Can’t find my username
HowardStanley
I signed up the other day and all seemed ok. I got the email confirming my username and it gave me my pass key. Now I entered everything in the FAH client and started folding. I went back to the crypto bullions site the next day but it’s still saying 0 points and it doesn’t seem like it’s recording anything.
Would anyone know what the issue is? My username is the same as the one on here and my user ID is 29732.
Thanks in advance
Thanks in advance
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Re: Can’t find my username
Hi Howard and welcome to the forum.
I looked up your username on https://apps.foldingathome.org/cpu and see that the software on your machine returned one workunit for 243 points. You won't get bonus points until you've completed ten workunits and the stats might take up to 24 hours to update completely.
Please note that this forum is about ensuring you have setup the client to fold on your system to suit your needs. We do not help with any bitcoin currency and instead, we suggest that you ask support from the bitcoin provider
HowardStanley
Ok thanks. It seems I was too impatient as I can see points on my account now.Jesse_V wrote:Hi Howard and welcome to the forum.
HowardStanley
Another thing, my CPU is “running” but my GPU just says “download” and stuck at 0% ..is that normal?
*edit - in the folding slots section it just says “ready”, in the work queue section it says “download”
With the number of persons/systems increased by about 20x over the last few weeks, they have been able to increase server capacity about 12x. So there can be a wait to get new work.
That said, if you post the first several hundred lines of you log file, we can take a look at your hardware and software configuration and see if there is another issue.
HowardStanley
*********************** Log Started 2020-04-06T13:37:01Z ***********************
13:37:02:************************* Folding@home Client *************************
13:37:02: Website: https://foldingathome.org/
13:37:02: Copyright: (c) 2009-2018 foldingathome.org
13:37:02: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:37:02: Args:
13:37:02: Config: <none>
13:37:02:******************************** Build ********************************
13:37:02: Version: 7.5.1
13:37:02: Date: May 11 2018
13:37:02: Time: 12:57:01
13:37:02: Repository: Git
13:37:02: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
13:37:02: Branch: master
13:37:02: Compiler: GNU 4.2.1 Compatible Apple LLVM 7.3.0 (clang-703.0.31)
13:37:02: Options: -std=gnu++98 -O3 -funroll-loops -mmacosx-version-min=10.6
13:37:02: -Wno-unused-local-typedefs
13:37:02: Platform: darwin 15.6.0
13:37:02: Bits: 64
13:37:02: Mode: Release
13:37:02:******************************* System ********************************
13:37:02: CPU: Intel(R) Core(TM)2 Duo CPU P7550 @ 2.26GHz
13:37:02: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
13:37:02: CPUs: 2
13:37:02: Memory: 4.00GiB
13:37:02:Free Memory: 31.09MiB
13:37:02: Threads: POSIX_THREADS
13:37:02: OS Version: 10.12
13:37:02:Has Battery: true
13:37:02: On Battery: false
13:37:02: UTC Offset: 1
13:37:02: PID: 29433
13:37:02: CWD: /Library/Application Support/FAHClient
13:37:02: OS: Darwin 16.7.0 x86_64
13:37:02: OS Arch: AMD64
13:37:02: GPUs: 1
13:37:02: GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:1 C79 [GeForce 9400M]
13:37:02: CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
13:37:02: dlopen(libcuda.dylib, 1): image not found
13:37:02: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
13:37:02: dlopen(libOpenCL.dylib, 1): image not found
13:37:02:***********************************************************************
13:37:02:<config>
13:37:02: <!-- Folding Slots -->
13:37:02:</config>
13:37:02:Trying to access database...
13:37:03:Successfully acquired database lock
13:37:03:Enabled folding slot 00: PAUSED cpu:0 (not configured)
13:38:04:Saving configuration to config.xml
13:38:05:<config>
13:38:05: <!-- Folding Slots -->
13:38:05: <slot id='0' type='CPU'/>
13:38:05:</config>
13:38:14:Set client configured
13:38:29:WU00:FS00:Connecting to 65.254.110.245:8080
13:38:44:WU00:FS00:Connecting to 65.254.110.245:8080
13:38:47:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:38:47:WU00:FS00:Connecting to 18.218.241.186:80
13:38:48:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:38:48:ERROR:WU00:FS00:Exception: Could not get an assignment
