Installed new GPU, new GPU is having problems
RiaSkies
Hardware configuration: CPU: Ryzen 7 1700 @ 3.2 GHz all core
GPU: Sapphire Pulse RX 5600 XT
Post by RiaSkies »
I just installed a new GPU today to help with my FAH performance. (Woo!)
But the new GPU doesn't much like the FAH cores. Seems like it randomly reaches a bad state, then decides to shut down the core and upload a Bad_Work_Unit to the server.
FAH log:
*********************** Log Started 2020-04-04T23:31:31Z ***********************
23:31:31:************************* Folding@home Client *************************
23:31:31:        Website: https://foldingathome.org/
23:31:31:      Copyright: (c) 2009-2018 foldingathome.org
23:31:31:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:31:31:           Args:
23:31:31:         Config: C:\Users\Ria\AppData\Roaming\FAHClient\config.xml
23:31:31:******************************** Build ********************************
23:31:31:        Version: 7.5.1
23:31:31:           Date: May 11 2018
23:31:31:           Time: 13:06:32
23:31:31:     Repository: Git
23:31:31:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
23:31:31:         Branch: master
23:31:31:       Compiler: Visual C++ 2008
23:31:31:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:31:31:       Platform: win32 10
23:31:31:           Bits: 32
23:31:31:           Mode: Release
23:31:31:******************************* System ********************************
23:31:31:            CPU: AMD Ryzen 7 1700 Eight-Core Processor
23:31:31:         CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
23:31:31:           CPUs: 16
23:31:31:         Memory: 15.95GiB
23:31:31:    Free Memory: 13.38GiB
23:31:31:        Threads: WINDOWS_THREADS
23:31:31:     OS Version: 6.2
23:31:31:    Has Battery: false
23:31:31:     On Battery: false
23:31:31:     UTC Offset: -5
23:31:31:            PID: 11072
23:31:31:            CWD: C:\Users\Ria\AppData\Roaming\FAHClient
23:31:31:             OS: Windows 10 Home
23:31:31:        OS Arch: AMD64
23:31:31:           GPUs: 1
23:31:31:          GPU 0: Bus:33 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600 XT
23:31:31:                 / 5700/5700 XT]
23:31:31:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
23:31:31:                 specified module could not be found.
23:31:31:
23:31:31:OpenCL Device 0: Platform:0 Device:0 Bus:33 Slot:0 Compute:1.2 Driver:3004.8
23:31:31:  Win32 Service: false
23:31:31:***********************************************************************
23:31:31:<config>
23:31:31:  <!-- Network -->
23:31:31:  <proxy v=':8080'/>
23:31:31:
23:31:31:  <!-- Slot Control -->
23:31:31:  <power v='full'/>
23:31:31:
23:31:31:  <!-- User Information -->
23:31:31:  <passkey v='********************************'/>
23:31:31:  <team v='232992'/>
23:31:31:  <user v='Ria_Skies'/>
23:31:31:
23:31:31:  <!-- Folding Slots -->
23:31:31:  <slot id='1' type='GPU'>
23:31:31:    <paused v='true'/>
23:31:31:  </slot>
23:31:31:  <slot id='0' type='CPU'>
23:31:31:    <cpus v='15'/>
23:31:31:  </slot>
23:31:31:</config>
23:31:31:Trying to access database...
23:31:31:Successfully acquired database lock
23:31:31:Enabled folding slot 01: PAUSED gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] (by user)
23:31:31:Enabled folding slot 00: PAUSED cpu:15 (by user)
23:33:09:FS01:Unpaused
23:33:09:FS00:Unpaused
23:33:09:WU00:FS01:Starting
23:33:09:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Ria\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 11072 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
23:33:09:WU00:FS01:Started FahCore on PID 9232
23:33:09:WU00:FS01:Core PID:12096
23:33:09:WU00:FS01:FahCore 0x22 started
23:33:10:WU01:FS00:Connecting to 65.254.110.245:8080
23:33:10:WU00:FS01:0x22:*********************** Log Started 2020-04-04T23:33:09Z ***********************
23:33:10:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
23:33:10:WU00:FS01:0x22:       Type: 0x22
23:33:10:WU00:FS01:0x22:       Core: Core22
23:33:10:WU00:FS01:0x22:    Website: https://foldingathome.org/
23:33:10:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
23:33:10:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
23:33:10:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
23:33:10:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 9232 -checkpoint 15
23:33:10:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
23:33:10:WU00:FS01:0x22:     Config: <none>
23:33:10:WU00:FS01:0x22:************************************ Build *************************************
23:33:10:WU00:FS01:0x22:    Version: 0.0.2
23:33:10:WU00:FS01:0x22:       Date: Dec 6 2019
23:33:10:WU00:FS01:0x22:       Time: 21:30:31
23:33:10:WU00:FS01:0x22: Repository: Git
23:33:10:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
23:33:10:WU00:FS01:0x22:     Branch: HEAD
23:33:10:WU00:FS01:0x22:   Compiler: Visual C++ 2008
23:33:10:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:33:10:WU00:FS01:0x22:   Platform: win32 10
23:33:10:WU00:FS01:0x22:       Bits: 64
23:33:10:WU00:FS01:0x22:       Mode: Release
23:33:10:WU00:FS01:0x22:************************************ System ************************************
23:33:10:WU00:FS01:0x22:        CPU: AMD Ryzen 7 1700 Eight-Core Processor
23:33:10:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
23:33:10:WU00:FS01:0x22:       CPUs: 16
23:33:10:WU00:FS01:0x22:     Memory: 15.95GiB
23:33:10:WU00:FS01:0x22:Free Memory: 12.98GiB
23:33:10:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
23:33:10:WU00:FS01:0x22: OS Version: 6.2
23:33:10:WU00:FS01:0x22:Has Battery: false
23:33:10:WU00:FS01:0x22: On Battery: false
23:33:10:WU00:FS01:0x22: UTC Offset: -5
23:33:10:WU00:FS01:0x22:        PID: 12096
23:33:10:WU00:FS01:0x22:        CWD: C:\Users\Ria\AppData\Roaming\FAHClient\work
23:33:10:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:33:10:WU00:FS01:0x22:         OS: Windows 10 Home
23:33:10:WU01:FS00:Connecting to 18.218.241.186:80
23:33:10:WU00:FS01:0x22:    OS Arch: AMD64
23:33:10:WU00:FS01:0x22:********************************************************************************
23:33:10:WU00:FS01:0x22:Project: 11781 (Run 0, Clone 9719, Gen 17)
23:33:10:WU00:FS01:0x22:Unit: 0x000000210d5a98395e7588d232521190
23:33:10:WU00:FS01:0x22:Reading tar file core.xml
23:33:10:WU00:FS01:0x22:Reading tar file integrator.xml
23:33:10:WU00:FS01:0x22:Reading tar file state.xml
23:33:10:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:33:10:ERROR:WU01:FS00:Exception: Could not get an assignment
