WU DUMPED after 8 days :( 13871 (Run 0, Clone 663, Gen 9)
SeanPearce44
Post by SeanPearce44 »
Thanks F@H - Committed 8 DAYS(!!) compute time to have a WU DUMPED, with only a few hours to go! :x :x
I have a number of CPUs squirrelling away - and I did see this one had an extended amount of time to complete, but just left it there as other CPUs delivering OK.
I hope I get *some* recognition for it?
05:11:52:WU02:FS00:Connecting to 65.254.110.245:8080
05:11:52:WU02:FS00:Assigned to work server 13.82.98.119
05:11:52:WU02:FS00:Requesting new work unit for slot 00: READY cpu:1 from 13.82.98.119
05:11:52:WU02:FS00:Connecting to 13.82.98.119:8080
05:11:52:WU02:FS00:Downloading 7.46MiB
05:11:58:WU02:FS00:Download 94.72%
05:11:58:WU02:FS00:Download complete
05:11:58:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13871 run:0 clone:663 gen:9 core:0xa7 unit:0x0000000a0d5262775e76c948916693c7
05:11:58:WU02:FS00:Starting
05:11:58:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Administrator\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 8388 -checkpoint 15 -np 1
05:11:59:WU02:FS00:Started FahCore on PID 9584
05:11:59:WU02:FS00:Core PID:5560
05:11:59:WU02:FS00:FahCore 0xa7 started
05:12:01:WU02:FS00:0xa7:*********************** Log Started 2020-03-27T05:12:00Z ***********************
05:12:01:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
05:12:01:WU02:FS00:0xa7:       Type: 0xa7
05:12:01:WU02:FS00:0xa7:       Core: Gromacs
05:12:01:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 9584 -checkpoint 15 -np 1
05:12:01:WU02:FS00:0xa7:************************************ CBang *************************************
05:12:01:WU02:FS00:0xa7:       Date: Oct 26 2019
05:12:01:WU02:FS00:0xa7:       Time: 01:38:35
05:12:01:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
05:12:01:WU02:FS00:0xa7:     Branch: master
05:12:01:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
05:12:01:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:12:01:WU02:FS00:0xa7:   Platform: win32 10
05:12:01:WU02:FS00:0xa7:       Bits: 64
05:12:01:WU02:FS00:0xa7:       Mode: Release
05:12:01:WU02:FS00:0xa7:************************************ System ************************************
05:12:01:WU02:FS00:0xa7:        CPU: AMD Turion(tm) II Neo N54L Dual-Core Processor
05:12:01:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 16 Model 6 Stepping 3
05:12:01:WU02:FS00:0xa7:       CPUs: 2
05:12:01:WU02:FS00:0xa7:     Memory: 7.75GiB
05:12:01:WU02:FS00:0xa7:Free Memory: 1.96GiB
05:12:01:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
05:12:01:WU02:FS00:0xa7: OS Version: 6.1
05:12:01:WU02:FS00:0xa7:Has Battery: false
05:12:01:WU02:FS00:0xa7: On Battery: false
05:12:01:WU02:FS00:0xa7: UTC Offset: 0
05:12:01:WU02:FS00:0xa7:        PID: 5560
05:12:01:WU02:FS00:0xa7:        CWD: C:\Users\Administrator\AppData\Roaming\FAHClient\work
05:12:01:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
05:12:01:WU02:FS00:0xa7:    Version: 0.0.18
05:12:01:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:12:01:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
05:12:01:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
05:12:01:WU02:FS00:0xa7:       Time: 01:52:44
05:12:01:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
05:12:01:WU02:FS00:0xa7:************************************ Build *************************************
05:12:01:WU02:FS00:0xa7:       SIMD: sse2
