FahCore_22.exe Entry Point Not Found
l2g2h
Post by l2g2h »
Hello~
I'm encountering the below error and trying to figure out what to do with it on the following hardware. I'm finding idle hardware around the workplace that can help fold for COVID-19 & later cancer/etc/good causes. Thanks to everyone that makes this stuff possible.
Win Srv 2012 R2
Intel Xeon CPU E5-1620 @ 3.6GHz
16GB Ram
2 GB NVIDIA Quadro K2000
I'm currently running 7.5.1. I've tried uninstalling & reinstalling 7.5.1 which issue still persists. The issue occurs after I tried installing 7.4.4 under old versions either Win 2008 or not.
fah-installer_7.4.4_x86
fah-installer_7.5.1_x86
the procedure entry point clreleasedevice could not be located in the dynamic link library
C:\Users\_username_\AppData\Roaming\FAHClient\cores.core.foldingathome.org\v7\win\64bit\Core_22.fah\FahCore_22.exe
Re: FahCore_22.exe Entry Point Not Found
Welcome to the F@H Forum l2g2h,
Please note that if you're planning to run F@H on systems you don't own, you need to obtain permission (generally it's written) from the system owners as per EULA.
Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file (viewtopic.php?f=24&t=26036).
Do you use a 64 bit OS ? If yes, update your GPU drivers, else, you need a 64 bits OS.
l2g2h
Post by l2g2h »
PantherX wrote:Welcome to the F@H Forum l2g2h,
Yes, I have permission.
Log file below
05:45:55:WU01:FS01:Server responded WORK_ACK (400)
05:45:55:WU01:FS01:Cleaning up
05:45:56:Adding folding slot 01: READY gpu:0:GK107 [Quadro K600]
05:45:56:FS00:Shutting core down
05:45:56:Saving configuration to config.xml
05:45:56:<config>
05:45:56:  <!-- Network -->
05:45:56:  <proxy v=':8080'/>
05:45:56:
05:45:56:  <!-- Slot Control -->
05:45:56:  <power v='FULL'/>
05:45:56:
05:45:56:  <!-- User Information -->
05:45:56:
05:45:56:
05:45:56:
05:45:56:  <!-- Folding Slots -->
05:45:56:  <slot id='0' type='CPU'/>
05:45:56:  <slot id='1' type='GPU'/>
05:45:56:</config>
05:45:56:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 1176
05:45:56:WU00:FS00:0xa7:Exiting, please wait. . .
05:45:56:WU01:FS01:Connecting to 65.254.110.245:8080
05:45:56:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:45:56:WU01:FS01:Connecting to 18.218.241.186:80
05:45:56:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
05:45:57:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:45:57:ERROR:WU01:FS01:Exception: Could not get an assignment
05:45:57:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:45:57:WU01:FS01:Connecting to 65.254.110.245:8080
05:45:57:WU00:FS00:Starting
05:45:57:WARNING:WU00:FS00:Changed SMP threads from 8 to 7 this can cause some work units to fail
05:45:57:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\_username_\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 1712 -checkpoint 15 -np 7
05:45:57:WU00:FS00:Started FahCore on PID 2360
05:45:57:WU00:FS00:Core PID:6024
05:45:57:WU00:FS00:FahCore 0xa7 started
05:45:58:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:45:58:WU01:FS01:Connecting to 18.218.241.186:80
05:45:58:WU00:FS00:0xa7:*********************** Log Started 2020-04-06T05:45:57Z ***********************
05:45:58:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
05:45:58:WU00:FS00:0xa7:       Type: 0xa7
05:45:58:WU00:FS00:0xa7:       Core: Gromacs
05:45:58:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 2360 -checkpoint 15 -np 7
05:45:58:WU00:FS00:0xa7:************************************ CBang *************************************
05:45:58:WU00:FS00:0xa7:       Date: Oct 26 2019
05:45:58:WU00:FS00:0xa7:       Time: 01:38:25
05:45:58:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
05:45:58:WU00:FS00:0xa7:     Branch: master
05:45:58:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
05:45:58:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:45:58:WU00:FS00:0xa7:   Platform: win32 10
05:45:58:WU00:FS00:0xa7:       Bits: 64
05:45:58:WU00:FS00:0xa7:       Mode: Release
05:45:58:WU00:FS00:0xa7:************************************ System ************************************
05:45:58:WU00:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
05:45:58:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
05:45:58:WU00:FS00:0xa7:       CPUs: 8
05:45:58:WU00:FS00:0xa7:     Memory: 15.93GiB
05:45:58:WU00:FS00:0xa7:Free Memory: 12.93GiB
05:45:58:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
05:45:58:WU00:FS00:0xa7: OS Version: 6.2
05:45:58:WU00:FS00:0xa7:Has Battery: false
05:45:58:WU00:FS00:0xa7: On Battery: false
05:45:58:WU00:FS00:0xa7: UTC Offset: -7
05:45:58:WU00:FS00:0xa7:        PID: 6024
05:45:58:WU00:FS00:0xa7:        CWD: C:\Users\_username_\AppData\Roaming\FAHClient\work
05:45:58:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
05:45:58:WU00:FS00:0xa7:    Version: 0.0.18
05:45:58:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:45:58:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
05:45:58:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
05:45:58:WU00:FS00:0xa7:       Time: 01:52:30
05:45:58:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
05:45:58:WU00:FS00:0xa7:************************************ Build *************************************
05:45:58:WU00:FS00:0xa7:       SIMD: avx_256
05:45:58:WU00:FS00:0xa7:********************************************************************************
05:45:58:WU00:FS00:0xa7:Project: 14367 (Run 1028, Clone 2, Gen 12)
05:45:58:WU00:FS00:0xa7:Unit: 0x0000000c9bf7a4d55e84b13d296694a1
05:45:58:WU00:FS00:0xa7:Digital signatures verified
05:45:58:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
05:45:58:WU00:FS00:0xa7:Calling: mdrun -s frame12.tpr -o frame12.trr -cpi state.cpt -cpt 15 -nt 6
05:45:58:WU00:FS00:0xa7:Steps: first=0 total=250000
05:45:58:WU00:FS00:0xa7:Completed 88980 out of 250000 steps (35%)
05:45:59:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:45:59:ERROR:WU01:FS01:Exception: Could not get an assignment
05:46:42:Saving configuration to config.xml
05:46:42:<config>
05:46:42:  <!-- Network -->
05:46:42:  <proxy v=':8080'/>
05:46:42:
05:46:42:  <!-- Slot Control -->
05:46:42:  <power v='FULL'/>
05:46:42:
05:46:42:  <!-- User Information -->
05:46:42:
05:46:42:
05:46:42:
05:46:42:  <!-- Folding Slots -->
05:46:42:  <slot id='0' type='CPU'/>
05:46:42:  <slot id='1' type='GPU'/>
05:46:42:</config>
05:46:54:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
05:46:57:WU01:FS01:Connecting to 65.254.110.245:8080
05:46:57:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:46:57:WU01:FS01:Connecting to 18.218.241.186:80
05:46:57:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:46:57:ERROR:WU01:FS01:Exception: Could not get an assignment
05:48:34:WU01:FS01:Connecting to 65.254.110.245:8080
05:48:34:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:48:34:WU01:FS01:Connecting to 18.218.241.186:80
05:48:35:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:48:35:ERROR:WU01:FS01:Exception: Could not get an assignment
05:49:10:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
05:51:11:WU01:FS01:Connecting to 65.254.110.245:8080
05:51:12:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:51:12:WU01:FS01:Connecting to 18.218.241.186:80
05:51:12:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:51:12:ERROR:WU01:FS01:Exception: Could not get an assignment
05:51:25:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
05:53:41:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
