Geforce 9600GT Ubuntu never gets job, connection timeout
Citosicarius
Post by Citosicarius »
I've been searching through help requests, not sure if this is a drive problem or not .. have done everything I can see or figure out for myself, not sure where to go.
I'm getting repeated 'Failed to connect to 192.0.2.1:80' but the CPU on the same system is folding away no problem
I have the Nvidia 340.107 drivers installed,
Verified with clinfo that I have OpenCL 1.2 and CUDA
Before getting too deep into this problem, is it even worth trying to get the 9600 to fold?
12:27:14:************************* Folding@home Client *************************
12:27:14:        Website: https://foldingathome.org/
12:27:14:      Copyright: (c) 2009-2018 foldingathome.org
12:27:14:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:27:14:           Args: --child --lifeline 7545 /etc/fahclient/config.xml --run-as
12:27:14:                 fahclient --pid-file=/var/run/fahclient.pid --daemon
12:27:14:         Config: /etc/fahclient/config.xml
12:27:14:******************************** Build ********************************
12:27:14:        Version: 7.5.1
12:27:14:           Date: May 11 2018
12:27:14:           Time: 19:59:04
12:27:14:     Repository: Git
12:27:14:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:27:14:         Branch: master
12:27:14:       Compiler: GNU 6.3.0 20170516
12:27:14:        Options: -std=gnu++98 -O3 -funroll-loops
12:27:14:       Platform: linux2 4.14.0-3-amd64
12:27:14:           Bits: 64
12:27:14:           Mode: Release
12:27:14:******************************* System ********************************
12:27:14:            CPU: AMD Phenom(tm) 9150e Quad-Core Processor
12:27:14:         CPU ID: AuthenticAMD Family 16 Model 2 Stepping 3
12:27:14:           CPUs: 4
12:27:14:         Memory: 3.85GiB
12:27:14:    Free Memory: 1.25GiB
12:27:14:        Threads: POSIX_THREADS
12:27:14:     OS Version: 4.15
12:27:14:    Has Battery: false
12:27:14:     On Battery: false
12:27:14:     UTC Offset: -4
12:27:14:            PID: 7547
12:27:14:            CWD: /var/lib/fahclient
12:27:14:             OS: Linux 4.15.0-91-generic x86_64
12:27:14:        OS Arch: AMD64
12:27:14:           GPUs: 1
12:27:14:          GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:0 G94 [GeForce 9600 GT]
12:27:14:  CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.1 Driver:6.5
12:27:14:OpenCL Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.0 Driver:340.107
12:27:14:***********************************************************************
12:27:14:<config>
12:27:14:  <!-- Client Control -->
12:27:14:  <fold-anon v='true'/>
12:27:14:
12:27:14:  <!-- HTTP Server -->
12:27:14:  <allow v='127.0.0.1 192.168.0.0/24'/>
12:27:14:
12:27:14:  <!-- Network -->
12:27:14:  <proxy v=':8080'/>
12:27:14:
12:27:14:  <!-- Remote Command Server -->
12:27:14:  <command-allow-no-pass v='127.0.0.1 192.168.0.0/24'/>
12:27:14:
12:27:14:  <!-- Slot Control -->
12:27:14:  <power v='full'/>
12:27:14:
12:27:14:  <!-- User Information -->
12:27:14:  <passkey v='********************************'/>
12:27:14:  <team v='******'/>
12:27:14:  <user v='***********'/>
12:27:14:
12:27:14:  <!-- Folding Slots -->
12:27:14:  <slot id='0' type='CPU'/>
12:27:14:  <slot id='1' type='GPU'/>
12:27:14:</config>
12:27:14:Switching to user fahclient
12:27:14:Trying to access database...
