42:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
13:13:42:WU02:FS00:0xa7:    Version: 0.0.18
13:13:42:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:13:42:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:13:42:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
13:13:42:WU02:FS00:0xa7:       Time: 01:52:44
13:13:42:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
13:13:42:WU02:FS00:0xa7:************************************ Build *************************************
13:13:42:WU02:FS00:0xa7:       SIMD: sse2
13:13:42:WU02:FS00:0xa7:********************************************************************************
13:13:42:WU02:FS00:0xa7:Project: 13860 (Run 0, Clone 15464, Gen 38)
13:13:42:WU02:FS00:0xa7:Unit: 0x0000002a0d5a98395e731087063af252
13:13:42:WU02:FS00:0xa7:Digital signatures verified
13:13:42:WU02:FS00:0xa7:Calling: mdrun -s frame38.tpr -o frame38.trr -x frame38.xtc -e frame38.edr -cpi state.cpt -cpt 15 -nt 1
13:13:45:WU02:FS00:0xa7:Steps: first=4750000 total=125000
13:13:47:WU02:FS00:0xa7:Completed 40441 out of 125000 steps (32%)
13:18:11:WU02:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
peterjammo
Re: AMD:5 Cypress Pro [Radeon HD 5800/6850] not getting wu
Fixed I think. I didn't realise that setting the slider to light would effectively disable the gpu. Looking for work now. In case anyone wonders why I waited 10 days to try to sort it, the display died soon after I installed and I only got that working again this afternoon.
Reviewing your client configuration, I noticed that you don't have a passkey. If you would like to get more points, then get a passkey and once you qualify, you will get the bonus points: https://apps.foldingathome.org/getpasskey
peterjammo
Thanks for the suggestion. I'm really only interested in the points tally as a monitor to give me an idea of how my machines are working. I've, possibly dubiously, decided that bonus points might muddy that a little. I was confidently expecting to sit more or less at the bottom of the points table anyway, though looking at the daily txt files, I seem to be about 530,000th of something over 1 million users (LibreOffice Calc hasn't got enough rows to display all), and it seems to be sorted by overall points. I guess a lot of other folders are also pretty slow and/or very part time.
