140.163.4.241 low disk space
iceman1992
Post by iceman1992 »
It's happening again, 20.48KiB of space left on this server according to https://apps.foldingathome.org/serverstats
Can someone please notify the team so this can be solved?
My logs just in case it's needed
08:38:22:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
08:38:23:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:38:23:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11742 run:0 clone:2541 gen:37 core:0x22 unit:0x0000003c8ca304f15e69910cdd0a884e
08:38:23:WU00:FS01:Uploading 12.58MiB to 140.163.4.241
08:38:23:WU00:FS01:Connecting to 140.163.4.241:8080
08:38:44:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:38:44:WU00:FS01:Connecting to 140.163.4.241:80
08:39:05:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.241:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Manfred.Knick
Hardware configuration: Multiple XEON + GTX
Re: 140.163.4.241 low disk space
Post by Manfred.Knick »
+ 1 :
$ grep WU02 /opt/foldingathome/log.txt | grep -i fail
08:12:49:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
08:14:28:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
08:38:01:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.241:80: Connection timed out
As already indicated by iceman1992 above, for this server,
https://apps.foldingathome.org/serverstats states:
- 1 Error : Not enough disk space
- Space: 20.48KiB
I guess the column header above is to be interpreted as "empty space left" ?
- 1 Warning: collection server not connected
- has CS: No (fah4.eastus.cloudapp.azure.com)
iceman1992
No updates on this?
bootsy
Post by bootsy »
Upload Complete with bad? results
13:08:56:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11742 run:0 clone:9120 gen:5 core:0x22 unit:0x000000148ca304f15e6bc4dbc2c2eaab
13:08:56:WU01:FS01:Uploading 12.58MiB to 140.163.4.241
13:08:56:WU01:FS01:Connecting to 140.163.4.241:8080
13:09:19:WU01:FS01:Upload 0.99%
13:45:51:WU01:FS01:Upload 99.87%
13:48:01:WU01:FS01:Upload complete
13:48:01:WU01:FS01:Server responded WORK_QUIT (404)
13:48:01:WARNING:WU01:FS01:Server did not like results, dumping
13:48:01:WU01:FS01:Cleaning up
Manfred.Knick
Reference: "Can't upload to 140.163.4.231"
viewtopic.php?f=18&t=33978#p323295
iceman1992
Yes it seems the servers at MSKCC are having frequent issues
Yes, the researchers are aware of the space issue, and are working on it.
Manfred.Knick
Where do I find any documentation upon FAHCoreWrapper keywords?
Esp.: What is the unit of "-lifeline xxx" ?
Manfred.Knick
+++ Status of MSKCC servers changed: "Errors: 0" / Disk Space available right now
140.163.4.231 plfah1-1.mskcc.org WS 9.6.1 rafal.wiewiora 3.600,00/hr 0 1 No Assign 75.283 75.283 OPENMM_22 5.68TiB an hour 2020-04-07T16:12:32Z
140.163.4.241 plfah2-1.mskcc.org WS 9.6.1 rafal.wiewiora 3.600,00/hr 0 1 No Assign 149.427 149.427 OPENMM_21, OPENMM_22 895.26GiB 17 minutes 2020-04-07T16:13:35Z
+++ SUCCESS:
15:30:52:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11742 run:0 clone:1983 gen:36 core:0x22 unit:0x0000003d8ca304f15e67da8cffcadf75
15:30:52:WU02:FS01:Uploading 12.58MiB to 140.163.4.241
15:30:52:WU02:FS01:Connecting to 140.163.4.241:8080
15:30:58:WU02:FS01:Upload 26.34%
15:31:04:WU02:FS01:Upload 54.17%
15:31:10:WU02:FS01:Upload 79.51%
15:31:16:WU02:FS01:Upload complete
15:31:16:WU02:FS01:Server responded WORK_ACK (400)
15:31:16:WU02:FS01:Final credit estimate, 15631.00 points
15:31:16:WU02:FS01:Cleaning up
Congratulations!
Thanks a lot!
