Radeon RX Vega M XT - No WUs
This GPU is in a Hades Canyon NUC. Has this GPU been addd? I saw the GH Variant and others were.
Thanks,
-K
Thanks,
-K
Re: Radeon RX Vega M XT - No WUs
They will need the Vendor ID and the Card ID
GPU-Z calls it Device ID
https://www.techpowerup.com/gpu-specs/r ... m-gh.c3056
The GPU GPU-Z picks is the one you put the link to, Jimbo. What else is needed? Thanks, btw.This is the last machine in my home arcade that is not folding that is capable.
-K
-K
We already have those two GPUs supported :
0x694c / Polaris 22 XT [Radeon RX Vega M GH]
0x694e / Polaris 22 XL [Radeon RX Vega M GL]
If this doesn't match with yours, we need a screenshot of GPUZ showing the Device ID ...
I confirm 0x694c / Polaris 22 XT [Radeon RX Vega M GH] is working fine, after toTOW have updated the server.
So, the GPU chip is supported, and you have downloaded a WU. We would need to see you actual log to see what the client is doing with that WU, please post the first 200 lines of the log, and a section showing what the client has done with the WU since it was downloaded and the processing started.
Directions for finding and posting your log are part of the Welcome topic - viewtopic.php?f=16&t=26036
Assuming this is what success looks like:
Unlike every other gpu or cpu I am running, it never gets past this, the machine is completely unresponsive until I pause it remotely. I have 4 other machines folding without issue but this one is "rogue" for some reason
16:22:36:WU01:FS01:Connecting to 65.254.110.245:8080
16:22:36:WU01:FS01:Assigned to work server 13.90.152.57
16:22:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:[Radeon RX Vega M XT] from 13.90.152.57
16:22:36:WU01:FS01:Connecting to 13.90.152.57:8080
16:22:57:WU01:FS01:Downloading 51.20MiB
16:23:03:WU01:FS01:Download 28.44%
16:23:09:WU01:FS01:Download 65.80%
16:23:12:WU01:FS01:Download complete
16:23:12:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11780 run:0 clone:8570 gen:42 core:0x22 unit:0x0000003f0d5a98395e758926737daed7
16:23:12:WU01:FS01:Starting
16:23:12:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Arcade\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 10888 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:23:12:WU01:FS01:Started FahCore on PID 2796
16:23:12:WU01:FS01:Core PID:4980
16:23:12:WU01:FS01:FahCore 0x22 started
16:23:12:WU01:FS01:0x22:*********************** Log Started 2020-04-08T16:23:12Z ***********************
16:23:12:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:23:12:WU01:FS01:0x22: Type: 0x22
16:23:12:WU01:FS01:0x22: Core: Core22
16:23:12:WU01:FS01:0x22: Website: https://foldingathome.org/
16:23:12:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
16:23:12:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
16:23:12:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
16:23:12:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 2796 -checkpoint 15
16:23:12:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:23:12:WU01:FS01:0x22: Config: <none>
16:23:12:WU01:FS01:0x22:************************************ Build *************************************
16:23:12:WU01:FS01:0x22: Version: 0.0.2
16:23:12:WU01:FS01:0x22: Date: Dec 6 2019
16:23:12:WU01:FS01:0x22: Time: 21:30:31
16:23:12:WU01:FS01:0x22: Repository: Git
16:23:12:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
16:23:12:WU01:FS01:0x22: Branch: HEAD
16:23:12:WU01:FS01:0x22: Compiler: Visual C++ 2008
16:23:12:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:23:13:WU01:FS01:0x22: Platform: win32 10
16:23:13:WU01:FS01:0x22: Bits: 64
16:23:13:WU01:FS01:0x22: Mode: Release
16:23:13:WU01:FS01:0x22:************************************ System ************************************
16:23:13:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
16:23:13:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
16:23:13:WU01:FS01:0x22: CPUs: 8
16:23:13:WU01:FS01:0x22: Memory: 7.96GiB
16:23:13:WU01:FS01:0x22:Free Memory: 5.33GiB
16:23:13:WU01:FS01:0x22: Threads: WINDOWS_THREADS
16:23:13:WU01:FS01:0x22: OS Version: 6.2
16:23:13:WU01:FS01:0x22:Has Battery: false
16:23:13:WU01:FS01:0x22: On Battery: false
16:23:13:WU01:FS01:0x22: UTC Offset: -7
16:23:13:WU01:FS01:0x22: PID: 4980
16:23:13:WU01:FS01:0x22: CWD: C:\Users\Arcade\AppData\Roaming\FAHClient\work
16:23:13:WU01:FS01:0x22: OS: Windows 10 Pro
16:23:13:WU01:FS01:0x22: OS Arch: AMD64
16:23:13:WU01:FS01:0x22:********************************************************************************
16:23:13:WU01:FS01:0x22:Project: 11780 (Run 0, Clone 8570, Gen 42)
16:23:13:WU01:FS01:0x22:Unit: 0x0000003f0d5a98395e758926737daed7
16:23:13:WU01:FS01:0x22:Reading tar file core.xml
16:23:13:WU01:FS01:0x22:Reading tar file integrator.xml
16:23:13:WU01:FS01:0x22:Reading tar file state.xml
16:23:13:WU01:FS01:0x22:Reading tar file system.xml
16:23:13:WU01:FS01:0x22:Digital signatures verified
16:23:13:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:23:13:WU01:FS01:0x22:Version 0.0.2
Sadly, what we need is the first 200 lines of the log, where it tells us what hardware and software you have.