05:55:26:WU01:FS01:Connecting to 65.254.110.245:8080
05:55:26:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:55:26:WU01:FS01:Connecting to 18.218.241.186:80
05:55:26:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:55:26:ERROR:WU01:FS01:Exception: Could not get an assignment
05:55:58:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
05:58:14:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
06:00:30:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
06:02:17:WU01:FS01:Connecting to 65.254.110.245:8080
06:02:17:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:02:17:WU01:FS01:Connecting to 18.218.241.186:80
06:02:18:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:02:18:ERROR:WU01:FS01:Exception: Could not get an assignment
06:02:46:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
06:05:02:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
06:07:18:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
06:09:34:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
06:11:49:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
06:13:23:WU01:FS01:Connecting to 65.254.110.245:8080
06:13:23:WU01:FS01:Assigned to work server 140.163.4.231
06:13:23:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [Quadro K600] from 140.163.4.231
06:13:23:WU01:FS01:Connecting to 140.163.4.231:8080
06:13:44:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
06:13:44:WU01:FS01:Connecting to 140.163.4.231:80
06:14:04:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
06:14:05:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
06:16:19:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
06:18:33:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
06:20:47:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
06:23:01:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
06:25:15:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
06:27:30:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
06:29:43:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
06:31:20:WU01:FS01:Connecting to 65.254.110.245:8080
06:31:20:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:31:20:WU01:FS01:Connecting to 18.218.241.186:80
06:31:20:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:31:20:ERROR:WU01:FS01:Exception: Could not get an assignment
06:32:00:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
06:34:16:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
06:36:32:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
06:38:48:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
06:41:04:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
06:43:20:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
06:45:36:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
06:47:52:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
06:50:07:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
06:52:23:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
06:54:40:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
06:56:56:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
06:59:12:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
07:00:22:WU01:FS01:Connecting to 65.254.110.245:8080
07:00:22:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:00:22:WU01:FS01:Connecting to 18.218.241.186:80
07:00:22:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:00:22:ERROR:WU01:FS01:Exception: Could not get an assignment
07:01:28:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
07:03:44:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
07:06:00:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
07:08:15:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
07:10:30:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
07:12:46:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
07:15:01:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
07:17:17:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
07:19:33:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
07:21:49:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
07:24:05:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
07:26:21:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
07:28:37:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
07:30:53:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
07:33:08:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
07:35:22:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
07:37:36:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
07:39:51:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
07:42:05:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
07:44:19:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
07:46:34:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
07:47:21:WU01:FS01:Connecting to 65.254.110.245:8080
07:47:21:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:47:21:WU01:FS01:Connecting to 18.218.241.186:80
07:47:21:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:47:21:ERROR:WU01:FS01:Exception: Could not get an assignment
07:48:49:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
07:51:03:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
07:53:17:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
07:55:31:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
07:57:45:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
07:59:59:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
08:02:14:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
08:04:27:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
08:06:41:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
08:08:55:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
08:08:56:WU02:FS00:Connecting to 65.254.110.245:8080
08:08:56:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:08:56:WU02:FS00:Connecting to 18.218.241.186:80
08:08:56:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:08:56:ERROR:WU02:FS00:Exception: Could not get an assignment
08:08:57:WU02:FS00:Connecting to 65.254.110.245:8080
08:08:57:WU02:FS00:Assigned to work server 13.82.98.119
08:08:57:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 13.82.98.119
08:08:57:WU02:FS00:Connecting to 13.82.98.119:8080
08:08:57:WU02:FS00:Downloading 7.46MiB
08:09:03:WU02:FS00:Download 87.18%
08:09:03:WU02:FS00:Download complete
08:09:03:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13871 run:0 clone:1182 gen:27 core:0xa7 unit:0x000000220d5262775e791baae30727f1
08:11:10:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
08:11:12:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
08:11:12:WU00:FS00:0xa7:Saving result file dhdl.xvg
08:11:12:WU00:FS00:0xa7:Saving result file frame12.trr
08:11:12:WU00:FS00:0xa7:Saving result file md.log
08:11:12:WU00:FS00:0xa7:Saving result file pullf.xvg
08:11:12:WU00:FS00:0xa7:Saving result file pullx.xvg
08:11:12:WU00:FS00:0xa7:Saving result file science.log
08:11:12:WU00:FS00:0xa7:Saving result file traj_comp.xtc
08:11:12:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
08:11:12:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:11:12:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14367 run:1028 clone:2 gen:12 core:0xa7 unit:0x0000000c9bf7a4d55e84b13d296694a1
08:11:12:WU00:FS00:Uploading 6.50MiB to 155.247.164.213
08:11:12:WU00:FS00:Connecting to 155.247.164.213:8080
08:11:12:WU02:FS00:Starting
