GPU: config reset to false Nvidia GP107GLM Ubuntu 18.4
AlSimons
Post by AlSimons »
I dual boot Win 10 and Ubuntu 18.4. I've been folding on Win 10 for a while using both my CPUs and GPU, but need to run Linux now for a while. I can't get my Nvidia GP107GLM to be used. The Log shows that CUDA and OpenCL are both found. I've gone into Config/Expert and set GPU to true. It keeps being reset to false immediately (tab out of the field and it immediately reverts to false).
Here are the steps I took to configure the GPU for FAH use (I previously hadn't installed anything for the GPU). I got these instructions from various posts on the forum (possibly other sites too--I wasn't too careful in noting the sources, sorry).
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt update
sudo ubuntu-drivers autoinstall
<reboot>
sudo apt install nvidia-opencl-dev
<reboot>
Here is my log:
*********************** Log Started 2020-04-08T18:35:40Z ***********************
18:35:40:************************* Folding@home Client *************************
18:35:40:        Website: https://foldingathome.org/
18:35:40:      Copyright: (c) 2009-2018 foldingathome.org
18:35:40:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:35:40:           Args: --child --lifeline 1653 /etc/fahclient/config.xml --run-as
18:35:40:                 fahclient --pid-file=/var/run/fahclient.pid --daemon
18:35:40:         Config: /etc/fahclient/config.xml
18:35:40:******************************** Build ********************************
18:35:40:        Version: 7.5.1
18:35:40:           Date: May 11 2018
18:35:40:           Time: 19:59:04
18:35:40:     Repository: Git
18:35:40:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:35:40:         Branch: master
18:35:40:       Compiler: GNU 6.3.0 20170516
18:35:40:        Options: -std=gnu++98 -O3 -funroll-loops
18:35:40:       Platform: linux2 4.14.0-3-amd64
18:35:40:           Bits: 64
18:35:40:           Mode: Release
18:35:40:******************************* System ********************************
18:35:40:            CPU: Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz
18:35:40:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:35:40:           CPUs: 12
18:35:40:         Memory: 15.49GiB
18:35:40:    Free Memory: 14.72GiB
18:35:40:        Threads: POSIX_THREADS
18:35:40:     OS Version: 5.3
18:35:40:    Has Battery: false
18:35:40:     On Battery: false
18:35:40:     UTC Offset: -7
18:35:40:            PID: 1655
18:35:40:            CWD: /var/lib/fahclient
18:35:40:             OS: Linux 5.3.0-46-generic x86_64
18:35:40:        OS Arch: AMD64
18:35:40:           GPUs: 0
18:35:40:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
18:35:40:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:440.64
18:35:40:***********************************************************************
18:35:40:<config>
18:35:40:  <!-- Client Control -->
18:35:40:  <fold-anon v='true'/>
18:35:40:
18:35:40:  <!-- Folding Slot Configuration -->
18:35:40:  <gpu v='false'/>
18:35:40:
18:35:40:  <!-- Network -->
18:35:40:  <proxy v=':8080'/>
18:35:40:
18:35:40:  <!-- Slot Control -->
18:35:40:  <power v='full'/>
18:35:40:
18:35:40:  <!-- User Information -->
18:35:40:  <passkey v='********************************'/>
18:35:40:  <user v='AlSimons'/>
18:35:40:
18:35:40:  <!-- Folding Slots -->
18:35:40:  <slot id='0' type='CPU'/>
18:35:40:</config>
18:35:40:Switching to user fahclient
18:35:40:Trying to access database...
18:35:40:Successfully acquired database lock
18:35:40:Enabled folding slot 00: READY cpu:12
18:35:40:WU00:FS00:Starting
18:35:40:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 1655 -checkpoint 15 -np 12
18:35:40:WU00:FS00:Started FahCore on PID 1665
18:35:40:WU00:FS00:Core PID:1669
18:35:40:WU00:FS00:FahCore 0xa7 started
18:35:40:WU00:FS00:0xa7:*********************** Log Started 2020-04-08T18:35:40Z ***********************
18:35:40:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:35:40:WU00:FS00:0xa7:       Type: 0xa7
18:35:40:WU00:FS00:0xa7:       Core: Gromacs
18:35:40:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 1665 -checkpoint 15 -np
18:35:40:WU00:FS00:0xa7:             12
18:35:40:WU00:FS00:0xa7:************************************ CBang *************************************
18:35:40:WU00:FS00:0xa7:       Date: Nov 5 2019
18:35:40:WU00:FS00:0xa7:       Time: 06:06:57
18:35:40:WU00:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
18:35:40:WU00:FS00:0xa7:     Branch: master
18:35:40:WU00:FS00:0xa7:   Compiler: GNU 8.3.0
18:35:40:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
18:35:40:WU00:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
18:35:40:WU00:FS00:0xa7:       Bits: 64
18:35:40:WU00:FS00:0xa7:       Mode: Release
18:35:40:WU00:FS00:0xa7:************************************ System ************************************
18:35:40:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz
18:35:40:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:35:40:WU00:FS00:0xa7:       CPUs: 12
18:35:40:WU00:FS00:0xa7:     Memory: 15.49GiB
18:35:40:WU00:FS00:0xa7:Free Memory: 14.70GiB
18:35:40:WU00:FS00:0xa7:    Threads: POSIX_THREADS
18:35:40:WU00:FS00:0xa7: OS Version: 5.3
18:35:40:WU00:FS00:0xa7:Has Battery: false
18:35:40:WU00:FS00:0xa7: On Battery: false
18:35:40:WU00:FS00:0xa7: UTC Offset: -7
18:35:40:WU00:FS00:0xa7:        PID: 1669
18:35:40:WU00:FS00:0xa7:        CWD: /var/lib/fahclient/work
18:35:40:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
18:35:40:WU00:FS00:0xa7:    Version: 0.0.18
18:35:40:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:35:40:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:35:40:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
18:35:40:WU00:FS00:0xa7:       Time: 06:13:26
18:35:40:WU00:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
18:35:40:WU00:FS00:0xa7:************************************ Build *************************************
18:35:40:WU00:FS00:0xa7:       SIMD: avx_256
18:35:40:WU00:FS00:0xa7:********************************************************************************
18:35:40:WU00:FS00:0xa7:Project: 14366 (Run 47, Clone 4, Gen 22)
18:35:40:WU00:FS00:0xa7:Unit: 0x000000169bf7a4d65e84aeab10c10fff
18:35:40:WU00:FS00:0xa7:Digital signatures verified
18:35:40:WU00:FS00:0xa7:Calling: mdrun -s frame22.tpr -o frame22.trr -cpi state.cpt -cpt 15 -nt 12
18:35:41:WU00:FS00:0xa7:Steps: first=0 total=250000
18:35:41:WU00:FS00:0xa7:Completed 54896 out of 250000 steps (21%)
18:35:45:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
18:36:34:8:127.0.0.1:New Web connection
18:36:36:32:127.0.0.1:New Web connection
18:36:46:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
Since I won't be going back to Win 10 for a while, I'd really like to get the GPU running here. Thanks for any pointers.
Re: GPU: config reset to false Nvidia GP107GLM Ubuntu 18.4
Instead of changing the field, try selecting the gpu false setting and deleting it. Save after making the change and either restart FAHClient, or reboot.
ipkh
Post by ipkh »
Please remove the ppa and install the mainline Nvidia drivers from Ubuntu.
The ppa is no longer needed and the drivers included in the standard repository will bring the nvidia-xxx-compute packages as well.
