Server, dumping: Project: 14613 (Run 155, Clone 9, Gen 17)
Sequence211
Post by Sequence211 »
Hello.
First i would like to say, that I don't know if this is a WU issue, or a server issue.
I just finished the WU
But when uploading, it returned
:Server responded WORK_QUIT (404)
Server did not like results, dumping
I only run a CPU slot in my server, it runs in a Ubuntu VM with 22 logical cores available
08:17:38:WU00:FS00:Connecting to 65.254.110.245:8080
08:17:40:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:17:40:WU00:FS00:Connecting to 18.218.241.186:80
08:17:41:WU00:FS00:Assigned to work server 155.247.164.214
08:17:41:WU00:FS00:Requesting new work unit for slot 00: READY cpu:22 from 155.247.164.214
08:17:41:WU00:FS00:Connecting to 155.247.164.214:8080
08:17:41:WU00:FS00:Downloading 2.87MiB
08:17:47:WU00:FS00:Download 58.87%
08:17:53:WU00:FS00:Download 76.31%
08:18:00:WU00:FS00:Download 85.03%
08:18:06:WU00:FS00:Download 93.75%
08:18:08:WU00:FS00:Download complete
08:18:08:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14613 run:155 clone:9 gen:17 core:0xa7 unit:0x000000129bf7a4d65e848f4728958d39
08:18:08:WU00:FS00:Starting
08:18:08:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 1329 -checkpoint 15 -np 22
08:18:08:WU00:FS00:Started FahCore on PID 1931
08:18:08:WU00:FS00:Core PID:1935
08:18:08:WU00:FS00:FahCore 0xa7 started
08:18:09:WU00:FS00:0xa7:*********************** Log Started 2020-04-06T08:18:08Z ***********************
08:18:09:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:18:09:WU00:FS00:0xa7:       Type: 0xa7
08:18:09:WU00:FS00:0xa7:       Core: Gromacs
08:18:09:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 1931 -checkpoint 15 -np
08:18:09:WU00:FS00:0xa7:             22
08:18:09:WU00:FS00:0xa7:************************************ CBang *************************************
08:18:09:WU00:FS00:0xa7:       Date: Nov 5 2019
08:18:09:WU00:FS00:0xa7:       Time: 06:06:57
08:18:09:WU00:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
08:18:09:WU00:FS00:0xa7:     Branch: master
08:18:09:WU00:FS00:0xa7:   Compiler: GNU 8.3.0
08:18:09:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
08:18:09:WU00:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
08:18:09:WU00:FS00:0xa7:       Bits: 64
08:18:09:WU00:FS00:0xa7:       Mode: Release
08:18:09:WU00:FS00:0xa7:************************************ System ************************************
08:18:09:WU00:FS00:0xa7:        CPU: Genuine Intel(R) CPU 0000 @ 2.40GHz
08:18:09:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 79 Stepping 0
08:18:09:WU00:FS00:0xa7:       CPUs: 22
08:18:09:WU00:FS00:0xa7:     Memory: 7.77GiB
08:18:09:WU00:FS00:0xa7:Free Memory: 6.65GiB
08:18:09:WU00:FS00:0xa7:    Threads: POSIX_THREADS
08:18:09:WU00:FS00:0xa7: OS Version: 5.3
08:18:09:WU00:FS00:0xa7:Has Battery: false
08:18:09:WU00:FS00:0xa7: On Battery: false
08:18:09:WU00:FS00:0xa7: UTC Offset: 2
08:18:09:WU00:FS00:0xa7:        PID: 1935
08:18:09:WU00:FS00:0xa7:        CWD: /var/lib/fahclient/work
08:18:09:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
08:18:09:WU00:FS00:0xa7:    Version: 0.0.18
08:18:09:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:18:09:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:18:09:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
08:18:09:WU00:FS00:0xa7:       Time: 06:13:26
08:18:09:WU00:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
08:18:09:WU00:FS00:0xa7:************************************ Build *************************************
08:18:09:WU00:FS00:0xa7:       SIMD: avx_256
08:18:09:WU00:FS00:0xa7:********************************************************************************
08:18:09:WU00:FS00:0xa7:Project: 14613 (Run 155, Clone 9, Gen 17)
08:18:09:WU00:FS00:0xa7:Unit: 0x000000129bf7a4d65e848f4728958d39
08:18:09:WU00:FS00:0xa7:Reading tar file core.xml
08:18:09:WU00:FS00:0xa7:Reading tar file frame17.tpr
08:18:09:WU00:FS00:0xa7:Digital signatures verified
08:18:09:WU00:FS00:0xa7:Reducing thread count from 22 to 21 to avoid domain decomposition with large prime factor 11
08:18:09:WU00:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -cpt 15 -nt 21
08:18:09:WU00:FS00:0xa7:Steps: first=0 total=250000
08:18:10:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
08:18:57:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
08:19:44:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
08:20:10:FS00:Finishing
08:20:30:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
08:21:15:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
08:22:00:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
08:22:45:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
08:23:30:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
08:24:17:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
08:25:03:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
08:25:49:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
08:26:35:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
08:27:21:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
08:28:06:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
08:28:51:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
08:29:36:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
08:30:22:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
08:31:07:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
08:31:53:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
08:32:39:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
08:33:24:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
08:34:08:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
08:34:52:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
08:35:36:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
08:36:20:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
08:37:05:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
08:37:54:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
08:38:38:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
08:39:22:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
08:40:08:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