13:38:48:WU00:FS00:Connecting to 65.254.110.245:8080
13:38:49:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:38:49:WU00:FS00:Connecting to 18.218.241.186:80
13:38:50:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:38:50:ERROR:WU00:FS00:Exception: Could not get an assignment
13:39:48:WU00:FS00:Connecting to 65.254.110.245:8080
13:39:49:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:39:49:WU00:FS00:Connecting to 18.218.241.186:80
13:39:49:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:39:49:ERROR:WU00:FS00:Exception: Could not get an assignment
13:41:25:WU00:FS00:Connecting to 65.254.110.245:8080
13:41:26:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:41:26:WU00:FS00:Connecting to 18.218.241.186:80
13:41:26:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:41:26:ERROR:WU00:FS00:Exception: Could not get an assignment
13:44:03:WU00:FS00:Connecting to 65.254.110.245:8080
13:44:03:WU00:FS00:Assigned to work server 168.245.198.125
13:44:03:WU00:FS00:Requesting new work unit for slot 00: READY cpu:0 from 168.245.198.125
13:44:04:WU00:FS00:Connecting to 168.245.198.125:8080
13:44:05:ERROR:WU00:FS00:Exception: Server did not assign work unit
13:45:55:Saving configuration to config.xml
13:45:55:<config>
13:45:55: <!-- Network -->
13:45:55: <proxy v=':8080'/>
13:45:55:
13:45:55: <!-- User Information -->
13:45:55: <team v='224497'/>
13:45:55: <user v='HowardStanley'/>
13:45:55:
13:45:55: <!-- Folding Slots -->
13:45:55: <slot id='0' type='CPU'/>
13:45:55:</config>
13:46:14:Saving configuration to config.xml
13:46:14:<config>
13:46:14: <!-- Network -->
13:46:14: <proxy v=':8080'/>
13:46:14:
13:46:14: <!-- User Information -->
13:46:14: <team v='224497'/>
13:46:14: <user v='HowardStanley'/>
13:46:14:
13:46:14: <!-- Folding Slots -->
13:46:14: <slot id='0' type='CPU'/>
13:46:14:</config>
13:46:25:Saving configuration to config.xml
13:46:25:<config>
13:46:25: <!-- Network -->
13:46:25: <proxy v=':8080'/>
13:46:25:
13:46:25: <!-- User Information -->
13:46:25: <passkey v='********************************'/>
13:46:25: <team v='224497'/>
13:46:25: <user v='HowardStanley'/>
13:46:25:
13:46:25: <!-- Folding Slots -->
13:46:25: <slot id='0' type='CPU'/>
13:46:25:</config>
13:47:15:Saving configuration to config.xml
13:47:15:<config>
13:47:15: <!-- Network -->
13:47:15: <proxy v=':8080'/>
13:47:15:
13:47:15: <!-- User Information -->
13:47:15: <passkey v='********************************'/>
13:47:15: <team v='224497'/>
13:47:15: <user v='HowardStanley'/>
13:47:15:
13:47:15: <!-- Folding Slots -->
13:47:15: <slot id='0' type='CPU'/>
13:47:15:</config>
13:48:17:WU00:FS00:Connecting to 65.254.110.245:8080
13:48:17:WU00:FS00:Assigned to work server 13.90.152.57
13:48:17:WU00:FS00:Requesting new work unit for slot 00: READY cpu:0 from 13.90.152.57
13:48:17:WU00:FS00:Connecting to 13.90.152.57:8080
13:48:33:WU00:FS00:Downloading 4.19MiB
13:48:40:WU00:FS00:Download 85.00%
13:48:41:WU00:FS00:Download complete
13:48:43:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13861 run:0 clone:7026 gen:25 core:0xa7 unit:0x0000001f0d5a98395e730e764053514e
13:48:48:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/osx/64bit/Core_a7.fah
13:48:48:WU00:FS00:Connecting to cores.foldingathome.org:80
13:48:49:WU00:FS00:FahCore a7: Downloading 5.84MiB
13:48:51:WU00:FS00:FahCore a7: Download complete
13:48:52:WU00:FS00:Valid core signature
13:48:52:WU00:FS00:Unpacked 14.88MiB to cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7
13:48:52:WU00:FS00:Starting
13:48:52:WARNING:WU00:FS00:Changed SMP threads from 1 to 0 this can cause some work units to fail
13:48:52:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 29433 -checkpoint 15
13:48:52:WU00:FS00:Started FahCore on PID 29636
13:48:53:WU00:FS00:Core PID:29637
13:48:53:WU00:FS00:FahCore 0xa7 started
13:48:54:WU00:FS00:0xa7:*********************** Log Started 2020-04-06T13:48:53Z ***********************
13:48:54:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:48:54:WU00:FS00:0xa7: Type: 0xa7
13:48:54:WU00:FS00:0xa7: Core: Gromacs
13:48:54:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 29636 -checkpoint 15
13:48:54:WU00:FS00:0xa7:************************************ CBang *************************************
13:48:54:WU00:FS00:0xa7: Date: Oct 26 2019
13:48:54:WU00:FS00:0xa7: Time: 03:00:47
13:48:54:WU00:FS00:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