23:33:11:WU01:FS00:Assigned to work server 128.252.203.9
23:33:11:WU01:FS00:Requesting new work unit for slot 00: READY cpu:15 from 128.252.203.9
23:33:11:WU01:FS00:Connecting to 128.252.203.9:8080
23:33:11:WU00:FS01:0x22:Reading tar file system.xml
23:33:12:WU00:FS01:0x22:Digital signatures verified
23:33:12:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
23:33:12:WU00:FS01:0x22:Version 0.0.2
23:33:32:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
23:33:32:WU01:FS00:Connecting to 128.252.203.9:80
23:33:33:Removing old file 'configs/config-20200402-105309.xml'
23:33:33:Saving configuration to config.xml
23:33:33:<config>
23:33:33:  <!-- Network -->
23:33:33:  <proxy v=':8080'/>
23:33:33:
23:33:33:  <!-- Slot Control -->
23:33:33:  <power v='full'/>
23:33:33:
23:33:33:  <!-- User Information -->
23:33:33:  <passkey v='********************************'/>
23:33:33:  <team v='232992'/>
23:33:33:  <user v='Ria_Skies'/>
23:33:33:
23:33:33:  <!-- Folding Slots -->
23:33:33:  <slot id='1' type='GPU'/>
23:33:33:  <slot id='0' type='CPU'>
23:33:33:    <cpus v='15'/>
23:33:33:  </slot>
23:33:33:</config>
23:34:17:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
23:34:17:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:35:34:WU01:FS00:Downloading 8.14MiB
23:35:41:WU01:FS00:Download 11.51%
23:35:48:WU01:FS00:Download 36.08%
23:35:51:WU01:FS00:Download complete
23:35:51:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13825 run:261 clone:1 gen:119 core:0xa7 unit:0x0000008f80fccb095c9565d22d40a546
23:35:51:WU01:FS00:Starting
23:35:51:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Ria\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 11072 -checkpoint 15 -np 15
23:35:51:WU01:FS00:Started FahCore on PID 9196
23:35:51:WU01:FS00:Core PID:1184
23:35:51:WU01:FS00:FahCore 0xa7 started
23:35:52:WU01:FS00:0xa7:*********************** Log Started 2020-04-04T23:35:52Z ***********************
23:35:52:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:35:52:WU01:FS00:0xa7:       Type: 0xa7
23:35:52:WU01:FS00:0xa7:       Core: Gromacs
23:35:52:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 9196 -checkpoint 15 -np
23:35:52:WU01:FS00:0xa7:             15
23:35:52:WU01:FS00:0xa7:************************************ CBang *************************************
23:35:52:WU01:FS00:0xa7:       Date: Oct 26 2019
23:35:52:WU01:FS00:0xa7:       Time: 01:38:25
23:35:52:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:35:52:WU01:FS00:0xa7:     Branch: master
23:35:52:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
23:35:52:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:35:52:WU01:FS00:0xa7:   Platform: win32 10
23:35:52:WU01:FS00:0xa7:       Bits: 64
23:35:52:WU01:FS00:0xa7:       Mode: Release
23:35:52:WU01:FS00:0xa7:************************************ System ************************************
23:35:52:WU01:FS00:0xa7:        CPU: AMD Ryzen 7 1700 Eight-Core Processor
23:35:52:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
23:35:52:WU01:FS00:0xa7:       CPUs: 16
23:35:52:WU01:FS00:0xa7:     Memory: 15.95GiB
23:35:52:WU01:FS00:0xa7:Free Memory: 12.21GiB
23:35:52:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
23:35:52:WU01:FS00:0xa7: OS Version: 6.2
23:35:52:WU01:FS00:0xa7:Has Battery: false
23:35:52:WU01:FS00:0xa7: On Battery: false
23:35:52:WU01:FS00:0xa7: UTC Offset: -5
23:35:52:WU01:FS00:0xa7:        PID: 1184
23:35:52:WU01:FS00:0xa7:        CWD: C:\Users\Ria\AppData\Roaming\FAHClient\work
23:35:52:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
23:35:52:WU01:FS00:0xa7:    Version: 0.0.18
23:35:52:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:35:52:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:35:52:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
23:35:52:WU01:FS00:0xa7:       Time: 01:52:30
23:35:52:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:35:52:WU01:FS00:0xa7:************************************ Build *************************************
23:35:52:WU01:FS00:0xa7:       SIMD: avx_256
23:35:52:WU01:FS00:0xa7:********************************************************************************
23:35:52:WU01:FS00:0xa7:Project: 13825 (Run 261, Clone 1, Gen 119)
23:35:52:WU01:FS00:0xa7:Unit: 0x0000008f80fccb095c9565d22d40a546
23:35:52:WU01:FS00:0xa7:Reading tar file core.xml
23:35:52:WU01:FS00:0xa7:Reading tar file frame119.tpr
23:35:52:WU01:FS00:0xa7:Digital signatures verified
23:35:52:WU01:FS00:0xa7:Calling: mdrun -s frame119.tpr -o frame119.trr -x frame119.xtc -cpt 15 -nt 15
23:35:52:WU01:FS00:0xa7:Steps: first=14875000 total=125000
23:35:56:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
23:36:27:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
23:37:22:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
23:38:43:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
23:38:44:WU01:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
23:40:06:WU01:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
23:40:58:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
23:41:28:WU01:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
23:42:50:WU01:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
23:43:15:WU00:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
23:44:12:WU01:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
23:45:30:WU00:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
23:45:35:WU01:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
23:46:58:WU01:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
23:47:55:WU00:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
23:48:20:WU01:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
23:49:42:WU01:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
23:50:18:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
23:50:18:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
23:50:41:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
23:50:41:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
23:51:04:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
23:51:04:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
23:51:04:WU00:FS01:0x22:ERROR:114: Max Retries Reached
23:51:04:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
23:51:04:WU00:FS01:0x22:Saving result file badstate-0.xml
23:51:04:WU00:FS01:0x22:Saving result file badstate-1.xml
23:51:05:WU00:FS01:0x22:Saving result file badstate-2.xml
23:51:05:WU00:FS01:0x22:Saving result file checkpointState.xml
23:51:06:WU00:FS01:0x22:Saving result file checkpt.crc
