yesterday I noticed this WU that finished 100% than fah core 22 crashed on GPU slot (only one I'm running) and started over again from zero. I'm wondering if something is bad on my side or is it faulty WU?
I removed the slot / dumped the WU because I did not wanted my machine to be stucked on this one WU. Other than this and occasional clEnqueueNDRangeKernel (-5) BAD_WORK_UNIT error (AMD driver issue for specific atom count?) fah is running without problems (until I start playing with GPU voltages
Error lines:
21:51:36:WU00:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
21:51:39:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:51:39:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740940 = 0xc0000374)
CPU is not OC
GPU is undervolted and stable, wotking at cca. 65-70°C (no thermal issues)
*********************** Log Started 2020-04-06T17:02:44Z ***********************
17:02:44:************************* Folding@home Client *************************
17:02:44: Website: https://foldingathome.org/
17:02:44: Copyright: (c) 2009-2018 foldingathome.org
17:02:44: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:02:44: Args:
17:02:44: Config: C:\Users\Kiklouni\AppData\Roaming\FAHClient\config.xml
17:02:44:******************************** Build ********************************
17:02:44: Version: 7.5.1
17:02:44: Date: May 11 2018
17:02:44: Time: 13:06:32
17:02:44: Repository: Git
17:02:44: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
17:02:44: Branch: master
17:02:44: Compiler: Visual C++ 2008
17:02:44: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:02:44: Platform: win32 10
17:02:44: Bits: 32
17:02:44: Mode: Release
17:02:44:******************************* System ********************************
17:02:44: CPU: Intel(R) Core(TM) i3-4170 CPU @ 3.70GHz
17:02:44: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
17:02:44: CPUs: 4
17:02:44: Memory: 7.94GiB
17:02:44: Free Memory: 5.59GiB
17:02:44: Threads: WINDOWS_THREADS
17:02:44: OS Version: 6.2
17:02:44: Has Battery: false
17:02:44: On Battery: false
17:02:44: UTC Offset: 2
17:02:44: PID: 8104
17:02:44: CWD: C:\Users\Kiklouni\AppData\Roaming\FAHClient
17:02:44: OS: Windows 10 Home
17:02:44: OS Arch: AMD64
17:02:44: GPUs: 1
17:02:44: GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
17:02:44: 470/480/570/580]
17:02:44: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
17:02:44: Uvedený modul nebyl nalezen.
17:02:44:
17:02:44:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
17:02:44: Win32 Service: false
17:02:44:***********************************************************************
17:02:44:<config>
17:02:44: <!-- Folding Core -->
17:02:44: <checkpoint v='10'/>
17:02:44:
17:02:44: <!-- HTTP Server -->
17:02:44: <allow v='127.0.0.1 192.168.0.0/24'/>
17:02:44:
17:02:44: <!-- Network -->
17:02:44: <proxy v=':8080'/>
17:02:44:
17:02:44: <!-- Remote Command Server -->
17:02:44: <command-allow-no-pass v='127.0.0.1 192.168.0.0/24'/>
17:02:44:
17:02:44: <!-- User Information -->
17:02:44: <passkey v='********************************'/>
17:02:44: <team v='236157'/>
17:02:44: <user v='EduardoCZ'/>
17:02:44:
17:02:44: <!-- Folding Slots -->
17:02:44: <slot id='0' type='GPU'>
17:02:44: <gpu-index v='0'/>
17:02:44: </slot>
17:02:44:</config>
17:02:44:Trying to access database...
