OpenCL not detected on GTX 1660 Super Windows 10
Driver issues associated with the Windows 10 roll-out
jakeii
Hardware configuration: NVIDIA GTX 1660 Super
Post by jakeii »
I can't seem to get my GPU Folding, OpenCL should be working right?
I have the latest drivers and CUDA toolkit from nvidia.
Managed to fold one time a few days ago without it:
*********************** Log Started 2020-03-16T21:47:04Z ***********************
21:47:04:************************* Folding@home Client *************************
21:47:04:      Website: https://foldingathome.org/
21:47:04:    Copyright: (c) 2009-2018 foldingathome.org
21:47:04:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:47:04:         Args: --open-web-control
21:47:04:       Config: C:\Users\Jake\AppData\Roaming\FAHClient\config.xml
21:47:04:******************************** Build ********************************
21:47:04:      Version: 7.5.1
21:47:04:         Date: May 11 2018
21:47:04:         Time: 13:06:32
21:47:04:   Repository: Git
21:47:04:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
21:47:04:       Branch: master
21:47:04:     Compiler: Visual C++ 2008
21:47:04:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:47:04:     Platform: win32 10
21:47:04:         Bits: 32
21:47:04:         Mode: Release
21:47:04:******************************* System ********************************
21:47:04:          CPU: Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
21:47:04:       CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
21:47:04:         CPUs: 4
21:47:04:       Memory: 7.86GiB
21:47:04:  Free Memory: 2.98GiB
21:47:04:      Threads: WINDOWS_THREADS
21:47:04:   OS Version: 6.2
21:47:04:  Has Battery: false
21:47:04:   On Battery: false
21:47:04:   UTC Offset: 0
21:47:04:          PID: 6348
21:47:04:          CWD: C:\Users\Jake\AppData\Roaming\FAHClient
21:47:04:           OS: Windows 10 Enterprise
21:47:04:      OS Arch: AMD64
21:47:04:         GPUs: 1
21:47:04:        GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU116 [GeForce GTX 1660 SUPER]
21:47:04:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
21:47:04:       OpenCL: Not detected: clGetDeviceIDs() returned -1
21:47:04:Win32 Service: false
21:47:04:***********************************************************************
21:47:04:<config>
21:47:04:  <!-- Folding Slot Configuration -->
21:47:04:  <opencl-index v='0'/>
21:47:04:
21:47:04:  <!-- Network -->
21:47:04:  <proxy v=':8080'/>
21:47:04:
21:47:04:  <!-- Slot Control -->
21:47:04:  <power v='FULL'/>
21:47:04:
21:47:04:  <!-- User Information -->
21:47:04:  <user v='Jakeii'/>
21:47:04:
21:47:04:  <!-- Folding Slots -->
21:47:04:  <slot id='1' type='GPU'/>
21:47:04:</config>
21:47:04:Trying to access database...
21:47:04:Successfully acquired database lock
21:47:04:Enabled folding slot 01: READY gpu:0:TU116 [GeForce GTX 1660 SUPER]
21:47:04:WU00:FS01:Starting
21:47:04:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
21:48:05:WU00:FS01:Starting
21:48:05:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
21:49:42:WU00:FS01:Starting
21:49:42:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
21:51:13:Saving configuration to config.xml
21:51:13:<config>
21:51:13:  <!-- Folding Slot Configuration -->
21:51:13:  <opencl-index v='0'/>
21:51:13:
21:51:13:  <!-- Network -->
21:51:13:  <proxy v=':8080'/>
21:51:13:
21:51:13:  <!-- Slot Control -->
21:51:13:  <power v='FULL'/>
21:51:13:
21:51:13:  <!-- User Information -->
21:51:13:  <user v='Jakeii'/>
21:51:13:
21:51:13:  <!-- Folding Slots -->
21:51:13:  <slot id='1' type='GPU'/>
21:51:13:</config>
21:52:19:WU00:FS01:Starting
21:52:19:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jake\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 6348 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
21:52:19:WU00:FS01:Started FahCore on PID 19828
21:52:19:WU00:FS01:Core PID:9460
21:52:19:WU00:FS01:FahCore 0x22 started
21:52:20:WU00:FS01:0x22:*********************** Log Started 2020-03-16T21:52:20Z ***********************
21:52:20:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:52:20:WU00:FS01:0x22:       Type: 0x22
21:52:20:WU00:FS01:0x22:       Core: Core22
21:52:20:WU00:FS01:0x22:    Website: https://foldingathome.org/
21:52:20:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:52:20:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:52:20:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:52:20:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 19828 -checkpoint 15
21:52:20:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
21:52:20:WU00:FS01:0x22:     Config: <none>
21:52:20:WU00:FS01:0x22:************************************ Build *************************************
21:52:20:WU00:FS01:0x22:    Version: 0.0.2
21:52:20:WU00:FS01:0x22:       Date: Dec 6 2019
21:52:20:WU00:FS01:0x22:       Time: 21:30:31
21:52:20:WU00:FS01:0x22: Repository: Git
21:52:20:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:52:20:WU00:FS01:0x22:     Branch: HEAD
21:52:20:WU00:FS01:0x22:   Compiler: Visual C++ 2008
