HOWTO: AMD Radeon RX 550 on Debian 10 with rocm driver
qwertz
Post by qwertz »
Hi,
after some struggling, I finally got my setup running with GPU. This setup includes:
  • A PC running Debian Linux Version 10 (Codename buster)
  • A AMD Radeon RX 550 Graphics card
I wanted to use Open Source drivers, so I installed rocm, as explained in https://rocm-documentation.readthedocs. ... Guide.html. I did not try proprietary AMD drivers, so I can say nothing about them. I checked it was working by running "clinfo".
I also installed FAH as explained in https://foldingathome.org/support/faq/i ... des/linux/.
Initially FAH worked, but did not use the GPU. So I did the following:
  • Add the user fahclient to the group render by running "adduser fahclient render" on a console as root. It is required to access the GPU, but it is not done by default (FAH 7.5.1).
  • restart the fahclient outside of systemd
    systemctl stop FAHClient.service
    /etc/init.d/FAHClient start
    Surprisingly, this made a difference. I do not know why.
  • configure the GPU slot with opencl-index=0
  • and most important: wait for the latest rocm update! (rocm-dkms version 3.3.0-19, early April 2020)
Then I just needed to verify that FAHControl "System Info" detects the OpenCL Device and finally run folding. :D
I hope this will help some of you in getting started.
(see also viewtopic.php?f=83&t=32226)
Re: HOWTO: AMD Radeon RX 550 on Debian 10 with rocm driver
Post by muziqaz »
Awesome stuff, thank you for your effort. Hopefully it will be helpful for other using Linux and AMD GPUs :)
FAH Omega tester
Thread pinned, unless some one complains that it didn't work for him ... ;)
Rainmaker
Hardware configuration: AMD Threadripper 3960X underclocked/undervolted to 3.7GHz 1.0125v
Asus RoG Strix TRX40-E Gaming motherboard
32GB DDR4 3600MHz 16,16,16,36 (Samsung B-Die)
Sapphire Vega 56 overclocked/undervolted to 1662MHz 1070mV
Samsung Evo Plus 1TB NVMe SSD
Linux FTW
Post by Rainmaker »
Nice! I'm still battling freezes that I think are attributable to the current proprietary AMD OpenCL driver, as they only happen on Linux not Windows (which runs different versions). Just a question: Did you install rocm-dkms or did you opt to use upstream kernel drivers (as outlined in the install guide you linked)?
qwertz
Post by qwertz »
Rainmaker wrote:Nice! I'm still battling freezes that I think are attributable to the current proprietary AMD OpenCL driver, as they only happen on Linux not Windows (which runs different versions). Just a question: Did you install rocm-dkms or did you opt to use upstream kernel drivers (as outlined in the install guide you linked)?
Right, I was not precise. I followed the Ubuntu instructions with rocm-dkms, not the Upstream Kernel Drivers.
holstien
Post by holstien »
Hopefully more success stories follow. I have been using the proprietary drivers without issue, but they are so painful to get installed and working.
braiam
Post by braiam »
I did the same. But instead I edited the init file so that it uses root user instead. viewtopic.php?f=106&t=34231