17:02:44:Successfully acquired database lock
17:02:44:Enabled folding slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580]
17:02:44:WU00:FS00:Connecting to 65.254.110.245:8080
17:02:45:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:02:45:WU00:FS00:Connecting to 18.218.241.186:80
17:02:47:WU00:FS00:Assigned to work server 128.252.203.10
17:02:47:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 128.252.203.10
17:02:47:WU00:FS00:Connecting to 128.252.203.10:8080
17:03:08:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
17:03:08:WU00:FS00:Connecting to 128.252.203.10:80
17:04:11:WU00:FS00:Downloading 29.59MiB
17:04:17:WU00:FS00:Download 9.29%
17:04:23:WU00:FS00:Download 21.76%
17:04:29:WU00:FS00:Download 38.87%
17:04:35:WU00:FS00:Download 50.06%
17:04:41:WU00:FS00:Download 59.36%
17:04:47:WU00:FS00:Download 74.35%
17:04:53:WU00:FS00:Download 95.90%
17:04:54:WU00:FS00:Download complete
17:04:54:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11761 run:0 clone:4506 gen:24 core:0x22 unit:0x0000003080fccb0a5e6d7d673ee4aec9
17:04:54:WU00:FS00:Starting
17:04:54:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Kiklouni\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 8104 -checkpoint 10 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
17:04:54:WU00:FS00:Started FahCore on PID 5888
17:04:54:WU00:FS00:Core PID:1484
17:04:54:WU00:FS00:FahCore 0x22 started
17:04:55:WU00:FS00:0x22:*********************** Log Started 2020-04-06T17:04:54Z ***********************
17:04:55:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
17:04:55:WU00:FS00:0x22: Type: 0x22
17:04:55:WU00:FS00:0x22: Core: Core22
17:04:55:WU00:FS00:0x22: Website: https://foldingathome.org/
17:04:55:WU00:FS00:0x22: Copyright: (c) 2009-2018 foldingathome.org
17:04:55:WU00:FS00:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
17:04:55:WU00:FS00:0x22: <rafal.wiewiora@choderalab.org>
17:04:55:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 5888 -checkpoint 10
17:04:55:WU00:FS00:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
17:04:55:WU00:FS00:0x22: Config: <none>
17:04:55:WU00:FS00:0x22:************************************ Build *************************************
17:04:55:WU00:FS00:0x22: Version: 0.0.2
17:04:55:WU00:FS00:0x22: Date: Dec 6 2019
17:04:55:WU00:FS00:0x22: Time: 21:30:31
17:04:55:WU00:FS00:0x22: Repository: Git
17:04:55:WU00:FS00:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
17:04:55:WU00:FS00:0x22: Branch: HEAD
17:04:55:WU00:FS00:0x22: Compiler: Visual C++ 2008
17:04:55:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:04:55:WU00:FS00:0x22: Platform: win32 10
17:04:55:WU00:FS00:0x22: Bits: 64
17:04:55:WU00:FS00:0x22: Mode: Release
17:04:55:WU00:FS00:0x22:************************************ System ************************************
17:04:55:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i3-4170 CPU @ 3.70GHz
17:04:55:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
17:04:55:WU00:FS00:0x22: CPUs: 4
17:04:55:WU00:FS00:0x22: Memory: 7.94GiB
17:04:55:WU00:FS00:0x22:Free Memory: 4.98GiB
17:04:55:WU00:FS00:0x22: Threads: WINDOWS_THREADS
17:04:55:WU00:FS00:0x22: OS Version: 6.2
17:04:55:WU00:FS00:0x22:Has Battery: false
17:04:55:WU00:FS00:0x22: On Battery: false
17:04:55:WU00:FS00:0x22: UTC Offset: 2
17:04:55:WU00:FS00:0x22: PID: 1484
17:04:55:WU00:FS00:0x22: CWD: C:\Users\Kiklouni\AppData\Roaming\FAHClient\work
17:04:55:WU00:FS00:0x22: OS: Windows 10 Home