13:48:54:WU00:FS00:0xa7: Branch: master
13:48:54:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
13:48:54:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
13:48:54:WU00:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
13:48:54:WU00:FS00:0xa7: Platform: darwin 19.0.0
13:48:54:WU00:FS00:0xa7: Bits: 64
13:48:54:WU00:FS00:0xa7: Mode: Release
13:48:54:WU00:FS00:0xa7:************************************ System ************************************
13:48:54:WU00:FS00:0xa7: CPU: Intel(R) Core(TM)2 Duo CPU P7550 @ 2.26GHz
13:48:54:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
13:48:54:WU00:FS00:0xa7: CPUs: 2
13:48:54:WU00:FS00:0xa7: Memory: 4.00GiB
13:48:54:WU00:FS00:0xa7:Free Memory: 41.02MiB
13:48:54:WU00:FS00:0xa7: Threads: POSIX_THREADS
13:48:54:WU00:FS00:0xa7: OS Version: 10.12
13:48:54:WU00:FS00:0xa7:Has Battery: true
13:48:54:WU00:FS00:0xa7: On Battery: false
13:48:54:WU00:FS00:0xa7: UTC Offset: 1
13:48:54:WU00:FS00:0xa7: PID: 29637
13:48:54:WU00:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
13:48:54:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
13:48:54:WU00:FS00:0xa7: Version: 0.0.18
13:48:54:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:48:54:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
13:48:54:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
13:48:54:WU00:FS00:0xa7: Time: 03:06:42
13:48:54:WU00:FS00:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
13:48:54:WU00:FS00:0xa7:************************************ Build *************************************
13:48:54:WU00:FS00:0xa7: SIMD: sse2
13:48:54:WU00:FS00:0xa7:********************************************************************************
13:48:54:WU00:FS00:0xa7:Project: 13861 (Run 0, Clone 7026, Gen 25)
13:48:54:WU00:FS00:0xa7:Unit: 0x0000001f0d5a98395e730e764053514e
13:48:54:WU00:FS00:0xa7:Reading tar file core.xml
13:48:54:WU00:FS00:0xa7:Reading tar file frame25.tpr
13:48:54:WU00:FS00:0xa7:Digital signatures verified
13:48:54:WU00:FS00:0xa7:Calling: mdrun -s frame25.tpr -o frame25.trr -x frame25.xtc -e frame25.edr -cpt 15 -nt 1
13:48:54:WU00:FS00:0xa7:Steps: first=3125000 total=125000
13:48:56:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
14:03:31:Saving configuration to config.xml
14:03:31:<config>
14:03:31: <!-- Network -->
14:03:31: <proxy v=':8080'/>
14:03:31:
14:03:31: <!-- Slot Control -->
14:03:31: <power v='full'/>
14:03:31:
14:03:31: <!-- User Information -->
14:03:31: <passkey v='********************************'/>
14:03:31: <team v='224497'/>
14:03:31: <user v='HowardStanley'/>
14:03:31:
14:03:31: <!-- Folding Slots -->
14:03:31: <slot id='0' type='CPU'/>
14:03:31:</config>
14:03:47:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
14:05:40:Saving configuration to config.xml
14:05:40:<config>
14:05:40: <!-- Folding Core -->
14:05:40: <checkpoint v='25'/>
14:05:40: <core-priority v='low'/>
14:05:40:
14:05:40: <!-- Network -->
14:05:40: <proxy v=':8080'/>
14:05:40:
14:05:40: <!-- Remote Command Server -->
14:05:40: <password v='*****************'/>
14:05:40:
14:05:40: <!-- Slot Control -->
14:05:40: <power v='full'/>
14:05:40:
14:05:40: <!-- User Information -->
14:05:40: <passkey v='********************************'/>
14:05:40: <team v='224497'/>
14:05:40: <user v='HowardStanley'/>
14:05:40:
14:05:40: <!-- Folding Slots -->
14:05:40: <slot id='0' type='CPU'/>
14:05:40:</config>
14:06:34:Saving configuration to config.xml
14:06:34:<config>
14:06:34: <!-- Folding Core -->
14:06:34: <checkpoint v='25'/>
14:06:34: <core-priority v='low'/>
14:06:34:
14:06:34: <!-- Network -->
14:06:34: <proxy v=':8080'/>
14:06:34:
14:06:34: <!-- Remote Command Server -->
14:06:34: <password v='*****************'/>
14:06:34:
14:06:34: <!-- Slot Control -->
14:06:34: <power v='full'/>
14:06:34:
14:06:34: <!-- User Information -->
14:06:34: <passkey v='********************************'/>
14:06:34: <team v='224497'/>
14:06:34: <user v='HowardStanley'/>
14:06:34:
14:06:34: <!-- Folding Slots -->
14:06:34: <slot id='0' type='CPU'/>
14:06:34:</config>
14:18:49:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
14:32:00:WU00:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
14:35:31:Adding folding slot 01: READY gpu:0:C79 [GeForce 9400M]
14:35:31:FS00:Shutting core down
14:35:31:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 29637
14:35:31:WU00:FS00:0xa7:Exiting, please wait. . .