21:52:20:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:52:20:WU00:FS01:0x22:   Platform: win32 10
21:52:20:WU00:FS01:0x22:       Bits: 64
21:52:20:WU00:FS01:0x22:       Mode: Release
21:52:20:WU00:FS01:0x22:************************************ System ************************************
21:52:20:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
21:52:20:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
21:52:20:WU00:FS01:0x22:       CPUs: 4
21:52:20:WU00:FS01:0x22:     Memory: 7.86GiB
21:52:20:WU00:FS01:0x22:Free Memory: 2.96GiB
21:52:20:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:52:20:WU00:FS01:0x22: OS Version: 6.2
21:52:20:WU00:FS01:0x22:Has Battery: false
21:52:20:WU00:FS01:0x22: On Battery: false
21:52:20:WU00:FS01:0x22: UTC Offset: 0
21:52:20:WU00:FS01:0x22:        PID: 9460
21:52:20:WU00:FS01:0x22:        CWD: C:\Users\Jake\AppData\Roaming\FAHClient\work
21:52:20:WU00:FS01:0x22:         OS: Windows 10 Pro
21:52:20:WU00:FS01:0x22:    OS Arch: AMD64
21:52:20:WU00:FS01:0x22:********************************************************************************
21:52:20:WU00:FS01:0x22:Project: 11759 (Run 0, Clone 12627, Gen 1)
21:52:20:WU00:FS01:0x22:Unit: 0x0000000180fccb0a5e6ebdebb98b23ed
21:52:20:WU00:FS01:0x22:Reading tar file core.xml
21:52:20:WU00:FS01:0x22:Reading tar file integrator.xml
21:52:20:WU00:FS01:0x22:Reading tar file state.xml
21:52:21:WU00:FS01:0x22:Reading tar file system.xml
21:52:22:WU00:FS01:0x22:Digital signatures verified
21:52:22:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:52:22:WU00:FS01:0x22:Version 0.0.2
21:52:48:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
21:52:48:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:53:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:53:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:54:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:54:56:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
21:57:02:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
21:58:25:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:58:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:58:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:59:09:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
21:59:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:59:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:59:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
22:00:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
22:00:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
22:00:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
22:00:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
22:00:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
22:01:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
22:01:20:WU00:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
22:01:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
22:01:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
22:03:20:Saving configuration to config.xml
22:03:20:<config>
22:03:20:  <!-- Folding Slot Configuration -->
22:03:20:  <opencl-index v='0'/>
22:03:20:
22:03:20:  <!-- Network -->
22:03:20:  <proxy v=':8080'/>
22:03:20:
22:03:20:  <!-- User Information -->
22:03:20:  <user v='Jakeii'/>
22:03:20:
22:03:20:  <!-- Folding Slots -->
22:03:20:  <slot id='1' type='GPU'/>
22:03:20:</config>
22:03:28:WU00:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
22:05:40:WU00:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
22:07:45:WU00:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
22:09:52:WU00:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
22:12:02:WU00:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
22:14:07:WU00:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
22:16:18:WU00:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
22:18:24:WU00:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
22:20:31:WU00:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
22:22:07:FS01:Finishing
22:22:39:WU00:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
22:24:45:WU00:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
22:26:58:WU00:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
22:29:04:WU00:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
22:31:10:WU00:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
22:33:16:WU00:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
22:35:21:WU00:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
22:37:34:WU00:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
22:39:42:WU00:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
22:41:47:WU00:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
22:43:53:WU00:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
22:45:59:WU00:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
22:48:12:WU00:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
22:50:18:WU00:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
22:52:24:WU00:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