17:04:55:WU00:FS00:0x22: OS Arch: AMD64
17:04:55:WU00:FS00:0x22:********************************************************************************
17:04:55:WU00:FS00:0x22:Project: 11761 (Run 0, Clone 4506, Gen 24)
17:04:55:WU00:FS00:0x22:Unit: 0x0000003080fccb0a5e6d7d673ee4aec9
17:04:55:WU00:FS00:0x22:Reading tar file core.xml
17:04:55:WU00:FS00:0x22:Reading tar file integrator.xml
17:04:55:WU00:FS00:0x22:Reading tar file state.xml
17:04:55:WU00:FS00:0x22:Reading tar file system.xml
17:04:55:WU00:FS00:0x22:Digital signatures verified
17:04:55:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
17:04:55:WU00:FS00:0x22:Version 0.0.2
17:05:05:WU00:FS00:0x22:Completed 0 out of 2000000 steps (0%)
17:05:05:WU00:FS00:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:07:13:WU00:FS00:0x22:Completed 20000 out of 2000000 steps (1%)
17:09:20:WU00:FS00:0x22:Completed 40000 out of 2000000 steps (2%)
17:11:28:WU00:FS00:0x22:Completed 60000 out of 2000000 steps (3%)
17:13:34:WU00:FS00:0x22:Completed 80000 out of 2000000 steps (4%)
17:15:40:WU00:FS00:0x22:Completed 100000 out of 2000000 steps (5%)
17:17:49:WU00:FS00:0x22:Completed 120000 out of 2000000 steps (6%)
17:19:55:WU00:FS00:0x22:Completed 140000 out of 2000000 steps (7%)
17:22:04:WU00:FS00:0x22:Completed 160000 out of 2000000 steps (8%)
17:24:10:WU00:FS00:0x22:Completed 180000 out of 2000000 steps (9%)
17:26:17:WU00:FS00:0x22:Completed 200000 out of 2000000 steps (10%)
17:28:25:WU00:FS00:0x22:Completed 220000 out of 2000000 steps (11%)
17:30:32:WU00:FS00:0x22:Completed 240000 out of 2000000 steps (12%)
17:32:40:WU00:FS00:0x22:Completed 260000 out of 2000000 steps (13%)
17:34:47:WU00:FS00:0x22:Completed 280000 out of 2000000 steps (14%)
17:36:53:WU00:FS00:0x22:Completed 300000 out of 2000000 steps (15%)
17:39:02:WU00:FS00:0x22:Completed 320000 out of 2000000 steps (16%)
17:41:09:WU00:FS00:0x22:Completed 340000 out of 2000000 steps (17%)
17:43:17:WU00:FS00:0x22:Completed 360000 out of 2000000 steps (18%)
17:45:23:WU00:FS00:0x22:Completed 380000 out of 2000000 steps (19%)
17:47:30:WU00:FS00:0x22:Completed 400000 out of 2000000 steps (20%)
17:49:39:WU00:FS00:0x22:Completed 420000 out of 2000000 steps (21%)
17:51:45:WU00:FS00:0x22:Completed 440000 out of 2000000 steps (22%)
17:54:01:WU00:FS00:0x22:Completed 460000 out of 2000000 steps (23%)
17:56:24:WU00:FS00:0x22:Completed 480000 out of 2000000 steps (24%)
17:58:36:FS00:Paused
17:58:36:FS00:Shutting core down
17:58:36:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:58:39:Removing old file 'configs/config-20200403-175114.xml'
17:58:39:Saving configuration to config.xml
17:58:39:<config>
17:58:39: <!-- Folding Core -->
17:58:39: <checkpoint v='10'/>
17:58:39:
17:58:39: <!-- HTTP Server -->
17:58:39: <allow v='127.0.0.1 192.168.0.0/24'/>
17:58:39:
17:58:39: <!-- Network -->
17:58:39: <proxy v=':8080'/>
17:58:39:
17:58:39: <!-- Remote Command Server -->
17:58:39: <command-allow-no-pass v='127.0.0.1 192.168.0.0/24'/>
17:58:39:
17:58:39: <!-- User Information -->
17:58:39: <passkey v='********************************'/>
17:58:39: <team v='236157'/>
17:58:39: <user v='EduardoCZ'/>
17:58:39:
17:58:39: <!-- Folding Slots -->
17:58:39: <slot id='0' type='GPU'>
17:58:39: <gpu-index v='0'/>
17:58:39: <paused v='true'/>
17:58:39: </slot>
17:58:39:</config>
18:35:04:FS00:Unpaused
18:35:04:WU00:FS00:Starting