23:51:06:WU00:FS01:0x22:Saving result file positions.xtc
23:51:06:WU00:FS01:0x22:Saving result file science.log
23:51:06:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
23:51:06:WU01:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
23:51:06:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:51:06:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11781 run:0 clone:9719 gen:17 core:0x22 unit:0x000000210d5a98395e7588d232521190
23:51:06:WU00:FS01:Uploading 103.11MiB to 13.90.152.57
23:51:06:WU00:FS01:Connecting to 13.90.152.57:8080
23:51:07:WU02:FS01:Connecting to 65.254.110.245:8080
23:51:07:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:51:07:WU02:FS01:Connecting to 18.218.241.186:80
23:51:07:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:51:07:ERROR:WU02:FS01:Exception: Could not get an assignment
23:51:08:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:51:08:WU02:FS01:Connecting to 18.218.241.186:80
23:51:08:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:51:08:ERROR:WU02:FS01:Exception: Could not get an assignment
23:51:12:WU00:FS01:Upload 4.79%
23:51:18:WU00:FS01:Upload 10.79%
23:51:24:WU00:FS01:Upload 16.85%
23:51:30:WU00:FS01:Upload 22.73%
23:51:36:WU00:FS01:Upload 28.49%
23:51:42:WU00:FS01:Upload 34.61%
23:51:48:WU00:FS01:Upload 39.64%
23:51:54:WU00:FS01:Upload 45.70%
23:52:00:WU00:FS01:Upload 51.70%
23:52:06:WU00:FS01:Upload 57.83%
23:52:08:WU02:FS01:Connecting to 65.254.110.245:8080
23:52:08:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:52:08:WU02:FS01:Connecting to 18.218.241.186:80
23:52:08:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:52:08:ERROR:WU02:FS01:Exception: Could not get an assignment
23:52:12:WU00:FS01:Upload 63.83%
23:52:18:WU00:FS01:Upload 69.89%
23:52:24:WU00:FS01:Upload 76.01%
23:52:28:WU01:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
23:52:30:WU00:FS01:Upload 82.01%
23:52:36:WU00:FS01:Upload 87.83%
23:52:42:WU00:FS01:Upload 93.22%
23:52:48:WU00:FS01:Upload 99.41%
23:52:50:WU00:FS01:Upload complete
23:52:51:WU00:FS01:Server responded WORK_ACK (400)
23:52:51:WU00:FS01:Cleaning up
23:53:45:WU02:FS01:Connecting to 65.254.110.245:8080
23:53:45:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:53:45:WU02:FS01:Connecting to 18.218.241.186:80
23:53:45:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:53:45:ERROR:WU02:FS01:Exception: Could not get an assignment
23:53:49:WU01:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
23:55:11:WU01:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
23:56:22:WU02:FS01:Connecting to 65.254.110.245:8080
23:56:22:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:56:22:WU02:FS01:Connecting to 18.218.241.186:80
23:56:22:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:56:22:ERROR:WU02:FS01:Exception: Could not get an assignment
23:56:34:WU01:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
23:57:56:WU01:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
23:59:18:WU01:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
00:00:36:WU02:FS01:Connecting to 65.254.110.245:8080
00:00:36:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
00:00:36:WU02:FS01:Connecting to 18.218.241.186:80
00:00:37:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:00:37:ERROR:WU02:FS01:Exception: Could not get an assignment
00:00:40:WU01:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
00:02:02:WU01:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
00:03:23:WU01:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
00:04:45:WU01:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
00:06:09:WU01:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
00:07:27:WU02:FS01:Connecting to 65.254.110.245:8080
00:07:28:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
00:07:28:WU02:FS01:Connecting to 18.218.241.186:80
00:07:28:WU02:FS01:Assigned to work server 128.252.203.10
00:07:28:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 128.252.203.10
00:07:28:WU02:FS01:Connecting to 128.252.203.10:8080
00:07:31:WU01:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
00:07:49:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
00:07:49:WU02:FS01:Connecting to 128.252.203.10:80
00:08:11:ERROR:WU02:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:08:52:WU01:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
00:10:14:WU01:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
00:11:36:WU01:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
00:12:58:WU01:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
00:14:20:WU01:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
00:15:42:WU01:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
00:17:04:WU01:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
00:18:26:WU01:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
00:18:33:WU02:FS01:Connecting to 65.254.110.245:8080
00:18:33:WU02:FS01:Assigned to work server 128.252.203.10
00:18:33:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 128.252.203.10
00:18:33:WU02:FS01:Connecting to 128.252.203.10:8080
00:18:55:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
00:18:55:WU02:FS01:Connecting to 128.252.203.10:80
00:19:46:WU02:FS01:Downloading 50.74MiB
00:19:48:WU01:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
00:19:52:WU02:FS01:Download 18.23%
00:19:58:WU02:FS01:Download 41.27%
00:20:04:WU02:FS01:Download 50.51%
00:20:10:WU02:FS01:Download 80.69%
00:20:13:WU02:FS01:Download complete
00:20:13:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11762 run:0 clone:6057 gen:21 core:0x22 unit:0x0000002a80fccb0a5e7113e51902bbab
00:20:13:WU02:FS01:Starting
00:20:13:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Ria\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 11072 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
00:20:13:WU02:FS01:Started FahCore on PID 9512
00:20:13:WU02:FS01:Core PID:1104
00:20:13:WU02:FS01:FahCore 0x22 started
00:20:14:WU02:FS01:0x22:*********************** Log Started 2020-04-05T00:20:13Z ***********************
00:20:14:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:20:14:WU02:FS01:0x22:       Type: 0x22
00:20:14:WU02:FS01:0x22:       Core: Core22
00:20:14:WU02:FS01:0x22:    Website: https://foldingathome.org/
00:20:14:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
00:20:14:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
00:20:14:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
00:20:14:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 9512 -checkpoint 15
00:20:14:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