05:12:01:WU02:FS00:0xa7:********************************************************************************
05:12:01:WU02:FS00:0xa7:Project: 13871 (Run 0, Clone 663, Gen 9)
05:12:01:WU02:FS00:0xa7:Unit: 0x0000000a0d5262775e76c948916693c7
05:12:01:WU02:FS00:0xa7:Reading tar file core.xml
05:12:01:WU02:FS00:0xa7:Reading tar file frame9.tpr
05:12:01:WU02:FS00:0xa7:Digital signatures verified
05:12:01:WU02:FS00:0xa7:Calling: mdrun -s frame9.tpr -o frame9.trr -x frame9.xtc -e frame9.edr -cpt 15 -nt 1
05:12:03:WU02:FS00:0xa7:Steps: first=625000 total=625000
05:12:09:WU02:FS00:0xa7:Completed 1 out of 625000 steps (0%)
06:58:06:WU02:FS00:0xa7:Completed 6250 out of 625000 steps (1%)
******************************* Date: 2020-03-27 *******************************
07:45:30:WU01:FS01:Connecting to 65.254.110.245:8080
07:45:31:WU01:FS01:Assigned to work server 192.0.2.1
07:45:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
07:45:34:WU01:FS01:Connecting to 192.0.2.1:8080
07:45:55:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:45:55:WU01:FS01:Connecting to 192.0.2.1:80
07:46:16:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:44:07:WU02:FS00:0xa7:Completed 12500 out of 625000 steps (2%)
10:30:24:WU02:FS00:0xa7:Completed 18750 out of 625000 steps (3%)
12:16:16:WU02:FS00:0xa7:Completed 25000 out of 625000 steps (4%)
13:45:31:WU01:FS01:Connecting to 65.254.110.245:8080
13:45:31:WU01:FS01:Assigned to work server 192.0.2.1
13:45:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
13:45:34:WU01:FS01:Connecting to 192.0.2.1:8080
13:45:55:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:45:55:WU01:FS01:Connecting to 192.0.2.1:80
13:46:16:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:02:08:WU02:FS00:0xa7:Completed 31250 out of 625000 steps (5%)
15:47:55:WU02:FS00:0xa7:Completed 37500 out of 625000 steps (6%)
17:34:23:WU02:FS00:0xa7:Completed 43750 out of 625000 steps (7%)
19:20:11:WU02:FS00:0xa7:Completed 50000 out of 625000 steps (8%)
19:45:31:WU01:FS01:Connecting to 65.254.110.245:8080
19:45:31:WU01:FS01:Assigned to work server 192.0.2.1
19:45:35:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
19:45:35:WU01:FS01:Connecting to 192.0.2.1:8080
19:45:56:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:45:56:WU01:FS01:Connecting to 192.0.2.1:80
19:46:17:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:06:05:WU02:FS00:0xa7:Completed 56250 out of 625000 steps (9%)
22:51:54:WU02:FS00:0xa7:Completed 62500 out of 625000 steps (10%)
00:37:39:WU02:FS00:0xa7:Completed 68750 out of 625000 steps (11%)
******************************* Date: 2020-03-28 *******************************
01:45:31:WU01:FS01:Connecting to 65.254.110.245:8080
01:45:31:WU01:FS01:Assigned to work server 192.0.2.1
01:45:35:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
01:45:35:WU01:FS01:Connecting to 192.0.2.1:8080
01:45:56:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
01:45:56:WU01:FS01:Connecting to 192.0.2.1:80
01:46:17:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:24:10:WU02:FS00:0xa7:Completed 75000 out of 625000 steps (12%)
04:11:11:WU02:FS00:0xa7:Completed 81250 out of 625000 steps (13%)
05:56:54:WU02:FS00:0xa7:Completed 87500 out of 625000 steps (14%)
07:42:41:WU02:FS00:0xa7:Completed 93750 out of 625000 steps (15%)
07:45:31:WU01:FS01:Connecting to 65.254.110.245:8080
07:45:32:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: No connection could be made because the target machine actively refused it.