18:35:04:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Kiklouni\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 8104 -checkpoint 10 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:35:04:WU00:FS00:Started FahCore on PID 11104
18:35:04:WU00:FS00:Core PID:10108
18:35:04:WU00:FS00:FahCore 0x22 started
18:35:05:WU00:FS00:0x22:*********************** Log Started 2020-04-06T18:35:04Z ***********************
18:35:05:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
18:35:05:WU00:FS00:0x22: Type: 0x22
18:35:05:WU00:FS00:0x22: Core: Core22
18:35:05:WU00:FS00:0x22: Website: https://foldingathome.org/
18:35:05:WU00:FS00:0x22: Copyright: (c) 2009-2018 foldingathome.org
18:35:05:WU00:FS00:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:35:05:WU00:FS00:0x22: <rafal.wiewiora@choderalab.org>
18:35:05:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 11104 -checkpoint 10
18:35:05:WU00:FS00:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:35:05:WU00:FS00:0x22: Config: <none>
18:35:05:WU00:FS00:0x22:************************************ Build *************************************
18:35:05:WU00:FS00:0x22: Version: 0.0.2
18:35:05:WU00:FS00:0x22: Date: Dec 6 2019
18:35:05:WU00:FS00:0x22: Time: 21:30:31
18:35:05:WU00:FS00:0x22: Repository: Git
18:35:05:WU00:FS00:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
18:35:05:WU00:FS00:0x22: Branch: HEAD
18:35:05:WU00:FS00:0x22: Compiler: Visual C++ 2008
18:35:05:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:35:05:WU00:FS00:0x22: Platform: win32 10
18:35:05:WU00:FS00:0x22: Bits: 64
18:35:05:WU00:FS00:0x22: Mode: Release
18:35:05:WU00:FS00:0x22:************************************ System ************************************
18:35:05:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i3-4170 CPU @ 3.70GHz
18:35:05:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:35:05:WU00:FS00:0x22: CPUs: 4
18:35:05:WU00:FS00:0x22: Memory: 7.94GiB
18:35:05:WU00:FS00:0x22:Free Memory: 5.22GiB
18:35:05:WU00:FS00:0x22: Threads: WINDOWS_THREADS
18:35:05:WU00:FS00:0x22: OS Version: 6.2
18:35:05:WU00:FS00:0x22:Has Battery: false
18:35:05:WU00:FS00:0x22: On Battery: false
18:35:05:WU00:FS00:0x22: UTC Offset: 2
18:35:05:WU00:FS00:0x22: PID: 10108
18:35:05:WU00:FS00:0x22: CWD: C:\Users\Kiklouni\AppData\Roaming\FAHClient\work
18:35:05:WU00:FS00:0x22: OS: Windows 10 Home
18:35:05:WU00:FS00:0x22: OS Arch: AMD64
18:35:05:WU00:FS00:0x22:********************************************************************************
18:35:05:WU00:FS00:0x22:Project: 11761 (Run 0, Clone 4506, Gen 24)
18:35:05:WU00:FS00:0x22:Unit: 0x0000003080fccb0a5e6d7d673ee4aec9
18:35:05:WU00:FS00:0x22:Digital signatures verified
18:35:05:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
18:35:05:WU00:FS00:0x22:Version 0.0.2
18:35:05:WU00:FS00:0x22: Found a checkpoint file
18:35:15:Removing old file 'configs/config-20200403-190632.xml'
18:35:15:Saving configuration to config.xml
18:35:15:<config>
18:35:15: <!-- Folding Core -->
18:35:15: <checkpoint v='10'/>
18:35:15:
18:35:15: <!-- HTTP Server -->
18:35:15: <allow v='127.0.0.1 192.168.0.0/24'/>
18:35:15:
18:35:15: <!-- Network -->
18:35:15: <proxy v=':8080'/>
18:35:15:
18:35:15: <!-- Remote Command Server -->
18:35:15: <command-allow-no-pass v='127.0.0.1 192.168.0.0/24'/>
18:35:15:
18:35:15: <!-- User Information -->
18:35:15: <passkey v='********************************'/>
18:35:15: <team v='236157'/>
18:35:15: <user v='EduardoCZ'/>
18:35:15:
18:35:15: <!-- Folding Slots -->