08:11:12:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\_username_\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 1712 -checkpoint 15 -np 7
08:11:12:WU02:FS00:Started FahCore on PID 5200
08:11:12:WU02:FS00:Core PID:2800
08:11:12:WU02:FS00:FahCore 0xa7 started
08:11:12:WU02:FS00:0xa7:*********************** Log Started 2020-04-06T08:11:12Z ***********************
08:11:12:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:11:12:WU02:FS00:0xa7:       Type: 0xa7
08:11:12:WU02:FS00:0xa7:       Core: Gromacs
08:11:12:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 5200 -checkpoint 15 -np 7
08:11:12:WU02:FS00:0xa7:************************************ CBang *************************************
08:11:12:WU02:FS00:0xa7:       Date: Oct 26 2019
08:11:12:WU02:FS00:0xa7:       Time: 01:38:25
08:11:12:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:11:12:WU02:FS00:0xa7:     Branch: master
08:11:12:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
08:11:12:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:11:12:WU02:FS00:0xa7:   Platform: win32 10
08:11:12:WU02:FS00:0xa7:       Bits: 64
08:11:12:WU02:FS00:0xa7:       Mode: Release
08:11:12:WU02:FS00:0xa7:************************************ System ************************************
08:11:12:WU02:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
08:11:12:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
08:11:12:WU02:FS00:0xa7:       CPUs: 8
08:11:13:WU02:FS00:0xa7:     Memory: 15.93GiB
08:11:13:WU02:FS00:0xa7:Free Memory: 12.94GiB
08:11:13:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
08:11:13:WU02:FS00:0xa7: OS Version: 6.2
08:11:13:WU02:FS00:0xa7:Has Battery: false
08:11:13:WU02:FS00:0xa7: On Battery: false
08:11:13:WU02:FS00:0xa7: UTC Offset: -7
08:11:13:WU02:FS00:0xa7:        PID: 2800
08:11:13:WU02:FS00:0xa7:        CWD: C:\Users\_username_\AppData\Roaming\FAHClient\work
08:11:13:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
08:11:13:WU02:FS00:0xa7:    Version: 0.0.18
08:11:13:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:11:13:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:11:13:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
08:11:13:WU02:FS00:0xa7:       Date: Oct 26 2019
08:11:13:WU02:FS00:0xa7:       Time: 01:52:30
08:11:13:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:11:13:WU02:FS00:0xa7:     Branch: master
08:11:13:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
08:11:13:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:11:13:WU02:FS00:0xa7:   Platform: win32 10
08:11:13:WU02:FS00:0xa7:       Bits: 64
08:11:13:WU02:FS00:0xa7:       Mode: Release
08:11:13:WU02:FS00:0xa7:************************************ Build *************************************
08:11:13:WU02:FS00:0xa7:       SIMD: avx_256
08:11:13:WU02:FS00:0xa7:********************************************************************************
08:11:13:WU02:FS00:0xa7:Project: 13871 (Run 0, Clone 1182, Gen 27)
08:11:13:WU02:FS00:0xa7:Unit: 0x000000220d5262775e791baae30727f1
08:11:13:WU02:FS00:0xa7:Reading tar file core.xml
08:11:13:WU02:FS00:0xa7:Reading tar file frame27.tpr
08:11:13:WU02:FS00:0xa7:Digital signatures verified
08:11:13:WU02:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
08:11:13:WU02:FS00:0xa7:Calling: mdrun -s frame27.tpr -o frame27.trr -x frame27.xtc -e frame27.edr -cpt 15 -nt 6
08:11:13:WU02:FS00:0xa7:Steps: first=3375000 total=125000
08:11:15:WU02:FS00:0xa7:Completed 1 out of 125000 steps (0%)
08:11:19:WU00:FS00:Upload 2.89%
08:11:25:WU00:FS00:Upload 34.63%
08:11:31:WU00:FS00:Upload 68.29%
08:11:36:WU00:FS00:Upload complete
08:11:37:WU00:FS00:Server responded WORK_ACK (400)
08:11:37:WU00:FS00:Final credit estimate, 3528.00 points
08:11:37:WU00:FS00:Cleaning up
08:13:40:WU02:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
08:16:05:WU02:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
08:18:30:WU02:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
08:20:53:WU02:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
08:23:16:WU02:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
08:25:39:WU02:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
08:28:02:WU02:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
08:30:25:WU02:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
08:32:48:WU02:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
08:35:10:WU02:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
08:37:33:WU02:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
08:39:56:WU02:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
08:42:19:WU02:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
08:44:42:WU02:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
08:47:04:WU02:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
08:49:27:WU02:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
08:51:50:WU02:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
08:54:13:WU02:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
08:56:36:WU02:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
08:58:59:WU02:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
09:01:22:WU02:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
09:03:22:WU01:FS01:Connecting to 65.254.110.245:8080
09:03:22:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:03:22:WU01:FS01:Connecting to 18.218.241.186:80
09:03:22:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:03:22:ERROR:WU01:FS01:Exception: Could not get an assignment
09:03:44:WU02:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
09:06:07:WU02:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
09:08:29:WU02:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
09:10:52:WU02:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
09:13:16:WU02:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
09:15:39:WU02:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
09:18:02:WU02:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
09:20:25:WU02:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
09:22:48:WU02:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
09:25:11:WU02:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
09:27:35:WU02:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
09:29:57:WU02:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
09:32:20:WU02:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
09:34:42:WU02:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
09:37:05:WU02:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
09:39:28:WU02:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
09:41:51:WU02:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
09:44:14:WU02:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
09:46:36:WU02:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
09:48:59:WU02:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
09:51:21:WU02:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
09:53:44:WU02:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
09:56:07:WU02:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
09:58:30:WU02:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
10:00:53:WU02:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
10:03:15:WU02:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
10:05:38:WU02:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
10:08:00:WU02:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
10:10:23:WU02:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
