Add Intel i3-9100F to known cpus / GUI shows "cpu:3" only
WebCF
Post by WebCF »
Hi,
FAH shows my i3-9100F as "cpu:3". The log described it correct, WebUI and GUI shows cpu:3 without description. Has it to be whitelisted first?
Thanks in advance!
*********************** Log Started 2020-04-03T13:02:51Z ***********************
13:02:51:************************* Folding@home Client *************************
13:02:51:        Website: https://foldingathome.org/
13:02:51:      Copyright: (c) 2009-2018 foldingathome.org
13:02:51:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:02:51:           Args: --child --lifeline 946 /etc/fahclient/config.xml --run-as
13:02:51:                 fahclient --pid-file=/var/run/fahclient.pid --daemon
13:02:51:         Config: /etc/fahclient/config.xml
13:02:51:******************************** Build ********************************
13:02:51:        Version: 7.5.1
13:02:51:           Date: May 11 2018
13:02:51:           Time: 19:59:04
13:02:51:     Repository: Git
13:02:51:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
13:02:51:         Branch: master
13:02:51:       Compiler: GNU 6.3.0 20170516
13:02:51:        Options: -std=gnu++98 -O3 -funroll-loops
13:02:51:       Platform: linux2 4.14.0-3-amd64
13:02:51:           Bits: 64
13:02:51:           Mode: Release
13:02:51:******************************* System ********************************
13:02:51:            CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
13:02:51:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 11
13:02:51:           CPUs: 4
13:02:51:         Memory: 3.78GiB
13:02:51:    Free Memory: 3.42GiB
13:02:51:        Threads: POSIX_THREADS
13:02:51:     OS Version: 4.15
13:02:51:    Has Battery: false
13:02:51:     On Battery: false
13:02:51:     UTC Offset: 2
13:02:51:            PID: 949
13:02:51:            CWD: /var/lib/fahclient
13:02:51:             OS: Linux 4.15.0-91-generic x86_64
13:02:51:        OS Arch: AMD64
13:02:51:           GPUs: 1
13:02:51:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106 [GeForce RTX 2060 Super]
13:02:51:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
13:02:51:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:440.64
13:02:51:***********************************************************************
Re: Add Intel i3-9100F to known cpus / GUI shows "cpu:3" onl
Post by Neil-B »
CPU:3 means the CPU folding slot has three cores assigned - the fourth will have been reserved for servicing your GPU
WebCF
Post by WebCF »
Ahh! Thanks!
Welcome to Folding@Home
Almost all x86 CPUs since 2002 are supported, the minimum requirement is SSE2, although F@H will take advantage of AVX_256 if available.
