Adding RX 560X To The GPUs.txt File
Jagor121
Post by Jagor121 »
Name - Radeon RX 560X
Device ID - 1002 67EF - 1043 17C1
*********************** Log Started 2020-04-03T10:40:36Z ***********************
10:40:36:************************* Folding@home Client *************************
10:40:36:        Website: https://foldingathome.org/
10:40:36:      Copyright: (c) 2009-2018 foldingathome.org
10:40:36:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:40:36:           Args: --open-web-control
10:40:36:         Config: <none>
10:40:36:******************************** Build ********************************
10:40:36:        Version: 7.5.1
10:40:36:           Date: May 11 2018
10:40:36:           Time: 13:06:32
10:40:36:     Repository: Git
10:40:36:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
10:40:36:         Branch: master
10:40:36:       Compiler: Visual C++ 2008
10:40:36:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:40:36:       Platform: win32 10
10:40:36:           Bits: 32
10:40:36:           Mode: Release
10:40:36:******************************* System ********************************
10:40:36:            CPU: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
10:40:36:         CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
10:40:36:           CPUs: 8
10:40:36:         Memory: 7.81GiB
10:40:36:    Free Memory: 4.49GiB
10:40:36:        Threads: WINDOWS_THREADS
10:40:36:     OS Version: 6.2
10:40:36:    Has Battery: true
10:40:36:     On Battery: true
10:40:36:     UTC Offset: 2
10:40:36:            PID: 6616
10:40:36:            CWD: C:\Users\Jagor\AppData\Roaming\FAHClient
10:40:36:             OS: Windows 10 Home
10:40:36:        OS Arch: AMD64
10:40:36:           GPUs: 0
10:40:36:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
10:40:36:                 specified module could not be found.
10:40:36:
10:40:36:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
10:40:36:OpenCL Device 1: Platform:0 Device:1 Bus:5 Slot:0 Compute:1.2 Driver:3004.8
10:40:36:  Win32 Service: false
10:40:36:***********************************************************************
10:40:36:<config>
10:40:36:  <!-- Folding Slots -->
10:40:36:</config>
10:40:36:Connecting to assign1.foldingathome.org:8080
10:40:37:Updated GPUs.txt
10:40:37:Read GPUs.txt
10:40:37:Trying to access database...
10:40:37:Successfully acquired database lock
10:40:37:Enabled folding slot 00: PAUSED cpu:2 (not configured)
10:40:37:Enabled folding slot 01: PAUSED gpu:0:Radeon RX Vega 10 Mobile (not configured)
10:40:37:Enabled folding slot 02: PAUSED gpu:1:Baffin XT [Radeon RX 460] (not configured)
10:40:41:10:127.0.0.1:New Web connection
10:40:56:Set client configured
10:41:38:Saving configuration to config.xml
10:41:38:<config>
10:41:38:  <!-- User Information -->
10:41:38:  <team v='69'/>
10:41:38:  <user v='Jagor121'/>
10:41:38:
10:41:38:  <!-- Folding Slots -->
10:41:38:  <slot id='0' type='CPU'/>
10:41:38:  <slot id='1' type='GPU'/>
10:41:38:  <slot id='2' type='GPU'/>
10:41:38:</config>
10:42:06:Saving configuration to config.xml
10:42:06:<config>
10:42:06:  <!-- Network -->
10:42:06:  <proxy v=':8080'/>
10:42:06:
10:42:06:  <!-- Slot Control -->
10:42:06:  <pause-on-battery v='false'/>
10:42:06:
10:42:06:  <!-- User Information -->
10:42:06:  <team v='69'/>
10:42:06:  <user v='Jagor121'/>
10:42:06:
10:42:06:  <!-- Folding Slots -->
10:42:06:  <slot id='0' type='CPU'/>
10:42:06:  <slot id='1' type='GPU'/>
10:42:06:  <slot id='2' type='GPU'/>
10:42:06:</config>
10:42:08:WU00:FS00:Connecting to 65.254.110.245:8080
10:42:09:WU01:FS01:Connecting to 65.254.110.245:8080
10:42:09:WU02:FS02:Connecting to 65.254.110.245:8080
10:42:09:WU00:FS00:Connecting to 65.254.110.245:8080
10:42:10:WU02:FS02:Connecting to 65.254.110.245:8080
10:42:10:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:42:10:WU00:FS00:Connecting to 18.218.241.186:80
10:42:10:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:42:10:WU01:FS01:Connecting to 18.218.241.186:80
