FahCore_a7.exe has stopped working
Bad.Company.Sr
Post by Bad.Company.Sr »
Hi to all, I'm having an issue on one of my systems. I get the title error and because of it that system will not complete a WU. Below is the log from the system. Any help in this matter would be appreciated.
*********************** Log Started 2020-04-04T04:31:13Z ***********************
04:31:13:************************* Folding@home Client *************************
04:31:13:        Website: https://foldingathome.org/
04:31:13:      Copyright: (c) 2009-2018 foldingathome.org
04:31:13:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:31:13:           Args: --open-web-control
04:31:13:         Config: C:\Users\Sr\AppData\Roaming\FAHClient\config.xml
04:31:13:******************************** Build ********************************
04:31:13:        Version: 7.5.1
04:31:13:           Date: May 11 2018
04:31:13:           Time: 13:06:32
04:31:13:     Repository: Git
04:31:13:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
04:31:13:         Branch: master
04:31:13:       Compiler: Visual C++ 2008
04:31:13:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:31:13:       Platform: win32 10
04:31:13:           Bits: 32
04:31:13:           Mode: Release
04:31:13:******************************* System ********************************
04:31:13:            CPU: AMD FX(tm)-6300 Six-Core Processor
04:31:13:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
04:31:13:           CPUs: 6
04:31:13:         Memory: 15.97GiB
04:31:13:    Free Memory: 13.19GiB
04:31:13:        Threads: WINDOWS_THREADS
04:31:13:     OS Version: 6.2
04:31:13:    Has Battery: false
04:31:13:     On Battery: false
04:31:13:     UTC Offset: -4
04:31:13:            PID: 12116
04:31:13:            CWD: C:\Users\Sr\AppData\Roaming\FAHClient
04:31:13:             OS: Windows 10 Enterprise
04:31:13:        OS Arch: AMD64
04:31:13:           GPUs: 1
04:31:13:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM206 [GeForce GTX 960] 2308
04:31:13:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:10.2
04:31:13:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.59
04:31:13:  Win32 Service: false
04:31:13:***********************************************************************
04:31:13:<config>
04:31:13:  <!-- Slot Control -->
04:31:13:  <power v='full'/>
04:31:13:
04:31:13:  <!-- User Information -->
04:31:13:  <passkey v='********************************'/>
04:31:13:  <team v='223518'/>
04:31:13:  <user v='Bad.Company.Sr'/>
04:31:13:
04:31:13:  <!-- Folding Slots -->
04:31:13:  <slot id='0' type='CPU'>
04:31:13:    <paused v='true'/>
04:31:13:  </slot>
04:31:13:  <slot id='1' type='GPU'>
04:31:13:  </slot>
04:31:13:</config>
04:31:13:Trying to access database...
04:31:13:Successfully acquired database lock
04:31:13:Enabled folding slot 00: PAUSED cpu:5 (by user)
04:31:13:Enabled folding slot 01: PAUSED gpu:0:GM206 [GeForce GTX 960] 2308 (by user)
04:31:14:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11752 run:0 clone:10664 gen:1 core:0x22 unit:0x000000038ca304e75e6d6dd01be07975
04:31:14:WU01:FS01:Uploading 24.33MiB to 140.163.4.231
04:31:14:WU01:FS01:Connecting to 140.163.4.231:8080
04:31:25:4:127.0.0.1:New Web connection
04:31:27:30:127.0.0.1:New Web connection
04:31:35:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:31:35:WU01:FS01:Connecting to 140.163.4.231:80
04:31:36:WU01:FS01:Upload 0.26%
04:31:36:FS00:Unpaused
04:31:36:FS01:Unpaused
04:31:36:WU02:FS00:Starting
04:31:36:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Sr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 12116 -checkpoint 15 -np 5
04:31:36:WU02:FS00:Started FahCore on PID 9416
04:31:36:WU02:FS00:Core PID:6908
04:31:36:WU02:FS00:FahCore 0xa7 started