10:12:46:WU02:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
10:15:09:WU02:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
10:17:31:WU02:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
10:19:54:WU02:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
10:22:16:WU02:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
10:24:39:WU02:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
10:27:02:WU02:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
10:29:25:WU02:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
10:31:47:WU02:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
10:34:10:WU02:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
10:36:32:WU02:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
10:38:55:WU02:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
10:41:19:WU02:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
10:43:41:WU02:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
10:46:04:WU02:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
10:48:27:WU02:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
10:50:49:WU02:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
10:53:13:WU02:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
10:55:36:WU02:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
10:58:00:WU02:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
11:00:23:WU02:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
11:02:46:WU02:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
11:05:09:WU02:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
11:06:21:WU01:FS01:Connecting to 65.254.110.245:8080
11:06:22:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:06:22:WU01:FS01:Connecting to 18.218.241.186:80
11:06:22:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:06:22:ERROR:WU01:FS01:Exception: Could not get an assignment
11:07:32:WU02:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
11:09:55:WU02:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
11:12:19:WU02:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
11:14:41:WU02:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
11:17:04:WU02:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
******************************* Date: 2020-04-06 *******************************
11:19:27:WU02:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
11:21:49:WU02:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
11:24:12:WU02:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
11:26:36:WU02:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
11:28:58:WU02:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
11:31:21:WU02:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
11:33:43:WU02:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
11:36:06:WU02:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
11:38:29:WU02:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
11:40:52:WU02:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
11:43:16:WU02:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
11:45:38:WU02:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
11:48:01:WU02:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
11:50:23:WU02:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
11:52:46:WU02:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
11:55:09:WU02:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
11:57:33:WU02:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
11:59:55:WU02:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
12:02:18:WU02:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
12:04:41:WU02:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
12:07:04:WU02:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
12:07:05:WU00:FS00:Connecting to 65.254.110.245:8080
12:07:05:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:07:05:WU00:FS00:Connecting to 18.218.241.186:80
12:07:05:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:07:05:ERROR:WU00:FS00:Exception: Could not get an assignment
12:07:06:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:07:06:WU00:FS00:Connecting to 18.218.241.186:80
12:07:06:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:07:06:ERROR:WU00:FS00:Exception: Could not get an assignment
12:08:06:WU00:FS00:Connecting to 65.254.110.245:8080
12:08:06:WU00:FS00:Assigned to work server 40.114.52.201
12:08:06:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 40.114.52.201
12:08:06:WU00:FS00:Connecting to 40.114.52.201:8080
12:08:30:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
12:09:27:WU02:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
12:09:31:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
12:09:31:WU02:FS00:0xa7:Saving result file frame27.edr
12:09:31:WU02:FS00:0xa7:Saving result file frame27.trr
12:09:31:WU02:FS00:0xa7:Saving result file frame27.xtc
12:09:31:WU02:FS00:0xa7:Saving result file md.log
12:09:31:WU02:FS00:0xa7:Saving result file science.log
12:09:31:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
12:09:32:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:09:32:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13871 run:0 clone:1182 gen:27 core:0xa7 unit:0x000000220d5262775e791baae30727f1
12:09:32:WU02:FS00:Uploading 10.10MiB to 13.82.98.119
12:09:32:WU02:FS00:Connecting to 13.82.98.119:8080
12:09:38:WU02:FS00:Upload 18.57%
12:09:43:WU00:FS00:Connecting to 65.254.110.245:8080
12:09:43:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:09:43:WU00:FS00:Connecting to 18.218.241.186:80
12:09:44:WU02:FS00:Upload 40.22%
12:09:44:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:09:44:ERROR:WU00:FS00:Exception: Could not get an assignment
12:09:50:WU02:FS00:Upload 61.88%
12:09:56:WU02:FS00:Upload 83.54%
12:10:00:WU02:FS00:Upload complete
12:10:00:WU02:FS00:Server responded WORK_ACK (400)
12:10:00:WU02:FS00:Final credit estimate, 4480.00 points
12:10:00:WU02:FS00:Cleaning up
12:12:20:WU00:FS00:Connecting to 65.254.110.245:8080
12:12:20:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:12:20:WU00:FS00:Connecting to 18.218.241.186:80
12:12:20:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:12:20:ERROR:WU00:FS00:Exception: Could not get an assignment
12:16:34:WU00:FS00:Connecting to 65.254.110.245:8080
12:16:34:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:16:34:WU00:FS00:Connecting to 18.218.241.186:80
12:16:35:WU00:FS00:Assigned to work server 13.82.98.119
12:16:35:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 13.82.98.119
12:16:35:WU00:FS00:Connecting to 13.82.98.119:8080
12:16:35:ERROR:WU00:FS00:Exception: Server did not assign work unit
12:23:26:WU00:FS00:Connecting to 65.254.110.245:8080
12:23:26:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:23:26:WU00:FS00:Connecting to 18.218.241.186:80
12:23:26:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:23:26:ERROR:WU00:FS00:Exception: Could not get an assignment
12:34:31:WU00:FS00:Connecting to 65.254.110.245:8080
12:34:31:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:34:31:WU00:FS00:Connecting to 18.218.241.186:80
12:34:32:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:34:32:ERROR:WU00:FS00:Exception: Could not get an assignment
12:52:28:WU00:FS00:Connecting to 65.254.110.245:8080
12:52:28:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:52:28:WU00:FS00:Connecting to 18.218.241.186:80
toTOW wrote:Do you use a 64 bit OS ? If yes, update your GPU drivers, else, you need a 64 bits OS.