22:54:30:WU00:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
22:56:36:WU00:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
22:58:47:WU00:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
23:00:52:WU00:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
23:02:57:WU00:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
23:05:02:WU00:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
23:07:07:WU00:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
23:09:18:WU00:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
23:11:23:WU00:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
23:13:28:WU00:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
23:15:32:WU00:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
23:17:37:WU00:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
23:19:49:WU00:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
23:21:54:WU00:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
23:23:59:WU00:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
23:26:03:WU00:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
23:28:08:WU00:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
23:30:19:WU00:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
23:32:24:WU00:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
23:34:29:WU00:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
23:36:33:WU00:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
23:38:38:WU00:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
23:40:49:WU00:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
23:42:54:WU00:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
23:44:59:WU00:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
23:47:04:WU00:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
23:49:09:WU00:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
23:51:20:WU00:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
23:53:25:WU00:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
23:55:30:WU00:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
23:57:35:WU00:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
23:59:39:WU00:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
00:01:50:WU00:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
00:03:55:WU00:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
00:06:00:WU00:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
00:08:05:WU00:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
00:10:10:WU00:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
00:12:21:WU00:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
00:14:26:WU00:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
00:16:31:WU00:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
00:18:35:WU00:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
00:20:40:WU00:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
00:22:52:WU00:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
00:24:56:WU00:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
00:27:01:WU00:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
00:29:06:WU00:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
00:31:11:WU00:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
00:33:22:WU00:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
00:35:27:WU00:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
00:37:32:WU00:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
00:39:36:WU00:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
00:41:41:WU00:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
00:43:52:WU00:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
00:45:57:WU00:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
00:48:02:WU00:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
00:50:07:WU00:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
00:52:11:WU00:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
00:54:23:WU00:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
00:56:28:WU00:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
00:58:33:WU00:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
01:00:38:WU00:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
01:02:43:WU00:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
01:04:55:WU00:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
01:07:00:WU00:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
01:09:05:WU00:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
01:11:10:WU00:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
01:13:15:WU00:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
01:15:27:WU00:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
01:17:32:WU00:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
01:19:37:WU00:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
01:21:42:WU00:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
01:23:47:WU00:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
01:23:54:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
01:23:54:WU00:FS01:0x22:Saving result file checkpointState.xml