04:31:37:WU02:FS00:0xa7:*********************** Log Started 2020-04-04T04:31:37Z ***********************
04:31:37:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:31:37:WU02:FS00:0xa7:       Type: 0xa7
04:31:37:WU02:FS00:0xa7:       Core: Gromacs
04:31:37:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 9416 -checkpoint 15 -np 5
04:31:37:WU02:FS00:0xa7:************************************ CBang *************************************
04:31:37:WU02:FS00:0xa7:       Date: Oct 26 2019
04:31:37:WU02:FS00:0xa7:       Time: 01:38:25
04:31:37:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
04:31:37:WU02:FS00:0xa7:     Branch: master
04:31:37:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
04:31:37:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:31:37:WU02:FS00:0xa7:   Platform: win32 10
04:31:37:WU02:FS00:0xa7:       Bits: 64
04:31:37:WU02:FS00:0xa7:       Mode: Release
04:31:37:WU02:FS00:0xa7:************************************ System ************************************
04:31:37:WU02:FS00:0xa7:        CPU: AMD FX(tm)-6300 Six-Core Processor
04:31:37:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
04:31:37:WU02:FS00:0xa7:       CPUs: 6
04:31:37:WU02:FS00:0xa7:     Memory: 15.97GiB
04:31:37:WU02:FS00:0xa7:Free Memory: 12.69GiB
04:31:37:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
04:31:37:WU02:FS00:0xa7: OS Version: 6.2
04:31:37:WU02:FS00:0xa7:Has Battery: false
04:31:37:WU02:FS00:0xa7: On Battery: false
04:31:37:WU02:FS00:0xa7: UTC Offset: -4
04:31:37:WU02:FS00:0xa7:        PID: 6908
04:31:37:WU02:FS00:0xa7:        CWD: C:\Users\Sr\AppData\Roaming\FAHClient\work
04:31:37:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
04:31:37:WU02:FS00:0xa7:    Version: 0.0.18
04:31:37:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:31:37:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
04:31:37:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
04:31:37:WU02:FS00:0xa7:       Time: 01:52:30
04:31:37:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
04:31:37:WU02:FS00:0xa7:************************************ Build *************************************
04:31:37:WU02:FS00:0xa7:       SIMD: avx_256
04:31:37:WU02:FS00:0xa7:********************************************************************************
04:31:37:WU02:FS00:0xa7:Project: 13826 (Run 133, Clone 4, Gen 5)
04:31:37:WU02:FS00:0xa7:Unit: 0x0000000780fccb095c979bf348b2d110
04:31:37:WU02:FS00:0xa7:Reading tar file core.xml
04:31:37:WU02:FS00:0xa7:Reading tar file frame5.tpr
04:31:38:WU02:FS00:0xa7:Digital signatures verified
04:31:38:WU02:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
04:31:38:WU02:FS00:0xa7:Calling: mdrun -s frame5.tpr -o frame5.trr -x frame5.xtc -cpi state.cpt -cpt 15 -nt 4
04:31:39:WU02:FS00:0xa7:ERROR:Guru Meditation: not checked '02/01/state.cpt'
04:31:39:WU02:FS00:0xa7:WARNING:Unexpected exit() call
04:31:39:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
04:31:39:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
04:31:39:WU02:FS00:0xa7:Saving result file frame5.trr
04:31:40:WU02:FS00:0xa7:ERROR:Guru Meditation: not checked '02/01/frame5.trr'
04:31:42:WU00:FS01:Connecting to 65.254.110.245:8080
04:31:43:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:31:43:WU00:FS01:Connecting to 18.218.241.186:80
04:31:43:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:31:43:ERROR:WU00:FS01:Exception: Could not get an assignment
04:31:43:WU00:FS01:Connecting to 65.254.110.245:8080
04:31:44:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:31:44:ERROR:WU00:FS01:Exception: Could not get an assignment
04:32:14:Saving configuration to config.xml
04:32:14:<config>
04:32:14:  <!-- Slot Control -->
04:32:14:  <power v='full'/>
04:32:14:
04:32:14:  <!-- User Information -->