Yes, it's a 64bit os. I upgraded the driver when I learned about &installed F@H. I'll clean reinstall it for thoroughness.
l2g2h
Post by l2g2h »
I clean install reinstalled the nvidia driver. Error persists.
Can you please post a fresh copy of the logs which shows what the system configuration is and how the client is setup?
l2g2h
Post by l2g2h »
Here's the logs for 4-7-2020.
******************************* Date: 2020-04-07 *******************************
02:50:01:WU00:FS00:Connecting to 65.254.110.245:8080
02:50:01:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:50:01:WU00:FS00:Connecting to 18.218.241.186:80
02:50:02:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:50:02:ERROR:WU00:FS00:Exception: Could not get an assignment
06:09:02:WU00:FS00:Connecting to 65.254.110.245:8080
06:09:02:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:09:02:WU00:FS00:Connecting to 18.218.241.186:80
06:09:02:WU00:FS00:Assigned to work server 40.114.52.201
06:09:02:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 40.114.52.201
06:09:02:WU00:FS00:Connecting to 40.114.52.201:8080
06:09:23:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
06:09:23:WU00:FS00:Connecting to 40.114.52.201:80
06:09:44:ERROR:WU00:FS00:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:31:01:WU00:FS00:Connecting to 65.254.110.245:8080
11:31:02:WU00:FS00:Assigned to work server 155.247.164.214
11:31:02:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.164.214
11:31:02:WU00:FS00:Connecting to 155.247.164.214:8080
11:31:02:WU00:FS00:Downloading 3.02MiB
11:31:06:WU00:FS00:Download complete
11:31:06:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14610 run:26 clone:1 gen:23 core:0xa7 unit:0x000000189bf7a4d65e7ba1282ab9d942
11:31:06:WU00:FS00:Starting
11:31:06:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\william\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 3824 -checkpoint 15 -np 7
11:31:06:WU00:FS00:Started FahCore on PID 3344
11:31:06:WU00:FS00:Core PID:6316
11:31:06:WU00:FS00:FahCore 0xa7 started
11:31:06:WU00:FS00:0xa7:*********************** Log Started 2020-04-07T11:31:06Z ***********************
11:31:06:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:31:06:WU00:FS00:0xa7:       Type: 0xa7
11:31:06:WU00:FS00:0xa7:       Core: Gromacs
11:31:06:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 3344 -checkpoint 15 -np 7
11:31:06:WU00:FS00:0xa7:************************************ CBang *************************************
11:31:06:WU00:FS00:0xa7:       Date: Oct 26 2019
11:31:06:WU00:FS00:0xa7:       Time: 01:38:25
11:31:06:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:31:06:WU00:FS00:0xa7:     Branch: master
11:31:06:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:31:06:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:31:06:WU00:FS00:0xa7:   Platform: win32 10
11:31:06:WU00:FS00:0xa7:       Bits: 64
11:31:06:WU00:FS00:0xa7:       Mode: Release
11:31:06:WU00:FS00:0xa7:************************************ System ************************************
11:31:06:WU00:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
11:31:06:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
11:31:06:WU00:FS00:0xa7:       CPUs: 8
11:31:06:WU00:FS00:0xa7:     Memory: 15.93GiB
11:31:06:WU00:FS00:0xa7:Free Memory: 13.75GiB
11:31:06:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:31:06:WU00:FS00:0xa7: OS Version: 6.2
11:31:06:WU00:FS00:0xa7:Has Battery: false
11:31:06:WU00:FS00:0xa7: On Battery: false
11:31:06:WU00:FS00:0xa7: UTC Offset: -7
11:31:06:WU00:FS00:0xa7:        PID: 6316
11:31:06:WU00:FS00:0xa7:        CWD: C:\Users\\AppData\Roaming\FAHClient\work
11:31:06:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:31:06:WU00:FS00:0xa7:    Version: 0.0.18
11:31:06:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:31:06:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:31:06:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:31:06:WU00:FS00:0xa7:       Time: 01:52:30
11:31:06:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:31:06:WU00:FS00:0xa7:************************************ Build *************************************
11:31:06:WU00:FS00:0xa7:       SIMD: avx_256
11:31:06:WU00:FS00:0xa7:********************************************************************************
11:31:06:WU00:FS00:0xa7:Project: 14610 (Run 26, Clone 1, Gen 23)
11:31:06:WU00:FS00:0xa7:Unit: 0x000000189bf7a4d65e7ba1282ab9d942
11:31:06:WU00:FS00:0xa7:Reading tar file core.xml
11:31:06:WU00:FS00:0xa7:Reading tar file frame23.tpr
11:31:06:WU00:FS00:0xa7:Digital signatures verified
11:31:06:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
11:31:06:WU00:FS00:0xa7:Calling: mdrun -s frame23.tpr -o frame23.trr -cpt 15 -nt 6
11:31:06:WU00:FS00:0xa7:Steps: first=0 total=250000
11:31:08:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
11:33:52:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
11:36:38:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
11:39:22:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
11:42:06:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
11:44:49:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
11:47:33:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
11:50:16:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
11:52:59:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
11:55:43:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
11:58:26:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
12:01:10:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
12:03:53:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
12:06:37:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
12:09:20:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
12:12:03:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
12:14:46:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
12:17:30:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
12:20:12:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
12:22:56:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
12:25:39:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
12:28:21:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
12:31:04:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
12:33:47:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
12:36:30:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
12:39:13:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
12:41:55:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
12:44:38:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
12:47:21:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
12:50:04:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
12:52:47:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
12:55:30:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
12:58:12:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
13:00:54:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
13:03:37:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
13:06:20:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
13:09:03:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