18:35:15: <slot id='0' type='GPU'>
18:35:15: <gpu-index v='0'/>
18:35:15: </slot>
18:35:15:</config>
18:35:15:WU00:FS00:0x22:Completed 450000 out of 2000000 steps (22%)
18:35:15:WU00:FS00:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:36:20:WU00:FS00:0x22:Completed 460000 out of 2000000 steps (23%)
18:38:27:WU00:FS00:0x22:Completed 480000 out of 2000000 steps (24%)
18:40:34:WU00:FS00:0x22:Completed 500000 out of 2000000 steps (25%)
18:42:44:WU00:FS00:0x22:Completed 520000 out of 2000000 steps (26%)
18:44:51:WU00:FS00:0x22:Completed 540000 out of 2000000 steps (27%)
18:46:59:WU00:FS00:0x22:Completed 560000 out of 2000000 steps (28%)
18:49:06:WU00:FS00:0x22:Completed 580000 out of 2000000 steps (29%)
18:51:13:WU00:FS00:0x22:Completed 600000 out of 2000000 steps (30%)
18:53:22:WU00:FS00:0x22:Completed 620000 out of 2000000 steps (31%)
18:55:28:WU00:FS00:0x22:Completed 640000 out of 2000000 steps (32%)
18:57:37:WU00:FS00:0x22:Completed 660000 out of 2000000 steps (33%)
18:59:44:WU00:FS00:0x22:Completed 680000 out of 2000000 steps (34%)
19:01:51:WU00:FS00:0x22:Completed 700000 out of 2000000 steps (35%)
19:04:00:WU00:FS00:0x22:Completed 720000 out of 2000000 steps (36%)
19:06:07:WU00:FS00:0x22:Completed 740000 out of 2000000 steps (37%)
19:08:16:WU00:FS00:0x22:Completed 760000 out of 2000000 steps (38%)
19:10:22:WU00:FS00:0x22:Completed 780000 out of 2000000 steps (39%)
19:12:29:WU00:FS00:0x22:Completed 800000 out of 2000000 steps (40%)
19:14:38:WU00:FS00:0x22:Completed 820000 out of 2000000 steps (41%)
19:16:44:WU00:FS00:0x22:Completed 840000 out of 2000000 steps (42%)
19:18:53:WU00:FS00:0x22:Completed 860000 out of 2000000 steps (43%)
19:21:00:WU00:FS00:0x22:Completed 880000 out of 2000000 steps (44%)
19:23:07:WU00:FS00:0x22:Completed 900000 out of 2000000 steps (45%)
19:25:16:WU00:FS00:0x22:Completed 920000 out of 2000000 steps (46%)
19:27:23:WU00:FS00:0x22:Completed 940000 out of 2000000 steps (47%)
19:29:32:WU00:FS00:0x22:Completed 960000 out of 2000000 steps (48%)
19:31:39:WU00:FS00:0x22:Completed 980000 out of 2000000 steps (49%)
19:33:46:WU00:FS00:0x22:Completed 1000000 out of 2000000 steps (50%)
19:35:55:WU00:FS00:0x22:Completed 1020000 out of 2000000 steps (51%)
19:38:01:WU00:FS00:0x22:Completed 1040000 out of 2000000 steps (52%)
19:40:10:WU00:FS00:0x22:Completed 1060000 out of 2000000 steps (53%)
19:42:17:WU00:FS00:0x22:Completed 1080000 out of 2000000 steps (54%)
19:44:24:WU00:FS00:0x22:Completed 1100000 out of 2000000 steps (55%)
19:45:57:20:127.0.0.1:New Web connection
19:46:36:WU00:FS00:0x22:Completed 1120000 out of 2000000 steps (56%)
19:48:44:WU00:FS00:0x22:Completed 1140000 out of 2000000 steps (57%)
19:50:52:WU00:FS00:0x22:Completed 1160000 out of 2000000 steps (58%)
19:52:59:WU00:FS00:0x22:Completed 1180000 out of 2000000 steps (59%)
19:55:06:WU00:FS00:0x22:Completed 1200000 out of 2000000 steps (60%)
19:57:15:WU00:FS00:0x22:Completed 1220000 out of 2000000 steps (61%)
19:59:22:WU00:FS00:0x22:Completed 1240000 out of 2000000 steps (62%)
20:01:31:WU00:FS00:0x22:Completed 1260000 out of 2000000 steps (63%)
20:03:38:WU00:FS00:0x22:Completed 1280000 out of 2000000 steps (64%)
20:05:50:WU00:FS00:0x22:Completed 1300000 out of 2000000 steps (65%)
20:08:00:WU00:FS00:0x22:Completed 1320000 out of 2000000 steps (66%)
20:10:08:WU00:FS00:0x22:Completed 1340000 out of 2000000 steps (67%)
20:12:17:WU00:FS00:0x22:Completed 1360000 out of 2000000 steps (68%)
