Radeon HD 6000 Series Not Getting Work
Marco88
Post by Marco88 »
Hey all,
I'm new to FaH and I've got a GPU that hasn't picked up a job since I downloaded the client (about three weeks now). I've got a Windows 10 installation with an AMD Radeon HD 6770 (Juniper series) graphics card. I know there's a lot of work demand these days, but I wanted to be sure I've got my installation set up correctly.
So far I've uninstalled/reinstalled the AMD graphics drivers (using 15.7.1 WHQL) and uninstalled/reinstalled the FaH client. Below is a log entry including the system information (CPU is getting work consistently, so no issues there). Thanks much for your help and consideration!
*********************** Log Started 2020-04-06T14:23:24Z ***********************
14:23:24:************************* Folding@home Client *************************
14:23:24:        Website: https://foldingathome.org/
14:23:24:      Copyright: (c) 2009-2018 foldingathome.org
14:23:24:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:23:24:           Args:
14:23:24:         Config: C:\Users\mhmoo\AppData\Roaming\FAHClient\config.xml
14:23:24:******************************** Build ********************************
14:23:24:        Version: 7.5.1
14:23:24:           Date: May 11 2018
14:23:24:           Time: 13:06:32
14:23:24:     Repository: Git
14:23:24:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:23:24:         Branch: master
14:23:24:       Compiler: Visual C++ 2008
14:23:24:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:23:24:       Platform: win32 10
14:23:24:           Bits: 32
14:23:24:           Mode: Release
14:23:24:******************************* System ********************************
14:23:24:            CPU: AMD Phenom(tm) II X6 1100T Processor
14:23:24:         CPU ID: AuthenticAMD Family 16 Model 10 Stepping 0
14:23:24:           CPUs: 6
14:23:24:         Memory: 16.00GiB
14:23:24:    Free Memory: 14.00GiB
14:23:24:        Threads: WINDOWS_THREADS
14:23:24:     OS Version: 6.2
14:23:24:    Has Battery: false
14:23:24:     On Battery: false
14:23:24:     UTC Offset: -5
14:23:24:            PID: 10800
14:23:24:            CWD: C:\Users\mhmoo\AppData\Roaming\FAHClient
14:23:24:             OS: Windows 10 Enterprise
14:23:24:        OS Arch: AMD64
14:23:24:           GPUs: 1
14:23:24:          GPU 0: Bus:1 Slot:0 Func:0 AMD:4 Juniper XT [Radeon HD 6000 Series]
14:23:24:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
14:23:24:                 specified module could not be found.
14:23:24:
14:23:24:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:1800.8
14:23:24:  Win32 Service: false
14:23:24:***********************************************************************
14:23:24:<config>
14:23:24:  <!-- Folding Core -->
14:23:24:  <core-priority v='low'/>
14:23:24:
14:23:24:  <!-- Folding Slot Configuration -->
14:23:24:  <client-type v='advanced'/>
14:23:24:
14:23:24:  <!-- Network -->
14:23:24:  <proxy v=':8080'/>
14:23:24:
14:23:24:  <!-- Slot Control -->
14:23:24:  <power v='full'/>
14:23:24:
14:23:24:  <!-- User Information -->
14:23:24:  <team v='240058'/>
14:23:24:  <user v='Marco88'/>
14:23:24:
14:23:24:  <!-- Folding Slots -->
14:23:24:  <slot id='0' type='CPU'/>
14:23:24:  <slot id='1' type='GPU'/>
14:23:24:</config>
14:23:24:Trying to access database...
