I recall it being mentioned that the number of logs in %appdata%\FAHClient\logs is 16 by default. Can this number be increased?
Thanks!
Increasing the number of logs in %appdata%\FAHClient\logs
Re: Increasing the number of logs in %appdata%\FAHClient\log
Yes, you can add an Extra Client Option under the Expert tab in FAHControl's Configure option.
The option is log-rotate-max, set the value to the number of past logs wanted to be kept. I don't know if there are limits to the setting, it is undocumented.
