PantherX , thank you!
Config:
ASRock Z87 Extreme3
Intel Core i5-4440
Sapphire Nitro+ Radeon RX 470 4GB (latest driver pack)
Hiper M500
16GB DDR3
here's the log file (RX470):
*********************** Log Started 2020-04-09T17:45:43Z ***********************
17:45:43:************************* Folding@home Client *************************
17:45:43: Website: https://foldingathome.org/
17:45:43: Copyright: (c) 2009-2018 foldingathome.org
17:45:43: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:45:43: Args:
17:45:43: Config: C:\Users\user\AppData\Roaming\FAHClient\config.xml
17:45:43:******************************** Build ********************************
17:45:43: Version: 7.5.1
17:45:43: Date: May 11 2018
17:45:43: Time: 13:06:32
17:45:43: Repository: Git
17:45:43: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
17:45:43: Branch: master
17:45:43: Compiler: Visual C++ 2008
17:45:43: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:45:43: Platform: win32 10
17:45:43: Bits: 32
17:45:43: Mode: Release
17:45:43:******************************* System ********************************
17:45:43: CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
17:45:43: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
17:45:43: CPUs: 4
17:45:43: Memory: 15.93GiB
17:45:43: Free Memory: 14.05GiB
17:45:43: Threads: WINDOWS_THREADS
17:45:43: OS Version: 6.1
17:45:43: Has Battery: false
17:45:43: On Battery: false
17:45:43: UTC Offset: 3
17:45:43: PID: 4156
17:45:43: CWD: C:\Users\user\AppData\Roaming\FAHClient
17:45:43: OS: Windows 7 Ultimate
17:45:43: OS Arch: AMD64
17:45:43: GPUs: 1
17:45:43: GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
17:45:43: 470/480/570/580/590]
17:45:43: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Не
17:45:43: найден указанный модуль.
17:45:43:
17:45:43:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
17:45:43: Win32 Service: false
17:45:43:***********************************************************************
17:45:43:<config>
17:45:43: <!-- Network -->
17:45:43: <proxy v=':8080'/>
17:45:43:
17:45:43: <!-- Slot Control -->
17:45:43: <power v='full'/>
17:45:43:
17:45:43: <!-- User Information -->
17:45:43: <passkey v='********************************'/>
17:45:43: <team v='224497'/>
17:45:43: <user v='SBPDreamer87'/>
17:45:43:
17:45:43: <!-- Folding Slots -->
17:45:43: <slot id='0' type='CPU'>
17:45:43: <paused v='true'/>
17:45:43: </slot>
17:45:43: <slot id='1' type='GPU'>
17:45:43: </slot>
17:45:43:</config>
17:45:43:Trying to access database...
17:45:43:Successfully acquired database lock
17:45:43:Enabled folding slot 00: PAUSED cpu:3 (by user)
17:45:43:Enabled folding slot 01: PAUSED gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] (by user)
18:44:16:FS00:Unpaused
18:44:16:FS01:Unpaused
18:44:17:WU00:FS00:Connecting to 65.254.110.245:8080
18:44:17:WU01:FS01:Connecting to 65.254.110.245:8080
18:44:17:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:44:17:WU00:FS00:Connecting to 18.218.241.186:80
18:44:17:WU01:FS01:Assigned to work server 140.163.4.231
18:44:17:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 140.163.4.231
18:44:17:WU01:FS01:Connecting to 140.163.4.231:8080
18:44:18:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:44:18:ERROR:WU00:FS00:Exception: Could not get an assignment
18:44:18:WU00:FS00:Connecting to 65.254.110.245:8080
18:44:19:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:44:19:WU00:FS00:Connecting to 18.218.241.186:80
18:44:19:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:44:19:ERROR:WU00:FS00:Exception: Could not get an assignment
18:44:41:Removing old file 'configs/config-20200408-121742.xml'
18:44:41:Saving configuration to config.xml
18:44:41:<config>
18:44:41: <!-- Network -->
18:44:41: <proxy v=':8080'/>
18:44:41:
18:44:41: <!-- Slot Control -->
18:44:41: <power v='full'/>
18:44:41:
18:44:41: <!-- User Information -->
18:44:41: <passkey v='********************************'/>
18:44:41: <team v='224497'/>
18:44:41: <user v='SBPDreamer87'/>
18:44:41:
18:44:41: <!-- Folding Slots -->
18:44:41: <slot id='0' type='CPU'/>
18:44:41: <slot id='1' type='GPU'/>
18:44:41:</config>
18:44:56:WU01:FS01:Downloading 7.93MiB
18:45:03:WU01:FS01:Download 12.62%
18:45:09:WU01:FS01:Download 44.94%
18:45:17:WU01:FS01:Download 51.25%