14:35:31:WU01:FS01:Connecting to 65.254.110.245:8080
14:35:31:Adding folding slot 02: READY cpu:1
14:35:31:Saving configuration to config.xml
14:35:31:<config>
14:35:31: <!-- Folding Core -->
14:35:31: <checkpoint v='25'/>
14:35:31: <core-priority v='low'/>
14:35:31:
14:35:31: <!-- Network -->
14:35:31: <proxy v=':8080'/>
14:35:31:
14:35:31: <!-- Remote Command Server -->
14:35:31: <password v='*****************'/>
14:35:31:
14:35:31: <!-- Slot Control -->
14:35:31: <power v='full'/>
14:35:31:
14:35:31: <!-- User Information -->
14:35:31: <passkey v='********************************'/>
14:35:31: <team v='224497'/>
14:35:31: <user v='HowardStanley'/>
14:35:31:
14:35:31: <!-- Folding Slots -->
14:35:31: <slot id='1' type='GPU'/>
14:35:31: <slot id='2' type='CPU'/>
14:35:31:</config>
14:35:31:WU02:FS02:Connecting to 65.254.110.245:8080
14:35:31:WU01:FS01:Assigned to work server 192.0.2.1
14:35:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
14:35:31:WU01:FS01:Connecting to 192.0.2.1:8080
14:35:31:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:35:31:WU02:FS02:Connecting to 18.218.241.186:80
14:35:32:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:35:32:ERROR:WU02:FS02:Exception: Could not get an assignment
14:35:32:WU02:FS02:Connecting to 65.254.110.245:8080
14:35:32:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:35:32:WU02:FS02:Connecting to 18.218.241.186:80
14:35:33:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:35:33:ERROR:WU02:FS02:Exception: Could not get an assignment
14:35:44:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
14:35:45:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:35:46:WARNING:WU00:Slot ID 0 no longer exists, migrating to FS02
14:35:47:WU00:Starting
14:35:47:WU00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 29433 -checkpoint 25
14:35:47:WU00:Started FahCore on PID 29764
14:35:47:WU00:Core PID:29765
14:35:47:WU00:FahCore 0xa7 started
14:35:48:WU00:FS02:0xa7:*********************** Log Started 2020-04-06T14:35:47Z ***********************
14:35:48:WU00:FS02:0xa7:************************** Gromacs Folding@home Core ***************************
14:35:48:WU00:FS02:0xa7: Type: 0xa7
14:35:48:WU00:FS02:0xa7: Core: Gromacs
14:35:48:WU00:FS02:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 29764 -checkpoint 25
14:35:48:WU00:FS02:0xa7:************************************ CBang *************************************
14:35:48:WU00:FS02:0xa7: Date: Oct 26 2019
14:35:48:WU00:FS02:0xa7: Time: 03:00:47
14:35:48:WU00:FS02:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
14:35:48:WU00:FS02:0xa7: Branch: master
14:35:48:WU00:FS02:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
14:35:48:WU00:FS02:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
14:35:48:WU00:FS02:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
14:35:48:WU00:FS02:0xa7: Platform: darwin 19.0.0
14:35:48:WU00:FS02:0xa7: Bits: 64
14:35:48:WU00:FS02:0xa7: Mode: Release
14:35:48:WU00:FS02:0xa7:************************************ System ************************************
14:35:48:WU00:FS02:0xa7: CPU: Intel(R) Core(TM)2 Duo CPU P7550 @ 2.26GHz
14:35:48:WU00:FS02:0xa7: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
14:35:48:WU00:FS02:0xa7: CPUs: 2
14:35:48:WU00:FS02:0xa7: Memory: 4.00GiB
14:35:48:WU00:FS02:0xa7:Free Memory: 203.20MiB
14:35:48:WU00:FS02:0xa7: Threads: POSIX_THREADS
14:35:48:WU00:FS02:0xa7: OS Version: 10.12
14:35:48:WU00:FS02:0xa7:Has Battery: true
14:35:48:WU00:FS02:0xa7: On Battery: false
14:35:48:WU00:FS02:0xa7: UTC Offset: 1
14:35:48:WU00:FS02:0xa7: PID: 29765
14:35:48:WU00:FS02:0xa7: CWD: /Library/Application Support/FAHClient/work
14:35:48:WU00:FS02:0xa7:******************************** Build - libFAH ********************************
14:35:48:WU00:FS02:0xa7: Version: 0.0.18
14:35:48:WU00:FS02:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:35:48:WU00:FS02:0xa7: Copyright: 2019 foldingathome.org
14:35:48:WU00:FS02:0xa7: Homepage: https://foldingathome.org/
14:35:48:WU00:FS02:0xa7: Time: 03:06:42
14:35:48:WU00:FS02:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
14:35:48:WU00:FS02:0xa7:************************************ Build *************************************
14:35:48:WU00:FS02:0xa7: SIMD: sse2
14:35:48:WU00:FS02:0xa7:********************************************************************************
14:35:48:WU00:FS02:0xa7:Project: 13861 (Run 0, Clone 7026, Gen 25)
14:35:48:WU00:FS02:0xa7:Unit: 0x0000001f0d5a98395e730e764053514e
14:35:48:WU00:FS02:0xa7:Digital signatures verified
14:35:48:WU00:FS02:0xa7:Calling: mdrun -s frame25.tpr -o frame25.trr -x frame25.xtc -e frame25.edr -cpi state.cpt -cpt 25 -nt 1
14:35:48:WU00:FS02:0xa7:Steps: first=3125000 total=125000
14:35:51:WU00:FS02:0xa7:Completed 4042 out of 125000 steps (3%)
14:36:03:Saving configuration to config.xml
14:36:03:<config>
14:36:03: <!-- Folding Core -->
14:36:03: <checkpoint v='25'/>
14:36:03: <core-priority v='low'/>
14:36:03:
14:36:03: <!-- Network -->
14:36:03: <proxy v=':8080'/>
14:36:03:
14:36:03: <!-- Remote Command Server -->
14:36:03: <password v='*****************'/>
14:36:03:
14:36:03: <!-- Slot Control -->
14:36:03: <power v='full'/>
14:36:03:
14:36:03: <!-- User Information -->
14:36:03: <passkey v='********************************'/>
14:36:03: <team v='224497'/>
14:36:03: <user v='HowardStanley'/>
14:36:03:
14:36:03: <!-- Folding Slots -->
14:36:03: <slot id='1' type='GPU'/>
14:36:03: <slot id='2' type='CPU'/>
14:36:03:</config>
14:36:32:WU02:FS02:Connecting to 65.254.110.245:8080
14:36:33:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:36:33:WU02:FS02:Connecting to 18.218.241.186:80
14:36:33:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:36:33:ERROR:WU02:FS02:Exception: Could not get an assignment