04:32:14:  <passkey v='********************************'/>
04:32:14:  <team v='223518'/>
04:32:14:  <user v='Bad.Company.Sr'/>
04:32:14:
04:32:14:  <!-- Folding Slots -->
04:32:14:  <slot id='0' type='CPU'/>
04:32:14:  <slot id='1' type='GPU'/>
04:32:14:</config>
04:32:43:WU00:FS01:Connecting to 65.254.110.245:8080
04:32:43:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:32:43:WU00:FS01:Connecting to 18.218.241.186:80
04:32:44:WU01:FS01:Upload 0.51%
04:32:44:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:32:44:ERROR:WU00:FS01:Exception: Could not get an assignment
04:32:44:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
04:32:44:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11752 run:0 clone:10664 gen:1 core:0x22 unit:0x000000038ca304e75e6d6dd01be07975
04:32:44:WU01:FS01:Uploading 24.33MiB to 140.163.4.231
04:32:44:WU01:FS01:Connecting to 140.163.4.231:8080
04:32:51:WU01:FS01:Upload 0.26%
04:33:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:33:59:WU01:FS01:Upload 0.51%
04:33:59:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
04:34:20:WU00:FS01:Connecting to 65.254.110.245:8080
04:34:21:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:34:21:WU00:FS01:Connecting to 18.218.241.186:80
04:34:21:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:34:21:ERROR:WU00:FS01:Exception: Could not get an assignment
04:34:21:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11752 run:0 clone:10664 gen:1 core:0x22 unit:0x000000038ca304e75e6d6dd01be07975
04:34:21:WU01:FS01:Uploading 24.33MiB to 140.163.4.231
04:34:21:WU01:FS01:Connecting to 140.163.4.231:8080
04:34:43:WU01:FS01:Upload 0.51%
04:34:43:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
04:36:58:WU00:FS01:Connecting to 65.254.110.245:8080
04:36:58:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:36:58:WU00:FS01:Connecting to 18.218.241.186:80
04:36:58:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:36:58:ERROR:WU00:FS01:Exception: Could not get an assignment
04:36:59:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11752 run:0 clone:10664 gen:1 core:0x22 unit:0x000000038ca304e75e6d6dd01be07975
04:36:59:WU01:FS01:Uploading 24.33MiB to 140.163.4.231
04:36:59:WU01:FS01:Connecting to 140.163.4.231:8080
04:37:20:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:37:20:WU01:FS01:Connecting to 140.163.4.231:80
04:37:41:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
uyaem
Re: FahCore_a7.exe has stopped working
Post by uyaem »
Quoting your post title, "has stopped working"?
Can you still see the process running, or is it gone?
Regarding the error messages in your log, that happens when the servers are overloaded. FAHClient will continue to try at a later time.
Welcome to the F@H Forum Bad.Company.Sr,
The above line from your log means that while yous CPU slot was allocated 5 CPUs, the FahCore didn't like 5 (as it is a prime number larger than 3) so instead as reduced it to 4 to ensure that the WU can be processed.
Bad.Company.Sr
The process continues to run, but the error won't allow it to complete. As in the WU will show 100%, but as I said it won't complete. This happens to either the CPU or the GPU. What I generally do is close the program as the error is a Windows error. On occasion this clears the issue, but the last WU the system completed just won't finish (closed the error/program probably 20 times). I uninstalled and reinstalled (keeping the data) without a change.
I would suggest that you open up FAHControl (Advanced Control), Click on Configure, Select the Slots tab, select the CPU, click edit and change the value from -1 to 4 to prevent the decomposition message from appearing again.
Bad.Company.Sr
Thanks for the suggestion, but I tried that and still get the same error. Log follows.
