can't send completed jobs
OddSoxChris
Post by OddSoxChris »
just started seeing this:
15:33:52:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
15:34:13:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Is there problem with that server or is there one on my side? It did work well before.
davidcoton
Re: can't send completed jobs
Post by davidcoton »
It's either a network problem, or (more likely) server overload. It will retry and sort itself out eventually.
OddSoxChris
also, the credit keeps going down while the WU is waiting for sending.
now it's worth a half of the initial credit score :/
I can see other WUs being sent!
Why is this only one lingering?
davidcoton
Different server?
Yes bonus points are reduced by delayed returns. It's the same for everyone. Sorry.
treckin
Post by treckin »
Oh yeah, Im also struggling with this server myself, at least now I know its not on my end
YaF3li
Post by YaF3li »
I have the same issue with that server, so it is likely just overloaded at the moment.
Norm!24
Post by Norm!24 »
Yes same for me with 140.163.4.231 ... now at 22 attempts :cry:
coppergrease
Post by coppergrease »
Another vote for a blocked send on the same server, 140.163.4.231
The Collection server is listed as 0.0.0.0 which is odd...
treckin
Post by treckin »
I mean I emailed the contact on the Psummary page about his server, never got a reply.
Manfred.Knick
Hardware configuration: Multiple XEON + GTX
Post by Manfred.Knick »
@ OP: Poposal:
Could you please edit the headline of this your thread
to include "40.163.4.231:" at the beginning?
Thanks!
davidcoton
coppergrease wrote:The Collection server is listed as 0.0.0.0 which is odd...
Not odd. Just non-existent. Not every project uses a CS, though it certainly helps to avoid some return problems.
uyaem
Post by uyaem »
Like was said before, not all WU servers have a collection server.
See the Has CS column at https://apps.foldingathome.org/serverstats :)
Norm!24
Post by Norm!24 »
Whew! It's away ....
16:55:34:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11747 run:0 clone:1735 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fcd9f43757e
16:55:34:WU01:FS01:Uploading 21.93MiB to 140.163.4.231
16:55:34:WU01:FS01:Connecting to 140.163.4.231:8080
16:56:53:WU01:FS01:Upload 0.86%
16:56:59:WU01:FS01:Upload 4.56%
16:57:05:WU01:FS01:Upload 15.39%
16:57:14:WU01:FS01:Upload 28.79%
16:57:20:WU01:FS01:Upload 42.47%
16:57:27:WU01:FS01:Upload 53.87%
16:57:35:WU01:FS01:Upload 63.28%
16:57:41:WU01:FS01:Upload 77.82%
16:57:48:WU01:FS01:Upload 86.94%
16:58:03:WU01:FS01:Upload complete
16:58:03:WU01:FS01:Server responded WORK_ACK (400)
16:58:03:WU01:FS01:Final credit estimate, 17385.00 points
mac
Post by mac »
Hi, i like to update this line of 2 or 3 ip that not upload just done the job and cant send it up, i have rebot, restart, update software but it still some error to upload.