14:36:46:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:36:46:WU01:FS01:Connecting to 192.0.2.1:80
14:38:02:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Operation timed out
14:38:02:WU01:FS01:Connecting to 65.254.110.245:8080
14:38:02:WU01:FS01:Assigned to work server 192.0.2.1
14:38:02:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
14:38:02:WU01:FS01:Connecting to 192.0.2.1:8080
14:38:09:WU02:FS02:Connecting to 65.254.110.245:8080
14:38:10:WU02:FS02:Assigned to work server 40.114.52.201
14:38:10:WU02:FS02:Requesting new work unit for slot 02: RUNNING cpu:1 from 40.114.52.201
14:38:10:WU02:FS02:Connecting to 40.114.52.201:8080
14:38:19:ERROR:WU02:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
14:39:17:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:39:17:WU01:FS01:Connecting to 192.0.2.1:80
14:40:33:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Operation timed out
14:40:33:WU01:FS01:Connecting to 65.254.110.245:8080
14:40:34:WU01:FS01:Assigned to work server 192.0.2.1
14:40:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
14:40:34:WU01:FS01:Connecting to 192.0.2.1:8080
14:40:47:WU02:FS02:Connecting to 65.254.110.245:8080
14:40:47:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:40:47:WU02:FS02:Connecting to 18.218.241.186:80
14:40:47:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:40:47:ERROR:WU02:FS02:Exception: Could not get an assignment
14:41:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:41:49:WU01:FS01:Connecting to 192.0.2.1:80
14:43:04:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Operation timed out
14:43:04:WU01:FS01:Connecting to 65.254.110.245:8080
14:43:05:WU01:FS01:Assigned to work server 192.0.2.1
14:43:05:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
14:43:05:WU01:FS01:Connecting to 192.0.2.1:8080
14:44:20:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:44:20:WU01:FS01:Connecting to 192.0.2.1:80
14:45:01:WU02:FS02:Connecting to 65.254.110.245:8080
14:45:01:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:45:01:WU02:FS02:Connecting to 18.218.241.186:80
14:45:02:WU02:FS02:Assigned to work server 150.136.14.110
14:45:02:WU02:FS02:Requesting new work unit for slot 02: RUNNING cpu:1 from 150.136.14.110
14:45:02:WU02:FS02:Connecting to 150.136.14.110:8080
14:45:02:WU02:FS02:Downloading 1.25MiB
14:45:03:WU02:FS02:Download complete
14:45:03:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16401 run:611 clone:1 gen:32 core:0xa7 unit:0x0000002296880e6e5e814cc814f186e9
14:45:35:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Operation timed out
14:45:42:WU01:FS01:Connecting to 65.254.110.245:8080
14:45:42:WU01:FS01:Assigned to work server 192.0.2.1
14:45:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
14:45:42:WU01:FS01:Connecting to 192.0.2.1:8080
14:45:53:WU00:FS02:0xa7:Completed 5000 out of 125000 steps (4%)
14:46:57:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:46:57:WU01:FS01:Connecting to 192.0.2.1:80
14:48:12:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Operation timed out
14:49:56:WU01:FS01:Connecting to 65.254.110.245:8080
14:49:56:WU01:FS01:Assigned to work server 192.0.2.1
14:49:56:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
14:49:56:WU01:FS01:Connecting to 192.0.2.1:8080
14:51:11:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:51:11:WU01:FS01:Connecting to 192.0.2.1:80
14:52:27:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Operation timed out
14:56:47:WU01:FS01:Connecting to 65.254.110.245:8080
14:56:48:WU01:FS01:Assigned to work server 192.0.2.1
14:56:48:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
14:56:48:WU01:FS01:Connecting to 192.0.2.1:8080
14:58:03:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:58:03:WU01:FS01:Connecting to 192.0.2.1:80
14:59:18:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Operation timed out
15:00:09:WU00:FS02:0xa7:Completed 6250 out of 125000 steps (5%)
15:07:53:WU01:FS01:Connecting to 65.254.110.245:8080
15:07:53:WU01:FS01:Assigned to work server 192.0.2.1
15:07:53:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
15:07:53:WU01:FS01:Connecting to 192.0.2.1:8080
15:09:08:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
15:09:08:WU01:FS01:Connecting to 192.0.2.1:80
15:10:23:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Operation timed out
15:12:54:WU00:FS02:0xa7:Completed 7500 out of 125000 steps (6%)
15:25:49:WU01:FS01:Connecting to 65.254.110.245:8080
15:25:50:WU01:FS01:Assigned to work server 192.0.2.1
15:25:50:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
15:25:50:WU01:FS01:Connecting to 192.0.2.1:8080
15:27:05:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
15:27:05:WU01:FS01:Connecting to 192.0.2.1:80
15:28:20:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Operation timed out
15:28:37:WU00:FS02:0xa7:Completed 8750 out of 125000 steps (7%)
15:48:24:WU00:FS02:0xa7:Completed 10000 out of 125000 steps (8%)
15:51:17:WARNING:WU00:FS02:Detected clock skew (1 mins 23 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
15:54:52:WU01:FS01:Connecting to 65.254.110.245:8080
15:54:52:WU01:FS01:Assigned to work server 192.0.2.1
15:54:52:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
15:54:52:WU01:FS01:Connecting to 192.0.2.1:8080
15:56:07:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
15:56:07:WU01:FS01:Connecting to 192.0.2.1:80
15:57:22:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Operation timed out
16:02:22:WU00:FS02:0xa7:Completed 11250 out of 125000 steps (9%)
16:15:23:WU00:FS02:0xa7:Completed 12500 out of 125000 steps (10%)
16:21:10:WU00:FS02:0xa7:Caught signal SIGTERM(15) on PID 29765
16:21:10:WU00:FS02:0xa7:Exiting, please wait. . .