18:45:18:WU00:FS00:Connecting to 65.254.110.245:8080
18:45:19:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:45:19:WU00:FS00:Connecting to 18.218.241.186:80
18:45:19:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:45:19:ERROR:WU00:FS00:Exception: Could not get an assignment
18:45:23:WU01:FS01:Download 88.31%
18:45:25:WU01:FS01:Download complete
18:45:25:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11751 run:0 clone:2028 gen:21 core:0x22 unit:0x000000258ca304e75e6a80441a0c9a86
18:45:25:WU01:FS01:Starting
18:45:25:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\user\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 4156 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:45:25:WU01:FS01:Started FahCore on PID 5992
18:45:25:WU01:FS01:Core PID:5936
18:45:25:WU01:FS01:FahCore 0x22 started
18:45:25:WU01:FS01:0x22:*********************** Log Started 2020-04-09T18:45:25Z ***********************
18:45:25:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:45:25:WU01:FS01:0x22: Type: 0x22
18:45:25:WU01:FS01:0x22: Core: Core22
18:45:25:WU01:FS01:0x22: Website: https://foldingathome.org/
18:45:25:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
18:45:25:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:45:25:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
18:45:25:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 5992 -checkpoint 15
18:45:25:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:45:25:WU01:FS01:0x22: Config: <none>
18:45:25:WU01:FS01:0x22:************************************ Build *************************************
18:45:25:WU01:FS01:0x22: Version: 0.0.2
18:45:25:WU01:FS01:0x22: Date: Dec 6 2019
18:45:25:WU01:FS01:0x22: Time: 21:30:31
18:45:25:WU01:FS01:0x22: Repository: Git
18:45:25:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
18:45:25:WU01:FS01:0x22: Branch: HEAD
18:45:25:WU01:FS01:0x22: Compiler: Visual C++ 2008
18:45:25:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:45:25:WU01:FS01:0x22: Platform: win32 10
18:45:25:WU01:FS01:0x22: Bits: 64
18:45:25:WU01:FS01:0x22: Mode: Release
18:45:25:WU01:FS01:0x22:************************************ System ************************************
18:45:25:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
18:45:25:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:45:25:WU01:FS01:0x22: CPUs: 4
18:45:25:WU01:FS01:0x22: Memory: 15.93GiB
18:45:25:WU01:FS01:0x22:Free Memory: 10.29GiB
18:45:25:WU01:FS01:0x22: Threads: WINDOWS_THREADS
18:45:25:WU01:FS01:0x22: OS Version: 6.1
18:45:25:WU01:FS01:0x22:Has Battery: false
18:45:25:WU01:FS01:0x22: On Battery: false
18:45:25:WU01:FS01:0x22: UTC Offset: 3
18:45:25:WU01:FS01:0x22: PID: 5936
18:45:25:WU01:FS01:0x22: CWD: C:\Users\user\AppData\Roaming\FAHClient\work
18:45:25:WU01:FS01:0x22: OS: Windows 7 Ultimate Service Pack 1
18:45:25:WU01:FS01:0x22: OS Arch: AMD64
18:45:25:WU01:FS01:0x22:********************************************************************************
18:45:25:WU01:FS01:0x22:Project: 11751 (Run 0, Clone 2028, Gen 21)
18:45:25:WU01:FS01:0x22:Unit: 0x000000258ca304e75e6a80441a0c9a86
18:45:25:WU01:FS01:0x22:Reading tar file core.xml
18:45:25:WU01:FS01:0x22:Reading tar file integrator.xml
18:45:25:WU01:FS01:0x22:Reading tar file state.xml
18:45:26:WU01:FS01:0x22:Reading tar file system.xml
18:45:27:WU01:FS01:0x22:Digital signatures verified
18:45:27:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:45:27:WU01:FS01:0x22:Version 0.0.2
18:45:40:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
18:45:41:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:46:55:WU00:FS00:Connecting to 65.254.110.245:8080
18:46:56:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:46:56:WU00:FS00:Connecting to 18.218.241.186:80
18:46:56:WU00:FS00:Assigned to work server 155.247.164.214
18:46:56:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.164.214
18:46:56:WU00:FS00:Connecting to 155.247.164.214:8080
18:46:57:WU00:FS00:Downloading 139.00KiB
18:46:57:WU00:FS00:Download complete
18:46:57:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14372 run:682 clone:1 gen:26 core:0xa7 unit:0x0000001b9bf7a4d65e80c5ccdcf54164
18:46:57:WU00:FS00:Starting
18:46:57:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\user\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4156 -checkpoint 15 -np 3