its 6 jobs are done and no upload in log it just say:
16:53:18:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16401 run:134 clone:0 gen:88 core:0xa7 unit:0x0000006396880e6e5e814ca45a2c4b62
16:53:18:WU01:FS00:Uploading 1.42MiB to 150.136.14.110
16:53:18:WU01:FS00:Connecting to 150.136.14.110:8080
16:53:38:WU01:FS00:Upload 8.79%
16:53:38:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
16:53:38:WU01:FS00:Trying to send results to collection server
16:53:38:WU01:FS00:Uploading 1.42MiB to 129.213.157.105
16:53:38:WU01:FS00:Connecting to 129.213.157.105:8080
16:53:58:WU01:FS00:Upload 8.79%
16:53:58:ERROR:WU01:FS00:Exception: Transfer failed
16:52:57:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:16403 run:2013 clone:2 gen:44 core:0xa7 unit:0x0000003096880e6e5e8bdf75af467a0b
16:52:57:WU02:FS00:Uploading 1.42MiB to 150.136.14.110
16:52:57:WU02:FS00:Connecting to 150.136.14.110:8080
16:53:16:WU02:FS00:Upload 8.78%
16:53:16:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
16:53:16:WU02:FS00:Trying to send results to collection server
16:53:16:WU02:FS00:Uploading 1.42MiB to 129.213.40.229
16:53:16:WU02:FS00:Connecting to 129.213.40.229:8080
16:53:36:WU02:FS00:Upload 8.78%
16:53:36:ERROR:WU02:FS00:Exception: Transfer failed
16:52:57:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:16403 run:1045 clone:2 gen:39 core:0xa7 unit:0x0000002b96880e6e5e8be0e697c95b78
16:52:57:WU03:FS00:Uploading 1.42MiB to 150.136.14.110
16:52:57:WU03:FS00:Connecting to 150.136.14.110:8080
16:53:16:WU03:FS00:Upload 8.81%
16:53:16:WARNING:WU03:FS00:Exception: Failed to send results to work server: Transfer failed
16:53:16:WU03:FS00:Trying to send results to collection server
16:53:16:WU03:FS00:Uploading 1.42MiB to 129.213.40.229
16:53:16:WU03:FS00:Connecting to 129.213.40.229:8080
16:53:36:WU03:FS00:Upload 8.81%
16:53:36:ERROR:WU03:FS00:Exception: Transfer failed
16:42:35:ERROR:WU04:FS00:Exception: Transfer failed
16:53:01:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:16423 run:811 clone:1 gen:31 core:0xa7 unit:0x0000002296880e6e5e8a8e017dec41f7
16:53:01:WU04:FS00:Uploading 1.85MiB to 150.136.14.110
16:53:01:WU04:FS00:Connecting to 150.136.14.110:8080
16:53:20:WU04:FS00:Upload 6.77%
16:53:20:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
16:53:20:WU04:FS00:Trying to send results to collection server
16:53:20:WU04:FS00:Uploading 1.85MiB to 129.213.157.105
16:53:20:WU04:FS00:Connecting to 129.213.157.105:8080
16:53:40:WU04:FS00:Upload 6.77%
16:53:40:ERROR:WU04:FS00:Exception: Transfer failed
16:52:57:WU06:FS00:Sending unit results: id:06 state:SEND error:NO_ERROR project:16417 run:2704 clone:2 gen:81 core:0xa7 unit:0x0000005996880e6e5e8a5fc6e6a0ea7b
16:52:57:WU06:FS00:Uploading 1.97MiB to 150.136.14.110
16:52:57:WU06:FS00:Connecting to 150.136.14.110:8080
16:53:16:WU06:FS00:Upload 6.33%
16:53:16:WARNING:WU06:FS00:Exception: Failed to send results to work server: Transfer failed
16:53:16:WU06:FS00:Trying to send results to collection server
16:53:16:WU06:FS00:Uploading 1.97MiB to 129.213.157.105
16:53:16:WU06:FS00:Connecting to 129.213.157.105:8080
16:53:35:WU06:FS00:Upload 6.33%
16:53:35:ERROR:WU06:FS00:Exception: Transfer failed
16:53:01:WU07:FS00:Sending unit results: id:07 state:SEND error:NO_ERROR project:16403 run:773 clone:2 gen:55 core:0xa7 unit:0x0000003e96880e6e5e8be0e31e252948
16:53:01:WU07:FS00:Uploading 1.42MiB to 150.136.14.110
16:53:01:WU07:FS00:Connecting to 150.136.14.110:8080
16:53:20:WU07:FS00:Upload 8.80%
16:53:20:WARNING:WU07:FS00:Exception: Failed to send results to work server: Transfer failed
16:53:20:WU07:FS00:Trying to send results to collection server
16:53:20:WU07:FS00:Uploading 1.42MiB to 129.213.40.229
16:53:20:WU07:FS00:Connecting to 129.213.40.229:8080
16:53:40:WU07:FS00:Upload 8.80%
16:53:40:ERROR:WU07:FS00:Exception: Transfer failed
and its start 17:th april, any suggestion ?
Welcome to the F@H Forum mac,
Please note that the Work Server was recently rebooted so hopefully, you can now upload the completed WUs :)