16:21:18:WU00:FS02:0xa7:Folding@home Core Shutdown: INTERRUPTED
16:21:19:WU00:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
16:21:19:WU02:FS02:Starting
16:21:19:WU02:FS02:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 02 -suffix 01 -version 705 -lifeline 29433 -checkpoint 25 -np 1
16:21:19:WU02:FS02:Started FahCore on PID 30207
16:21:19:WU02:FS02:Core PID:30208
16:21:19:WU02:FS02:FahCore 0xa7 started
16:21:20:WU02:FS02:0xa7:*********************** Log Started 2020-04-06T16:21:19Z ***********************
16:21:20:WU02:FS02:0xa7:************************** Gromacs Folding@home Core ***************************
16:21:20:WU02:FS02:0xa7: Type: 0xa7
16:21:20:WU02:FS02:0xa7: Core: Gromacs
16:21:20:WU02:FS02:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 30207 -checkpoint 25 -np
16:21:20:WU02:FS02:0xa7: 1
16:21:20:WU02:FS02:0xa7:************************************ CBang *************************************
16:21:20:WU02:FS02:0xa7: Date: Oct 26 2019
16:21:20:WU02:FS02:0xa7: Time: 03:00:47
16:21:20:WU02:FS02:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
16:21:20:WU02:FS02:0xa7: Branch: master
16:21:20:WU02:FS02:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
16:21:20:WU02:FS02:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
16:21:20:WU02:FS02:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
16:21:20:WU02:FS02:0xa7: Platform: darwin 19.0.0
16:21:20:WU02:FS02:0xa7: Bits: 64
16:21:20:WU02:FS02:0xa7: Mode: Release
16:21:20:WU02:FS02:0xa7:************************************ System ************************************
16:21:20:WU02:FS02:0xa7: CPU: Intel(R) Core(TM)2 Duo CPU P7550 @ 2.26GHz
16:21:20:WU02:FS02:0xa7: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
16:21:20:WU02:FS02:0xa7: CPUs: 2
16:21:20:WU02:FS02:0xa7: Memory: 4.00GiB
16:21:20:WU02:FS02:0xa7:Free Memory: 326.38MiB
16:21:20:WU02:FS02:0xa7: Threads: POSIX_THREADS
16:21:20:WU02:FS02:0xa7: OS Version: 10.12
16:21:20:WU02:FS02:0xa7:Has Battery: true
16:21:20:WU02:FS02:0xa7: On Battery: false
16:21:20:WU02:FS02:0xa7: UTC Offset: 1
16:21:20:WU02:FS02:0xa7: PID: 30208
16:21:20:WU02:FS02:0xa7: CWD: /Library/Application Support/FAHClient/work
16:21:20:WU02:FS02:0xa7:******************************** Build - libFAH ********************************
16:21:20:WU02:FS02:0xa7: Version: 0.0.18
16:21:20:WU02:FS02:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:21:20:WU02:FS02:0xa7: Copyright: 2019 foldingathome.org
16:21:20:WU02:FS02:0xa7: Homepage: https://foldingathome.org/
16:21:20:WU02:FS02:0xa7: Time: 03:06:42
16:21:20:WU02:FS02:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
16:21:20:WU02:FS02:0xa7:************************************ Build *************************************
16:21:20:WU02:FS02:0xa7: SIMD: sse2
16:21:20:WU02:FS02:0xa7:********************************************************************************
16:21:20:WU02:FS02:0xa7:Project: 16401 (Run 611, Clone 1, Gen 32)
16:21:20:WU02:FS02:0xa7:Unit: 0x0000002296880e6e5e814cc814f186e9
16:21:20:WU02:FS02:0xa7:Reading tar file core.xml
16:21:20:WU02:FS02:0xa7:Reading tar file frame32.tpr
16:21:20:WU02:FS02:0xa7:Digital signatures verified
16:21:20:WU02:FS02:0xa7:Calling: mdrun -s frame32.tpr -o frame32.trr -x frame32.xtc -cpt 25 -nt 1
16:21:20:WU02:FS02:0xa7:Steps: first=16000000 total=500000
16:21:21:WU02:FS02:0xa7:Completed 1 out of 500000 steps (0%)
16:21:37:WU00:FS02:Starting
16:21:37:WU00:FS02:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 29433 -checkpoint 25
16:21:37:WU00:FS02:Started FahCore on PID 30209
16:21:37:WU00:FS02:Core PID:30210
16:21:37:WU00:FS02:FahCore 0xa7 started
16:21:38:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
16:21:39:WU00:FS02:0xa7:*********************** Log Started 2020-04-06T16:21:38Z ***********************
16:21:39:WU00:FS02:0xa7:************************** Gromacs Folding@home Core ***************************
16:21:39:WU00:FS02:0xa7: Type: 0xa7
16:21:39:WU00:FS02:0xa7: Core: Gromacs
16:21:39:WU00:FS02:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 30209 -checkpoint 25
16:21:39:WU00:FS02:0xa7:************************************ CBang *************************************
16:21:39:WU00:FS02:0xa7: Date: Oct 26 2019
16:21:39:WU00:FS02:0xa7: Time: 03:00:47
16:21:39:WU00:FS02:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