07:45:32:WU01:FS01:Connecting to 18.218.241.186:80
07:45:32:WU01:FS01:Assigned to work server 192.0.2.1
07:45:35:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
07:45:35:WU01:FS01:Connecting to 192.0.2.1:8080
07:45:56:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:45:56:WU01:FS01:Connecting to 192.0.2.1:80
07:46:17:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:28:25:WU02:FS00:0xa7:Completed 100000 out of 625000 steps (16%)
11:14:28:WU02:FS00:0xa7:Completed 106250 out of 625000 steps (17%)
13:00:52:WU02:FS00:0xa7:Completed 112500 out of 625000 steps (18%)
13:45:35:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
13:45:35:WU01:FS01:Connecting to 192.0.2.1:8080
13:45:56:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:45:56:WU01:FS01:Connecting to 192.0.2.1:80
13:46:17:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:46:39:WU02:FS00:0xa7:Completed 118750 out of 625000 steps (19%)
16:33:23:WU02:FS00:0xa7:Completed 125000 out of 625000 steps (20%)
18:19:45:WU02:FS00:0xa7:Completed 131250 out of 625000 steps (21%)
20:05:56:WU02:FS00:0xa7:Completed 137500 out of 625000 steps (22%)
21:52:20:WU02:FS00:0xa7:Completed 143750 out of 625000 steps (23%)
23:38:35:WU02:FS00:0xa7:Completed 150000 out of 625000 steps (24%)
01:28:21:WU02:FS00:0xa7:Completed 156250 out of 625000 steps (25%)
******************************* Date: 2020-03-29 *******************************
03:17:17:WU02:FS00:0xa7:Completed 162500 out of 625000 steps (26%)
05:03:25:WU02:FS00:0xa7:Completed 168750 out of 625000 steps (27%)
06:49:39:WU02:FS00:0xa7:Completed 175000 out of 625000 steps (28%)
08:36:01:WU02:FS00:0xa7:Completed 181250 out of 625000 steps (29%)
10:22:16:WU02:FS00:0xa7:Completed 187500 out of 625000 steps (30%)
12:08:30:WU02:FS00:0xa7:Completed 193750 out of 625000 steps (31%)
13:45:32:WU01:FS01:Assigned to work server 192.0.2.1
13:54:51:WU02:FS00:0xa7:Completed 200000 out of 625000 steps (32%)
15:41:51:WU02:FS00:0xa7:Completed 206250 out of 625000 steps (33%)
17:28:06:WU02:FS00:0xa7:Completed 212500 out of 625000 steps (34%)
19:14:16:WU02:FS00:0xa7:Completed 218750 out of 625000 steps (35%)
19:45:32:WU01:FS01:Connecting to 65.254.110.245:8080
19:45:32:WU01:FS01:Assigned to work server 192.0.2.1
21:00:31:WU02:FS00:0xa7:Completed 225000 out of 625000 steps (36%)
22:46:58:WU02:FS00:0xa7:Completed 231250 out of 625000 steps (37%)
00:33:11:WU02:FS00:0xa7:Completed 237500 out of 625000 steps (38%)
******************************* Date: 2020-03-30 *******************************
01:45:35:WU01:FS01:Connecting to 65.254.110.245:8080
01:45:36:WU01:FS01:Assigned to work server 192.0.2.1
01:45:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
01:45:36:WU01:FS01:Connecting to 192.0.2.1:8080
01:45:57:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
01:45:57:WU01:FS01:Connecting to 192.0.2.1:80
01:46:18:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:23:25:WU02:FS00:0xa7:Completed 243750 out of 625000 steps (39%)
04:09:55:WU02:FS00:0xa7:Completed 250000 out of 625000 steps (40%)
05:56:08:WU02:FS00:0xa7:Completed 256250 out of 625000 steps (41%)
07:42:12:WU02:FS00:0xa7:Completed 262500 out of 625000 steps (42%)
07:45:32:WU01:FS01:Connecting to 65.254.110.245:8080
07:45:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
07:45:36:WU01:FS01:Connecting to 192.0.2.1:8080
07:45:57:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:45:57:WU01:FS01:Connecting to 192.0.2.1:80
07:46:18:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:28:26:WU02:FS00:0xa7:Completed 268750 out of 625000 steps (43%)
11:14:39:WU02:FS00:0xa7:Completed 275000 out of 625000 steps (44%)
13:00:58:WU02:FS00:0xa7:Completed 281250 out of 625000 steps (45%)
13:45:32:WU01:FS01:Connecting to 65.254.110.245:8080
13:45:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
13:45:36:WU01:FS01:Connecting to 192.0.2.1:8080
13:45:57:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:45:57:WU01:FS01:Connecting to 192.0.2.1:80
13:46:18:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:47:13:WU02:FS00:0xa7:Completed 287500 out of 625000 steps (46%)
16:33:55:WU02:FS00:0xa7:Completed 293750 out of 625000 steps (47%)
18:20:04:WU02:FS00:0xa7:Completed 300000 out of 625000 steps (48%)
19:45:33:WU01:FS01:Assigned to work server 192.0.2.1
19:45:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
19:45:36:WU01:FS01:Connecting to 192.0.2.1:8080
19:45:57:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:45:57:WU01:FS01:Connecting to 192.0.2.1:80
19:46:18:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
20:06:07:WU02:FS00:0xa7:Completed 306250 out of 625000 steps (49%)
21:52:41:WU02:FS00:0xa7:Completed 312500 out of 625000 steps (50%)
23:38:39:WU02:FS00:0xa7:Completed 318750 out of 625000 steps (51%)
01:25:29:WU02:FS00:0xa7:Completed 325000 out of 625000 steps (52%)
01:45:32:WU01:FS01:Connecting to 65.254.110.245:8080
01:45:33:WU01:FS01:Assigned to work server 192.0.2.1
******************************* Date: 2020-03-31 *******************************
01:45:37:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
01:45:37:WU01:FS01:Connecting to 192.0.2.1:8080
01:45:58:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
01:45:58:WU01:FS01:Connecting to 192.0.2.1:80
01:46:19:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:13:26:WU02:FS00:0xa7:Completed 331250 out of 625000 steps (53%)
03:28:14:FS00:Finishing
03:28:59:FS00:Paused
03:28:59:FS01:Paused
03:28:59:FS00:Shutting core down
03:29:00:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 5560
03:29:00:WU02:FS00:0xa7:Exiting, please wait. . .