10:42:11:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:42:11:WU02:FS02:Connecting to 18.218.241.186:80
10:42:11:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:42:11:ERROR:WU00:FS00:Exception: Could not get an assignment
10:42:11:WU00:FS00:Connecting to 65.254.110.245:8080
10:42:11:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:42:11:ERROR:WU01:FS01:Exception: Could not get an assignment
10:42:11:WU01:FS01:Connecting to 65.254.110.245:8080
10:42:11:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:42:11:ERROR:WU02:FS02:Exception: Could not get an assignment
10:42:11:WU02:FS02:Connecting to 65.254.110.245:8080
10:42:12:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:42:12:WU00:FS00:Connecting to 18.218.241.186:80
10:42:12:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:42:12:WU01:FS01:Connecting to 18.218.241.186:80
10:42:12:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:42:12:WU02:FS02:Connecting to 18.218.241.186:80
10:42:12:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:42:12:ERROR:WU00:FS00:Exception: Could not get an assignment
10:42:12:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:42:12:ERROR:WU01:FS01:Exception: Could not get an assignment
10:42:13:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:42:13:ERROR:WU02:FS02:Exception: Could not get an assignment
10:42:39:Saving configuration to config.xml
10:42:39:<config>
10:42:39:  <!-- Network -->
10:42:39:  <proxy v=':8080'/>
10:42:39:
10:42:39:  <!-- Slot Control -->
10:42:39:  <pause-on-battery v='false'/>
10:42:39:  <power v='medium'/>
10:42:39:
10:42:39:  <!-- User Information -->
10:42:39:  <team v='69'/>
10:42:39:  <user v='Jagor121'/>
10:42:39:
10:42:39:  <!-- Folding Slots -->
10:42:39:  <slot id='0' type='CPU'/>
10:42:39:  <slot id='1' type='GPU'/>
10:42:39:  <slot id='2' type='GPU'/>
10:42:39:</config>
10:43:11:WU00:FS00:Connecting to 65.254.110.245:8080
10:43:12:WU01:FS01:Connecting to 65.254.110.245:8080
10:43:12:WU02:FS02:Connecting to 65.254.110.245:8080
10:43:12:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:43:12:WU00:FS00:Connecting to 18.218.241.186:80
10:43:12:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:43:12:WU01:FS01:Connecting to 18.218.241.186:80
10:43:13:WU02:FS02:Assigned to work server 128.252.203.10
10:43:13:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Baffin XT [Radeon RX 460] from 128.252.203.10
10:43:13:WU02:FS02:Connecting to 128.252.203.10:8080
10:43:13:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:43:13:ERROR:WU00:FS00:Exception: Could not get an assignment
10:43:13:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:43:13:ERROR:WU01:FS01:Exception: Could not get an assignment
10:43:37:ERROR:WU02:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
10:43:48:FS00:Paused
10:43:48:FS01:Paused
10:43:48:FS02:Paused
10:43:52:FS00:Unpaused
10:43:52:FS01:Unpaused
10:43:52:FS02:Unpaused
10:44:11:WU00:FS00:Connecting to 65.254.110.245:8080
10:44:12:WU01:FS01:Connecting to 65.254.110.245:8080
10:44:12:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:44:12:WU00:FS00:Connecting to 18.218.241.186:80
10:44:12:WU02:FS02:Connecting to 65.254.110.245:8080
10:44:12:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:44:12:WU01:FS01:Connecting to 18.218.241.186:80
10:44:12:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:44:12:WU02:FS02:Connecting to 18.218.241.186:80
10:44:12:WU00:FS00:Assigned to work server 168.245.198.125
10:44:12:WU00:FS00:Requesting new work unit for slot 00: READY cpu:5 from 168.245.198.125
10:44:12:WU00:FS00:Connecting to 168.245.198.125:8080
10:44:13:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:44:13:ERROR:WU01:FS01:Exception: Could not get an assignment
10:44:13:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:44:13:ERROR:WU02:FS02:Exception: Could not get an assignment
10:44:13:ERROR:WU00:FS00:Exception: Server did not assign work unit
10:45:49:WU00:FS00:Connecting to 65.254.110.245:8080
10:45:49:WU01:FS01:Connecting to 65.254.110.245:8080