00:20:14:WU02:FS01:0x22:     Config: <none>
00:20:14:WU02:FS01:0x22:************************************ Build *************************************
00:20:14:WU02:FS01:0x22:    Version: 0.0.2
00:20:14:WU02:FS01:0x22:       Date: Dec 6 2019
00:20:14:WU02:FS01:0x22:       Time: 21:30:31
00:20:14:WU02:FS01:0x22: Repository: Git
00:20:14:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
00:20:14:WU02:FS01:0x22:     Branch: HEAD
00:20:14:WU02:FS01:0x22:   Compiler: Visual C++ 2008
00:20:14:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:20:14:WU02:FS01:0x22:   Platform: win32 10
00:20:14:WU02:FS01:0x22:       Bits: 64
00:20:14:WU02:FS01:0x22:       Mode: Release
00:20:14:WU02:FS01:0x22:************************************ System ************************************
00:20:14:WU02:FS01:0x22:        CPU: AMD Ryzen 7 1700 Eight-Core Processor
00:20:14:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
00:20:14:WU02:FS01:0x22:       CPUs: 16
00:20:14:WU02:FS01:0x22:     Memory: 15.95GiB
00:20:14:WU02:FS01:0x22:Free Memory: 12.53GiB
00:20:14:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
00:20:14:WU02:FS01:0x22: OS Version: 6.2
00:20:14:WU02:FS01:0x22:Has Battery: false
00:20:14:WU02:FS01:0x22: On Battery: false
00:20:14:WU02:FS01:0x22: UTC Offset: -5
00:20:14:WU02:FS01:0x22:        PID: 1104
00:20:14:WU02:FS01:0x22:        CWD: C:\Users\Ria\AppData\Roaming\FAHClient\work
00:20:14:WU02:FS01:0x22:         OS: Windows 10 Home
00:20:14:WU02:FS01:0x22:    OS Arch: AMD64
00:20:14:WU02:FS01:0x22:********************************************************************************
00:20:14:WU02:FS01:0x22:Project: 11762 (Run 0, Clone 6057, Gen 21)
00:20:14:WU02:FS01:0x22:Unit: 0x0000002a80fccb0a5e7113e51902bbab
00:20:14:WU02:FS01:0x22:Reading tar file core.xml
00:20:14:WU02:FS01:0x22:Reading tar file integrator.xml
00:20:14:WU02:FS01:0x22:Reading tar file state.xml
00:20:14:WU02:FS01:0x22:Reading tar file system.xml
00:20:15:WU02:FS01:0x22:Digital signatures verified
00:20:15:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:20:15:WU02:FS01:0x22:Version 0.0.2
00:21:14:WU01:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
00:21:26:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
00:21:26:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:22:37:WU01:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
00:22:48:WU02:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
00:24:00:WU01:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
00:24:14:WU02:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
00:25:22:WU01:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
00:25:32:WU02:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
00:26:45:WU01:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
00:26:51:WU02:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
00:28:07:WU01:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
00:28:09:WU02:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
00:29:30:WU01:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
00:29:34:WU02:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
00:30:53:WU01:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
00:30:54:WU02:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
00:32:13:WU02:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
00:32:15:WU01:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
00:33:33:WU02:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
00:33:37:WU01:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
00:34:51:WU02:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
00:35:00:WU01:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
00:36:16:WU02:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
00:36:24:WU01:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
00:37:34:WU02:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
00:37:46:WU01:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
00:38:24:11:127.0.0.1:New Web connection
00:38:59:WU02:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
00:39:11:WU01:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
00:40:17:WU02:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
00:40:33:WU01:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
00:41:22:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
00:41:22:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
00:41:32:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
00:41:32:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
00:41:42:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
00:41:42:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
00:41:42:WU02:FS01:0x22:ERROR:114: Max Retries Reached
00:41:42:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
00:41:42:WU02:FS01:0x22:Saving result file badstate-0.xml
00:41:42:WU02:FS01:0x22:Saving result file badstate-1.xml
00:41:42:WU02:FS01:0x22:Saving result file badstate-2.xml
00:41:42:WU02:FS01:0x22:Saving result file checkpointState.xml
00:41:43:WU02:FS01:0x22:Saving result file checkpt.crc
00:41:43:WU02:FS01:0x22:Saving result file positions.xtc
00:41:43:WU02:FS01:0x22:Saving result file science.log
00:41:43:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
00:41:44:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:41:44:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11762 run:0 clone:6057 gen:21 core:0x22 unit:0x0000002a80fccb0a5e7113e51902bbab
00:41:44:WU02:FS01:Uploading 62.50MiB to 128.252.203.10
00:41:44:WU02:FS01:Connecting to 128.252.203.10:8080
00:41:44:WU00:FS01:Connecting to 65.254.110.245:8080
00:41:44:WU00:FS01:Assigned to work server 13.82.98.119
00:41:44:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 13.82.98.119
00:41:44:WU00:FS01:Connecting to 13.82.98.119:8080
00:41:46:WU00:FS01:Downloading 119.45MiB
00:41:52:WU00:FS01:Download 15.59%
00:41:55:WU01:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
00:41:58:WU00:FS01:Download 34.48%
00:42:04:WU00:FS01:Download 54.21%
00:42:10:WU00:FS01:Download 75.50%
00:42:16:WU00:FS01:Download 96.22%
00:42:16:WU00:FS01:Download complete
00:42:17:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14539 run:0 clone:1559 gen:4 core:0x22 unit:0x000000050d5262775e7bf1f6d8e0f245
00:42:17:WU00:FS01:Starting
00:42:17:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Ria\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 11072 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
00:42:17:WU00:FS01:Started FahCore on PID 3124
00:42:17:WU00:FS01:Core PID:8084