03:29:01:FS00:Unpaused
03:29:01:FS01:Unpaused
03:29:01:WU01:FS01:Connecting to 65.254.110.245:8080
03:29:02:WU01:FS01:Assigned to work server 192.0.2.1
03:29:02:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
03:29:02:WU01:FS01:Connecting to 192.0.2.1:8080
03:29:04:FS00:Paused
03:29:04:FS01:Paused
03:29:04:FS00:Shutting core down
03:29:05:FS00:Unpaused
03:29:05:FS01:Unpaused
03:29:09:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
03:29:09:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:29:10:WU02:FS00:Starting
03:29:10:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Administrator\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 8388 -checkpoint 15 -np 1
03:29:10:WU02:FS00:Started FahCore on PID 2700
03:29:10:WU02:FS00:Core PID:2924
03:29:10:WU02:FS00:FahCore 0xa7 started
03:29:11:WU02:FS00:0xa7:*********************** Log Started 2020-03-31T03:29:10Z ***********************
03:29:11:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:29:11:WU02:FS00:0xa7:       Type: 0xa7
03:29:11:WU02:FS00:0xa7:       Core: Gromacs
03:29:11:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 2700 -checkpoint 15 -np 1
03:29:11:WU02:FS00:0xa7:************************************ CBang *************************************
03:29:11:WU02:FS00:0xa7:       Date: Oct 26 2019
03:29:11:WU02:FS00:0xa7:       Time: 01:38:35
03:29:11:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:29:11:WU02:FS00:0xa7:     Branch: master
03:29:11:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
03:29:11:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:29:11:WU02:FS00:0xa7:   Platform: win32 10
03:29:11:WU02:FS00:0xa7:       Bits: 64
03:29:11:WU02:FS00:0xa7:       Mode: Release
03:29:11:WU02:FS00:0xa7:************************************ System ************************************
03:29:11:WU02:FS00:0xa7:        CPU: AMD Turion(tm) II Neo N54L Dual-Core Processor
03:29:11:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 16 Model 6 Stepping 3
03:29:11:WU02:FS00:0xa7:       CPUs: 2
03:29:11:WU02:FS00:0xa7:     Memory: 7.75GiB
03:29:11:WU02:FS00:0xa7:Free Memory: 1.94GiB
03:29:11:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
03:29:11:WU02:FS00:0xa7: OS Version: 6.1
03:29:11:WU02:FS00:0xa7:Has Battery: false
03:29:11:WU02:FS00:0xa7: On Battery: false
03:29:11:WU02:FS00:0xa7: UTC Offset: 1
03:29:11:WU02:FS00:0xa7:        PID: 2924
03:29:11:WU02:FS00:0xa7:        CWD: C:\Users\Administrator\AppData\Roaming\FAHClient\work
03:29:11:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
03:29:11:WU02:FS00:0xa7:    Version: 0.0.18
03:29:11:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:29:11:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:29:11:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
03:29:11:WU02:FS00:0xa7:       Time: 01:52:44
03:29:11:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:29:11:WU02:FS00:0xa7:************************************ Build *************************************
03:29:11:WU02:FS00:0xa7:       SIMD: sse2
03:29:11:WU02:FS00:0xa7:********************************************************************************
03:29:11:WU02:FS00:0xa7:Project: 13871 (Run 0, Clone 663, Gen 9)
03:29:11:WU02:FS00:0xa7:Unit: 0x0000000a0d5262775e76c948916693c7
03:29:11:WU02:FS00:0xa7:Digital signatures verified
03:29:11:WU02:FS00:0xa7:Calling: mdrun -s frame9.tpr -o frame9.trr -x frame9.xtc -e frame9.edr -cpi state.cpt -cpt 15 -nt 1
03:29:18:WU02:FS00:0xa7:Steps: first=625000 total=625000
03:29:22:WU02:FS00:0xa7:Completed 332172 out of 625000 steps (53%)
03:29:23:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:29:23:WU01:FS01:Connecting to 192.0.2.1:80
03:29:29:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
03:29:44:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:30:02:WU01:FS01:Connecting to 65.254.110.245:8080
03:30:02:WU01:FS01:Assigned to work server 192.0.2.1
03:30:02:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
03:30:02:WU01:FS01:Connecting to 192.0.2.1:8080
03:30:23:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:30:23:WU01:FS01:Connecting to 192.0.2.1:80
03:30:44:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:31:39:WU01:FS01:Connecting to 65.254.110.245:8080