18:46:57:WU00:FS00:Started FahCore on PID 5416
18:46:57:WU00:FS00:Core PID:6356
18:46:57:WU00:FS00:FahCore 0xa7 started
18:46:58:WU00:FS00:0xa7:*********************** Log Started 2020-04-09T18:46:57Z ***********************
18:46:58:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:46:58:WU00:FS00:0xa7: Type: 0xa7
18:46:58:WU00:FS00:0xa7: Core: Gromacs
18:46:58:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 5416 -checkpoint 15 -np 3
18:46:58:WU00:FS00:0xa7:************************************ CBang *************************************
18:46:58:WU00:FS00:0xa7: Date: Oct 26 2019
18:46:58:WU00:FS00:0xa7: Time: 01:38:25
18:46:58:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:46:58:WU00:FS00:0xa7: Branch: master
18:46:58:WU00:FS00:0xa7: Compiler: Visual C++ 2008
18:46:58:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:46:58:WU00:FS00:0xa7: Platform: win32 10
18:46:58:WU00:FS00:0xa7: Bits: 64
18:46:58:WU00:FS00:0xa7: Mode: Release
18:46:58:WU00:FS00:0xa7:************************************ System ************************************
18:46:58:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
18:46:58:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:46:58:WU00:FS00:0xa7: CPUs: 4
18:46:58:WU00:FS00:0xa7: Memory: 15.93GiB
18:46:58:WU00:FS00:0xa7:Free Memory: 9.83GiB
18:46:58:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
18:46:58:WU00:FS00:0xa7: OS Version: 6.1
18:46:58:WU00:FS00:0xa7:Has Battery: false
18:46:58:WU00:FS00:0xa7: On Battery: false
18:46:58:WU00:FS00:0xa7: UTC Offset: 3
18:46:58:WU00:FS00:0xa7: PID: 6356
18:46:58:WU00:FS00:0xa7: CWD: C:\Users\user\AppData\Roaming\FAHClient\work
18:46:58:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
18:46:58:WU00:FS00:0xa7: Version: 0.0.18
18:46:58:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:46:58:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
18:46:58:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
18:46:58:WU00:FS00:0xa7: Time: 01:52:30
18:46:58:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:46:58:WU00:FS00:0xa7:************************************ Build *************************************
18:46:58:WU00:FS00:0xa7: SIMD: avx_256
18:46:58:WU00:FS00:0xa7:********************************************************************************
18:46:58:WU00:FS00:0xa7:Project: 14372 (Run 682, Clone 1, Gen 26)
18:46:58:WU00:FS00:0xa7:Unit: 0x0000001b9bf7a4d65e80c5ccdcf54164
18:46:58:WU00:FS00:0xa7:Reading tar file core.xml
18:46:58:WU00:FS00:0xa7:Reading tar file frame26.tpr
18:46:58:WU00:FS00:0xa7:Digital signatures verified
18:46:58:WU00:FS00:0xa7:Calling: mdrun -s frame26.tpr -o frame26.trr -cpt 15 -nt 3
18:46:58:WU00:FS00:0xa7:Steps: first=0 total=2500000
18:46:58:WU00:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
18:47:43:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
18:49:11:WU00:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
18:49:44:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
18:51:23:WU00:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
18:51:45:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
18:53:40:WU00:FS00:0xa7:Completed 75000 out of 2500000 steps (3%)
18:53:47:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
18:55:48:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
18:55:55:WU00:FS00:0xa7:Completed 100000 out of 2500000 steps (4%)
18:57:58:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
18:58:09:WU00:FS00:0xa7:Completed 125000 out of 2500000 steps (5%)
19:00:15:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
19:00:30:WU00:FS00:0xa7:Completed 150000 out of 2500000 steps (6%)
19:02:54:WU00:FS00:0xa7:Completed 175000 out of 2500000 steps (7%)
19:02:55:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
19:05:05:WU00:FS00:0xa7:Completed 200000 out of 2500000 steps (8%)
19:05:10:WU01:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
19:07:16:WU00:FS00:0xa7:Completed 225000 out of 2500000 steps (9%)
19:07:24:WU01:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
19:09:27:WU00:FS00:0xa7:Completed 250000 out of 2500000 steps (10%)
19:09:31:WU01:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
Graph looked like this:
Without any overclock/undervolt I didn't notice the difference, that's why I tried undervolt - at least lower the temperature..