10:45:49:WU02:FS02:Connecting to 65.254.110.245:8080
10:45:51:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:45:51:WU00:FS00:Connecting to 18.218.241.186:80
10:45:51:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:45:51:WU01:FS01:Connecting to 18.218.241.186:80
10:45:51:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:45:51:WU02:FS02:Connecting to 18.218.241.186:80
10:45:52:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:45:52:ERROR:WU02:FS02:Exception: Could not get an assignment
10:45:52:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:45:52:ERROR:WU01:FS01:Exception: Could not get an assignment
10:45:53:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:45:53:ERROR:WU00:FS00:Exception: Could not get an assignment
10:48:26:WU00:FS00:Connecting to 65.254.110.245:8080
10:48:26:WU01:FS01:Connecting to 65.254.110.245:8080
10:48:26:WU02:FS02:Connecting to 65.254.110.245:8080
10:48:27:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:48:27:WU00:FS00:Connecting to 18.218.241.186:80
10:48:28:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:48:28:WU01:FS01:Connecting to 18.218.241.186:80
10:48:29:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:48:29:WU02:FS02:Connecting to 18.218.241.186:80
10:48:29:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:48:29:ERROR:WU00:FS00:Exception: Could not get an assignment
10:48:29:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:48:29:ERROR:WU01:FS01:Exception: Could not get an assignment
10:48:30:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:48:30:ERROR:WU02:FS02:Exception: Could not get an assignment
10:50:29:Saving configuration to config.xml
10:50:29:<config>
10:50:29:  <!-- Network -->
10:50:29:  <proxy v=':8080'/>
10:50:29:
10:50:29:  <!-- Slot Control -->
10:50:29:  <power v='medium'/>
10:50:29:
10:50:29:  <!-- User Information -->
10:50:29:  <team v='69'/>
10:50:29:  <user v='Jagor121'/>
10:50:29:
10:50:29:  <!-- Folding Slots -->
10:50:29:  <slot id='0' type='CPU'/>
10:50:29:  <slot id='1' type='GPU'/>
10:50:29:  <slot id='2' type='GPU'/>
10:50:29:</config>
10:50:47:Saving configuration to config.xml
10:50:47:<config>
10:50:47:  <!-- Network -->
10:50:47:  <proxy v=':8080'/>
10:50:47:
10:50:47:  <!-- Slot Control -->
10:50:47:  <power v='medium'/>
10:50:47:
10:50:47:  <!-- User Information -->
10:50:47:  <team v='69'/>
10:50:47:  <user v='Jagor121'/>
10:50:47:
10:50:47:  <!-- Folding Slots -->
10:50:47:  <slot id='0' type='CPU'/>
10:50:47:  <slot id='1' type='GPU'/>
10:50:47:  <slot id='2' type='GPU'/>
10:50:47:</config>
10:52:40:WU00:FS00:Connecting to 65.254.110.245:8080
10:52:40:WU01:FS01:Connecting to 65.254.110.245:8080
10:52:41:WU02:FS02:Connecting to 65.254.110.245:8080
10:52:41:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:52:41:WU00:FS00:Connecting to 18.218.241.186:80
10:52:41:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:52:41:WU01:FS01:Connecting to 18.218.241.186:80
10:52:41:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:52:41:WU02:FS02:Connecting to 18.218.241.186:80
10:52:41:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:52:41:ERROR:WU00:FS00:Exception: Could not get an assignment
10:52:42:WU01:FS01:Assigned to work server 128.252.203.10
10:52:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Radeon RX Vega 10 Mobile from 128.252.203.10
10:52:42:WU02:FS02:Assigned to work server 128.252.203.10
10:52:42:WU01:FS01:Connecting to 128.252.203.10:8080
10:52:42:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Baffin XT [Radeon RX 460] from 128.252.203.10
10:52:42:WU02:FS02:Connecting to 128.252.203.10:8080
10:52:54:Saving configuration to config.xml
10:52:54:<config>
10:52:54:  <!-- Network -->
10:52:54:  <proxy v=':8080'/>
10:52:54:
10:52:54:  <!-- Slot Control -->
10:52:54:  <pause-on-battery v='false'/>
10:52:54:  <power v='medium'/>
10:52:54:
10:52:54:  <!-- User Information -->
10:52:54:  <team v='69'/>
10:52:54:  <user v='Jagor121'/>
10:52:54:
10:52:54:  <!-- Folding Slots -->