20:14:58:WU00:FS00:0x22:Completed 1380000 out of 2000000 steps (69%)
20:18:21:WU00:FS00:0x22:Completed 1400000 out of 2000000 steps (70%)
20:21:50:WU00:FS00:0x22:Completed 1420000 out of 2000000 steps (71%)
20:25:13:WU00:FS00:0x22:Completed 1440000 out of 2000000 steps (72%)
20:28:29:WU00:FS00:0x22:Completed 1460000 out of 2000000 steps (73%)
20:31:45:WU00:FS00:0x22:Completed 1480000 out of 2000000 steps (74%)
20:35:01:WU00:FS00:0x22:Completed 1500000 out of 2000000 steps (75%)
20:38:23:WU00:FS00:0x22:Completed 1520000 out of 2000000 steps (76%)
20:41:28:WU00:FS00:0x22:Completed 1540000 out of 2000000 steps (77%)
20:44:56:WU00:FS00:0x22:Completed 1560000 out of 2000000 steps (78%)
20:48:05:WU00:FS00:0x22:Completed 1580000 out of 2000000 steps (79%)
20:51:26:WU00:FS00:0x22:Completed 1600000 out of 2000000 steps (80%)
20:54:49:WU00:FS00:0x22:Completed 1620000 out of 2000000 steps (81%)
20:58:01:WU00:FS00:0x22:Completed 1640000 out of 2000000 steps (82%)
21:01:25:WU00:FS00:0x22:Completed 1660000 out of 2000000 steps (83%)
21:04:52:WU00:FS00:0x22:Completed 1680000 out of 2000000 steps (84%)
21:08:19:WU00:FS00:0x22:Completed 1700000 out of 2000000 steps (85%)
21:11:41:WU00:FS00:0x22:Completed 1720000 out of 2000000 steps (86%)
21:15:07:WU00:FS00:0x22:Completed 1740000 out of 2000000 steps (87%)
21:18:34:WU00:FS00:0x22:Completed 1760000 out of 2000000 steps (88%)
21:22:04:WU00:FS00:0x22:Completed 1780000 out of 2000000 steps (89%)
21:25:36:WU00:FS00:0x22:Completed 1800000 out of 2000000 steps (90%)
21:29:19:WU00:FS00:0x22:Completed 1820000 out of 2000000 steps (91%)
21:32:57:WU00:FS00:0x22:Completed 1840000 out of 2000000 steps (92%)
21:36:19:WU00:FS00:0x22:Completed 1860000 out of 2000000 steps (93%)
21:38:59:WU00:FS00:0x22:Completed 1880000 out of 2000000 steps (94%)
21:41:06:WU00:FS00:0x22:Completed 1900000 out of 2000000 steps (95%)
21:43:15:WU00:FS00:0x22:Completed 1920000 out of 2000000 steps (96%)
21:45:21:WU00:FS00:0x22:Completed 1940000 out of 2000000 steps (97%)
21:47:24:WU00:FS00:0x22:Completed 1960000 out of 2000000 steps (98%)
21:49:23:WU00:FS00:0x22:Completed 1980000 out of 2000000 steps (99%)
21:49:24:WU01:FS00:Connecting to 65.254.110.245:8080
21:49:24:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:49:24:WU01:FS00:Connecting to 18.218.241.186:80
21:49:25:WU01:FS00:Assigned to work server 40.114.52.201
21:49:25:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 40.114.52.201
21:49:25:WU01:FS00:Connecting to 40.114.52.201:8080
21:49:39:61:127.0.0.1:New Web connection
21:49:46:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
21:49:46:WU01:FS00:Connecting to 40.114.52.201:80
21:50:21:ERROR:WU01:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:50:21:WU01:FS00:Connecting to 65.254.110.245:8080
21:50:22:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:50:22:WU01:FS00:Connecting to 18.218.241.186:80
21:50:22:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:50:22:ERROR:WU01:FS00:Exception: Could not get an assignment
21:51:21:WU01:FS00:Connecting to 65.254.110.245:8080
21:51:22:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:51:22:WU01:FS00:Connecting to 18.218.241.186:80
21:51:22:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:51:22:ERROR:WU01:FS00:Exception: Could not get an assignment
21:51:33:WU00:FS00:0x22:Completed 2000000 out of 2000000 steps (100%)
21:51:36:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
21:51:36:WU00:FS00:0x22:Saving result file checkpointState.xml