13:11:46:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
13:14:29:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
13:17:11:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
13:19:54:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
13:22:36:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
13:25:20:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
13:28:02:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
13:30:45:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
13:33:27:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
13:36:10:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
13:38:53:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
13:41:35:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
13:44:18:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
13:47:00:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
13:49:43:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
13:52:26:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
13:55:09:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
13:57:52:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
14:00:34:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
14:03:17:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
14:06:01:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
14:08:43:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
14:11:25:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
14:14:08:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
14:16:51:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
14:19:34:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
14:22:16:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
14:24:59:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
14:27:42:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
14:30:25:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
14:33:07:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
14:35:51:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
14:38:33:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
14:41:17:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
14:43:59:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
14:46:42:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
14:49:25:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
14:52:08:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
14:54:51:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
14:57:33:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
15:00:17:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
15:03:00:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
15:05:43:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
15:08:27:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
15:11:10:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
15:13:53:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
15:16:36:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
15:19:19:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
15:22:02:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
15:24:46:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
15:27:31:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
15:30:17:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
15:33:03:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
15:35:48:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
15:38:33:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
15:41:18:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
15:44:03:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
15:46:49:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
15:49:34:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
15:52:20:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
15:55:06:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
15:57:51:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
16:00:37:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
16:00:37:WU02:FS00:Connecting to 65.254.110.245:8080
16:00:37:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:00:37:WU02:FS00:Connecting to 18.218.241.186:80
16:00:37:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:00:37:ERROR:WU02:FS00:Exception: Could not get an assignment
16:00:38:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:00:38:WU02:FS00:Connecting to 18.218.241.186:80
16:00:38:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:00:38:ERROR:WU02:FS00:Exception: Could not get an assignment
16:01:38:WU02:FS00:Connecting to 65.254.110.245:8080
16:01:38:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:01:38:WU02:FS00:Connecting to 18.218.241.186:80
16:01:38:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:01:38:ERROR:WU02:FS00:Exception: Could not get an assignment
16:03:15:WU02:FS00:Connecting to 65.254.110.245:8080
16:03:15:WU02:FS00:Assigned to work server 168.245.198.125
16:03:15:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 168.245.198.125
16:03:15:WU02:FS00:Connecting to 168.245.198.125:8080
16:03:15:WU02:FS00:Downloading 1.92MiB
16:03:16:WU02:FS00:Download complete
16:03:16:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16405 run:0 clone:1354 gen:18 core:0xa7 unit:0x00000013a8f5c67d5e83ae93c3018d49
16:03:22:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
16:03:24:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
16:03:24:WU00:FS00:0xa7:Saving result file dhdl.xvg
16:03:24:WU00:FS00:0xa7:Saving result file frame23.trr
16:03:24:WU00:FS00:0xa7:Saving result file md.log
16:03:24:WU00:FS00:0xa7:Saving result file pullf.xvg
16:03:24:WU00:FS00:0xa7:Saving result file pullx.xvg
16:03:24:WU00:FS00:0xa7:Saving result file science.log
16:03:24:WU00:FS00:0xa7:Saving result file traj_comp.xtc
16:03:24:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
16:03:25:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:03:25:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14610 run:26 clone:1 gen:23 core:0xa7 unit:0x000000189bf7a4d65e7ba1282ab9d942
16:03:25:WU00:FS00:Uploading 6.77MiB to 155.247.164.214
16:03:25:WU02:FS00:Starting
16:03:25:WU00:FS00:Connecting to 155.247.164.214:8080
16:03:25:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\william\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 3824 -checkpoint 15 -np 7
16:03:25:WU02:FS00:Started FahCore on PID 3188
16:03:25:WU02:FS00:Core PID:2464
16:03:25:WU02:FS00:FahCore 0xa7 started
16:03:25:WU02:FS00:0xa7:*********************** Log Started 2020-04-07T16:03:25Z ***********************
16:03:25:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:03:25:WU02:FS00:0xa7:       Type: 0xa7
16:03:25:WU02:FS00:0xa7:       Core: Gromacs
16:03:25:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 3188 -checkpoint 15 -np 7
16:03:25:WU02:FS00:0xa7:************************************ CBang *************************************
16:03:25:WU02:FS00:0xa7:       Date: Oct 26 2019
16:03:25:WU02:FS00:0xa7:       Time: 01:38:25
16:03:25:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:03:25:WU02:FS00:0xa7:     Branch: master
16:03:25:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