*********************** Log Started 2020-04-05T00:06:58Z ***********************
00:06:58:************************* Folding@home Client *************************
00:06:58:        Website: https://foldingathome.org/
00:06:58:      Copyright: (c) 2009-2018 foldingathome.org
00:06:58:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:06:58:           Args: --open-web-control
00:06:58:         Config: C:\Users\Sr\AppData\Roaming\FAHClient\config.xml
00:06:58:******************************** Build ********************************
00:06:58:        Version: 7.5.1
00:06:58:           Date: May 11 2018
00:06:58:           Time: 13:06:32
00:06:58:     Repository: Git
00:06:58:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:06:58:         Branch: master
00:06:58:       Compiler: Visual C++ 2008
00:06:58:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:06:58:       Platform: win32 10
00:06:58:           Bits: 32
00:06:58:           Mode: Release
00:06:58:******************************* System ********************************
00:06:58:            CPU: AMD FX(tm)-6300 Six-Core Processor
00:06:58:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
00:06:58:           CPUs: 6
00:06:58:         Memory: 15.97GiB
00:06:58:    Free Memory: 13.23GiB
00:06:58:        Threads: WINDOWS_THREADS
00:06:58:     OS Version: 6.2
00:06:58:    Has Battery: false
00:06:58:     On Battery: false
00:06:58:     UTC Offset: -4
00:06:58:            PID: 7816
00:06:58:            CWD: C:\Users\Sr\AppData\Roaming\FAHClient
00:06:58:             OS: Windows 10 Enterprise
00:06:58:        OS Arch: AMD64
00:06:58:           GPUs: 1
00:06:58:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM206 [GeForce GTX 960] 2308
00:06:58:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:10.2
00:06:58:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.59
00:06:58:  Win32 Service: false
00:06:58:***********************************************************************
00:06:58:<config>
00:06:58:  <!-- Network -->
00:06:58:  <proxy v=':8080'/>
00:06:58:
00:06:58:  <!-- Slot Control -->
00:06:58:  <power v='full'/>
00:06:58:
00:06:58:  <!-- User Information -->
00:06:58:  <passkey v='********************************'/>
00:06:58:  <team v='223518'/>
00:06:58:  <user v='Bad.Company.Sr'/>
00:06:58:
00:06:58:  <!-- Folding Slots -->
00:06:58:  <slot id='0' type='CPU'>
00:06:58:    <cpus v='4'/>
00:06:58:    <paused v='true'/>
00:06:58:  </slot>
00:06:58:  <slot id='1' type='GPU'>
00:06:58:  </slot>
00:06:58:</config>
00:06:58:Trying to access database...
00:06:58:Successfully acquired database lock
00:06:58:Enabled folding slot 00: PAUSED cpu:4 (by user)
00:06:58:Enabled folding slot 01: PAUSED gpu:0:GM206 [GeForce GTX 960] 2308 (by user)
00:06:58:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11752 run:0 clone:10664 gen:1 core:0x22 unit:0x000000038ca304e75e6d6dd01be07975
00:06:58:WU01:FS01:Uploading 24.33MiB to 140.163.4.231
00:06:58:WU01:FS01:Connecting to 140.163.4.231:8080
00:07:08:13:127.0.0.1:New Web connection
00:07:14:FS00:Unpaused
00:07:14:FS01:Unpaused
00:07:14:WU00:FS01:Starting
00:07:14:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Sr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 7816 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
00:07:14:WU00:FS01:Started FahCore on PID 10364
00:07:14:WU00:FS01:Core PID:3416
00:07:14:WU00:FS01:FahCore 0x22 started
00:07:14:WU02:FS00:Starting
00:07:14:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Sr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 7816 -checkpoint 15 -np 4
00:07:14:WU02:FS00:Started FahCore on PID 4168
00:07:14:WU02:FS00:Core PID:2588
00:07:14:WU02:FS00:FahCore 0xa7 started
00:07:14:WU00:FS01:0x22:*********************** Log Started 2020-04-05T00:07:14Z ***********************
00:07:14:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:07:15:WU00:FS01:0x22:       Type: 0x22
00:07:15:WU00:FS01:0x22:       Core: Core22
00:07:15:WU00:FS01:0x22:    Website: https://foldingathome.org/
