Unable to receive bonus points
Turaiel
Post by Turaiel »
Hello,
Over the last few weeks I have completed a total of 274 work units under the name Turaiel, but I've only received a bit over 2 million points. I think that for some reason I am not receiving bonus points at all. I do have a couple previous identities that use the same name but different passkeys, at least one of which has been lost to time. Any idea if that could be the problem?
Log:
*********************** Log Started 2020-04-01T12:08:13Z ***********************
12:08:13:************************* Folding@home Client *************************
12:08:13:        Website: https://foldingathome.org/
12:08:13:      Copyright: (c) 2009-2018 foldingathome.org
12:08:13:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:08:13:           Args:
12:08:13:         Config: C:\Users\brand\AppData\Roaming\FAHClient\config.xml
12:08:13:******************************** Build ********************************
12:08:13:        Version: 7.5.1
12:08:13:           Date: May 11 2018
12:08:13:           Time: 13:06:32
12:08:13:     Repository: Git
12:08:13:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:08:13:         Branch: master
12:08:13:       Compiler: Visual C++ 2008
12:08:13:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:08:13:       Platform: win32 10
12:08:13:           Bits: 32
12:08:13:           Mode: Release
12:08:13:******************************* System ********************************
12:08:13:            CPU: AMD Ryzen 7 3700X 8-Core Processor
12:08:13:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
12:08:13:           CPUs: 16
12:08:13:         Memory: 31.95GiB
12:08:13:    Free Memory: 27.78GiB
12:08:13:        Threads: WINDOWS_THREADS
12:08:13:     OS Version: 6.2
12:08:13:    Has Battery: false
12:08:13:     On Battery: false
12:08:13:     UTC Offset: -4
12:08:13:            PID: 17176
12:08:13:            CWD: C:\Users\brand\AppData\Roaming\FAHClient
12:08:13:             OS: Windows 10 Enterprise
12:08:13:        OS Arch: AMD64
12:08:13:           GPUs: 1
12:08:13:          GPU 0: Bus:45 Slot:0 Func:0 NVIDIA:8 TU104 [GeForce RTX 2070 Super]
12:08:13:                 8218
12:08:13:  CUDA Device 0: Platform:0 Device:0 Bus:45 Slot:0 Compute:7.5 Driver:11.0
12:08:13:OpenCL Device 0: Platform:0 Device:0 Bus:45 Slot:0 Compute:1.2 Driver:445.75
12:08:13:  Win32 Service: false
12:08:13:***********************************************************************
12:08:13:<config>
12:08:13:  <!-- User Information -->
12:08:13:  <passkey v='********************************'/>
12:08:13:  <team v='236749'/>
12:08:13:  <user v='Turaiel'/>
12:08:13:
12:08:13:  <!-- Folding Slots -->
12:08:13:  <slot id='0' type='CPU'/>
12:08:13:  <slot id='1' type='GPU'/>
12:08:13:</config>
12:08:13:Trying to access database...
12:08:13:Successfully acquired database lock
12:08:13:Enabled folding slot 00: READY cpu:14
12:08:13:Enabled folding slot 01: READY gpu:0:TU104 [GeForce RTX 2070 Super] 8218
12:08:13:WU00:FS00:Connecting to 65.254.110.245:8080
12:08:13:WU01:FS01:Connecting to 65.254.110.245:8080
12:08:14:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:08:14:WU00:FS00:Connecting to 18.218.241.186:80
12:08:14:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:08:14:WU01:FS01:Connecting to 18.218.241.186:80
12:08:14:WU00:FS00:Assigned to work server 13.90.152.57
12:08:14:WU00:FS00:Requesting new work unit for slot 00: READY cpu:14 from 13.90.152.57
12:08:14:WU00:FS00:Connecting to 13.90.152.57:8080
12:08:14:WU01:FS01:Assigned to work server 13.90.152.57
12:08:14:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104 [GeForce RTX 2070 Super] 8218 from 13.90.152.57
12:08:14:WU01:FS01:Connecting to 13.90.152.57:8080
12:08:27:WU00:FS00:Downloading 4.50MiB
12:08:28:WU01:FS01:Downloading 86.23MiB
12:08:28:WU00:FS00:Download complete
12:08:28:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13860 run:0 clone:17448 gen:21 core:0xa7 unit:0x000000180d5a98395e730fe070ae91dc
12:08:28:WU00:FS00:Starting
12:08:28:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\brand\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 17176 -checkpoint 15 -np 14
12:08:28:WU00:FS00:Started FahCore on PID 16296
12:08:28:WU00:FS00:Core PID:15980
12:08:28:WU00:FS00:FahCore 0xa7 started
12:08:29:WU00:FS00:0xa7:*********************** Log Started 2020-04-01T12:08:28Z ***********************
12:08:29:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:08:29:WU00:FS00:0xa7:       Type: 0xa7
12:08:29:WU00:FS00:0xa7:       Core: Gromacs
12:08:29:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 16296 -checkpoint 15 -np
12:08:29:WU00:FS00:0xa7:             14
12:08:29:WU00:FS00:0xa7:************************************ CBang *************************************
12:08:29:WU00:FS00:0xa7:       Date: Oct 26 2019
12:08:29:WU00:FS00:0xa7:       Time: 01:38:25
12:08:29:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
12:08:29:WU00:FS00:0xa7:     Branch: master
12:08:29:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:08:29:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:08:29:WU00:FS00:0xa7:   Platform: win32 10
12:08:29:WU00:FS00:0xa7:       Bits: 64
12:08:29:WU00:FS00:0xa7:       Mode: Release
12:08:29:WU00:FS00:0xa7:************************************ System ************************************