16:03:25:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:03:25:WU02:FS00:0xa7:   Platform: win32 10
16:03:25:WU02:FS00:0xa7:       Bits: 64
16:03:25:WU02:FS00:0xa7:       Mode: Release
16:03:25:WU02:FS00:0xa7:************************************ System ************************************
16:03:25:WU02:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
16:03:25:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
16:03:25:WU02:FS00:0xa7:       CPUs: 8
16:03:25:WU02:FS00:0xa7:     Memory: 15.93GiB
16:03:25:WU02:FS00:0xa7:Free Memory: 13.72GiB
16:03:25:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
16:03:25:WU02:FS00:0xa7: OS Version: 6.2
16:03:25:WU02:FS00:0xa7:Has Battery: false
16:03:25:WU02:FS00:0xa7: On Battery: false
16:03:25:WU02:FS00:0xa7: UTC Offset: -7
16:03:25:WU02:FS00:0xa7:        PID: 2464
16:03:25:WU02:FS00:0xa7:        CWD: C:\Users\william\AppData\Roaming\FAHClient\work
16:03:25:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
16:03:25:WU02:FS00:0xa7:    Version: 0.0.18
16:03:25:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:03:25:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:03:25:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
16:03:25:WU02:FS00:0xa7:       Time: 01:52:30
16:03:25:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:03:26:WU02:FS00:0xa7:       Bits: 64
16:03:26:WU02:FS00:0xa7:       Mode: Release
16:03:26:WU02:FS00:0xa7:************************************ Build *************************************
16:03:26:WU02:FS00:0xa7:       SIMD: avx_256
16:03:26:WU02:FS00:0xa7:********************************************************************************
16:03:26:WU02:FS00:0xa7:Project: 16405 (Run 0, Clone 1354, Gen 18)
16:03:26:WU02:FS00:0xa7:Unit: 0x00000013a8f5c67d5e83ae93c3018d49
16:03:26:WU02:FS00:0xa7:Reading tar file core.xml
16:03:26:WU02:FS00:0xa7:Reading tar file frame18.tpr
16:03:26:WU02:FS00:0xa7:Digital signatures verified
16:03:26:WU02:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
16:03:26:WU02:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -x frame18.xtc -cpt 15 -nt 6
16:03:26:WU02:FS00:0xa7:Steps: first=4500000 total=250000
16:03:26:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
16:03:31:WU00:FS00:Upload 28.64%
16:03:37:WU00:FS00:Upload 60.05%
16:03:43:WU00:FS00:Upload 91.45%
16:03:45:WU00:FS00:Upload complete
16:03:45:WU00:FS00:Server responded WORK_ACK (400)
16:03:45:WU00:FS00:Final credit estimate, 4456.00 points
16:03:45:WU00:FS00:Cleaning up
16:04:32:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
16:05:38:WU02:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
16:06:44:WU02:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
16:07:49:WU02:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
16:08:55:WU02:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
16:10:01:WU02:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
16:11:07:WU02:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
16:12:13:WU02:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
16:13:19:WU02:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
I'm afraid that Win Server 2012 R2 might have some missing features to support Core 22 ... :?
l2g2h
Post by l2g2h »
Is there knowledge of any prior Fah version working with server 2012? Does the current version work with server 2016 and/or 2019?
Technically speaking until covid policy changes and/or govt sends us back to work the machines at the office aren't any good to me/my employees so it makes sense for me to dual boot w10 temporarily to aid in the fight to get us all back to work - for w/e difference the gpu makes.
The issue is not the F@h client version, but the folding core that gets downloaded by the client to process the GPU WUs. There are two, Core_21 is an older one, a few older, non-COVID-19 projects use that. The current Core_22 is more recent, it is possible they did not compile it against libraries that would be present in and supported by Windows 8 / Server 2012. Or possibly a library needed by the core is an optional install on the server version.
Server 2016 & 19 should work being based on Windows 10, but not certain as I do not recall the question coming up before.
If you do boot into Win 10, the Quadro K2000 would have approximately the processing power of a GTX 650. That is capable of completing current GPU assignments reasonably well, but no speed demon.
l2g2h
Post by l2g2h »
New Error. This is on W10. I uninstalled as the error suggested -> restarted -> installed -> restarted -> started F@H -> issue persists.
FahCore_22.exe - System Error
The code execution cannot proceed because OpenCL.dll was not found. Reinstalling the program may fix this problem.
*********************** Log Started 2020-04-09T03:59:01Z ***********************
03:59:01:************************* Folding@home Client *************************
03:59:01:        Website: https://foldingathome.org/
03:59:01:      Copyright: (c) 2009-2018 foldingathome.org
03:59:01:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:59:01:           Args: --open-web-control
03:59:01:         Config: C:\Users\\AppData\Roaming\FAHClient\config.xml
03:59:01:******************************** Build ********************************
03:59:01:        Version: 7.5.1
03:59:01:           Date: May 11 2018
03:59:01:           Time: 13:06:32
03:59:01:     Repository: Git
03:59:01:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
03:59:01:         Branch: master
03:59:01:       Compiler: Visual C++ 2008
03:59:01:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:59:01:       Platform: win32 10
03:59:01:           Bits: 32
03:59:01:           Mode: Release
03:59:01:******************************* System ********************************
03:59:01:            CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
03:59:01:         CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
03:59:01:           CPUs: 8
03:59:01:         Memory: 15.93GiB
03:59:01:    Free Memory: 13.99GiB
03:59:01:        Threads: WINDOWS_THREADS
03:59:01:     OS Version: 6.2
03:59:01:    Has Battery: false
03:59:01:     On Battery: false
03:59:01:     UTC Offset: -7
03:59:01:            PID: 656
03:59:01:            CWD: C:\Users\\AppData\Roaming\FAHClient
03:59:01:             OS: Windows 10 Enterprise
03:59:01:        OS Arch: AMD64
03:59:01:           GPUs: 1
03:59:01:          GPU 0: Bus:3 Slot:0 Func:0 NVIDIA:3 GK107 [Quadro K600]
03:59:01:  CUDA Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:3.0 Driver:7.5
03:59:01:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:353.62
03:59:01:  Win32 Service: false
03:59:01:***********************************************************************
03:59:01:<config>
03:59:01:  <!-- Network -->
03:59:01:  <proxy v=':8080'/>
03:59:01:
03:59:01:  <!-- Slot Control -->
03:59:01:  <power v='full'/>
03:59:01:
03:59:01:  <!-- User Information -->
03:59:01:  <team v=''/>
03:59:01:  <user v=''/>
03:59:01:
03:59:01:  <!-- Folding Slots -->
03:59:01:  <slot id='0' type='CPU'/>
03:59:01:  <slot id='1' type='GPU'/>
03:59:01:</config>
03:59:01:Trying to access database...