00:07:15:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
00:07:15:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
00:07:15:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
00:07:15:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 10364 -checkpoint 15
00:07:15:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
00:07:15:WU00:FS01:0x22:             0 -gpu 0
00:07:15:WU00:FS01:0x22:     Config: <none>
00:07:15:WU00:FS01:0x22:************************************ Build *************************************
00:07:15:WU00:FS01:0x22:    Version: 0.0.2
00:07:15:WU00:FS01:0x22:       Date: Dec 6 2019
00:07:15:WU00:FS01:0x22:       Time: 21:30:31
00:07:15:WU00:FS01:0x22: Repository: Git
00:07:15:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
00:07:15:WU00:FS01:0x22:     Branch: HEAD
00:07:15:WU00:FS01:0x22:   Compiler: Visual C++ 2008
00:07:15:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:07:15:WU00:FS01:0x22:   Platform: win32 10
00:07:15:WU00:FS01:0x22:       Bits: 64
00:07:15:WU02:FS00:0xa7:*********************** Log Started 2020-04-05T00:07:14Z ***********************
00:07:15:WU00:FS01:0x22:       Mode: Release
00:07:15:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:07:15:WU00:FS01:0x22:************************************ System ************************************
00:07:15:WU02:FS00:0xa7:       Type: 0xa7
00:07:15:WU00:FS01:0x22:        CPU: AMD FX(tm)-6300 Six-Core Processor
00:07:15:WU02:FS00:0xa7:       Core: Gromacs
00:07:15:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
00:07:15:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 4168 -checkpoint 15 -np 4
00:07:15:WU00:FS01:0x22:       CPUs: 6
00:07:15:WU02:FS00:0xa7:************************************ CBang *************************************
00:07:15:WU00:FS01:0x22:     Memory: 15.97GiB
00:07:15:WU02:FS00:0xa7:       Date: Oct 26 2019
00:07:15:WU00:FS01:0x22:Free Memory: 12.69GiB
00:07:15:WU02:FS00:0xa7:       Time: 01:38:25
00:07:15:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
00:07:15:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
00:07:15:WU00:FS01:0x22: OS Version: 6.2
00:07:15:WU02:FS00:0xa7:     Branch: master
00:07:15:WU00:FS01:0x22:Has Battery: false
00:07:15:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
00:07:15:WU00:FS01:0x22: On Battery: false
00:07:15:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:07:15:WU00:FS01:0x22: UTC Offset: -4
00:07:15:WU02:FS00:0xa7:   Platform: win32 10
00:07:15:WU00:FS01:0x22:        PID: 3416
00:07:15:WU02:FS00:0xa7:       Bits: 64
00:07:15:WU00:FS01:0x22:        CWD: C:\Users\Sr\AppData\Roaming\FAHClient\work
00:07:15:WU02:FS00:0xa7:       Mode: Release
00:07:15:WU00:FS01:0x22:         OS: Windows 10 Pro
00:07:15:WU02:FS00:0xa7:************************************ System ************************************
00:07:15:WU00:FS01:0x22:    OS Arch: AMD64
00:07:15:WU02:FS00:0xa7:        CPU: AMD FX(tm)-6300 Six-Core Processor
00:07:15:WU00:FS01:0x22:********************************************************************************
00:07:15:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
00:07:15:WU00:FS01:0x22:Project: 13874 (Run 0, Clone 694, Gen 15)
00:07:15:WU02:FS00:0xa7:       CPUs: 6
00:07:15:WU00:FS01:0x22:Unit: 0x000000150d5262775e7adc2d70e321f0
00:07:15:WU02:FS00:0xa7:     Memory: 15.97GiB
00:07:15:WU00:FS01:0x22:Reading tar file core.xml
00:07:15:WU02:FS00:0xa7:Free Memory: 12.68GiB
00:07:15:WU00:FS01:0x22:Reading tar file integrator.xml
00:07:15:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
00:07:15:WU00:FS01:0x22:Reading tar file state.xml
00:07:15:WU02:FS00:0xa7: OS Version: 6.2
00:07:15:WU02:FS00:0xa7:Has Battery: false
00:07:15:WU02:FS00:0xa7: On Battery: false
00:07:15:WU02:FS00:0xa7: UTC Offset: -4
00:07:15:WU02:FS00:0xa7:        PID: 2588
00:07:15:WU02:FS00:0xa7:        CWD: C:\Users\Sr\AppData\Roaming\FAHClient\work
00:07:15:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
00:07:15:WU02:FS00:0xa7:    Version: 0.0.18