00:42:17:WU00:FS01:FahCore 0x22 started
00:42:17:WU00:FS01:0x22:*********************** Log Started 2020-04-05T00:42:17Z ***********************
00:42:17:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:42:17:WU00:FS01:0x22:       Type: 0x22
00:42:17:WU00:FS01:0x22:       Core: Core22
00:42:17:WU00:FS01:0x22:    Website: https://foldingathome.org/
00:42:17:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
00:42:17:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
00:42:17:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
00:42:17:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 3124 -checkpoint 15
00:42:17:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
00:42:17:WU00:FS01:0x22:     Config: <none>
00:42:17:WU00:FS01:0x22:************************************ Build *************************************
00:42:17:WU00:FS01:0x22:    Version: 0.0.2
00:42:17:WU00:FS01:0x22:       Date: Dec 6 2019
00:42:17:WU00:FS01:0x22:       Time: 21:30:31
00:42:17:WU00:FS01:0x22: Repository: Git
00:42:17:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
00:42:17:WU00:FS01:0x22:     Branch: HEAD
00:42:17:WU00:FS01:0x22:   Compiler: Visual C++ 2008
00:42:17:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:42:17:WU00:FS01:0x22:   Platform: win32 10
00:42:17:WU00:FS01:0x22:       Bits: 64
00:42:17:WU00:FS01:0x22:       Mode: Release
00:42:17:WU00:FS01:0x22:************************************ System ************************************
00:42:17:WU00:FS01:0x22:        CPU: AMD Ryzen 7 1700 Eight-Core Processor
00:42:17:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
00:42:17:WU00:FS01:0x22:       CPUs: 16
00:42:17:WU00:FS01:0x22:     Memory: 15.95GiB
00:42:17:WU00:FS01:0x22:Free Memory: 12.51GiB
00:42:17:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
00:42:17:WU00:FS01:0x22: OS Version: 6.2
00:42:17:WU00:FS01:0x22:Has Battery: false
00:42:17:WU00:FS01:0x22: On Battery: false
00:42:17:WU00:FS01:0x22: UTC Offset: -5
00:42:17:WU00:FS01:0x22:        PID: 8084
00:42:17:WU00:FS01:0x22:        CWD: C:\Users\Ria\AppData\Roaming\FAHClient\work
00:42:17:WU00:FS01:0x22:         OS: Windows 10 Home
00:42:17:WU00:FS01:0x22:    OS Arch: AMD64
00:42:17:WU00:FS01:0x22:********************************************************************************
00:42:17:WU00:FS01:0x22:Project: 14539 (Run 0, Clone 1559, Gen 4)
00:42:17:WU00:FS01:0x22:Unit: 0x000000050d5262775e7bf1f6d8e0f245
00:42:17:WU00:FS01:0x22:Reading tar file core.xml
00:42:17:WU00:FS01:0x22:Reading tar file integrator.xml
00:42:17:WU00:FS01:0x22:Reading tar file state.xml
00:42:19:WU00:FS01:0x22:Reading tar file system.xml
00:42:21:WU00:FS01:0x22:Digital signatures verified
00:42:21:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:42:21:WU00:FS01:0x22:Version 0.0.2
00:42:22:WU02:FS01:Upload 0.60%
00:42:28:WU02:FS01:Upload 11.10%
00:42:34:WU02:FS01:Upload 24.50%
00:42:40:WU02:FS01:Upload 39.80%
00:42:46:WU02:FS01:Upload 44.70%
00:42:52:WU02:FS01:Upload 57.90%
00:42:58:WU02:FS01:Upload 73.89%
00:43:05:WU02:FS01:Upload 80.99%
00:43:11:WU02:FS01:Upload 98.39%
00:43:13:WU02:FS01:Upload complete
00:43:13:WU02:FS01:Server responded WORK_ACK (400)
00:43:13:WU02:FS01:Cleaning up
00:43:20:WU01:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
00:43:37:WU00:FS01:0x22:Completed 0 out of 500000 steps (0%)
00:43:37:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:44:46:WU01:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
00:45:27:WU00:FS01:0x22:Completed 5000 out of 500000 steps (1%)
00:46:10:WU01:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
00:46:58:WU00:FS01:0x22:Completed 10000 out of 500000 steps (2%)
00:47:32:WU01:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
Hypothesis: Old GPU was a GTX 970. New GPU is an RX 5600 XT. Architectural differences between NVidia and AMD are causing issues with the core and the configuration log for FAH hasn't detected the change when polling the server for appropriate work units (some work units don't like Navi or AMD for some reason based on my reading of the forums)
Proposed solution: Edit or recreate the configuration logs so FAH recognizes that I now have a Radeon Navi-based GPU.
Question: How to do this?
Re: Installed new GPU, new GPU is having problems
Welcome to the F@H Forum RiaSkies,
Congrats for your new GPU!
What temperature is your GPU folding at? Did you perform any manual OC or not?
RiaSkies
Post by RiaSkies »
No manual OC, just running at factory stock settings (only installed the card a couple of hours ago)
GPU temperature in the Radeon software wasn't exceeding 70 C during the inspections I did. Reported wattage for the GPU under load was about 105 W, which is less than my 970 was drawing (about 125 W with a target of 75% power), so this is very unlikely to be a PSU issue either (I have a 500 W PSU which should be sufficient for my CPU + GPU)
CPU units are folding fine. All previous GPU units on the 970 were also fine.
The log message mentions something about detecting a 'single Nvidia GPU' when checking the core conditions though, which is why I think it's an issue with the configuration logs.
By far the simplest way to reset is to copy down your name, optionally your team, and optionally your passkey.
Now uninstall F@H including data and it will forget your config. (if you keep the data, it will not investigate your hardware)
Reinstall and reenter your personal info and life should be better. It seems the installer is much better at detecting hardware than the client is.
If you didn't use a driver cleaner utility to remove the nVidia drivers, this is the time to do that. You may also want to do a clean reinstall of the AMD drivers.
RiaSkies
Post by RiaSkies »
Is there a driver cleaner utility which is recommended? I just installed the AMD drivers earlier today, but I can uninstall those and reinstall if that may help.
I have previously used DDU and others on this forum have used it too: https://www.guru3d.com/files-details/di ... nload.html
RiaSkies
Post by RiaSkies »
Okay, I have used the DDU utility on all my gpu drivers and have reinstalled the AMD Radeon drivers. I have also uninstalled and reinstalled the FAH 7.5.1 client as well and reentered my user name & passkey. The GPU immediately dumped the Work Unit as bad as soon as it got a new assignment after doing all of this.
The log is still including the message: "Requirements: single Nvidia GPU, tmax must be < 110 and twait >=900"
So somehow it is still detecting an Nvidia GPU and/or the server is giving me units I can't accept?
