Folding Workload
Folding Workload
On light mode folding only seems to use my CPU and used about 40- 50 percent but does not seem to use GPU at all but on medium it maxes my CPU and used my GPU, is they're a way to get both GPU and CPU to run on light at about 50 percent? Or on light mode can you only use the CPU? As i feel that if i could use GPU and CPU on light mode i could justify constantly using Folding. But with it putting 100 percent strain on my PC CPU I find it hard to trust that something bad won't happen if I leave my CPU running light that overnight. Just a quick btw my PC specs are a ryzen 2700X, AIO water cooler, GTX 1080, 32 GB ram so on and so forth, so why is it that medium maxes out my CPU? Is it really that intensive of a workload? or is there something wrong on my end?
Re: Folding Workload
I would say that there's no general issue with loading the CPU to 100% 24/7, most modern CPUs, including your 2700X has thermal throttling and will downclock to ensure that it stays within its thermal limits, and in worst case fully shut down in the case of overheating.
That said, I would personally try to avoid running at the maximum spec temperature for 24/7, which seems to be 85C for your CPU.
If you cannot get your temperature below this at full load (or don't want to due to noise), I would suggest trying either limiting the number of CPU threads in FAH Advanced Control to somewhere around 6, 8 or 10 (experiment), or by limiting the CPU frequency. I don't know what tools there are available for AMD, but a "universal" Windows solution would be to limit the "Maximum processor state" in the power plan settings, see for e.g. https://www.geeks3d.com/20170213/how-to ... -notebook/ (some options may be Intel only, but Windows power plan should be universal)
Official F@H Twitter (frequently updated): https://twitter.com/foldingathome
Official F@H Facebook: https://www.facebook.com/Foldinghome-136059519794607/
(I'm not affiliated with the F@H Team, just promoting these channels for official updates)
Welcome to Folding@Home!
Your CPU has 16 threads, F@H calls them CPUs. Here are generic instructions to choose how many you want to use. start at 8.
If you have GPUs, F@H reserves one CPU per GPU to feed it data across the PCIE bus.
F@H has difficulty with large primes and their multiples number of CPUs.
7 is always large, 5 is sometimes large, and 3 is never large. Try to choose a number that is a multiple of 2 and/or 3.
2, 3, 4, 6, 8, 9, 12, 16, etc. are good numbers of CPUs to choose.
5. 10. 15, etc may work most of the time. Other numbers will bite you
Type the number you want, and click save.
Your CPU is just newer than F@H expected. Imagine you had 4 threads then light would use 1/2 =2, medium would use 4-1 = 3, and full would use all 4Domadea wrote:why is it that medium maxes out my CPU? Is it really that intensive of a workload? or is there something wrong on my end?
With 16 threads, light is 1/2 - 8, medium is 16-1 = 15 and full is 16. You just can't tell 15 out of 16 from full blast, no one can.
So I did this and now it seems that the CPU is still hitting 100 percent witch is weird as not in the actual program my CPU seems to be doing nothing. so my cpu utilization is jumping up and down from 10-100 percent yet the program shows my CPU doing noting as of now. So now its acting even stranger than before.JimboPalmer wrote:Welcome to Folding@Home!
FAHClient is just the process that communicates with FAH's servers.
It actually starts further processes (currently named FahCore_22 for GPU and FahCore_a7 for CPU) which are doing the calculations. You'll find that they are the ones using your CPU.
