FS02:WorkServer connection failed on port 8080 trying 80
gaetano.lazzo
Post by gaetano.lazzo »
I have a windows machine, running under a firewall. I'm stuck. I don't use any gateway.
07:44:35:FS00:Paused
07:44:35:FS01:Paused
07:44:35:FS02:Paused
07:44:37:FS00:Unpaused
07:44:37:FS01:Unpaused
07:44:37:FS02:Unpaused
07:44:37:WU02:FS02:Connecting to 65.254.110.245:8080
07:44:37:WU02:FS02:Assigned to work server 192.0.2.1
07:44:37:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
07:44:37:WU02:FS02:Connecting to 192.0.2.1:8080
07:44:58:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
07:44:58:WU02:FS02:Connecting to 192.0.2.1:80
07:45:13:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
07:46:14:WU02:FS02:Connecting to 65.254.110.245:8080
07:46:14:WU02:FS02:Assigned to work server 192.0.2.1
07:46:14:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
07:46:14:WU02:FS02:Connecting to 192.0.2.1:8080
07:46:35:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
07:46:35:WU02:FS02:Connecting to 192.0.2.1:80
07:46:50:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
Tohya
Re: FS02:WorkServer connection failed on port 8080 trying 80
Post by Tohya »
192.0.2.1 would typically be a router and not one of F@H work servers.
You will to need to look into why F@H is talking to your router rather than the servers. It could be a firewall on the router or something on your computer rerouting traffic.
Post by Neil-B »
192.0.2.1 is also where GPUs get sent if they aren't configured correctly or aren't up to running FAH iirc … can you post the top 200 lines or so of your log as this will help rule that out.
gaetano.lazzo
Thanks for the reply,
this is the complete log I currently see
*********************** Log Started 2020-04-03T11:38:40Z ***********************
11:38:40:************************* Folding@home Client *************************
11:38:40:        Website: https://foldingathome.org/
11:38:40:      Copyright: (c) 2009-2018 foldingathome.org
11:38:40:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:38:40:           Args: --open-web-control
11:38:40:         Config: C:\Users\Nino\AppData\Roaming\FAHClient\config.xml
11:38:40:******************************** Build ********************************
11:38:40:        Version: 7.5.1
11:38:40:           Date: May 11 2018
11:38:40:           Time: 13:06:32
11:38:40:     Repository: Git
11:38:40:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
11:38:40:         Branch: master
11:38:40:       Compiler: Visual C++ 2008
11:38:40:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:38:40:       Platform: win32 10
11:38:40:           Bits: 32
11:38:40:           Mode: Release
11:38:40:******************************* System ********************************
11:38:40:            CPU: Intel(R) Xeon(R) CPU E5-1620 v2 @ 3.70GHz
11:38:40:         CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
11:38:40:           CPUs: 8
11:38:40:         Memory: 31.93GiB
11:38:40:    Free Memory: 26.12GiB
11:38:40:        Threads: WINDOWS_THREADS
11:38:40:     OS Version: 6.2
11:38:40:    Has Battery: false
11:38:40:     On Battery: false
11:38:40:     UTC Offset: 2
11:38:40:            PID: 12012
11:38:40:            CWD: C:\Users\Nino\AppData\Roaming\FAHClient
11:38:40:             OS: Windows 8.1 Pro
11:38:40:        OS Arch: AMD64
11:38:40:           GPUs: 2
11:38:40:          GPU 0: Bus:5 Slot:0 Func:0 NVIDIA:5 GM204 [GeForce GTX 970] 3494
11:38:40:          GPU 1: Bus:4 Slot:0 Func:0 AMD:4 Cedar PRO [Radeon HD
11:38:40:                 5400/6300/7350/8350]
11:38:40:  CUDA Device 0: Platform:0 Device:0 Bus:5 Slot:0 Compute:5.2 Driver:10.1
11:38:40:OpenCL Device 0: Platform:0 Device:0 Bus:5 Slot:0 Compute:1.2 Driver:430.39
11:38:40:OpenCL Device 1: Platform:1 Device:0 Bus:4 Slot:0 Compute:1.2 Driver:1642.5
11:38:40:  Win32 Service: false
11:38:40:***********************************************************************
11:38:40:<config>
11:38:40:  <!-- Folding Core -->
11:38:40:  <checkpoint v='30'/>
11:38:40:
11:38:40:  <!-- Network -->
11:38:40:  <proxy v=':0'/>
11:38:40:
11:38:40:  <!-- Slot Control -->
11:38:40:  <power v='MEDIUM'/>
11:38:40:
11:38:40:  <!-- User Information -->
11:38:40:  <passkey v='********************************'/>
11:38:40:  <user v='gaelazzo'/>
11:38:40:
11:38:40:  <!-- Folding Slots -->
11:38:40:  <slot id='0' type='CPU'/>
11:38:40:  <slot id='1' type='GPU'/>
11:38:40:  <slot id='2' type='GPU'/>
11:38:40:</config>
11:38:40:Trying to access database...