08:40:53:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
08:41:39:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
08:42:25:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
08:43:10:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
08:43:56:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
08:44:42:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
08:45:27:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
08:46:15:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
08:47:02:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
08:47:49:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
08:48:37:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
08:49:24:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
08:50:10:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
08:50:55:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
08:51:39:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
08:52:23:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
08:53:07:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
08:53:52:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
08:54:36:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
08:55:20:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
08:56:04:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
08:56:49:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
08:57:33:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
08:58:16:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
08:59:01:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
08:59:45:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
09:00:29:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
09:01:12:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
09:01:57:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
09:02:41:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
09:03:25:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
09:04:09:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
09:04:54:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
09:05:39:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
09:06:24:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
09:07:08:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
09:07:52:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
09:08:36:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
09:09:20:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
09:10:04:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
09:10:48:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
09:11:33:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
09:12:19:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
09:13:05:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
09:13:49:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
09:14:34:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
09:15:19:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
09:16:04:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
09:16:50:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
09:17:35:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
09:18:20:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
09:19:06:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
09:19:52:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
09:20:37:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
09:21:24:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
09:22:10:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
09:22:55:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
09:23:40:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
09:24:24:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
09:25:11:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
09:25:56:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
09:26:43:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
09:27:28:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
09:28:13:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
09:28:58:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
09:29:44:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
09:30:31:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
09:31:18:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
09:32:04:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
09:32:49:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
09:33:35:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
09:33:37:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
09:33:37:WU00:FS00:0xa7:Saving result file dhdl.xvg
09:33:37:WU00:FS00:0xa7:Saving result file frame17.trr
09:33:37:WU00:FS00:0xa7:Saving result file md.log
09:33:37:WU00:FS00:0xa7:Saving result file pullf.xvg
09:33:37:WU00:FS00:0xa7:Saving result file pullx.xvg
09:33:37:WU00:FS00:0xa7:Saving result file science.log
09:33:37:WU00:FS00:0xa7:Saving result file traj_comp.xtc
09:33:37:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
09:33:37:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:33:37:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14613 run:155 clone:9 gen:17 core:0xa7 unit:0x000000129bf7a4d65e848f4728958d39
09:33:37:WU00:FS00:Uploading 6.54MiB to 155.247.164.214
09:33:37:WU00:FS00:Connecting to 155.247.164.214:8080
09:33:48:WU00:FS00:Upload 2.87%
09:34:07:WU00:FS00:Upload 3.82%
09:35:13:WU00:FS00:Upload 4.78%
09:35:45:WU00:FS00:Upload 5.73%
09:35:45:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
09:35:45:WU00:FS00:Trying to send results to collection server
09:35:45:WU00:FS00:Uploading 6.54MiB to 155.247.166.220
09:35:45:WU00:FS00:Connecting to 155.247.166.220:8080
09:36:30:WU00:FS00:Upload 32.48%
09:36:36:WU00:FS00:Upload 81.21%
09:36:39:WU00:FS00:Upload complete
09:36:39:WU00:FS00:Server responded WORK_QUIT (404)
09:36:39:WARNING:WU00:FS00:Server did not like results, dumping
09:36:39:WU00:FS00:Cleaning up
davidcoton
Re: Server, dumping: Project: 14613 (Run 155, Clone 9, Gen 1
Post by davidcoton »
Not sure what happened there, both servers (WS and CS) report OK. Project team notified, though it may just be a "random" failure
