12:29:42:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11748 run:0 clone:5487 gen:10 core:0x22 unit:0x0000001a8ca304e75e6bafe323dd07eb
12:29:42:WU01:FS01:Uploading 12.58MiB to 140.163.4.231
12:29:42:WU01:FS01:Connecting to 140.163.4.231:8080
12:30:04:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:30:04:WU01:FS01:Connecting to 140.163.4.231:80
12:30:19:WU01:FS01:Upload 0.50%
12:31:01:WU01:FS01:Upload 0.99%
12:31:01:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
12:31:19:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11748 run:0 clone:5487 gen:10 core:0x22 unit:0x0000001a8ca304e75e6bafe323dd07eb
12:31:19:WU01:FS01:Uploading 12.58MiB to 140.163.4.231
12:31:19:WU01:FS01:Connecting to 140.163.4.231:8080
12:32:02:WU01:FS01:Upload 0.99%
12:32:02:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
12:33:56:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11748 run:0 clone:5487 gen:10 core:0x22 unit:0x0000001a8ca304e75e6bafe323dd07eb
12:33:56:WU01:FS01:Uploading 12.58MiB to 140.163.4.231
12:33:56:WU01:FS01:Connecting to 140.163.4.231:8080
12:35:36:WU01:FS01:Upload 0.99%
12:35:36:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
12:38:11:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11748 run:0 clone:5487 gen:10 core:0x22 unit:0x0000001a8ca304e75e6bafe323dd07eb
12:38:11:WU01:FS01:Uploading 12.58MiB to 140.163.4.231
12:38:11:WU01:FS01:Connecting to 140.163.4.231:8080
12:38:32:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:38:32:WU01:FS01:Connecting to 140.163.4.231:80
12:38:53:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:45:02:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11748 run:0 clone:5487 gen:10 core:0x22 unit:0x0000001a8ca304e75e6bafe323dd07eb
12:45:02:WU01:FS01:Uploading 12.58MiB to 140.163.4.231
12:45:02:WU01:FS01:Connecting to 140.163.4.231:8080
12:45:23:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:45:23:WU01:FS01:Connecting to 140.163.4.231:80
12:45:44:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:56:07:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11748 run:0 clone:5487 gen:10 core:0x22 unit:0x0000001a8ca304e75e6bafe323dd07eb
12:56:07:WU01:FS01:Uploading 12.58MiB to 140.163.4.231
12:56:07:WU01:FS01:Connecting to 140.163.4.231:8080
12:56:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:56:28:WU01:FS01:Connecting to 140.163.4.231:80
12:56:50:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