RiaSkies
Post by RiaSkies »
new log file, still getting the Bad_Work_Unit:
02:20:16:Saving configuration to config.xml
02:20:16:<config>
02:20:16:  <!-- Network -->
02:20:16:  <proxy v=':8080'/>
02:20:16:
02:20:16:  <!-- User Information -->
02:20:16:  <passkey v='********************************'/>
02:20:16:  <team v='232992'/>
02:20:16:  <user v='Ria_Skies'/>
02:20:16:
02:20:16:  <!-- Folding Slots -->
02:20:16:  <slot id='0' type='CPU'>
02:20:16:    <cpus v='12'/>
02:20:16:    <paused v='true'/>
02:20:16:  </slot>
02:20:16:  <slot id='1' type='GPU'>
02:20:16:  </slot>
02:20:16:</config>
02:20:21:FS00:Unpaused
02:20:21:FS01:Unpaused
02:20:22:WU00:FS00:Connecting to 65.254.110.245:8080
02:20:22:WU01:FS01:Connecting to 65.254.110.245:8080
02:20:22:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:20:22:WU00:FS00:Connecting to 18.218.241.186:80
02:20:22:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:20:22:WU01:FS01:Connecting to 18.218.241.186:80
02:20:22:WU00:FS00:Assigned to work server 155.247.164.213
02:20:22:WU00:FS00:Requesting new work unit for slot 00: READY cpu:12 from 155.247.164.213
02:20:22:WU00:FS00:Connecting to 155.247.164.213:8080
02:20:23:WU01:FS01:Assigned to work server 13.90.152.57
02:20:23:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 13.90.152.57
02:20:23:WU01:FS01:Connecting to 13.90.152.57:8080
02:20:23:WU00:FS00:Downloading 137.00KiB
02:20:23:WU00:FS00:Download complete
02:20:23:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14371 run:1169 clone:3 gen:14 core:0xa7 unit:0x0000000e9bf7a4d55e84afd7ca544d7a
02:20:23:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
02:20:23:WU00:FS00:Connecting to cores.foldingathome.org:80
02:20:23:WU00:FS00:FahCore a7: Downloading 6.71MiB
02:20:24:WU01:FS01:Downloading 51.20MiB
02:20:24:WU00:FS00:FahCore a7: Download complete
02:20:24:WU00:FS00:Valid core signature
02:20:24:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
02:20:24:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
02:20:25:WU00:FS00:Starting
02:20:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Ria\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 10132 -checkpoint 15 -np 12
02:20:25:WU00:FS00:Started FahCore on PID 3612
02:20:25:WU00:FS00:Core PID:4900
02:20:25:WU00:FS00:FahCore 0xa7 started
02:20:25:WU00:FS00:0xa7:*********************** Log Started 2020-04-05T02:20:25Z ***********************
02:20:25:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:20:25:WU00:FS00:0xa7:       Type: 0xa7
02:20:25:WU00:FS00:0xa7:       Core: Gromacs
02:20:25:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 3612 -checkpoint 15 -np
02:20:25:WU00:FS00:0xa7:             12
02:20:25:WU00:FS00:0xa7:************************************ CBang *************************************
02:20:25:WU00:FS00:0xa7:       Date: Oct 26 2019
02:20:25:WU00:FS00:0xa7:       Time: 01:38:25
02:20:25:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
02:20:25:WU00:FS00:0xa7:     Branch: master
02:20:25:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
02:20:25:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:20:25:WU00:FS00:0xa7:   Platform: win32 10
02:20:25:WU00:FS00:0xa7:       Bits: 64
02:20:25:WU00:FS00:0xa7:       Mode: Release
02:20:25:WU00:FS00:0xa7:************************************ System ************************************
02:20:25:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 1700 Eight-Core Processor
02:20:25:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
02:20:25:WU00:FS00:0xa7:       CPUs: 16
02:20:25:WU00:FS00:0xa7:     Memory: 15.95GiB
02:20:25:WU00:FS00:0xa7:Free Memory: 13.29GiB
02:20:25:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
02:20:25:WU00:FS00:0xa7: OS Version: 6.2
02:20:25:WU00:FS00:0xa7:Has Battery: false
02:20:25:WU00:FS00:0xa7: On Battery: false
02:20:25:WU00:FS00:0xa7: UTC Offset: -5
02:20:25:WU00:FS00:0xa7:        PID: 4900
02:20:25:WU00:FS00:0xa7:        CWD: C:\Users\Ria\AppData\Roaming\FAHClient\work
02:20:25:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
02:20:25:WU00:FS00:0xa7:    Version: 0.0.18
02:20:25:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:20:25:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
02:20:25:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
02:20:25:WU00:FS00:0xa7:       Time: 01:52:30
02:20:25:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
02:20:26:WU00:FS00:0xa7:************************************ Build *************************************
02:20:26:WU00:FS00:0xa7:       SIMD: avx_256
02:20:26:WU00:FS00:0xa7:********************************************************************************
02:20:26:WU00:FS00:0xa7:Project: 14371 (Run 1169, Clone 3, Gen 14)
02:20:26:WU00:FS00:0xa7:Unit: 0x0000000e9bf7a4d55e84afd7ca544d7a
02:20:26:WU00:FS00:0xa7:Reading tar file core.xml
02:20:26:WU00:FS00:0xa7:Reading tar file frame14.tpr
02:20:26:WU00:FS00:0xa7:Digital signatures verified
02:20:26:WU00:FS00:0xa7:Calling: mdrun -s frame14.tpr -o frame14.trr -cpt 15 -nt 12
02:20:26:WU00:FS00:0xa7:Steps: first=0 total=2500000
02:20:26:WU00:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
02:20:30:WU01:FS01:Download 41.51%
02:20:36:WU01:FS01:Download 86.19%
02:20:37:WU01:FS01:Download complete
02:20:37:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11780 run:0 clone:9301 gen:35 core:0x22 unit:0x000000310d5a98395e75891da207c528
02:20:38:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
02:20:38:WU01:FS01:Connecting to cores.foldingathome.org:80
02:20:38:WU01:FS01:FahCore 22: Downloading 4.04MiB
02:20:38:WU01:FS01:FahCore 22: Download complete
02:20:38:WU01:FS01:Valid core signature
02:20:39:WU01:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
02:20:39:WU01:FS01:Starting
02:20:39:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Ria\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 10132 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
02:20:39:WU01:FS01:Started FahCore on PID 9344
02:20:39:WU01:FS01:Core PID:8560
02:20:39:WU01:FS01:FahCore 0x22 started