01:23:54:WU00:FS01:0x22:Saving result file checkpt.crc
01:23:54:WU00:FS01:0x22:Saving result file positions.xtc
01:23:54:WU00:FS01:0x22:Saving result file science.log
01:23:54:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
01:23:56:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:23:56:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11759 run:0 clone:12627 gen:1 core:0x22 unit:0x0000000180fccb0a5e6ebdebb98b23ed
01:23:56:WU00:FS01:Uploading 49.92MiB to 128.252.203.10
01:23:56:WU00:FS01:Connecting to 128.252.203.10:8080
01:24:23:WU00:FS01:Upload 0.63%
01:24:29:WU00:FS01:Upload 5.88%
01:24:35:WU00:FS01:Upload 11.39%
01:24:41:WU00:FS01:Upload 16.90%
01:24:47:WU00:FS01:Upload 22.16%
01:24:53:WU00:FS01:Upload 28.17%
01:24:59:WU00:FS01:Upload 34.80%
01:25:05:WU00:FS01:Upload 41.56%
01:25:11:WU00:FS01:Upload 48.20%
01:25:17:WU00:FS01:Upload 54.84%
01:25:23:WU00:FS01:Upload 61.60%
01:25:29:WU00:FS01:Upload 68.23%
01:25:35:WU00:FS01:Upload 74.87%
01:25:41:WU00:FS01:Upload 81.25%
01:25:47:WU00:FS01:Upload 87.64%
01:25:53:WU00:FS01:Upload 94.27%
01:25:59:WU00:FS01:Upload complete
01:25:59:WU00:FS01:Server responded WORK_ACK (400)
01:25:59:WU00:FS01:Final credit estimate, 95187.00 points
01:25:59:WU00:FS01:Cleaning up
But Now nope:
*********************** Log Started 2020-04-06T20:30:31Z ***********************
20:30:31:************************* Folding@home Client *************************
20:30:31:      Website: https://foldingathome.org/
20:30:31:    Copyright: (c) 2009-2018 foldingathome.org
20:30:31:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:30:31:         Args: --open-web-control
20:30:31:       Config: C:\Users\Jake\AppData\Roaming\FAHClient\config.xml
20:30:31:******************************** Build ********************************
20:30:31:      Version: 7.5.1
20:30:31:         Date: May 11 2018
20:30:31:         Time: 13:06:32
20:30:31:   Repository: Git
20:30:31:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:30:31:       Branch: master
20:30:31:     Compiler: Visual C++ 2008
20:30:31:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:30:31:     Platform: win32 10
20:30:31:         Bits: 32
20:30:31:         Mode: Release
20:30:31:******************************* System ********************************
20:30:31:          CPU: Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
20:30:31:       CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
20:30:31:         CPUs: 4
20:30:31:       Memory: 7.93GiB
20:30:31:  Free Memory: 4.42GiB
20:30:31:      Threads: WINDOWS_THREADS
20:30:31:   OS Version: 6.2
20:30:31:  Has Battery: false
20:30:31:   On Battery: false
20:30:31:   UTC Offset: 1
20:30:31:          PID: 16716
20:30:31:          CWD: C:\Users\Jake\AppData\Roaming\FAHClient
20:30:31:           OS: Windows 10 Enterprise
20:30:31:      OS Arch: AMD64
20:30:31:         GPUs: 1
20:30:31:        GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU116 [GeForce GTX 1660 SUPER]
20:30:31:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
20:30:31:       OpenCL: Not detected: clGetDeviceIDs() returned -1
20:30:31:Win32 Service: false
20:30:31:***********************************************************************
20:30:31:<config>
20:30:31:  <!-- Network -->
20:30:31:  <proxy v=':8080'/>
20:30:31:
20:30:31:  <!-- User Information -->
20:30:31:  <user v='Jakeii'/>
20:30:31:
20:30:31:  <!-- Folding Slots -->
20:30:31:  <slot id='1' type='GPU'/>
20:30:31:</config>
20:30:31:Trying to access database...
20:30:31:Successfully acquired database lock
20:30:31:Enabled folding slot 01: READY gpu:0:TU116 [GeForce GTX 1660 SUPER]
20:30:31:WU00:FS01:Connecting to 65.254.110.245:8080
20:30:32:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:30:32:WU00:FS01:Connecting to 18.218.241.186:80
20:30:32:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:30:33:ERROR:WU00:FS01:Exception: Could not get an assignment
20:30:33:WU00:FS01:Connecting to 65.254.110.245:8080
20:30:33:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:30:33:WU00:FS01:Connecting to 18.218.241.186:80
20:30:34:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:30:34:ERROR:WU00:FS01:Exception: Could not get an assignment
20:31:27:10:127.0.0.1:New Web connection
20:31:33:WU00:FS01:Connecting to 65.254.110.245:8080
20:31:33:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:31:33:WU00:FS01:Connecting to 18.218.241.186:80
20:31:33:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:31:34:ERROR:WU00:FS01:Exception: Could not get an assignment
20:33:10:WU00:FS01:Connecting to 65.254.110.245:8080
20:33:10:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:33:10:WU00:FS01:Connecting to 18.218.241.186:80
20:33:11:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:33:11:ERROR:WU00:FS01:Exception: Could not get an assignment
20:35:47:WU00:FS01:Connecting to 65.254.110.245:8080
20:35:48:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:35:48:WU00:FS01:Connecting to 18.218.241.186:80
20:35:48:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:35:48:ERROR:WU00:FS01:Exception: Could not get an assignment