14:23:24:Successfully acquired database lock
14:23:24:Enabled folding slot 00: READY cpu:5
14:23:24:Enabled folding slot 01: READY gpu:0:Juniper XT [Radeon HD 6000 Series]
14:23:24:WU00:FS00:Starting
14:23:24:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\mhmoo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 10800 -checkpoint 15 -np 5
14:23:24:WU00:FS00:Started FahCore on PID 11064
14:23:24:WU00:FS00:Core PID:11080
14:23:24:WU00:FS00:FahCore 0xa7 started
14:23:25:WU00:FS00:0xa7:*********************** Log Started 2020-04-06T14:23:24Z ***********************
14:23:25:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:23:25:WU00:FS00:0xa7:       Type: 0xa7
14:23:25:WU00:FS00:0xa7:       Core: Gromacs
14:23:25:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 11064 -checkpoint 15 -np
14:23:25:WU00:FS00:0xa7:             5
14:23:25:WU00:FS00:0xa7:************************************ CBang *************************************
14:23:25:WU00:FS00:0xa7:       Date: Oct 26 2019
14:23:25:WU00:FS00:0xa7:       Time: 01:38:35
14:23:25:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:23:25:WU00:FS00:0xa7:     Branch: master
14:23:25:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
14:23:25:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:23:25:WU00:FS00:0xa7:   Platform: win32 10
14:23:25:WU00:FS00:0xa7:       Bits: 64
14:23:25:WU00:FS00:0xa7:       Mode: Release
14:23:25:WU00:FS00:0xa7:************************************ System ************************************
14:23:25:WU00:FS00:0xa7:        CPU: AMD Phenom(tm) II X6 1100T Processor
14:23:25:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 16 Model 10 Stepping 0
14:23:25:WU00:FS00:0xa7:       CPUs: 6
14:23:25:WU00:FS00:0xa7:     Memory: 16.00GiB
14:23:25:WU00:FS00:0xa7:Free Memory: 13.93GiB
14:23:25:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
14:23:25:WU00:FS00:0xa7: OS Version: 6.2
14:23:25:WU00:FS00:0xa7:Has Battery: false
14:23:25:WU00:FS00:0xa7: On Battery: false
14:23:25:WU00:FS00:0xa7: UTC Offset: -5
14:23:25:WU00:FS00:0xa7:        PID: 11080
14:23:25:WU00:FS00:0xa7:        CWD: C:\Users\mhmoo\AppData\Roaming\FAHClient\work
14:23:25:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:23:25:WU00:FS00:0xa7:    Version: 0.0.18
14:23:25:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:23:25:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:23:25:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
14:23:25:WU00:FS00:0xa7:       Time: 01:52:44
14:23:25:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:23:25:WU00:FS00:0xa7:************************************ Build *************************************
14:23:25:WU00:FS00:0xa7:       SIMD: sse2
14:23:25:WU00:FS00:0xa7:********************************************************************************
14:23:25:WU00:FS00:0xa7:Project: 14576 (Run 0, Clone 1510, Gen 19)
14:23:25:WU00:FS00:0xa7:Unit: 0x0000001d287234c95e79223181ee292b
14:23:25:WU00:FS00:0xa7:Digital signatures verified
14:23:25:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
14:23:25:WU00:FS00:0xa7:Calling: mdrun -s frame19.tpr -o frame19.trr -x frame19.xtc -cpi state.cpt -cpt 15 -nt 4
14:23:25:WU00:FS00:0xa7:Steps: first=9500000 total=500000
14:23:25:WU01:FS01:Connecting to 65.254.110.245:8080
14:23:26:WU00:FS00:0xa7:Completed 33631 out of 500000 steps (6%)
14:23:26:WU01:FS01:Assigned to work server 192.0.2.1
14:23:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper XT [Radeon HD 6000 Series] from 192.0.2.1
14:23:26:WU01:FS01:Connecting to 192.0.2.1:8080
14:23:47:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:23:47:WU01:FS01:Connecting to 192.0.2.1:80
14:24:06:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
14:24:08:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:24:09:WU01:FS01:Connecting to 65.254.110.245:8080
14:24:09:WU01:FS01:Assigned to work server 192.0.2.1
14:24:09:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper XT [Radeon HD 6000 Series] from 192.0.2.1
14:24:09:WU01:FS01:Connecting to 192.0.2.1:8080
14:24:30:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:24:30:WU01:FS01:Connecting to 192.0.2.1:80
14:24:51:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:25:09:WU01:FS01:Connecting to 65.254.110.245:8080
14:25:09:WU01:FS01:Assigned to work server 192.0.2.1
14:25:09:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper XT [Radeon HD 6000 Series] from 192.0.2.1
14:25:09:WU01:FS01:Connecting to 192.0.2.1:8080
14:25:30:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:25:30:WU01:FS01:Connecting to 192.0.2.1:80
14:25:52:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:26:23:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
14:26:46:WU01:FS01:Connecting to 65.254.110.245:8080
14:26:46:WU01:FS01:Assigned to work server 192.0.2.1
14:26:46:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper XT [Radeon HD 6000 Series] from 192.0.2.1
14:26:46:WU01:FS01:Connecting to 192.0.2.1:8080
14:27:07:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:27:07:WU01:FS01:Connecting to 192.0.2.1:80
14:27:29:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:28:34:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
14:29:23:WU01:FS01:Connecting to 65.254.110.245:8080
14:29:23:WU01:FS01:Assigned to work server 192.0.2.1
14:29:24:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper XT [Radeon HD 6000 Series] from 192.0.2.1
14:29:24:WU01:FS01:Connecting to 192.0.2.1:8080
14:29:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:29:45:WU01:FS01:Connecting to 192.0.2.1:80
14:30:06:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:30:49:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
14:33:06:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
14:33:37:WU01:FS01:Connecting to 65.254.110.245:8080
14:33:37:WU01:FS01:Assigned to work server 192.0.2.1
14:33:38:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper XT [Radeon HD 6000 Series] from 192.0.2.1
14:33:38:WU01:FS01:Connecting to 192.0.2.1:8080
14:33:59:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:33:59:WU01:FS01:Connecting to 192.0.2.1:80
14:34:20:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:35:22:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
14:37:38:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
14:39:56:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
14:40:29:WU01:FS01:Connecting to 65.254.110.245:8080
14:40:29:WU01:FS01:Assigned to work server 192.0.2.1
14:40:29:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper XT [Radeon HD 6000 Series] from 192.0.2.1
14:40:29:WU01:FS01:Connecting to 192.0.2.1:8080
14:40:50:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:40:50:WU01:FS01:Connecting to 192.0.2.1:80
14:41:12:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:42:13:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
14:44:25:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