02:20:39:WU01:FS01:0x22:*********************** Log Started 2020-04-05T02:20:39Z ***********************
02:20:39:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
02:20:39:WU01:FS01:0x22:       Type: 0x22
02:20:39:WU01:FS01:0x22:       Core: Core22
02:20:39:WU01:FS01:0x22:    Website: https://foldingathome.org/
02:20:39:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
02:20:39:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
02:20:39:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
02:20:39:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 9344 -checkpoint 15
02:20:39:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
02:20:39:WU01:FS01:0x22:     Config: <none>
02:20:39:WU01:FS01:0x22:************************************ Build *************************************
02:20:40:WU01:FS01:0x22:    Version: 0.0.2
02:20:40:WU01:FS01:0x22:       Date: Dec 6 2019
02:20:40:WU01:FS01:0x22:       Time: 21:30:31
02:20:40:WU01:FS01:0x22: Repository: Git
02:20:40:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
02:20:40:WU01:FS01:0x22:     Branch: HEAD
02:20:40:WU01:FS01:0x22:   Compiler: Visual C++ 2008
02:20:40:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:20:40:WU01:FS01:0x22:   Platform: win32 10
02:20:40:WU01:FS01:0x22:       Bits: 64
02:20:40:WU01:FS01:0x22:       Mode: Release
02:20:40:WU01:FS01:0x22:************************************ System ************************************
02:20:40:WU01:FS01:0x22:        CPU: AMD Ryzen 7 1700 Eight-Core Processor
02:20:40:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
02:20:40:WU01:FS01:0x22:       CPUs: 16
02:20:40:WU01:FS01:0x22:     Memory: 15.95GiB
02:20:40:WU01:FS01:0x22:Free Memory: 13.23GiB
02:20:40:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
02:20:40:WU01:FS01:0x22: OS Version: 6.2
02:20:40:WU01:FS01:0x22:Has Battery: false
02:20:40:WU01:FS01:0x22: On Battery: false
02:20:40:WU01:FS01:0x22: UTC Offset: -5
02:20:40:WU01:FS01:0x22:        PID: 8560
02:20:40:WU01:FS01:0x22:        CWD: C:\Users\Ria\AppData\Roaming\FAHClient\work
02:20:40:WU01:FS01:0x22:         OS: Windows 10 Home
02:20:40:WU01:FS01:0x22:    OS Arch: AMD64
02:20:40:WU01:FS01:0x22:********************************************************************************
02:20:40:WU01:FS01:0x22:Project: 11780 (Run 0, Clone 9301, Gen 35)
02:20:40:WU01:FS01:0x22:Unit: 0x000000310d5a98395e75891da207c528
02:20:40:WU01:FS01:0x22:Reading tar file core.xml
02:20:40:WU01:FS01:0x22:Reading tar file integrator.xml
02:20:40:WU01:FS01:0x22:Reading tar file state.xml
02:20:40:WU01:FS01:0x22:Reading tar file system.xml
02:20:41:WU01:FS01:0x22:Digital signatures verified
02:20:41:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
02:20:41:WU01:FS01:0x22:Version 0.0.2
02:21:05:Saving configuration to config.xml
02:21:05:<config>
02:21:05:  <!-- Network -->
02:21:05:  <proxy v=':8080'/>
02:21:05:
02:21:05:  <!-- User Information -->
02:21:05:  <passkey v='********************************'/>
02:21:05:  <team v='232992'/>
02:21:05:  <user v='Ria_Skies'/>
02:21:05:
02:21:05:  <!-- Folding Slots -->
02:21:05:  <slot id='0' type='CPU'>
02:21:05:    <cpus v='12'/>
02:21:05:  </slot>
02:21:05:  <slot id='1' type='GPU'/>
02:21:05:</config>
02:21:32:WU00:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
02:21:45:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
02:21:45:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:22:02:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
02:22:02:WU01:FS01:0x22:Following exception occured: Particle coordinate is nan
02:22:16:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
02:22:16:WU01:FS01:0x22:Following exception occured: Particle coordinate is nan
02:22:30:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
02:22:30:WU01:FS01:0x22:Following exception occured: Particle coordinate is nan
02:22:30:WU01:FS01:0x22:ERROR:114: Max Retries Reached
02:22:30:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
02:22:30:WU01:FS01:0x22:Saving result file badstate-0.xml
02:22:31:WU01:FS01:0x22:Saving result file badstate-1.xml
02:22:31:WU01:FS01:0x22:Saving result file badstate-2.xml
02:22:31:WU01:FS01:0x22:Saving result file checkpt.crc
02:22:31:WU01:FS01:0x22:Saving result file science.log
02:22:31:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
02:22:32:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
02:22:32:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11780 run:0 clone:9301 gen:35 core:0x22 unit:0x000000310d5a98395e75891da207c528
02:22:32:WU01:FS01:Uploading 36.53MiB to 13.90.152.57
02:22:32:WU01:FS01:Connecting to 13.90.152.57:8080
02:22:32:WU02:FS01:Connecting to 65.254.110.245:8080
02:22:32:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:22:32:WU02:FS01:Connecting to 18.218.241.186:80
02:22:32:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:22:32:ERROR:WU02:FS01:Exception: Could not get an assignment
02:22:33:WU02:FS01:Connecting to 65.254.110.245:8080
02:22:33:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:22:33:WU02:FS01:Connecting to 18.218.241.186:80
02:22:33:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:22:33:ERROR:WU02:FS01:Exception: Could not get an assignment
02:22:38:WU01:FS01:Upload 6.50%
02:22:38:WU00:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
02:22:44:WU01:FS01:Upload 21.39%
02:22:50:WU01:FS01:Upload 35.93%
02:22:56:WU01:FS01:Upload 51.50%
02:23:02:WU01:FS01:Upload 65.87%
02:23:08:WU01:FS01:Upload 81.10%
02:23:14:WU01:FS01:Upload 97.01%
02:23:16:WU01:FS01:Upload complete
02:23:16:WU01:FS01:Server responded WORK_ACK (400)
02:23:16:WU01:FS01:Cleaning up
02:23:33:WU02:FS01:Connecting to 65.254.110.245:8080
02:23:33:WU02:FS01:Assigned to work server 128.252.203.10
02:23:33:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 128.252.203.10
02:23:33:WU02:FS01:Connecting to 128.252.203.10:8080
02:23:44:WU00:FS00:0xa7:Completed 75000 out of 2500000 steps (3%)
02:23:54:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
02:23:54:WU02:FS01:Connecting to 128.252.203.10:80
02:24:15:ERROR:WU02:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:24:48:WU00:FS00:0xa7:Completed 100000 out of 2500000 steps (4%)