03:59:01:Successfully acquired database lock
03:59:01:Enabled folding slot 00: READY cpu:7
03:59:01:Enabled folding slot 01: READY gpu:0:GK107 [Quadro K600]
03:59:01:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:11764 run:0 clone:1100 gen:16 core:0x22 unit:0x0000002780fccb0a5e6d81935e331d0f
03:59:02:WU00:FS01:Starting
03:59:02:WU01:FS01:Connecting to 128.252.203.10:8080
03:59:02:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\william\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 656 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
03:59:02:WU00:FS01:Started FahCore on PID 7724
03:59:02:WU00:FS01:Core PID:3984
03:59:02:WU00:FS01:FahCore 0x22 started
03:59:02:WU03:FS00:Starting
03:59:02:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\william\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 705 -lifeline 656 -checkpoint 15 -np 7
03:59:02:WU03:FS00:Started FahCore on PID 4780
03:59:03:WU03:FS00:Core PID:4704
03:59:03:WU03:FS00:FahCore 0xa7 started
03:59:04:WU03:FS00:0xa7:*********************** Log Started 2020-04-09T03:59:03Z ***********************
03:59:04:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:59:04:WU03:FS00:0xa7:       Type: 0xa7
03:59:04:WU03:FS00:0xa7:       Core: Gromacs
03:59:04:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 705 -lifeline 4780 -checkpoint 15 -np 7
03:59:04:WU03:FS00:0xa7:************************************ CBang *************************************
03:59:04:WU03:FS00:0xa7:       Date: Oct 26 2019
03:59:04:WU03:FS00:0xa7:       Time: 01:38:25
03:59:04:WU03:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:59:04:WU03:FS00:0xa7:     Branch: master
03:59:04:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
03:59:04:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:59:04:WU03:FS00:0xa7:   Platform: win32 10
03:59:04:WU03:FS00:0xa7:       Bits: 64
03:59:04:WU03:FS00:0xa7:       Mode: Release
03:59:04:WU03:FS00:0xa7:************************************ System ************************************
03:59:04:WU03:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
03:59:04:WU03:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
03:59:04:WU03:FS00:0xa7:       CPUs: 8
03:59:04:WU03:FS00:0xa7:     Memory: 15.93GiB
03:59:04:WU03:FS00:0xa7:Free Memory: 13.97GiB
03:59:04:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
03:59:04:WU03:FS00:0xa7: OS Version: 6.2
03:59:04:WU03:FS00:0xa7:Has Battery: false
03:59:04:WU03:FS00:0xa7: On Battery: false
03:59:04:WU03:FS00:0xa7: UTC Offset: -7
03:59:04:WU03:FS00:0xa7:        PID: 4704
03:59:04:WU03:FS00:0xa7:        CWD: C:\Users\\AppData\Roaming\FAHClient\work
03:59:04:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
03:59:04:WU03:FS00:0xa7:    Version: 0.0.18
03:59:04:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:59:04:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:59:04:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
03:59:04:WU03:FS00:0xa7:       Time: 01:52:30
03:59:04:WU03:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:59:04:WU03:FS00:0xa7:************************************ Build *************************************
03:59:04:WU03:FS00:0xa7:       SIMD: avx_256
03:59:04:WU03:FS00:0xa7:********************************************************************************
03:59:04:WU03:FS00:0xa7:Project: 16402 (Run 0, Clone 364, Gen 49)
03:59:04:WU03:FS00:0xa7:Unit: 0x0000003596880e6e5e7ebe0d8c38348f
03:59:04:WU03:FS00:0xa7:Digital signatures verified
03:59:04:WU03:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
03:59:04:WU03:FS00:0xa7:Calling: mdrun -s frame49.tpr -o frame49.trr -x frame49.xtc -cpi state.cpt -cpt 15 -nt 6
03:59:05:WU03:FS00:0xa7:Steps: first=24500000 total=500000
03:59:07:WU03:FS00:0xa7:Completed 222842 out of 500000 steps (44%)
03:59:55:WU03:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
04:00:04:WU01:FS01:Server responded WORK_ACK (400)
04:00:04:WU01:FS01:Cleaning up
04:01:50:WU03:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
04:03:35:WU03:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
04:05:21:WU03:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
04:07:06:WU03:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
04:08:52:WU03:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
04:10:37:WU03:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
04:12:23:WU03:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
04:14:08:WU03:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
04:15:53:WU03:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
04:17:39:WU03:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
04:19:25:WU03:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
04:21:10:WU03:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
04:22:55:WU03:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
04:24:40:WU03:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
04:26:26:WU03:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
04:28:11:WU03:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
04:29:57:WU03:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
Re: FahCore_22.exe Entry Point Not Found
Drivers are rather old ... :(
Did you get them from nVidia (and not from Microsoft) ?
