Hey All,
Windows 10 will crash semi-randomly (at least once or twice a day) due to something going wrong in FAH.
It's very strange, there's no BSOD, or any kind of system recovery that shows up, my computer will just blink off like there's a power cut. So it seems like the error is so bad that even windows can't recover from it!
I've checked that there are no hardware issues, Furmark and Prime95 can run side by side for hours with no issues and the system is drawing well below what the power supply can handle.
Iv tried reinstalling FAH with no success
Heres some more info on my system:
Windows 10 1903
FAH V7.5.1
CPU - Ryzen 3700X
GPU - RTX 2070 Super
750W Power Supply
V 7.5.1 Completely crashes windows 10!
Re: V 7.5.1 Completely crashes windows 10!
A few have posted of problems with systems having similar hardware, some have traced it to inadequate cooling for their Ryzen CPU. You can try reducing the number of CPU threads assigned to folding and monitoring temperatures.
One person posted a link to an article that put forward that the location of the chipsets in the Ryzen is a bit off center, so orientation of the cooler can make a difference. A larger cooler was used by another.
The fan and power curve for the RTX 2070 may also need checking.
For testing run FAH only on CPU and disable GPU slots for some days then vice versa. To see if CPU or GPU alone makes a problem.
It is a hardware issue and FAH uses compute on GPU which can be more demanding than game stress testing like furmark.
There is one benchmark which is also very demanding on GPU. Maybe try that
https://benchmark.unigine.com/superposition
I guess power supply overload or a 12V plug from power supply to mainboard or to GPU has sporadic issues. If there is voltage or power discrepancy it must shutdown. What brand is your power supply? Does it have several 12V lines?
jrweiss
Are you monitoring your temperatures and voltages? HWMonitor from CPUID is a good choice to see if you have any problems.
Many GPUs are VERY sensitive to fluctuations in the 12V output. Monitor the 12V rail over time to see if there are any significant spikes or dips. HWMon shows mine at 11.904 - 12.096, which is < +/- 0.1V or 0.8%. The ATX and EPS specs allow +/- 0.6V or 5%, which may be too large a variation for some systems.
FireFox-89
- Hardware configuration: Luna - Active
AMD Ryzen 7 3700X @ stock | Noctua NH-U9s with 2 Noctua B9 Redux 1600 92mm Fans
Gigabyte B550 Gaming X V2 Revision 1.3 BIOS version FFg
Corsair Vengeance LPX 2x16GB DDR4-3600 | Timings 18-22-22-42
ASUS GeForce RTX 3060 Ti Strix OC 8GB
SeaSonic M12II 850w 80+Bronze PSU
Terra - Active
Intel Core i5-4690K @ 4.20GHz with Vcore of 1.138v | Corsair H100i V2 with 2 Corsair SP120 120mm fans
Gigabyte Z87X-UD3H BIOS version 10b
Kingston HyperX Fury 4x4GB DDR3-1866 | Timings 9-10-9-28
Asus GeForce GTX 1070 Ti Strix OC 8GB
OCZ Technology ZS Series 550w 80+Bronze PSU
Anubis - Active
Intel Xeon E5-2695 V4 @ 0.980 Vcore | Cooler Master Hyper 212 with Noctua NF-F12 120mm IPPC 3000 fan
Gigabyte X99-SOC Champion BIOS version F23c
Corsair Vengeance LPX 4x8GB @ 2400 | Timings 20-18-18-40 (Need Sorting)
Sapphire Radeon RX 580 Nitro+ 4GB
Sapphire Radeon RX 570 Pulse 4GB
SeaSonic Prime Platinum 750w 80+Platinum PSU
All machines running F@H v8.4.9 - Location: Lincolnshire, UK
You're on Windows 10 version 1903, have you tried updating to the current 1909?
Do you even fold bro?