03:31:39:WU01:FS01:Assigned to work server 192.0.2.1
03:31:39:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
03:31:39:WU01:FS01:Connecting to 192.0.2.1:8080
03:32:00:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:32:00:WU01:FS01:Connecting to 192.0.2.1:80
03:32:21:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:34:16:WU01:FS01:Connecting to 65.254.110.245:8080
03:34:16:WU01:FS01:Assigned to work server 192.0.2.1
03:34:16:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
03:34:16:WU01:FS01:Connecting to 192.0.2.1:8080
03:34:37:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:34:37:WU01:FS01:Connecting to 192.0.2.1:80
03:34:59:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:38:30:WU01:FS01:Connecting to 65.254.110.245:8080
03:38:31:WU01:FS01:Assigned to work server 192.0.2.1
03:38:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
03:38:31:WU01:FS01:Connecting to 192.0.2.1:8080
03:38:52:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:38:52:WU01:FS01:Connecting to 192.0.2.1:80
03:39:13:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:45:22:WU01:FS01:Connecting to 65.254.110.245:8080
03:45:22:WU01:FS01:Assigned to work server 192.0.2.1
03:45:22:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
03:45:22:WU01:FS01:Connecting to 192.0.2.1:8080
03:45:43:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:45:43:WU01:FS01:Connecting to 192.0.2.1:80
03:46:04:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:56:27:WU01:FS01:Connecting to 65.254.110.245:8080
03:56:28:WU01:FS01:Assigned to work server 192.0.2.1
03:56:28:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
03:56:28:WU01:FS01:Connecting to 192.0.2.1:8080
03:56:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:56:49:WU01:FS01:Connecting to 192.0.2.1:80
03:57:10:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:14:24:WU01:FS01:Connecting to 65.254.110.245:8080
04:14:24:WU01:FS01:Assigned to work server 192.0.2.1
04:14:24:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
04:14:24:WU01:FS01:Connecting to 192.0.2.1:8080
04:14:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:14:45:WU01:FS01:Connecting to 192.0.2.1:80
04:15:06:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:43:26:WU01:FS01:Connecting to 65.254.110.245:8080
04:43:27:WU01:FS01:Assigned to work server 192.0.2.1
04:43:27:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
04:43:27:WU01:FS01:Connecting to 192.0.2.1:8080
04:43:48:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:43:48:WU01:FS01:Connecting to 192.0.2.1:80
04:44:09:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:59:48:WU02:FS00:0xa7:Completed 337500 out of 625000 steps (54%)
05:30:25:WU01:FS01:Connecting to 65.254.110.245:8080
05:30:26:WU01:FS01:Assigned to work server 192.0.2.1
05:30:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
05:30:26:WU01:FS01:Connecting to 192.0.2.1:8080
05:30:47:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:30:47:WU01:FS01:Connecting to 192.0.2.1:80
05:31:08:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
06:46:11:WU02:FS00:0xa7:Completed 343750 out of 625000 steps (55%)
06:46:26:WU01:FS01:Connecting to 65.254.110.245:8080
06:46:26:WU01:FS01:Assigned to work server 192.0.2.1
06:46:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
06:46:26:WU01:FS01:Connecting to 192.0.2.1:8080
06:46:47:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
06:46:47:WU01:FS01:Connecting to 192.0.2.1:80
06:47:08:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:32:27:WU02:FS00:0xa7:Completed 350000 out of 625000 steps (56%)
08:49:26:WU01:FS01:Connecting to 65.254.110.245:8080
08:49:26:WU01:FS01:Assigned to work server 192.0.2.1
08:49:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
08:49:26:WU01:FS01:Connecting to 192.0.2.1:8080
08:49:47:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:49:47:WU01:FS01:Connecting to 192.0.2.1:80
08:50:08:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:19:27:WU02:FS00:0xa7:Completed 356250 out of 625000 steps (57%)
12:05:53:WU02:FS00:0xa7:Completed 362500 out of 625000 steps (58%)
