Hello
When I add an avatar image using Imgur, the forum says the link is invalid. Can you give me suggestions on any free image hosting sites that work?
Avatar image problems
MobileGamesMotion
- Hardware configuration: Windows 7, Intel i7-6600U CPU on a laptop
#StayAtHome #AlertNotAnxious #FoldForCOVID
Basic help stuff:viewtopic.php?f=61&t=26036 | Find Your Stats:https://stats.foldingathome.org/donors
https://folding.extremeoverclocking.com/
Re: Avatar image problems
Out of curiousity, are you meeting this requirement for your avatar?
Maximum dimensions; width: 80 pixels, height: 80 pixels, file size: 6.00 KiB.
You have to host your image somewhere that will provide direct link to it like "http://www.yourserver.com/yourimage.gif" ...
I'm not sure that free image hosts allow this.
comixgoddess
- Hardware configuration: MacBook Pro 2017
There are free image hosting sites that will work. I used Postimage and selected the "Direct link" option for my avatar.
Starduster
- Hardware configuration: Dell Optiplex 3020 SFF; Intel Core i7-4790, 16 GB mem, 512 Gb SSD; AMD Radeon Pro WX-2100, 2 GB.
Good morning. Thank you for allowing me to join the party. I have an avatar properly sized and ready to add to the team I fold for. Once I get access permissions from the team founder, how do I install it?