21:51:36:WU00:FS00:0x22:Saving result file checkpt.crc
21:51:36:WU00:FS00:0x22:Saving result file positions.xtc
21:51:36:WU00:FS00:0x22:Saving result file science.log
21:51:39:WU00:FS00:Starting
21:51:39:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Kiklouni\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 8104 -checkpoint 10 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:51:39:WU00:FS00:Started FahCore on PID 3108
21:51:39:WU00:FS00:Core PID:2316
21:51:39:WU00:FS00:FahCore 0x22 started
21:51:40:WU00:FS00:0x22:*********************** Log Started 2020-04-06T21:51:39Z ***********************
21:51:40:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
21:51:40:WU00:FS00:0x22: Type: 0x22
21:51:40:WU00:FS00:0x22: Core: Core22
21:51:40:WU00:FS00:0x22: Website: https://foldingathome.org/
21:51:40:WU00:FS00:0x22: Copyright: (c) 2009-2018 foldingathome.org
21:51:40:WU00:FS00:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:51:40:WU00:FS00:0x22: <rafal.wiewiora@choderalab.org>
21:51:40:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 3108 -checkpoint 10
21:51:40:WU00:FS00:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:51:40:WU00:FS00:0x22: Config: <none>
21:51:40:WU00:FS00:0x22:************************************ Build *************************************
21:51:40:WU00:FS00:0x22: Version: 0.0.2
21:51:40:WU00:FS00:0x22: Date: Dec 6 2019
21:51:40:WU00:FS00:0x22: Time: 21:30:31
21:51:40:WU00:FS00:0x22: Repository: Git
21:51:40:WU00:FS00:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:51:40:WU00:FS00:0x22: Branch: HEAD
21:51:40:WU00:FS00:0x22: Compiler: Visual C++ 2008
21:51:40:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:51:40:WU00:FS00:0x22: Platform: win32 10
21:51:40:WU00:FS00:0x22: Bits: 64
21:51:40:WU00:FS00:0x22: Mode: Release
21:51:40:WU00:FS00:0x22:************************************ System ************************************
21:51:40:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i3-4170 CPU @ 3.70GHz
21:51:40:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
21:51:40:WU00:FS00:0x22: CPUs: 4
21:51:40:WU00:FS00:0x22: Memory: 7.94GiB
21:51:40:WU00:FS00:0x22:Free Memory: 4.48GiB
21:51:40:WU00:FS00:0x22: Threads: WINDOWS_THREADS
21:51:40:WU00:FS00:0x22: OS Version: 6.2
21:51:40:WU00:FS00:0x22:Has Battery: false
21:51:40:WU00:FS00:0x22: On Battery: false
21:51:40:WU00:FS00:0x22: UTC Offset: 2
21:51:40:WU00:FS00:0x22: PID: 2316
21:51:40:WU00:FS00:0x22: CWD: C:\Users\Kiklouni\AppData\Roaming\FAHClient\work
21:51:40:WU00:FS00:0x22: OS: Windows 10 Home
21:51:40:WU00:FS00:0x22: OS Arch: AMD64
21:51:40:WU00:FS00:0x22:********************************************************************************
21:51:40:WU00:FS00:0x22:Project: 11761 (Run 0, Clone 4506, Gen 24)
21:51:40:WU00:FS00:0x22:Unit: 0x0000003080fccb0a5e6d7d673ee4aec9
21:51:40:WU00:FS00:0x22:Reading tar file core.xml
21:51:40:WU00:FS00:0x22:Reading tar file integrator.xml
21:51:40:WU00:FS00:0x22:Reading tar file state.xml
21:51:40:WU00:FS00:0x22:Reading tar file system.xml
21:51:40:WU00:FS00:0x22:Digital signatures verified
21:51:40:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
21:51:40:WU00:FS00:0x22:Version 0.0.2
21:51:51:WU00:FS00:0x22:Completed 0 out of 2000000 steps (0%)
21:51:51:WU00:FS00:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:51:55:ERROR:Receive error: 10053: Software v hostitelském počítači ukončil vytvořené připojení.