But I'm still looking for the "perfect" numbers for my cards
e.g. this log file and graph: -118 undervolt and 1236 mHZ
foldy wrote:It is expected that you do not get a constant load at 100% but more around 95% with drops
So that graph looks ok?
Why the CPU graph looks "better'?
foldy wrote:Maybe you can increase the power limit for your GPU and improve case cooling?
I'll try with the power limit but how many percent do I need to add?
foldy wrote:Hope you are not running on x1 risers which bottleneck on Windows.
No, I don't use them.
So you can use them in mining but to use them here is bad idea?
Also I noticed that
MEDIUM mode works better than
FULL mode
I checked it on 2 different computers with RX460 and RX470
UPD:
2nd PC Config:
Asus P8H61-M LX R2.0
I5 2400
RX 460 4GB
DDR3 4GB
RX 460 log file and graph (without overclock and undervolt):
20:14:34:WU00:FS01:0x22:*********************** Log Started 2020-04-08T20:14:33Z ***********************
20:14:34:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:14:34:WU00:FS01:0x22: Type: 0x22
20:14:34:WU00:FS01:0x22: Core: Core22
20:14:34:WU00:FS01:0x22: Website: https://foldingathome.org/
20:14:34:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:14:34:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:14:34:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:14:34:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 5108 -checkpoint 15
20:14:34:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:14:34:WU00:FS01:0x22: Config: <none>
20:14:34:WU00:FS01:0x22:************************************ Build *************************************
20:14:34:WU00:FS01:0x22: Version: 0.0.2
20:14:34:WU00:FS01:0x22: Date: Dec 6 2019
20:14:34:WU00:FS01:0x22: Time: 21:30:31
20:14:34:WU00:FS01:0x22: Repository: Git
20:14:34:WU00:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:14:34:WU00:FS01:0x22: Branch: HEAD
20:14:34:WU00:FS01:0x22: Compiler: Visual C++ 2008
20:14:34:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:14:34:WU00:FS01:0x22: Platform: win32 10
20:14:34:WU00:FS01:0x22: Bits: 64
20:14:34:WU00:FS01:0x22: Mode: Release
20:14:34:WU00:FS01:0x22:************************************ System ************************************
20:14:34:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
20:14:34:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
20:14:34:WU00:FS01:0x22: CPUs: 4
20:14:34:WU00:FS01:0x22: Memory: 3.95GiB
20:14:34:WU00:FS01:0x22:Free Memory: 2.38GiB
20:14:34:WU00:FS01:0x22: Threads: WINDOWS_THREADS
20:14:34:WU00:FS01:0x22: OS Version: 6.1
20:14:34:WU00:FS01:0x22:Has Battery: false
20:14:34:WU00:FS01:0x22: On Battery: false
20:14:34:WU00:FS01:0x22: UTC Offset: 4
20:14:34:WU00:FS01:0x22: PID: 3088
20:14:34:WU00:FS01:0x22: CWD: C:\Users\5555\AppData\Roaming\FAHClient\work
20:14:34:WU00:FS01:0x22: OS: Windows 7 Ultimate Service Pack 1
20:14:34:WU00:FS01:0x22: OS Arch: AMD64
20:14:34:WU00:FS01:0x22:********************************************************************************
20:14:34:WU00:FS01:0x22:Project: 11744 (Run 0, Clone 9232, Gen 33)
20:14:34:WU00:FS01:0x22:Unit: 0x000000318ca304f15e6bc3f244cfab03
20:14:34:WU00:FS01:0x22:Reading tar file core.xml
20:14:34:WU00:FS01:0x22:Reading tar file integrator.xml
20:14:34:WU00:FS01:0x22:Reading tar file state.xml
20:14:35:WU00:FS01:0x22:Reading tar file system.xml
20:14:35:WU00:FS01:0x22:Digital signatures verified
20:14:35:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:14:35:WU00:FS01:0x22:Version 0.0.2
20:15:01:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
20:15:01:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:15:54:WU01:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
20:18:05:WU01:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
20:18:40:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
20:20:17:WU01:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
20:22:20:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
20:22:28:WU01:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
20:24:38:WU01:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
20:25:57:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
20:26:49:WU01:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
20:28:59:WU01:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
20:29:33:WU00:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
20:31:10:WU01:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
20:33:10:WU00:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
20:33:21:WU01:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
20:35:32:WU01:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