16:21:39:WU00:FS02:0xa7: Branch: master
16:21:39:WU00:FS02:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
16:21:39:WU00:FS02:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
16:21:39:WU00:FS02:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
16:21:39:WU00:FS02:0xa7: Platform: darwin 19.0.0
16:21:39:WU00:FS02:0xa7: Bits: 64
16:21:39:WU00:FS02:0xa7: Mode: Release
16:21:39:WU00:FS02:0xa7:************************************ System ************************************
16:21:39:WU00:FS02:0xa7: CPU: Intel(R) Core(TM)2 Duo CPU P7550 @ 2.26GHz
16:21:39:WU00:FS02:0xa7: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
16:21:39:WU00:FS02:0xa7: CPUs: 2
16:21:39:WU00:FS02:0xa7: Memory: 4.00GiB
16:21:39:WU00:FS02:0xa7:Free Memory: 302.27MiB
16:21:39:WU00:FS02:0xa7: Threads: POSIX_THREADS
16:21:39:WU00:FS02:0xa7: OS Version: 10.12
16:21:39:WU00:FS02:0xa7:Has Battery: true
16:21:39:WU00:FS02:0xa7: On Battery: false
16:21:39:WU00:FS02:0xa7: UTC Offset: 1
16:21:39:WU00:FS02:0xa7: PID: 30210
16:21:39:WU00:FS02:0xa7: CWD: /Library/Application Support/FAHClient/work
16:21:39:WU00:FS02:0xa7:******************************** Build - libFAH ********************************
16:21:39:WU00:FS02:0xa7: Version: 0.0.18
16:21:39:WU00:FS02:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:21:39:WU00:FS02:0xa7: Copyright: 2019 foldingathome.org
16:21:39:WU00:FS02:0xa7: Homepage: https://foldingathome.org/
16:21:39:WU00:FS02:0xa7: Time: 03:06:42
16:21:39:WU00:FS02:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
16:21:39:WU00:FS02:0xa7:************************************ Build *************************************
16:21:39:WU00:FS02:0xa7: SIMD: sse2
16:21:39:WU00:FS02:0xa7:********************************************************************************
16:21:39:WU00:FS02:0xa7:Project: 13861 (Run 0, Clone 7026, Gen 25)
16:21:39:WU00:FS02:0xa7:Unit: 0x0000001f0d5a98395e730e764053514e
16:21:39:WU00:FS02:0xa7:Digital signatures verified
16:21:39:WU00:FS02:0xa7:Calling: mdrun -s frame25.tpr -o frame25.trr -x frame25.xtc -e frame25.edr -cpi state.cpt -cpt 25 -nt 1
16:21:40:WU00:FS02:0xa7:Steps: first=3125000 total=125000
16:21:48:WU00:FS02:0xa7:Completed 12982 out of 125000 steps (10%)
16:34:11:WU00:FS02:0xa7:Completed 13750 out of 125000 steps (11%)
16:41:50:WU01:FS01:Connecting to 65.254.110.245:8080
16:41:51:WU01:FS01:Assigned to work server 192.0.2.1
16:41:51:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
16:41:51:WU01:FS01:Connecting to 192.0.2.1:8080
16:43:06:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
16:43:06:WU01:FS01:Connecting to 192.0.2.1:80
16:44:21:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Operation timed out
16:49:38:WU00:FS02:0xa7:Completed 15000 out of 125000 steps (12%)
17:02:32:WU00:FS02:0xa7:Completed 16250 out of 125000 steps (13%)
17:16:25:WU00:FS02:0xa7:Completed 17500 out of 125000 steps (14%)
17:30:11:WU00:FS02:0xa7:Completed 18750 out of 125000 steps (15%)
17:44:39:WU00:FS02:0xa7:Completed 20000 out of 125000 steps (16%)
17:57:45:WU00:FS02:0xa7:Completed 21250 out of 125000 steps (17%)
17:57:51:WU01:FS01:Connecting to 65.254.110.245:8080
17:57:52:WU01:FS01:Assigned to work server 192.0.2.1
17:57:52:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
17:57:52:WU01:FS01:Connecting to 192.0.2.1:8080
17:59:07:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:59:07:WU01:FS01:Connecting to 192.0.2.1:80
18:00:22:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Operation timed out
18:12:28:WU00:FS02:0xa7:Completed 22500 out of 125000 steps (18%)
18:25:38:WU00:FS02:0xa7:Completed 23750 out of 125000 steps (19%)
18:38:23:WU00:FS02:0xa7:Completed 25000 out of 125000 steps (20%)
18:51:30:WU00:FS02:0xa7:Completed 26250 out of 125000 steps (21%)
19:05:03:WU00:FS02:0xa7:Completed 27500 out of 125000 steps (22%)
19:18:46:WU00:FS02:0xa7:Completed 28750 out of 125000 steps (23%)
19:31:29:WU00:FS02:0xa7:Completed 30000 out of 125000 steps (24%)
******************************* Date: 2020-04-06 *******************************
19:44:40:WU00:FS02:0xa7:Completed 31250 out of 125000 steps (25%)
19:57:51:WU00:FS02:0xa7:Completed 32500 out of 125000 steps (26%)
20:00:51:WU01:FS01:Connecting to 65.254.110.245:8080
20:00:52:WU01:FS01:Assigned to work server 192.0.2.1
