Unable to Connect to Assignment Server
Keineahnung4010
Hardware configuration: Ryzen 3900XT @4,45 Ghz
GTX 1060 6 Gb
32 Gb RAM @3600Mhz
Post by Keineahnung4010 »
Hello Guys,
I have an Issue: being unable to connect to the Server:
15:06:29:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
Start of the Log:
*********************** Log Started 2020-04-08T15:06:25Z ***********************
15:06:25:************************* Folding@home Client *************************
15:06:25:        Website: https://foldingathome.org/
15:06:25:      Copyright: (c) 2009-2018 foldingathome.org
15:06:25:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:06:25:           Args:
15:06:25:         Config: C:\Users\Sebastian\AppData\Roaming\FAHClient\config.xml
15:06:25:******************************** Build ********************************
15:06:25:        Version: 7.5.1
15:06:25:           Date: May 11 2018
15:06:25:           Time: 13:06:32
15:06:25:     Repository: Git
15:06:25:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
15:06:25:         Branch: master
15:06:25:       Compiler: Visual C++ 2008
15:06:25:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:06:25:       Platform: win32 10
15:06:25:           Bits: 32
15:06:25:           Mode: Release
15:06:25:******************************* System ********************************
15:06:25:            CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
15:06:25:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
15:06:25:           CPUs: 4
15:06:25:         Memory: 30.94GiB
15:06:25:    Free Memory: 25.94GiB
15:06:25:        Threads: WINDOWS_THREADS
15:06:25:     OS Version: 6.2
15:06:25:    Has Battery: false
15:06:25:     On Battery: false
15:06:25:     UTC Offset: 2
15:06:25:            PID: 14908
15:06:25:            CWD: C:\Users\Sebastian\AppData\Roaming\FAHClient
15:06:25:             OS: Windows 10 Home
15:06:25:        OS Arch: AMD64
15:06:25:           GPUs: 0
15:06:25:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
15:06:25:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.59
15:06:25:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
15:06:25:  Win32 Service: false
15:06:25:***********************************************************************
15:06:26:<config>
15:06:26:  <!-- Network -->
15:06:26:  <proxy v=':8080'/>
15:06:26:
15:06:26:  <!-- Slot Control -->
15:06:26:  <power v='FULL'/>
15:06:26:
15:06:26:  <!-- User Information -->
15:06:26:  <team v='159845'/>
15:06:26:  <user v='Keineahnung4015'/>
15:06:26:
15:06:26:  <!-- Folding Slots -->
15:06:26:  <slot id='0' type='CPU'/>
15:06:26:  <slot id='1' type='CPU'>
15:06:26:    <cpus v='2'/>
15:06:26:  </slot>
15:06:26:</config>
15:06:26:Trying to access database...
15:06:26:Successfully acquired database lock
15:06:26:Enabled folding slot 00: READY cpu:2
15:06:26:Enabled folding slot 01: READY cpu:2
15:06:26:WU00:FS00:Connecting to 65.254.110.245:8080
15:06:26:WU01:FS01:Connecting to 65.254.110.245:8080
15:06:27:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
15:06:27:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
15:06:27:WU01:FS01:Connecting to 18.218.241.186:80
15:06:27:WU00:FS00:Connecting to 18.218.241.186:80
15:06:28:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
15:06:28:ERROR:WU01:FS01:Exception: Could not get an assignment ID
15:06:28:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
15:06:28:ERROR:WU00:FS00:Exception: Could not get an assignment ID
15:06:28:WU01:FS01:Connecting to 65.254.110.245:8080
15:06:28:WU00:FS00:Connecting to 65.254.110.245:8080
15:06:29:WU01:FS01:Connecting to 18.218.241.186:80
15:06:29:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
15:06:29:WU00:FS00:Connecting to 18.218.241.186:80
15:06:29:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
15:06:29:ERROR:WU01:FS01:Exception: Could not get an assignment ID
15:06:29:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
15:06:29:ERROR:WU00:FS00:Exception: Could not get an assignment ID
Re: Unable to Connect to Assignment Server
You may be running into issues with firewall or other ant-malware settings. FAHClient uses HTTP over ports 8080 and 80 to download and upload data, the same as a web browser. Some firewalls block these transfers if they are not from a "known browser". You may need to add an exception allowing FAHClient to do these transfers.
Keineahnung4010
GTX 1060 6 Gb
32 Gb RAM @3600Mhz
I have tried to add the Client to the firewall, but it already was on there. Could this be a problem with my Wifi router ?
Edit: I can ping the Website assign4.foldingathome.org:80 without trouble, just like i can open it in the Browser
WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10001: Server responded: HTTP_NOT_FOUND
This message suggests a problem with the server, itself. If you wait, you'll probably be assigned to a different server. You may get an assignment there unless the ones you need happen to be is short supply.
And, yes, it might be your router.