02:25:10:WU02:FS01:Connecting to 65.254.110.245:8080
02:25:10:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:25:10:WU02:FS01:Connecting to 18.218.241.186:80
02:25:11:WU02:FS01:Assigned to work server 13.90.152.57
02:25:11:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 13.90.152.57
02:25:11:WU02:FS01:Connecting to 13.90.152.57:8080
02:25:12:WU02:FS01:Downloading 51.19MiB
02:25:18:WU02:FS01:Download 35.16%
02:25:24:WU02:FS01:Download 64.46%
02:25:29:WU02:FS01:Download complete
02:25:29:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11780 run:0 clone:5030 gen:35 core:0x22 unit:0x000000320d5a98395e7589574b5e1cd4
02:25:29:WU02:FS01:Starting
02:25:29:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Ria\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 10132 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
02:25:29:WU02:FS01:Started FahCore on PID 10792
02:25:29:WU02:FS01:Core PID:7860
02:25:29:WU02:FS01:FahCore 0x22 started
02:25:30:WU02:FS01:0x22:*********************** Log Started 2020-04-05T02:25:29Z ***********************
02:25:30:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
02:25:30:WU02:FS01:0x22:       Type: 0x22
02:25:30:WU02:FS01:0x22:       Core: Core22
02:25:30:WU02:FS01:0x22:    Website: https://foldingathome.org/
02:25:30:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
02:25:30:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
02:25:30:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
02:25:30:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 10792 -checkpoint 15
02:25:30:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
02:25:30:WU02:FS01:0x22:     Config: <none>
02:25:30:WU02:FS01:0x22:************************************ Build *************************************
02:25:30:WU02:FS01:0x22:    Version: 0.0.2
02:25:30:WU02:FS01:0x22:       Date: Dec 6 2019
02:25:30:WU02:FS01:0x22:       Time: 21:30:31
02:25:30:WU02:FS01:0x22: Repository: Git
02:25:30:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
02:25:30:WU02:FS01:0x22:     Branch: HEAD
02:25:30:WU02:FS01:0x22:   Compiler: Visual C++ 2008
02:25:30:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:25:30:WU02:FS01:0x22:   Platform: win32 10
02:25:30:WU02:FS01:0x22:       Bits: 64
02:25:30:WU02:FS01:0x22:       Mode: Release
02:25:30:WU02:FS01:0x22:************************************ System ************************************
02:25:30:WU02:FS01:0x22:        CPU: AMD Ryzen 7 1700 Eight-Core Processor
02:25:30:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
02:25:30:WU02:FS01:0x22:       CPUs: 16
02:25:30:WU02:FS01:0x22:     Memory: 15.95GiB
02:25:30:WU02:FS01:0x22:Free Memory: 13.30GiB
02:25:30:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
02:25:30:WU02:FS01:0x22: OS Version: 6.2
02:25:30:WU02:FS01:0x22:Has Battery: false
02:25:30:WU02:FS01:0x22: On Battery: false
02:25:30:WU02:FS01:0x22: UTC Offset: -5
02:25:30:WU02:FS01:0x22:        PID: 7860
02:25:30:WU02:FS01:0x22:        CWD: C:\Users\Ria\AppData\Roaming\FAHClient\work
02:25:30:WU02:FS01:0x22:         OS: Windows 10 Home
02:25:30:WU02:FS01:0x22:    OS Arch: AMD64
02:25:30:WU02:FS01:0x22:********************************************************************************
02:25:30:WU02:FS01:0x22:Project: 11780 (Run 0, Clone 5030, Gen 35)
02:25:30:WU02:FS01:0x22:Unit: 0x000000320d5a98395e7589574b5e1cd4
02:25:30:WU02:FS01:0x22:Reading tar file core.xml
02:25:30:WU02:FS01:0x22:Reading tar file integrator.xml
02:25:30:WU02:FS01:0x22:Reading tar file state.xml
02:25:30:WU02:FS01:0x22:Reading tar file system.xml
02:25:31:WU02:FS01:0x22:Digital signatures verified
02:25:31:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
02:25:31:WU02:FS01:0x22:Version 0.0.2
02:25:54:WU00:FS00:0xa7:Completed 125000 out of 2500000 steps (5%)
02:26:35:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
02:26:36:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
RiaSkies wrote:...The log is still including the message: "Requirements: single Nvidia GPU, tmax must be < 110 and twait >=900"
That line will always be printed out as it's part of the FahCore. Here's the argument when it's actually running the FahCore:
Here's the log where your GPU is correctly identified:
The first WU that was downloaded, just as it was about to be processed, the client settings changed which might have caused data corruption so the WU was lost :(
However, at the end of your log, there are no error messages so give it an hour or so and see what happens. Hopefully, it is working as expected :)
uyaem
Post by uyaem »
Just double-checking: This line will even appear for people with AMD GPUs?
extide
Post by extide »
Yes, it does.
Rel25917
Post by Rel25917 »
Could be a bad card or a bad factory overclock. Nan errors are usually bad calculations either from bad hardware or a bad overclock.
RiaSkies
Post by RiaSkies »
I am unfortunately still having problems. All throughout the night, I was getting "ERROR:exception: Error initializing context: clCreateCommandQueue (-6)" and the core wouldn't even start. Now I have a core that stalled at 99.99% with an ETA of unknown, but there doesn't seem to be any log files relating to the GPU unit now.
I've tried installing the drivers again, I've tried everything here, I haven't touched the factory settings (for everyone who is alleging this is an overclock issue), and I am still not able to fold a protein on this GPU despite all of this, and now I'm even getting a couple of BSOD's
At this point, I have yet to get a single successfully folded protein ever since installing this new GPU (on the GPU, CPU folds fine) and I am not sure where to go from here. I wish there was some more information about the problems and potential solutions. :cry:
Rel25917
Post by Rel25917 »
That really sounds like a bum card. Have you tried any stress test or benchmarking software on it? Got another system you could try it in?
The stuck at 99% thing happens because fahcontrol/web control think its running and keep counting up but it actually crashed.