10:52:54:  <slot id='0' type='CPU'/>
10:52:54:  <slot id='1' type='GPU'/>
10:52:54:  <slot id='2' type='GPU'/>
10:52:54:</config>
10:53:03:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
10:53:03:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
10:53:03:WU01:FS01:Connecting to 128.252.203.10:80
10:53:03:WU02:FS02:Connecting to 128.252.203.10:80
10:53:24:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:53:24:ERROR:WU02:FS02:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:53:40:WU00:FS00:Connecting to 65.254.110.245:8080
10:53:40:WU01:FS01:Connecting to 65.254.110.245:8080
10:53:41:WU02:FS02:Connecting to 65.254.110.245:8080
10:53:41:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:53:41:WU00:FS00:Connecting to 18.218.241.186:80
10:53:42:WU01:FS01:Assigned to work server 13.90.152.57
10:53:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Radeon RX Vega 10 Mobile from 13.90.152.57
10:53:42:WU01:FS01:Connecting to 13.90.152.57:8080
10:53:42:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:53:42:WU02:FS02:Connecting to 18.218.241.186:80
10:53:43:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:53:43:ERROR:WU00:FS00:Exception: Could not get an assignment
10:53:44:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:53:44:ERROR:WU02:FS02:Exception: Could not get an assignment
10:53:50:Saving configuration to config.xml
10:53:50:<config>
10:53:50:  <!-- Network -->
10:53:50:  <proxy v=':8080'/>
10:53:50:
10:53:50:  <!-- Slot Control -->
10:53:50:  <pause-on-battery v='false'/>
10:53:50:  <power v='medium'/>
10:53:50:
10:53:50:  <!-- User Information -->
10:53:50:  <team v='69'/>
10:53:50:  <user v='Jagor121'/>
10:53:50:
10:53:50:  <!-- Folding Slots -->
10:53:50:  <slot id='0' type='CPU'/>
10:53:50:  <slot id='1' type='GPU'/>
10:53:50:  <slot id='2' type='GPU'/>
10:53:50:</config>
10:54:03:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
10:54:03:WU01:FS01:Connecting to 13.90.152.57:80
10:54:23:WU01:FS01:Downloading 51.20MiB
10:54:29:WU01:FS01:Download 9.40%
10:54:35:WU01:FS01:Download 23.44%
10:54:41:WU01:FS01:Download 38.33%
10:54:47:WU01:FS01:Download 56.16%
10:54:53:WU01:FS01:Download 72.15%
10:54:59:WU01:FS01:Download 89.12%
10:55:02:WU01:FS01:Download complete
10:55:02:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11780 run:0 clone:1254 gen:40 core:0x22 unit:0x000000370d5a98395e73c57f595bea57
10:55:02:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
10:55:02:WU01:FS01:Connecting to cores.foldingathome.org:80
10:55:03:WU01:FS01:FahCore 22: Downloading 4.04MiB
10:55:05:WU01:FS01:FahCore 22: Download complete
10:55:05:WU01:FS01:Valid core signature
10:55:05:WU01:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
10:55:06:WU01:FS01:Starting
10:55:06:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jagor\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 6616 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
10:55:06:WU01:FS01:Started FahCore on PID 2556
10:55:06:WU01:FS01:Core PID:6036
10:55:06:WU01:FS01:FahCore 0x22 started
10:55:07:WU01:FS01:0x22:*********************** Log Started 2020-04-03T10:55:06Z ***********************
10:55:07:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
10:55:07:WU01:FS01:0x22:       Type: 0x22
10:55:07:WU01:FS01:0x22:       Core: Core22
10:55:07:WU01:FS01:0x22:    Website: https://foldingathome.org/
10:55:07:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
10:55:07:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
10:55:07:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
10:55:07:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 2556 -checkpoint 15
10:55:07:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
10:55:07:WU01:FS01:0x22:     Config: <none>
10:55:07:WU01:FS01:0x22:************************************ Build *************************************
10:55:07:WU01:FS01:0x22:    Version: 0.0.2
10:55:07:WU01:FS01:0x22:       Date: Dec 6 2019
10:55:07:WU01:FS01:0x22:       Time: 21:30:31