00:07:15:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:07:15:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
00:07:15:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
00:07:15:WU02:FS00:0xa7:       Time: 01:52:30
00:07:15:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
00:07:15:WU02:FS00:0xa7:************************************ Build *************************************
00:07:15:WU02:FS00:0xa7:       SIMD: avx_256
00:07:15:WU02:FS00:0xa7:********************************************************************************
00:07:15:WU02:FS00:0xa7:Project: 13826 (Run 133, Clone 4, Gen 5)
00:07:15:WU02:FS00:0xa7:Unit: 0x0000000780fccb095c979bf348b2d110
00:07:15:WU02:FS00:0xa7:Reading tar file core.xml
00:07:15:WU02:FS00:0xa7:Reading tar file frame5.tpr
00:07:15:WU02:FS00:0xa7:Digital signatures verified
00:07:15:WU02:FS00:0xa7:Calling: mdrun -s frame5.tpr -o frame5.trr -x frame5.xtc -cpi state.cpt -cpt 15 -nt 4
00:07:15:WU02:FS00:0xa7:ERROR:Guru Meditation: not checked '02/01/state.cpt'
00:07:15:WU02:FS00:0xa7:WARNING:Unexpected exit() call
00:07:15:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
00:07:15:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
00:07:15:WU02:FS00:0xa7:Saving result file frame5.trr
00:07:15:WU02:FS00:0xa7:ERROR:Guru Meditation: not checked '02/01/frame5.trr'
00:07:15:WU00:FS01:0x22:Reading tar file system.xml
00:07:18:WU00:FS01:0x22:Digital signatures verified
00:07:18:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:07:18:WU00:FS01:0x22:Version 0.0.2
00:07:59:Removing old file 'configs/config-20200329-092621.xml'
00:07:59:Saving configuration to config.xml
00:07:59:<config>
00:07:59:  <!-- Network -->
00:07:59:  <proxy v=':8080'/>
00:07:59:
00:07:59:  <!-- Slot Control -->
00:07:59:  <power v='full'/>
00:07:59:
00:07:59:  <!-- User Information -->
00:07:59:  <passkey v='********************************'/>
00:07:59:  <team v='223518'/>
00:07:59:  <user v='Bad.Company.Sr'/>
00:07:59:
00:07:59:  <!-- Folding Slots -->
00:07:59:  <slot id='0' type='CPU'>
00:07:59:    <cpus v='4'/>
00:07:59:  </slot>
00:07:59:  <slot id='1' type='GPU'/>
00:07:59:</config>
00:08:35:WU01:FS01:Upload 0.51%
00:08:35:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
00:08:36:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11752 run:0 clone:10664 gen:1 core:0x22 unit:0x000000038ca304e75e6d6dd01be07975
00:08:36:WU01:FS01:Uploading 24.33MiB to 140.163.4.231
00:08:36:WU01:FS01:Connecting to 140.163.4.231:8080
00:09:22:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
00:09:23:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:09:47:WU01:FS01:Upload 0.51%
00:09:47:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
00:10:13:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11752 run:0 clone:10664 gen:1 core:0x22 unit:0x000000038ca304e75e6d6dd01be07975
00:10:13:WU01:FS01:Uploading 24.33MiB to 140.163.4.231
00:10:13:WU01:FS01:Connecting to 140.163.4.231:8080
I see the "Error: Guru Meditation" messages on the WU. Has this system processed WUs on the CPU before? And is it trying to process the same WU - Project: 13826 (Run 133, Clone 4, Gen 5) - each time?
The Guru Meditation appears to be point to an issue opening part of the work files for this WU, specifically the checkpoint file. It is either locked or corrupted, the second is most likely. To continue you will need to remove this WU.
Pause folding first. The go to: C:\Users\Sr\AppData\Roaming\FAHClient\work and delete the folder named '02'. Then restart folding. The client will detect the missing WU, and clean up the CPU folding slot to request another.
Bad.Company.Sr
It has, but as far as I can tell it is processing different WUs. It has one completed but stalled at sending. It is working on another WU as I type this, as is the GPU.
When I paused the client, the system deleted that folder on it's own and had just started another WU. Seems fine at the moment, no error after closing the last one.
Wait and see is what I'll do.