12:08:26:WU01:FS01:Connecting to 65.254.110.245:8080
12:08:26:WU01:FS01:Assigned to work server 192.0.2.1
12:08:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
12:08:26:WU01:FS01:Connecting to 192.0.2.1:8080
12:08:47:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:08:47:WU01:FS01:Connecting to 192.0.2.1:80
12:09:09:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:52:14:WU02:FS00:0xa7:Completed 368750 out of 625000 steps (59%)
15:38:32:WU02:FS00:0xa7:Completed 375000 out of 625000 steps (60%)
17:24:58:WU02:FS00:0xa7:Completed 381250 out of 625000 steps (61%)
17:30:26:WU01:FS01:Connecting to 65.254.110.245:8080
17:30:26:WU01:FS01:Assigned to work server 192.0.2.1
17:30:27:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
17:30:27:WU01:FS01:Connecting to 192.0.2.1:8080
17:30:48:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:30:48:WU01:FS01:Connecting to 192.0.2.1:80
17:31:09:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:11:33:WU02:FS00:0xa7:Completed 387500 out of 625000 steps (62%)
20:57:33:WU02:FS00:0xa7:Completed 393750 out of 625000 steps (63%)
22:43:07:WU02:FS00:0xa7:Completed 400000 out of 625000 steps (64%)
23:30:26:WU01:FS01:Connecting to 65.254.110.245:8080
23:30:27:WU01:FS01:Assigned to work server 192.0.2.1
23:30:27:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
23:30:27:WU01:FS01:Connecting to 192.0.2.1:8080
23:30:48:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:30:48:WU01:FS01:Connecting to 192.0.2.1:80
23:31:09:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:28:52:WU02:FS00:0xa7:Completed 406250 out of 625000 steps (65%)
02:16:39:WU02:FS00:0xa7:Completed 412500 out of 625000 steps (66%)
04:02:11:WU02:FS00:0xa7:Completed 418750 out of 625000 steps (67%)
******************************* Date: 2020-04-01 *******************************
05:30:26:WU01:FS01:Connecting to 65.254.110.245:8080
05:30:27:WU01:FS01:Assigned to work server 192.0.2.1
05:30:27:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
05:30:27:WU01:FS01:Connecting to 192.0.2.1:8080
05:30:48:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:30:48:WU01:FS01:Connecting to 192.0.2.1:80
05:31:09:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:47:49:WU02:FS00:0xa7:Completed 425000 out of 625000 steps (68%)
07:33:24:WU02:FS00:0xa7:Completed 431250 out of 625000 steps (69%)
09:18:56:WU02:FS00:0xa7:Completed 437500 out of 625000 steps (70%)
11:04:50:WU02:FS00:0xa7:Completed 443750 out of 625000 steps (71%)
11:30:27:WU01:FS01:Connecting to 65.254.110.245:8080
11:30:28:WU01:FS01:Assigned to work server 192.0.2.1
11:30:28:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
11:30:28:WU01:FS01:Connecting to 192.0.2.1:8080
11:30:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
11:30:49:WU01:FS01:Connecting to 192.0.2.1:80
11:31:11:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:50:27:WU02:FS00:0xa7:Completed 450000 out of 625000 steps (72%)
14:35:59:WU02:FS00:0xa7:Completed 456250 out of 625000 steps (73%)
16:21:50:WU02:FS00:0xa7:Completed 462500 out of 625000 steps (74%)
17:30:27:WU01:FS01:Connecting to 65.254.110.245:8080
17:30:28:WU01:FS01:Assigned to work server 192.0.2.1
17:30:29:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
17:30:29:WU01:FS01:Connecting to 192.0.2.1:8080
17:30:50:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:30:50:WU01:FS01:Connecting to 192.0.2.1:80
17:31:11:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:07:19:WU02:FS00:0xa7:Completed 468750 out of 625000 steps (75%)
19:53:03:WU02:FS00:0xa7:Completed 475000 out of 625000 steps (76%)
21:38:41:WU02:FS00:0xa7:Completed 481250 out of 625000 steps (77%)
23:24:14:WU02:FS00:0xa7:Completed 487500 out of 625000 steps (78%)
23:30:27:WU01:FS01:Connecting to 65.254.110.245:8080
23:30:29:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
23:30:29:WU01:FS01:Connecting to 192.0.2.1:8080
23:30:50:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:30:50:WU01:FS01:Connecting to 192.0.2.1:80
23:31:11:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:10:50:WU02:FS00:0xa7:Completed 493750 out of 625000 steps (79%)
02:57:55:WU02:FS00:0xa7:Completed 500000 out of 625000 steps (80%)