10:55:07:WU01:FS01:0x22: Repository: Git
10:55:07:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
10:55:07:WU01:FS01:0x22:     Branch: HEAD
10:55:07:WU01:FS01:0x22:   Compiler: Visual C++ 2008
10:55:07:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:55:07:WU01:FS01:0x22:   Platform: win32 10
10:55:07:WU01:FS01:0x22:       Bits: 64
10:55:07:WU01:FS01:0x22:       Mode: Release
10:55:07:WU01:FS01:0x22:************************************ System ************************************
10:55:07:WU01:FS01:0x22:        CPU: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
10:55:07:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
10:55:07:WU01:FS01:0x22:       CPUs: 8
10:55:07:WU01:FS01:0x22:     Memory: 7.81GiB
10:55:07:WU01:FS01:0x22:Free Memory: 4.31GiB
10:55:07:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
10:55:07:WU01:FS01:0x22: OS Version: 6.2
10:55:07:WU01:FS01:0x22:Has Battery: true
10:55:07:WU01:FS01:0x22: On Battery: true
10:55:07:WU01:FS01:0x22: UTC Offset: 2
10:55:07:WU01:FS01:0x22:        PID: 6036
10:55:07:WU01:FS01:0x22:        CWD: C:\Users\Jagor\AppData\Roaming\FAHClient\work
10:55:07:WU01:FS01:0x22:         OS: Windows 10 Home
10:55:07:WU01:FS01:0x22:    OS Arch: AMD64
10:55:07:WU01:FS01:0x22:********************************************************************************
10:55:07:WU01:FS01:0x22:Project: 11780 (Run 0, Clone 1254, Gen 40)
10:55:07:WU01:FS01:0x22:Unit: 0x000000370d5a98395e73c57f595bea57
10:55:07:WU01:FS01:0x22:Reading tar file core.xml
10:55:07:WU01:FS01:0x22:Reading tar file integrator.xml
10:55:07:WU01:FS01:0x22:Reading tar file state.xml
10:55:08:WU01:FS01:0x22:Reading tar file system.xml
10:55:09:WU01:FS01:0x22:Digital signatures verified
10:55:09:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
10:55:09:WU01:FS01:0x22:Version 0.0.2
10:55:17:WU00:FS00:Connecting to 65.254.110.245:8080
10:55:18:WU02:FS02:Connecting to 65.254.110.245:8080
10:55:19:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:55:19:WU00:FS00:Connecting to 18.218.241.186:80
10:55:19:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:55:19:WU02:FS02:Connecting to 18.218.241.186:80
10:55:21:WU02:FS02:Assigned to work server 40.114.52.201
10:55:21:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Baffin XT [Radeon RX 460] from 40.114.52.201
10:55:21:WU00:FS00:Assigned to work server 40.114.52.201
10:55:21:WU02:FS02:Connecting to 40.114.52.201:8080
10:55:21:WU00:FS00:Requesting new work unit for slot 00: READY cpu:5 from 40.114.52.201
10:55:21:WU00:FS00:Connecting to 40.114.52.201:8080
10:55:42:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
10:55:42:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:55:42:WU02:FS02:Connecting to 40.114.52.201:80
10:55:42:WU00:FS00:Connecting to 40.114.52.201:80
10:55:45:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
10:55:45:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
10:56:03:ERROR:WU02:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
10:56:15:WU00:FS00:Downloading 2.14MiB
10:56:19:WU00:FS00:Download complete
10:56:19:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13850 run:0 clone:2258 gen:17 core:0xa7 unit:0x00000019287234c95e7259320cf8bb5f
10:56:19:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
10:56:19:WU00:FS00:Connecting to cores.foldingathome.org:80
10:56:19:WU00:FS00:FahCore a7: Downloading 6.71MiB
10:56:23:WU00:FS00:FahCore a7: Download complete
10:56:23:WU00:FS00:Valid core signature
10:56:23:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
10:56:23:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
10:56:23:WU00:FS00:Starting
10:56:23:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jagor\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 6616 -checkpoint 15 -np 5
10:56:23:WU00:FS00:Started FahCore on PID 8476
10:56:23:WU00:FS00:Core PID:1016
10:56:23:WU00:FS00:FahCore 0xa7 started
10:56:24:WU00:FS00:0xa7:*********************** Log Started 2020-04-03T10:56:23Z ***********************