11:38:40:Successfully acquired database lock
11:38:40:Enabled folding slot 00: READY cpu:5
11:38:40:Enabled folding slot 01: READY gpu:0:GM204 [GeForce GTX 970] 3494
11:38:40:Enabled folding slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350]
11:38:40:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
11:38:40:WU00:FS00:Connecting to cores.foldingathome.org:80
11:38:40:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
11:38:40:WU01:FS01:Connecting to cores.foldingathome.org:80
11:38:41:WU02:FS02:Connecting to 65.254.110.245:8080
11:38:41:ERROR:WU00:FS00:Exception: Failed reading core package header.
11:38:41:ERROR:WU01:FS01:Exception: Failed reading core package header.
11:38:41:WU02:FS02:Assigned to work server 192.0.2.1
11:38:41:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
11:38:41:WU02:FS02:Connecting to 192.0.2.1:8080
11:39:02:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
11:39:02:WU02:FS02:Connecting to 192.0.2.1:80
11:39:17:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
11:39:18:WU02:FS02:Connecting to 65.254.110.245:8080
11:39:18:WU02:FS02:Assigned to work server 192.0.2.1
11:39:18:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
11:39:18:WU02:FS02:Connecting to 192.0.2.1:8080
11:39:39:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
11:39:39:WU02:FS02:Connecting to 192.0.2.1:80
11:39:41:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
11:39:41:WU00:FS00:Connecting to cores.foldingathome.org:80
11:39:41:ERROR:WU00:FS00:Exception: Failed reading core package header.
11:39:41:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
11:39:41:WU01:FS01:Connecting to cores.foldingathome.org:80
11:39:41:ERROR:WU01:FS01:Exception: Failed reading core package header.
11:39:54:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
11:40:18:WU02:FS02:Connecting to 65.254.110.245:8080
11:40:18:WU02:FS02:Assigned to work server 192.0.2.1
11:40:18:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
11:40:18:WU02:FS02:Connecting to 192.0.2.1:8080
11:40:39:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
11:40:39:WU02:FS02:Connecting to 192.0.2.1:80
11:40:54:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
11:41:18:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
11:41:18:WU00:FS00:Connecting to cores.foldingathome.org:80
11:41:18:ERROR:WU00:FS00:Exception: Failed reading core package header.
11:41:18:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
11:41:18:WU01:FS01:Connecting to cores.foldingathome.org:80
11:41:18:ERROR:WU01:FS01:Exception: Failed reading core package header.
11:41:55:WU02:FS02:Connecting to 65.254.110.245:8080
11:41:56:WU02:FS02:Assigned to work server 192.0.2.1
11:41:56:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
11:41:56:WU02:FS02:Connecting to 192.0.2.1:8080
11:42:17:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
11:42:17:WU02:FS02:Connecting to 192.0.2.1:80
11:42:32:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
11:42:57:FS00:Paused
11:42:57:FS01:Paused
11:42:57:FS02:Paused
11:42:58:FS00:Unpaused
11:42:58:FS01:Unpaused
11:42:58:FS02:Unpaused
11:42:58:WU02:FS02:Connecting to 65.254.110.245:8080
11:42:59:WU02:FS02:Assigned to work server 192.0.2.1
11:42:59:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
11:42:59:WU02:FS02:Connecting to 192.0.2.1:8080
11:43:20:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
11:43:20:WU02:FS02:Connecting to 192.0.2.1:80
11:43:35:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
11:43:55:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
11:43:55:WU00:FS00:Connecting to cores.foldingathome.org:80
11:43:55:ERROR:WU00:FS00:Exception: Failed reading core package header.
11:43:55:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
11:43:55:WU01:FS01:Connecting to cores.foldingathome.org:80
11:43:55:ERROR:WU01:FS01:Exception: Failed reading core package header.
11:44:36:WU02:FS02:Connecting to 65.254.110.245:8080
11:44:36:WU02:FS02:Assigned to work server 192.0.2.1
11:44:36:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
11:44:36:WU02:FS02:Connecting to 192.0.2.1:8080
11:44:57:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
11:44:57:WU02:FS02:Connecting to 192.0.2.1:80
11:45:12:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
11:47:13:WU02:FS02:Connecting to 65.254.110.245:8080
11:47:13:WU02:FS02:Assigned to work server 192.0.2.1
11:47:13:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
11:47:13:WU02:FS02:Connecting to 192.0.2.1:8080
11:47:34:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
11:47:34:WU02:FS02:Connecting to 192.0.2.1:80
11:47:49:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
11:48:09:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
11:48:09:WU00:FS00:Connecting to cores.foldingathome.org:80
11:48:09:ERROR:WU00:FS00:Exception: Failed reading core package header.
11:48:09:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
11:48:09:WU01:FS01:Connecting to cores.foldingathome.org:80
11:48:10:ERROR:WU01:FS01:Exception: Failed reading core package header.
11:51:27:WU02:FS02:Connecting to 65.254.110.245:8080
11:51:28:WU02:FS02:Assigned to work server 192.0.2.1
11:51:28:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
11:51:28:WU02:FS02:Connecting to 192.0.2.1:8080
11:51:49:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
11:51:49:WU02:FS02:Connecting to 192.0.2.1:80
11:52:04:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
11:55:00:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
11:55:00:WU00:FS00:Connecting to cores.foldingathome.org:80
11:55:01:ERROR:WU00:FS00:Exception: Failed reading core package header.