04:43:20:WU02:FS00:0xa7:Completed 506250 out of 625000 steps (81%)
******************************* Date: 2020-04-02 *******************************
05:30:30:WU01:FS01:Connecting to 65.254.110.245:8080
05:30:31:WU01:FS01:Assigned to work server 192.0.2.1
05:30:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
05:30:31:WU01:FS01:Connecting to 192.0.2.1:8080
05:30:52:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:30:52:WU01:FS01:Connecting to 192.0.2.1:80
05:31:13:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
06:28:55:WU02:FS00:0xa7:Completed 512500 out of 625000 steps (82%)
08:14:25:WU02:FS00:0xa7:Completed 518750 out of 625000 steps (83%)
09:59:59:WU02:FS00:0xa7:Completed 525000 out of 625000 steps (84%)
11:30:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
11:30:31:WU01:FS01:Connecting to 192.0.2.1:8080
11:30:52:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
11:30:52:WU01:FS01:Connecting to 192.0.2.1:80
11:31:13:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:45:27:WU02:FS00:0xa7:Completed 531250 out of 625000 steps (85%)
13:31:14:WU02:FS00:0xa7:Completed 537500 out of 625000 steps (86%)
15:16:40:WU02:FS00:0xa7:Completed 543750 out of 625000 steps (87%)
17:02:05:WU02:FS00:0xa7:Completed 550000 out of 625000 steps (88%)
17:30:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
17:30:31:WU01:FS01:Connecting to 192.0.2.1:8080
17:30:52:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:30:52:WU01:FS01:Connecting to 192.0.2.1:80
17:31:13:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:47:30:WU02:FS00:0xa7:Completed 556250 out of 625000 steps (89%)
19:23:03:Saving configuration to config.xml
19:23:03:<config>
19:23:03:  <!-- HTTP Server -->
19:23:03:  <allow v='127.0.0.1 192.168.44.0/24'/>
19:23:03:
19:23:03:  <!-- Network -->
19:23:03:  <proxy v=':8080'/>
19:23:03:
19:23:03:  <!-- Remote Command Server -->
19:23:03:  <command-allow-no-pass v='127.0.0.1 192.168.44.0/24'/>
19:23:03:
19:23:03:  <!-- Slot Control -->
19:23:03:  <power v='FULL'/>
19:23:03:
19:23:03:  <!-- User Information -->
19:23:03:  <passkey v='********************************'/>
19:23:03:  <team v='242321'/>
19:23:03:  <user v='SeanPearce44'/>
19:23:03:
19:23:03:  <!-- Folding Slots -->
19:23:03:  <slot id='0' type='CPU'/>
19:23:03:  <slot id='1' type='GPU'/>
19:23:03:</config>
19:23:32:Saving configuration to config.xml
19:23:32:<config>
19:23:32:  <!-- HTTP Server -->
19:23:32:  <allow v='127.0.0.1 192.168.44.0/24'/>
19:23:32:
19:23:32:  <!-- Network -->
19:23:32:  <proxy v=':8080'/>
19:23:32:
19:23:32:  <!-- Remote Command Server -->
19:23:32:  <command-allow-no-pass v='127.0.0.1 192.168.44.0/24'/>
19:23:32:
19:23:32:  <!-- Slot Control -->
19:23:32:  <power v='FULL'/>
19:23:32:
19:23:32:  <!-- User Information -->
19:23:32:  <passkey v='********************************'/>
19:23:32:  <team v='242321'/>
19:23:32:  <user v='SeanPearce44'/>
19:23:32:
19:23:32:  <!-- Folding Slots -->
19:23:32:  <slot id='0' type='CPU'/>
19:23:32:  <slot id='1' type='GPU'/>
19:23:32:</config>
20:32:58:WU02:FS00:0xa7:Completed 562500 out of 625000 steps (90%)
21:15:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:15:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:15:12:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
22:18:30:WU02:FS00:0xa7:Completed 568750 out of 625000 steps (91%)
23:30:28:WU01:FS01:Assigned to work server 192.0.2.1
23:30:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:M880G [Mobility Radeon HD 4200] from 192.0.2.1
23:30:31:WU01:FS01:Connecting to 192.0.2.1:8080
23:30:52:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:30:52:WU01:FS01:Connecting to 192.0.2.1:80
23:31:14:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:03:56:WU02:FS00:0xa7:Completed 575000 out of 625000 steps (92%)
01:51:23:WU02:FS00:0xa7:Completed 581250 out of 625000 steps (93%)
03:37:26:WU02:FS00:0xa7:Completed 587500 out of 625000 steps (94%)
05:11:53:WARNING:WU02:FS00:Past final deadline 2020-04-03T05:11:52Z, dumping
05:11:53:WU02:FS00:Shutting core down
05:11:53:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 2924
05:11:53:WU02:FS00:0xa7:Exiting, please wait. . .