10:56:24:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:56:24:WU00:FS00:0xa7:       Type: 0xa7
10:56:24:WU00:FS00:0xa7:       Core: Gromacs
10:56:24:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 8476 -checkpoint 15 -np 5
10:56:24:WU00:FS00:0xa7:************************************ CBang *************************************
10:56:24:WU00:FS00:0xa7:       Date: Oct 26 2019
10:56:24:WU00:FS00:0xa7:       Time: 01:38:25
10:56:24:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:56:24:WU00:FS00:0xa7:     Branch: master
10:56:24:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:56:24:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:56:24:WU00:FS00:0xa7:   Platform: win32 10
10:56:24:WU00:FS00:0xa7:       Bits: 64
10:56:24:WU00:FS00:0xa7:       Mode: Release
10:56:24:WU00:FS00:0xa7:************************************ System ************************************
10:56:24:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
10:56:24:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
10:56:24:WU00:FS00:0xa7:       CPUs: 8
10:56:24:WU00:FS00:0xa7:     Memory: 7.81GiB
10:56:24:WU00:FS00:0xa7:Free Memory: 3.72GiB
10:56:24:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:56:24:WU00:FS00:0xa7: OS Version: 6.2
10:56:24:WU00:FS00:0xa7:Has Battery: true
10:56:24:WU00:FS00:0xa7: On Battery: true
10:56:24:WU00:FS00:0xa7: UTC Offset: 2
10:56:24:WU00:FS00:0xa7:        PID: 1016
10:56:24:WU00:FS00:0xa7:        CWD: C:\Users\Jagor\AppData\Roaming\FAHClient\work
10:56:24:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:56:24:WU00:FS00:0xa7:    Version: 0.0.18
10:56:24:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:56:24:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:56:24:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:56:24:WU00:FS00:0xa7:       Time: 01:52:30
10:56:24:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:56:24:WU00:FS00:0xa7:************************************ Build *************************************
10:56:24:WU00:FS00:0xa7:       SIMD: avx_256
10:56:24:WU00:FS00:0xa7:********************************************************************************
10:56:24:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 2258, Gen 17)
10:56:24:WU00:FS00:0xa7:Unit: 0x00000019287234c95e7259320cf8bb5f
10:56:24:WU00:FS00:0xa7:Reading tar file core.xml
10:56:24:WU00:FS00:0xa7:Reading tar file frame17.tpr
10:56:24:WU00:FS00:0xa7:Digital signatures verified
10:56:24:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
10:56:24:WU00:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -x frame17.xtc -e frame17.edr -cpt 15 -nt 4
10:56:24:WU00:FS00:0xa7:Steps: first=8500000 total=500000
10:56:26:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
10:57:55:WU02:FS02:Connecting to 65.254.110.245:8080
10:57:57:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:57:57:WU02:FS02:Connecting to 18.218.241.186:80
10:57:57:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:57:57:ERROR:WU02:FS02:Exception: Could not get an assignment
11:02:09:WU02:FS02:Connecting to 65.254.110.245:8080
11:02:11:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:02:11:WU02:FS02:Connecting to 18.218.241.186:80
11:02:12:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:02:12:ERROR:WU02:FS02:Exception: Could not get an assignment
11:03:56:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
11:09:01:WU02:FS02:Connecting to 65.254.110.245:8080
11:09:01:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:09:01:WU02:FS02:Connecting to 18.218.241.186:80
11:09:02:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:09:02:ERROR:WU02:FS02:Exception: Could not get an assignment
11:09:29:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
11:11:22:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
Re: Adding RX 560X To The GPUs.txt File
Device already in whitelist:
0x1002:0x67ef:1:5:Baffin XT [Radeon RX 460]
The description field is merely cosmetic, will not keep the card from being used as it is essentially identical to the 460.