20:00:52:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
20:00:52:WU01:FS01:Connecting to 192.0.2.1:8080
20:02:07:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:02:07:WU01:FS01:Connecting to 192.0.2.1:80
20:03:22:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Operation timed out
20:11:39:WU00:FS02:0xa7:Completed 33750 out of 125000 steps (27%)
20:11:59:Saving configuration to config.xml
20:11:59:<config>
20:11:59: <!-- Folding Core -->
20:11:59: <checkpoint v='25'/>
20:11:59:
20:11:59: <!-- Network -->
20:11:59: <proxy v=':8080'/>
20:11:59:
20:11:59: <!-- Remote Command Server -->
20:11:59: <password v='*****************'/>
20:11:59:
20:11:59: <!-- Slot Control -->
20:11:59: <pause-on-battery v='false'/>
20:11:59: <power v='full'/>
20:11:59:
20:11:59: <!-- User Information -->
20:11:59: <passkey v='********************************'/>
20:11:59: <team v='224497'/>
20:11:59: <user v='HowardStanley'/>
20:11:59:
20:11:59: <!-- Folding Slots -->
20:11:59: <slot id='1' type='GPU'/>
20:11:59: <slot id='2' type='CPU'/>
20:11:59:</config>
20:12:36:Saving configuration to config.xml
20:12:36:<config>
20:12:36: <!-- Folding Core -->
20:12:36: <checkpoint v='25'/>
20:12:36:
20:12:36: <!-- Network -->
20:12:36: <proxy v=':8080'/>
20:12:36:
20:12:36: <!-- Remote Command Server -->
20:12:36: <password v='*****************'/>
20:12:36:
20:12:36: <!-- Slot Control -->
20:12:36: <pause-on-battery v='false'/>
20:12:36: <power v='full'/>
20:12:36:
20:12:36: <!-- User Information -->
20:12:36: <passkey v='********************************'/>
20:12:36: <team v='224497'/>
20:12:36: <user v='HowardStanley'/>
20:12:36:
20:12:36: <!-- Folding Slots -->
20:12:36: <slot id='1' type='GPU'/>
20:12:36: <slot id='2' type='CPU'/>
20:12:36:</config>
20:25:11:WU00:FS02:0xa7:Completed 35000 out of 125000 steps (28%)
20:38:33:WU00:FS02:0xa7:Completed 36250 out of 125000 steps (29%)
20:54:03:WU00:FS02:0xa7:Completed 37500 out of 125000 steps (30%)
21:07:49:WU00:FS02:0xa7:Completed 38750 out of 125000 steps (31%)
21:22:40:WU00:FS02:0xa7:Completed 40000 out of 125000 steps (32%)
21:38:21:WU00:FS02:0xa7:Completed 41250 out of 125000 steps (33%)
21:52:13:WU00:FS02:0xa7:Completed 42500 out of 125000 steps (34%)
22:06:14:WU00:FS02:0xa7:Completed 43750 out of 125000 steps (35%)
22:10:16:Caught signal SIGPIPE(13) on PID 29433
22:10:16:ERROR:Send error: 32: Broken pipe
22:22:21:WU00:FS02:0xa7:Completed 45000 out of 125000 steps (36%)
22:37:16:WU00:FS02:0xa7:Completed 46250 out of 125000 steps (37%)
22:54:27:WU00:FS02:0xa7:Completed 47500 out of 125000 steps (38%)
23:13:46:WU00:FS02:0xa7:Completed 48750 out of 125000 steps (39%)
23:19:52:WU01:FS01:Connecting to 65.254.110.245:8080
23:19:52:WU01:FS01:Assigned to work server 192.0.2.1
23:19:52:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:C79 [GeForce 9400M] from 192.0.2.1
Modsizeit: Added Code Tags - PantherX
m_vokhm
- Hardware configuration: CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz (4 kernels)
Memory: 16 GiB
No GPU - Location: Kurgan, Russia
I have the same question. I have installed the FAH client more than a week ago (2020.03.31), it has been working 24/7 since then, and it has completed and successfully uploaded tens of WUs, yet https://stats.foldingathome.org/donors shows nothing for me. https://apps.foldingathome.org/cpu shows "last credit" and "last returned" where figures change as new WUs get uploaded. The FAH client's log says "08:09:32:WU00:FS00:Server responded WORK_ACK (400)" every time a WU is uploaded. What may be the reason?
@HowardStanley
GPU folding isn't support on Mac so you can remove that GPU slot.
@m_vokhm
I would say that as long as you have successfully uploaded the WU, you will eventually get points. Currently, there a massive load on the F@H Server and thus, the points/stats are being impacted. Here's the graph which shows when the backlog of WUs were credited there was a massive spike and most donors got the missing WUs: https://apps.foldingathome.org/credit-log
@m_vokhm
m_vokhm
Memory: 16 GiB
OK, thanks.PantherX wrote: I would say that as long as you have successfully uploaded the WU, you will eventually get points.
HowardStanley
Ok thanks for clearing that upPantherX wrote:@HowardStanley
Mod Edit: Fixed Quote Tags - PantherX