05:11:53:WU00:FS00:Connecting to 65.254.110.245:8080
05:11:54:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:11:54:WU00:FS00:Connecting to 18.218.241.186:80
05:11:54:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:11:54:ERROR:WU00:FS00:Exception: Could not get an assignment
05:11:54:WU00:FS00:Connecting to 65.254.110.245:8080
05:11:55:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:11:55:WU00:FS00:Connecting to 18.218.241.186:80
05:11:55:WU00:FS00:Assigned to work server 13.82.98.119
05:11:55:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:1 from 13.82.98.119
05:11:55:WU00:FS00:Connecting to 13.82.98.119:8080
05:11:55:ERROR:WU00:FS00:Exception: Server did not assign work unit
05:12:09:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
05:12:53:WU02:FS00:Cleaning up
05:12:54:WU00:FS00:Connecting to 65.254.110.245:8080
05:12:55:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:12:55:WU00:FS00:Connecting to 18.218.241.186:80
rwh202
3x GTX 1080 Ti
3x GTX 1060
Various other bits and pieces
Re: WU DUMPED after 5 days :( 13871 (Run 0, Clone 663, Gen 9
Post by rwh202 »
Unfortunately that system is going to be on the slow side to complete the current projects before the deadlines.
If you want to give it a better chance and don't mind maxing out the CPU, remove the unused GPU slot and set the CPU to use both threads - it's currently reserved one for the GPU.
jonault
Post by jonault »
I agree with rwh202. That GPU doesn't have 64 bit floating point, so it's never going to get a work unit. Using both CPU cores for CPU folding will significantly reduce the time it takes to complete CPU work units, reducing the chances of this happening again.
SeanPearce44
rwh202 wrote:Unfortunately that system is going to be on the slow side to complete the current projects before the deadlines.
Many thanks - pointers on how to achieve that? Why wouldn't it use all the CPU threads anyway (even if a GPU is available)?
That machine HAS completed some WUs... If I get a biggy again - is there some way of manually dumping it early on?
Quite literally would have only been a few more hours and complete today - that's the annoyance! :(
SeanPearce44
Not being totally lazy... Making may way through https://foldingathome.org/support/faq/i ... ion-guide/
SeanPearce44
OK - I've removed the defunct GPU slot... Should I add / change CPU to make use of all CPUs threads I don't mind maxing out a few of these machines, they're ONLY folding :D
peterjammo
Re: WU DUMPED after 8 days :( 13871 (Run 0, Clone 663, Gen 9
Post by peterjammo »
I'm also folding with several 2 core machines. Using FAH Control I had to go to Configure (top left of screen), slots tab and set number of threads slot should use to 2, using edit function. If you add a second cpu it will pick up and fold 2 wu's at the same time, very slowly.
peterjammo
Oh, and I've been told that it's still productive work even with slow cpu like ours as long as you can complete inside the expiry time, although the wu will be allocated to another folder as well when the timeout is reached (nothing to say yours won't finish firt,or second one allocated won't fail so still useful even when 2 are folding same wu. Most of mine complete inside the timeout limit, and all have either completed or failed inside the expiry time. I've been told never to dump a wu once its downloaded. I'm currently 2 days into a 2.7 day one. Another similar length one died 3 days in to a 3.5 day estimate,which is frustrating.
Rel25917
Post by Rel25917 »
SeanPearce44 wrote:Why wouldn't it use all the CPU threads anyway (even if a GPU is available)?
GPU needs a core to keep it running so the default leaves a core open for the gpu.
