Hello,
I have 4 PCs running the folding service, all are reporting sending WUs out and downloading new WUs, but only 3 are reported in the stats as being online.
Any ideas on how to troubleshoot this further?
Thanks and regards
4 PCs running only 3 PCs are reported online in stats
Re: 4 PCs running only 3 PCs are reported online in stats
Welcome to the F@H Forum arg,
If you have 4 PCs that are folding without issues, I am not sure what you mean by "but only 3 are reported in the stats as being online". Could you please elaborate a bit further?
If you're talking about missing points, the F@H Servers are under significant load (viewtopic.php?f=61&t=33193) and as long as you successfully uploaded the WU, it will be credited.
Hi, thanks for your reply. What I mean is that I see in the stats 3 clients
in donor stats: https://1drv.ms/u/s!AmtCz-mPInTyjYUhoob ... g?e=lwWTZH and in CPU stats: https://1drv.ms/u/s!AmtCz-mPInTyjYUjilf ... w?e=rJDmSF
whereas I am running FAHclient in 4 PCS: https://1drv.ms/u/s!AmtCz-mPInTyjYUiBlb ... g?e=OJPkdd
I hope that makes more sense now.
Thanks for the screenshots. If you recently started folding, it could be that the WUs from the fourth system haven't yet made it to the Stats system.
You can identify what system is missing based on which WUs were returned. Once you have identified the missing system, you can post the log here for analysis.
The client gets a unique machineID when it is first started after installation. If one of the computers is a clone/copy the stats will merge.