20:40:02:WU00:FS01:Connecting to 65.254.110.245:8080
20:40:02:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:40:02:WU00:FS01:Connecting to 18.218.241.186:80
20:40:02:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:40:02:ERROR:WU00:FS01:Exception: Could not get an assignment
20:46:53:WU00:FS01:Connecting to 65.254.110.245:8080
20:46:53:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:46:53:WU00:FS01:Connecting to 18.218.241.186:80
20:46:54:WU00:FS01:Assigned to work server 13.90.152.57
20:46:54:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660 SUPER] from 13.90.152.57
20:46:54:WU00:FS01:Connecting to 13.90.152.57:8080
20:46:55:WU00:FS01:Downloading 86.24MiB
20:47:01:WU00:FS01:Download 4.86%
20:47:07:WU00:FS01:Download 10.36%
20:47:13:WU00:FS01:Download 15.87%
20:47:19:WU00:FS01:Download 21.24%
20:47:25:WU00:FS01:Download 26.74%
20:47:31:WU00:FS01:Download 31.96%
20:47:37:WU00:FS01:Download 37.47%
20:47:43:WU00:FS01:Download 42.62%
20:47:49:WU00:FS01:Download 48.05%
20:47:55:WU00:FS01:Download 53.20%
20:48:01:WU00:FS01:Download 58.27%
20:48:07:WU00:FS01:Download 63.71%
20:48:13:WU00:FS01:Download 69.21%
20:48:19:WU00:FS01:Download 74.50%
20:48:25:WU00:FS01:Download 79.79%
20:48:31:WU00:FS01:Download 83.78%
20:48:37:WU00:FS01:Download 89.14%
20:48:43:WU00:FS01:Download 94.51%
20:48:49:WU00:FS01:Download 99.87%
20:48:49:WU00:FS01:Download complete
20:48:49:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11781 run:0 clone:5963 gen:28 core:0x22 unit:0x000000350d5a98395e758905a7e72a00
20:48:49:WU00:FS01:Starting
20:48:49:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
20:49:49:WU00:FS01:Starting
20:49:49:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
20:51:26:WU00:FS01:Starting
20:51:26:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
20:54:04:WU00:FS01:Starting
20:54:04:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
20:58:18:WU00:FS01:Starting
20:58:18:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
20:58:18:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:11781 run:0 clone:5963 gen:28 core:0x22 unit:0x000000350d5a98395e758905a7e72a00
20:58:18:WU00:FS01:Connecting to 13.90.152.57:8080
20:58:18:WU00:FS01:Server responded WORK_ACK (400)
20:58:18:WU00:FS01:Cleaning up
Re: OpenCL not detected on GTX 1660 Super Windows 10
Post by foldy »
Download driver from nvidia.com manually and install. That should bring OpenCL
Check to see if MS Windows Update downloaded and installed a new driver for you after you did your initial installation. Their driver would not include OpenCL support, and even if it does not remove the support, the version may no longer match the driver.
jakeii
Post by jakeii »
Thanks guys, tried that (and again with the link from @JimboPalmer), but no change.
We are in over my head, But i bet that somewhere there is a log with errors during the driver install.
https://nvidia.custhelp.com/app/answers ... er-logging
Hopefully that would show why OpenCL was not installed. (I have never tried it, never needed it)
uyaem
Post by uyaem »
This may be way out, but open nvidia's control panel and check if you accepted the license.
I had a similar experience when my laptop was new.
I had a new thought, GPU-Z detect OpenCL near the bottom of the main screen. If you run it and it is not there you have an Nvidia problem, If it is there, perhaps F@H is wrong.
I have a couple of thoughts.
In Windows, sometimes the OpenCL downloaded from nVidia is the only installed and FAH seems always able to detect i. Microsoft also has a version that works well with the Intel iGPU but not with FAH. When more than on version is present, there's a registry entry that indexes which one is active. The recommended procedure to make it work is to uninstall the Intel version but there might be another way.
For Linux, as you install varous versions of OpenCL, each one has a number and there's a link from the unnumbered name to the preferred version. You still can be pointing to the "wrong" one.
I don't know how GPU-Z decides a True/False indication when there are multiple copies and one or more DOESN'T work
jakeii
Post by jakeii »
JimboPalmer wrote:I had a new thought, GPU-Z detect OpenCL near the bottom of the main screen. If you run it and it is not there you have an Nvidia problem, If it is there, perhaps F@H is wrong.
OpenCL is definitely there:
bruce wrote:I have a couple of thoughts.
You might be on to something, I did have the integrated GPU enabled at one point.
kostuek
Post by kostuek »
Did you try to set opencl-index manually like suggested in the log?
jakeii
Post by jakeii »
I found in the registry where OpenCL is configured with Bruce's suggestion
Source - https://stackoverflow.com/questions/352 ... on-windows
Neither of these look NVIDIAey
First looks like for AMD (my old GPU) second looks like for Intel?
jakeii
Post by jakeii »
I deleted the AMD looking registry key and now FAH is detecting OpenCL!
Thanks for the suggestion bruce, led me down the right path!