14:46:38:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
14:48:50:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
14:51:02:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
14:51:34:WU01:FS01:Connecting to 65.254.110.245:8080
14:51:35:WU01:FS01:Assigned to work server 192.0.2.1
14:51:35:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper XT [Radeon HD 6000 Series] from 192.0.2.1
14:51:35:WU01:FS01:Connecting to 192.0.2.1:8080
14:51:56:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:51:56:WU01:FS01:Connecting to 192.0.2.1:80
14:52:18:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:53:18:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
14:55:32:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
14:57:46:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
14:59:57:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
15:02:10:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
15:04:19:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
15:06:30:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
15:08:43:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
15:09:31:WU01:FS01:Connecting to 65.254.110.245:8080
15:09:31:WU01:FS01:Assigned to work server 192.0.2.1
15:09:32:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper XT [Radeon HD 6000 Series] from 192.0.2.1
15:09:32:WU01:FS01:Connecting to 192.0.2.1:8080
15:09:53:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
15:09:53:WU01:FS01:Connecting to 192.0.2.1:80
15:10:14:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:10:55:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
15:13:09:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
15:15:25:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
15:17:40:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
15:19:52:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
15:22:06:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
15:24:21:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
15:26:33:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
15:28:46:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
15:31:00:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
15:33:14:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
15:35:27:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
15:37:39:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
15:38:34:WU01:FS01:Connecting to 65.254.110.245:8080
15:38:34:WU01:FS01:Assigned to work server 192.0.2.1
15:38:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper XT [Radeon HD 6000 Series] from 192.0.2.1
15:38:34:WU01:FS01:Connecting to 192.0.2.1:8080
15:38:55:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
15:38:55:WU01:FS01:Connecting to 192.0.2.1:80
15:39:16:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:39:52:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
15:42:04:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
15:44:17:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
15:46:30:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
15:48:47:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
15:51:06:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
15:53:26:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
15:55:40:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
15:57:57:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
16:00:12:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
16:02:25:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
16:04:41:WU00:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
16:06:54:WU00:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
16:09:11:WU00:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
16:11:27:WU00:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
16:13:39:WU00:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
16:15:54:WU00:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
16:18:07:WU00:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
16:20:18:WU00:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
16:22:28:WU00:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
16:24:40:WU00:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
16:25:32:WU01:FS01:Connecting to 65.254.110.245:8080
16:25:33:WU01:FS01:Assigned to work server 192.0.2.1
16:25:33:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper XT [Radeon HD 6000 Series] from 192.0.2.1
16:25:33:WU01:FS01:Connecting to 192.0.2.1:8080
16:25:54:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
16:25:54:WU01:FS01:Connecting to 192.0.2.1:80
16:26:15:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
16:26:54:WU00:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
16:29:07:WU00:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
16:31:19:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
16:33:33:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
16:35:51:WU00:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
16:38:11:WU00:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
16:40:29:WU00:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
16:42:43:WU00:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
16:44:57:WU00:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
16:47:12:WU00:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
16:49:28:WU00:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
16:51:43:WU00:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
16:53:56:WU00:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
16:56:13:WU00:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
16:58:29:WU00:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
17:00:44:WU00:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
17:02:58:WU00:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
17:05:17:WU00:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
17:07:32:WU00:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
17:09:50:WU00:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
17:12:05:WU00:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
17:14:19:WU00:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
17:16:35:WU00:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
17:18:53:WU00:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
17:21:12:WU00:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
17:23:27:WU00:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
17:25:49:WU00:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
17:28:07:WU00:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
Re: Radeon HD 6000 Series Not Getting Work
All of the HD 6000 cards except for the 6900 series are no longer usable for GPU folding. They do not support the use of Double Precision calculations which is now required for a portion of the calculations a GPU WU needs done.
They were usable until last year when the last projects that did not require DP arithmetic finished.
Marco88
Post by Marco88 »
Understood; thanks for confirming and the explanation!
