OpenCL: Not detected: clGetDeviceIDs() returned -1
nadirian
Post by nadirian »
Hello,
I am running a GTX1050-card on Fedora31, the CPU folding is working but not the GPU.
The log says "OpenCL: Not detected: clGetDeviceIDs() returned -1", and as far as i've read, ive installed the missing packages "ocl-icd" and "ocl-icd-devel", restarted the process and yeah.
Im out of ideas and google is not giving me any solution...
What happens is that the GPU is found, but it never receives a WU (it has been sitting 12 hrs without any WU).
Re: OpenCL: Not detected: clGetDeviceIDs() returned -1
Welcome to the F@H Forum nadirian,
Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file (viewtopic.php?f=80&t=26036).
nadirian
Post by nadirian »
Absolutely!
*********************** Log Started 2020-04-09T10:05:54Z ***********************
10:05:54:************************* Folding@home Client *************************
10:05:54:      Website: https://foldingathome.org/
10:05:54:    Copyright: (c) 2009-2018 foldingathome.org
10:05:54:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:05:54:         Args: --child --lifeline 477478 /etc/fahclient/config.xml --run-as
10:05:54:               fahclient --pid-file=/var/run/fahclient.pid --daemon
10:05:54:       Config: /etc/fahclient/config.xml
10:05:54:******************************** Build ********************************
10:05:54:      Version: 7.5.1
10:05:54:         Date: May 12 2018
10:05:54:         Time: 22:51:07
10:05:54:   Repository: Git
10:05:54:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
10:05:54:       Branch: master
10:05:54:     Compiler: GNU 4.4.7 20120313 (Red Hat 4.4.7-18)
10:05:54:      Options: -std=gnu++98 -O3 -funroll-loops
10:05:54:     Platform: linux2 4.14.0-3-amd64
10:05:54:         Bits: 64
10:05:54:         Mode: Release
10:05:54:******************************* System ********************************
10:05:54:          CPU: Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz
10:05:54:       CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
10:05:54:         CPUs: 12
10:05:54:       Memory: 15.55GiB
10:05:54:  Free Memory: 6.06GiB
10:05:54:      Threads: POSIX_THREADS
10:05:54:   OS Version: 5.5
10:05:54:  Has Battery: false
10:05:54:   On Battery: false
10:05:54:   UTC Offset: 2
10:05:54:          PID: 477480
10:05:54:          CWD: /var/lib/fahclient
10:05:54:           OS: Linux 5.5.10-200.fc31.x86_64 x86_64
10:05:54:      OS Arch: AMD64
10:05:54:         GPUs: 1
10:05:54:        GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP107 [GeForce GTX 1050 LP] 1862
10:05:54:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
10:05:54:       OpenCL: Not detected: clGetDeviceIDs() returned -1
10:05:54:***********************************************************************
10:05:54:<config>
10:05:54:
10:05:54:  <!-- Network -->
10:05:54:  <proxy v=':8080'/>
10:05:54:
10:05:54:  <!-- User Information -->
10:05:54:  <passkey v='********************************'/>
10:05:54:  <team v='foo'/>
10:05:54:  <user v='bar'/>
10:05:54:
10:05:54:
10:05:54:  <!-- Folding Slots -->
10:05:54:  <slot id='0' type='GPU'>
10:05:54:    <opencl-index v='0'/>
10:05:54:  </slot>
10:05:54:</config>
10:05:54:Switching to user fahclient
10:05:54:Trying to access database...
10:05:54:Successfully acquired database lock
10:05:54:Enabled folding slot 00: READY gpu:0:GP107 [GeForce GTX 1050 LP] 1862
10:05:54:WU00:FS00:Connecting to 65.254.110.245:8080
10:05:55:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:05:55:WU00:FS00:Connecting to 18.218.241.186:80
10:05:56:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:05:56:ERROR:WU00:FS00:Exception: Could not get an assignment
10:05:56:WU00:FS00:Connecting to 65.254.110.245:8080
10:05:56:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:05:56:WU00:FS00:Connecting to 18.218.241.186:80
10:05:57:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:05:57:ERROR:WU00:FS00:Exception: Could not get an assignment
10:06:56:WU00:FS00:Connecting to 65.254.110.245:8080
10:06:56:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
Thanks for your log... while I am not an expert in Linux, you might find this thread useful as it does mention Fedora 31 in it: viewtopic.php?f=106&t=33345
nadirian
Post by nadirian »
Thanks for that post.
But sadly there wasnt anything for me there.
The "python2"-fix is more for the FAHControl, and not the FAHClient (which i have problem with).
MarcvdM
Post by MarcvdM »
read my post in this forum, had the same issue. caused by multiple .icd's in /etc/OpenCL/vendors. clinfo goes trough the list one by one, FAHClient doesn't know what to do. Rename all .icd files to something not ending in ".icd" and just leave the nvidia.icd
viewtopic.php?f=80&t=34020
58Enfield
Post by 58Enfield »
Thank You , MarcvdM
This is a great deal easier than mindlessly wiping and re-installing nvidia drivers over and over and over until nvidia, opencl and FAH deign to recognise each other. There have been times I have just walked away and let a machine not fold for a couple of days instead of re-installing one.....more......family blog....adjective-deleted time.
The works on Xubuntu 18.04 Various Nvidia Cards
Thank You
nadirian
Post by nadirian »
MarcvdM wrote:read my post in this forum, had the same issue. caused by multiple .icd's in /etc/OpenCL/vendors. clinfo goes trough the list one by one, FAHClient doesn't know what to do. Rename all .icd files to something not ending in ".icd" and just leave the nvidia.icd
Thanks alot!
This made me realise that i didnt have cuda-drivers installed
'sudo dnf install xorg-x11-drv-nvidia-cuda' (because i was missing the nvidia.icd).
But as you said, i had to remove (rename) the mesa.icd and pool.icd and FAHclient were working!
Lets see if it gets any WUs now then.
nadirian
Post by nadirian »
Ah yes! It took some time, but now it has a job! :)
Post by Neil-B »
GZ … but don't tell everyone you got a GPU WU - they might try to steal it ;)