11:55:01:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
11:55:01:WU01:FS01:Connecting to cores.foldingathome.org:80
11:55:01:ERROR:WU01:FS01:Exception: Failed reading core package header.
11:58:18:WU02:FS02:Connecting to 65.254.110.245:8080
11:58:19:WU02:FS02:Assigned to work server 192.0.2.1
11:58:19:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
11:58:19:WU02:FS02:Connecting to 192.0.2.1:8080
11:58:40:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
11:58:40:WU02:FS02:Connecting to 192.0.2.1:80
11:58:55:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
12:06:06:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
12:06:06:WU00:FS00:Connecting to cores.foldingathome.org:80
12:06:06:ERROR:WU00:FS00:Exception: Failed reading core package header.
12:06:06:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
12:06:06:WU01:FS01:Connecting to cores.foldingathome.org:80
12:06:06:ERROR:WU01:FS01:Exception: Failed reading core package header.
12:09:24:WU02:FS02:Connecting to 65.254.110.245:8080
12:09:24:WU02:FS02:Assigned to work server 192.0.2.1
12:09:24:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
12:09:24:WU02:FS02:Connecting to 192.0.2.1:8080
12:09:45:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
12:09:45:WU02:FS02:Connecting to 192.0.2.1:80
12:10:00:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
12:24:02:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
12:24:02:WU00:FS00:Connecting to cores.foldingathome.org:80
12:24:03:ERROR:WU00:FS00:Exception: Failed reading core package header.
12:24:03:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
12:24:03:WU01:FS01:Connecting to cores.foldingathome.org:80
12:24:03:ERROR:WU01:FS01:Exception: Failed reading core package header.
12:27:21:WU02:FS02:Connecting to 65.254.110.245:8080
12:27:21:WU02:FS02:Assigned to work server 192.0.2.1
12:27:21:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
12:27:21:WU02:FS02:Connecting to 192.0.2.1:8080
12:27:42:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
12:27:42:WU02:FS02:Connecting to 192.0.2.1:80
12:27:57:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
12:53:05:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
12:53:05:WU00:FS00:Connecting to cores.foldingathome.org:80
12:53:05:ERROR:WU00:FS00:Exception: Failed reading core package header.
12:53:05:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
12:53:05:WU01:FS01:Connecting to cores.foldingathome.org:80
12:53:05:ERROR:WU01:FS01:Exception: Failed reading core package header.
12:56:23:WU02:FS02:Connecting to 65.254.110.245:8080
12:56:23:WU02:FS02:Assigned to work server 192.0.2.1
12:56:23:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Cedar PRO [Radeon HD 5400/6300/7350/8350] from 192.0.2.1
12:56:23:WU02:FS02:Connecting to 192.0.2.1:8080
12:56:44:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
12:56:44:WU02:FS02:Connecting to 192.0.2.1:80
12:56:59:ERROR:WU02:FS02:Exception: 10001: Server responded: HTTP_BAD_GATEWAY
Post by Neil-B »
SO I am reckoning that the GeForce GTX 970 should be able to fold but is throwing an error I haven't encountered before:
For the Radeon HD 5400/6300/7350/8350 (not sure which you GPU actually is) - I have a suspicion that it will be a model that does not support double precision floating point and therefore is not suitable for folding - this is what the 192.0.2.1 messages relate to … feel free to check https://www.techpowerup.com/gpu-specs/ and see if you can track down you actual GPU - what you are looking for on their layout is for a figure listed next to "FP64 (double) performance" (you can see this on the record for the GTX) … There are other factors as well but this seems to be the one most cards fall short on.
So someone with better technical knowledge than me will hopefully step in and advise on the GTX GPU … instinct tells me this might be a firewall type issue - but that is a guess on my part.
The Radeon does not support DP, that is the redirect to A test/documentation IP. Just remove that folding slot and possibly the card if you are not using it for your display.
Tohya wrote:192.0.2.1 would typically be a router and not one of F@H work servers.
No, that range you will not see on a router as it is reserved for test/documentation purposes.
As for the "Failed reading core package header" error messages, those most likely come from firewall blocking. The FAHClient process uses HTTP over ports 8080 and/or 80 to do data transfers inbound and outbound. By default many firewalls block inbound connections using HTTP if it is not being done by a "known" web browsers such as Chrome, Firefox, IE, and so on. You will need to add an exception for FAHClient allowing it the same ability to transfer as a web browser.
Also make certain that the user that FAHClient is running under has R/W access to the directory shown in th log as CWD:
Neil-B wrote:12:24:03:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
Proxy/Firewall/Security software blocking the connection of FAHClient.
gaetano.lazzo
I've tried disabling the firewall, giving authenticated users all permissions on tghe fsa folders, running fsa as administrator.
Nothing worked.
Thanks to all, I surrender.
This software is too hard to use, you should not be such a network engineer to contribute a distributed calculus. Very bad.
Have a nice day.