12:08:29:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 3700X 8-Core Processor
12:08:29:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
12:08:29:WU00:FS00:0xa7:       CPUs: 16
12:08:29:WU00:FS00:0xa7:     Memory: 31.95GiB
12:08:29:WU00:FS00:0xa7:Free Memory: 25.92GiB
12:08:29:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
12:08:29:WU00:FS00:0xa7: OS Version: 6.2
12:08:29:WU00:FS00:0xa7:Has Battery: false
12:08:29:WU00:FS00:0xa7: On Battery: false
12:08:29:WU00:FS00:0xa7: UTC Offset: -4
12:08:29:WU00:FS00:0xa7:        PID: 15980
12:08:29:WU00:FS00:0xa7:        CWD: C:\Users\brand\AppData\Roaming\FAHClient\work
12:08:29:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
12:08:29:WU00:FS00:0xa7:    Version: 0.0.18
12:08:29:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:08:29:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:08:29:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
12:08:29:WU00:FS00:0xa7:       Time: 01:52:30
12:08:29:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
12:08:29:WU00:FS00:0xa7:************************************ Build *************************************
12:08:29:WU00:FS00:0xa7:       SIMD: avx_256
12:08:29:WU00:FS00:0xa7:********************************************************************************
12:08:29:WU00:FS00:0xa7:Project: 13860 (Run 0, Clone 17448, Gen 21)
12:08:29:WU00:FS00:0xa7:Unit: 0x000000180d5a98395e730fe070ae91dc
12:08:29:WU00:FS00:0xa7:Reading tar file core.xml
12:08:29:WU00:FS00:0xa7:Reading tar file frame21.tpr
12:08:29:WU00:FS00:0xa7:Digital signatures verified
12:08:29:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
12:08:29:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
12:08:29:WU00:FS00:0xa7:Calling: mdrun -s frame21.tpr -o frame21.trr -x frame21.xtc -e frame21.edr -cpt 15 -nt 12
12:08:29:WU00:FS00:0xa7:Steps: first=2625000 total=125000
12:08:30:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
12:08:34:WU01:FS01:Download 32.47%
12:08:40:WU01:FS01:Download 57.69%
12:08:46:WU01:FS01:Download 93.64%
12:08:47:WU01:FS01:Download complete
12:08:47:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11781 run:0 clone:5014 gen:11 core:0x22 unit:0x000000170d5a98395e758914ed25a68f
12:08:47:WU01:FS01:Starting
12:08:47:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\brand\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 17176 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:08:47:WU01:FS01:Started FahCore on PID 13980
12:08:48:WU01:FS01:Core PID:11400
12:08:48:WU01:FS01:FahCore 0x22 started
[truncated...]
Edit: Sorry to the admins for having two posts in the approval queue; I didn't notice it was moderated until I retried
Re: Unable to receive bonus points
The first 10 WUs you return with a passkey will just get the base point, no bonus. However the client has no means of checking whether the username and passkey have or have not completed 10 WUs already, it displays an estimate as if qualified for the bonus if a passkey is ended into the client. That may account for some of the discrepancy.
The F@h team is also looking into reports that one of the servers is not recording bonus points when it should. If this turns out to be the case, those point would be awarded at some point in the future after running a re-credit script to pick up the missing points.
Turaiel
Post by Turaiel »
Hi Joe_H,
As I noted, I've completed over 270 work units with my username + passkey and apparently have not been receiving a bonus, seemingly at all given the number of points I've gained. Is it possible that it's related to the fact that my username's original passkey (from many years ago) did not have more than 10 units associated?
Thanks.
The check for bonus status shows that user Turaiel has completed 81 WU's with a passkey, only one shows up o the check. The check for the most recent WUs on your different folding slots shows two returning WUs which got bonus, and two which did not. That could be from the reason I gave in the second paragraph or for the passkey not being entered into the client.
You can make the same checks at apps.foldingathome.org.
Rel25917
Post by Rel25917 »
Check your username and passkey combos here. https://apps.foldingathome.org/bonus
The original combo should not be relevant. Just the current combo.
Turaiel
Post by Turaiel »
Thanks for the information. It looks like the stats now show 94 completed WUs (same info shows for both passkeys), so I suppose maybe the problem is fixed? Yesterday I changed both clients to my old passkey and then changed them back today. I will watch to see if the count continues to increase today and if not, I will change back to the old passkey.
On the old passkey before yesterday I had only completed 76 work units. This suggests to me that it may only be counting the bonus for my prior passkey.
I will update this thread tonight.
Turaiel
Post by Turaiel »
(Late) Update: looks like I started getting bonus and then stopped again. I discovered that the clients reverted to the wrong passkey. I've reset the passkey and restarted both clients and now the bonus appears to be working properly.
Thanks again for the assistance.
Forfi100886
Post by Forfi100886 »
Only after reading this forum thread I realized, that you need to complete a certain amount of WUs to qualify for the bonus.
Would be nice to state that somewhere, I thought something was broken ;)
Post by Neil-B »