Pause, or reduce the number of CPU threads being used for CPU folding. The setup of some GPU WUs can take a substantial amount of CPU resources to get going. Also, in this case your GPU and CPU are packaged together. TDP for the package applies to the total heat output for both, to stay within that limit the thermal management will downclock the CPU or GPU or both.
I restarted that machine. this is what was logged
*********************** Log Started 2020-04-08T19:55:54Z ***********************
19:55:54:************************* Folding@home Client *************************
19:55:54: Website: https://foldingathome.org/
19:55:54: Copyright: (c) 2009-2018 foldingathome.org
19:55:54: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:55:54: Args:
19:55:54: Config: C:\Users\Arcade\AppData\Roaming\FAHClient\config.xml
19:55:54:******************************** Build ********************************
19:55:54: Version: 7.5.1
19:55:54: Date: May 11 2018
19:55:54: Time: 13:06:32
19:55:54: Repository: Git
19:55:54: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
19:55:54: Branch: master
19:55:54: Compiler: Visual C++ 2008
19:55:54: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:55:54: Platform: win32 10
19:55:54: Bits: 32
19:55:54: Mode: Release
19:55:54:******************************* System ********************************
19:55:54: CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
19:55:54: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
19:55:54: CPUs: 8
19:55:54: Memory: 7.96GiB
19:55:54: Free Memory: 5.56GiB
19:55:54: Threads: WINDOWS_THREADS
19:55:54: OS Version: 6.2
19:55:54: Has Battery: false
19:55:54: On Battery: false
19:55:54: UTC Offset: -7
19:55:54: PID: 10572
19:55:54: CWD: C:\Users\Arcade\AppData\Roaming\FAHClient
19:55:54: OS: Windows 10 Enterprise
19:55:54: OS Arch: AMD64
19:55:54: GPUs: 1
19:55:54: GPU 0: Bus:1 Slot:0 Func:0 AMD:5 [Radeon RX Vega M XT]
19:55:54: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
19:55:54: specified module could not be found.
19:55:54:
19:55:54:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
19:55:54: Win32 Service: false
19:55:54:***********************************************************************
19:55:54:<config>
19:55:54: <!-- HTTP Server -->
19:55:54: <allow v='127.0.0.1 10.0.0.0/24'/>
19:55:54:
19:55:54: <!-- Network -->
19:55:54: <proxy v=':8080'/>
19:55:54:
19:55:54: <!-- Remote Command Server -->
19:55:54: <command-allow-no-pass v='127.0.0.1 10.0.0.0/24'/>
19:55:54:
19:55:54: <!-- Slot Control -->
19:55:54: <power v='FULL'/>
19:55:54:
19:55:54: <!-- User Information -->
19:55:54: <passkey v='********************************'/>
19:55:54: <team v='259194'/>
19:55:54: <user v='MrKai'/>
19:55:54:
19:55:54: <!-- Folding Slots -->
19:55:54: <slot id='0' type='CPU'>
19:55:54: <cpus v='7'/>
19:55:54: <paused v='true'/>
19:55:54: </slot>
19:55:54: <slot id='1' type='GPU'>
19:55:54: </slot>
19:55:54:</config>
19:55:55:Trying to access database...
19:55:55:Successfully acquired database lock
19:55:55:Enabled folding slot 00: PAUSED cpu:7 (by user)
19:55:55:Enabled folding slot 01: PAUSED gpu:0:[Radeon RX Vega M XT] (by user)
What was seen in the last log. Nothing. The machine becomes completely unresponsive until I pause the gpu slot. Something is not "exactly" right. Like I noticed for some reason every other GPU lists some sort of name or something before [Gpu description] but this one does not. Pausing, unpausing, removing, re-adding slot or cpu slots, nothing. When this starts, the AMD Software show the GPU spiking to 100% utilization, but as I said, everything is just "stuck" until I pause the gpu folding from another machine.
Have you done all the steps in BIOS that the origonal thread mentioned?
jiashiuan wrote:Hello guys,
Thanks for your quick reply. Yes this is Intel Hades Canyon NUC, combining a KabyLakeG (i7-8809G) and AMD Radeon RX Vega M GH (Polaris 22) .
I managed to remove Intel drivers, disabled iGD in BIOS, installed latest Adrenalin from AMD website (and worked), but still got funny "192.0.2.1" errors, which means "not supported" as far as I know.
Sorry for the Chinese characters. I am from Taiwan.