12:27:14:Successfully acquired database lock
12:27:14:Enabled folding slot 00: READY cpu:3
12:27:14:Enabled folding slot 01: READY gpu:0:G94 [GeForce 9600 GT]
12:27:14:WU02:FS00:Starting
12:27:14:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 02 -suffix 01 -version 705 -lifeline 7547 -checkpoint 15 -np 3
12:27:14:WU02:FS00:Started FahCore on PID 7556
12:27:14:WU02:FS00:Core PID:7560
12:27:14:WU02:FS00:FahCore 0xa7 started
12:27:14:WU02:FS00:0xa7:*********************** Log Started 2020-04-05T12:27:14Z ***********************
12:27:14:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:27:14:WU02:FS00:0xa7:       Type: 0xa7
12:27:14:WU02:FS00:0xa7:       Core: Gromacs
12:27:14:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 7556 -checkpoint 15 -np 3
12:27:14:WU02:FS00:0xa7:************************************ CBang *************************************
12:27:14:WU02:FS00:0xa7:       Date: Nov 5 2019
12:27:14:WU02:FS00:0xa7:       Time: 05:57:01
12:27:14:WU02:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
12:27:14:WU02:FS00:0xa7:     Branch: master
12:27:14:WU02:FS00:0xa7:   Compiler: GNU 8.3.0
12:27:14:WU02:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
12:27:14:WU02:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
12:27:14:WU02:FS00:0xa7:       Bits: 64
12:27:14:WU02:FS00:0xa7:       Mode: Release
12:27:14:WU02:FS00:0xa7:************************************ System ************************************
12:27:14:WU02:FS00:0xa7:        CPU: AMD Phenom(tm) 9150e Quad-Core Processor
12:27:14:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 16 Model 2 Stepping 3
12:27:14:WU02:FS00:0xa7:       CPUs: 4
12:27:14:WU02:FS00:0xa7:     Memory: 3.85GiB
12:27:14:WU02:FS00:0xa7:Free Memory: 1.25GiB
12:27:14:WU02:FS00:0xa7:    Threads: POSIX_THREADS
12:27:14:WU02:FS00:0xa7: OS Version: 4.15
12:27:14:WU02:FS00:0xa7:Has Battery: false
12:27:14:WU02:FS00:0xa7: On Battery: false
12:27:14:WU02:FS00:0xa7: UTC Offset: -4
12:27:14:WU02:FS00:0xa7:        PID: 7560
12:27:14:WU02:FS00:0xa7:        CWD: /var/lib/fahclient/work
12:27:14:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
12:27:14:WU02:FS00:0xa7:    Version: 0.0.18
12:27:14:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:27:14:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:27:14:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
12:27:14:WU02:FS00:0xa7:       Time: 06:13:26
12:27:14:WU02:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
12:27:14:WU02:FS00:0xa7:************************************ Build *************************************
12:27:14:WU02:FS00:0xa7:       SIMD: sse2
12:27:14:WU02:FS00:0xa7:********************************************************************************
12:27:14:WU02:FS00:0xa7:Project: 13829 (Run 892, Clone 5, Gen 6)
12:27:14:WU02:FS00:0xa7:Unit: 0x0000000980fccb095e73a6027458c354
12:27:14:WU02:FS00:0xa7:Digital signatures verified
12:27:14:WU02:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -x frame6.xtc -cpi state.cpt -cpt 15 -nt 3
12:27:14:WU02:FS00:0xa7:Steps: first=750000 total=125000
12:27:15:WU00:FS01:Connecting to 65.254.110.245:8080
12:27:17:WU00:FS01:Assigned to work server 192.0.2.1
12:27:17:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:G94 [GeForce 9600 GT] from 192.0.2.1
12:27:17:WU00:FS01:Connecting to 192.0.2.1:8080
Re: Geforce 9600GT Ubuntu never gets job, connection timeout
The 9600 GT is too old to fold, all 10 of the entries for 9600 GT in the GPUs.txt file show it as blacklisted.
https://www.techpowerup.com/gpu-specs/g ... 00-gt.c206
Says no OpenCL 1.2 and no Double Precision floating point. If it could fold, it could never meet a deadline.
Citosicarius
I didn’t notice it blacklisted.. I just searched the GPUs.txt figuring if it was in there, it was good. Since it’s not gonna do anything then I’ll abort this mission.
Thank you for the replies
The list is a whitelist and a blacklist. Any entry that contains no number or a zero in the 3rd and 4th fields is blacklisted. For example:
0x10de:0x0637:::G94 [GeForce 9600 GT]
1st field is manufacturer number, 2nd is the device ID, 3rd and 4th are used by the servers to determine make and capabilities for assigning WUs.
There's talk about releasing a version of FAHCore_22 that runs on CUDA without OpenCL. Nobody has mentioned a minimum version of CUDA but my guess is it'll be 2.0. (Current is 7.x or better.) Your GPU only supports CUDA 1.1 which i'm pretty confident will still be insufficient. Upgrade your GPU