21:52:59:WU01:FS00:Connecting to 65.254.110.245:8080
21:52:59:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:52:59:WU01:FS00:Connecting to 18.218.241.186:80
21:53:00:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:53:00:ERROR:WU01:FS00:Exception: Could not get an assignment
21:54:00:WU00:FS00:0x22:Completed 20000 out of 2000000 steps (1%)
21:55:36:WU01:FS00:Connecting to 65.254.110.245:8080
21:55:36:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:55:36:WU01:FS00:Connecting to 18.218.241.186:80
21:55:37:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:55:37:ERROR:WU01:FS00:Exception: Could not get an assignment
21:56:06:WU00:FS00:0x22:Completed 40000 out of 2000000 steps (2%)
21:56:10:Removing old file 'configs/config-20200403-210226.xml'
21:56:10:Saving configuration to config.xml
21:56:10:<config>
21:56:10: <!-- Folding Core -->
21:56:10: <checkpoint v='10'/>
21:56:10:
21:56:10: <!-- HTTP Server -->
21:56:10: <allow v='127.0.0.1 192.168.0.0/24'/>
21:56:10:
21:56:10: <!-- Network -->
21:56:10: <proxy v=':8080'/>
21:56:10:
21:56:10: <!-- Remote Command Server -->
21:56:10: <command-allow-no-pass v='127.0.0.1 192.168.0.0/24'/>
21:56:10:
21:56:10: <!-- User Information -->
21:56:10: <passkey v='********************************'/>
21:56:10: <team v='236157'/>
21:56:10: <user v='EduardoCZ'/>
21:56:10:
21:56:10: <!-- Folding Slots -->
21:56:10:</config>
21:56:10:FS00:Shutting core down
21:56:10:WU01:FS00:Slot ID 0 no longer exists and not yet downloaded, dumping
21:56:10:WU01:FS00:Cleaning up
21:56:10:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:56:11:WARNING:WU00:Slot ID 0 no longer exists and there are no other matching slots, dumping
21:56:11:WU00:Sending unit results: id:00 state:SEND error:DUMPED project:11761 run:0 clone:4506 gen:24 core:0x22 unit:0x0000003080fccb0a5e6d7d673ee4aec9
21:56:11:WU00:Uploading 23.04MiB to 128.252.203.10
21:56:11:WU00:Connecting to 128.252.203.10:8080
21:56:33:Removing old file 'configs/config-20200403-213256.xml'
21:56:33:Saving configuration to config.xml
21:56:33:<config>
21:56:33: <!-- Folding Core -->
21:56:33: <checkpoint v='10'/>
21:56:33:
21:56:33: <!-- HTTP Server -->
21:56:33: <allow v='127.0.0.1 192.168.0.0/24'/>
21:56:33:
21:56:33: <!-- Network -->
21:56:33: <proxy v=':8080'/>
21:56:33:
21:56:33: <!-- Remote Command Server -->
21:56:33: <command-allow-no-pass v='127.0.0.1 192.168.0.0/24'/>
21:56:33:
21:56:33: <!-- User Information -->
21:56:33: <passkey v='********************************'/>
21:56:33: <team v='236157'/>
21:56:33: <user v='EduardoCZ'/>
21:56:33:
21:56:33: <!-- Folding Slots -->
21:56:33:</config>
