I received a WU that was already credited to someone else
VirtualCtor
Post by VirtualCtor »
Today, I received the following WU in my client:
00:17:42:WU00:FS01:0x22:Project: 11751 (Run 0, Clone 6032, Gen 2)
00:17:42:WU00:FS01:0x22:Unit: 0x000000078ca304e75e6bbb6dd94c4d2c
This WU completed processing and was submitted:
02:16:03:WU00:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
02:17:13:WU00:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
02:17:18:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
02:17:18:WU00:FS01:0x22:Saving result file checkpointState.xml
02:17:20:WU00:FS01:0x22:Saving result file checkpt.crc
02:17:20:WU00:FS01:0x22:Saving result file positions.xtc
02:17:22:WU00:FS01:0x22:Saving result file science.log
02:17:22:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
02:17:22:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:17:22:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11751 run:0 clone:6032 gen:2 core:0x22 unit:0x000000078ca304e75e6bbb6dd94c4d2c
02:17:22:WU00:FS01:Uploading 14.66MiB to 140.163.4.231
02:17:22:WU00:FS01:Connecting to 140.163.4.231:8080
02:17:28:WU00:FS01:Upload 48.62%
02:17:34:WU00:FS01:Upload 86.14%
02:17:37:WU00:FS01:Upload complete
But the server did not like it:
02:17:37:WU00:FS01:Server responded WORK_QUIT (404)
02:17:37:WARNING:WU00:FS01:Server did not like results, dumping
I went to try to figure out why this was the case and it turns out that this WU was already returned by zientek106 on 2020-03-30 13:17:09.
Why are finished WUs being sent out again?
nerok
Re: I received a WU that was already credited to someone els
Post by nerok »
This happended to me aswell but on another project (close in numbering so might be similar).
03:33:41:WU02:FS01:0x22:Project: 11750 (Run 0, Clone 6441, Gen 1)
03:33:41:WU02:FS01:0x22:Unit: 0x000000078ca304e75e6bb9cf570ce00c
My computer never managed to upload though.
06:23:10:WU02:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
06:23:14:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
06:23:14:WU02:FS01:0x22:Saving result file checkpointState.xml
06:23:16:WU02:FS01:0x22:Saving result file checkpt.crc
06:23:16:WU02:FS01:0x22:Saving result file positions.xtc
06:23:18:WU02:FS01:0x22:Saving result file science.log
06:23:18:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
06:23:18:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:23:18:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11750 run:0 clone:6441 gen:1 core:0x22 unit:0x000000078ca304e75e6bb9cf570ce00c
06:23:18:WU02:FS01:Uploading 14.51MiB to 140.163.4.231
06:23:18:WU02:FS01:Connecting to 140.163.4.231:8080
06:23:40:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
06:23:40:WU02:FS01:Connecting to 140.163.4.231:80
06:24:01:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
When checking WU status I see that it was assigned, returned and credited around the same time, March 30th at 04:24GMT
Hi KIT-ETP (team 250565), Your WU (P11750 R0 C6441 G1) was added to the stats database on Mon, 30 Mar 2020 04:24:35 GMT for 7608 points of credit.
The primary reason why WUs are sent out more than once is that somebody got the WU and could not finish it. Of the failed WUs, that arrive back at the FAH servers, several things can happen. In no particular order:
1) The WU fails because it was in an invalid configuration when it was generated.
2) The client running the WU is overclocked and, in fact, unstable
3) The WU passes the Timeout and is therefore assumed to be lost.
In all cases, the WU is reissued a limited number of times.
Especially in case 3, it's possible that both WUs are still "in flight" and either one may be returned first. (Each one becomes an independent assignment.)
When duplicates are, in fact, issued and are returned, each one can receive credit. Without any additional information, I'm going to assume that's true in your case.
treckin
Post by treckin »
Hey Bruce,
I wanted to point out that this particular server appears to be causing multiple issues (See threads in "issues with specific server"
I have a WU that fails on uploading every time at 0.51% uploaded.
Best,
Understood.
I recently commented in a topic called "PLEASE_WAIT" that there's a pending fix for some upload problems. Being an optimist, I'm hoping that the same fix may help with other upload problems which do not include the PLEASE_WAIT message. I have no way of knowing, though.
VirtualCtor
bruce wrote: When duplicates are, in fact, issued and are returned, each one can receive credit. Without any additional information, I'm going to assume that's true in your case.
Hmmm, In this particular case, I did not get credit. There is only one person listed as having processed the WU and the WU passed days before I even received the it.
WU in question: https://apps.foldingathome.org/wu#proje ... 6032&gen=2
You can see from the log snippits that I processed the WU, but I am not listed in the status as having processed it or having a failure. I'm not clear what combination of factors from your list would cause this. Why would a WU be processed again after it was successful and there were no previous failures?
Oh, well, probably not important, just very odd. Thanks!
VirtualCtor
That's the same machine I was connecting to. Looks like others have noted that this machine may have issues, so hopefully it will get fixed.
I hope they remember to reboot it three times for maximum stability. :mrgreen:
VirtualCtor
This just happened to me again.
Work unit: project:11751 run:0 clone:5232 gen:13
This work unit was already credited on 2020-04-02 18:58:21.
Note that a single person successfully processed the work unit. There are no errors associated with the work unit on the page.
Why are work units that were already credited 6 days ago being sent out today?
Full log:
01:16:29:WU01:FS01:Downloading 7.92MiB
01:16:37:WU01:FS01:Download 3.94%
01:16:38:WU01:FS01:Download complete
01:16:38:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11751 run:0 clone:5232 gen:13 core:0x22 unit:0x0000001b8ca304e75e6bbb1a9c0ee701
01:16:38:WU01:FS01:Starting
01:16:38:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\me\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 7320 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
01:16:38:WU01:FS01:Started FahCore on PID 10060
01:16:38:WU01:FS01:Core PID:15644
01:16:38:WU01:FS01:FahCore 0x22 started
01:16:39:WU01:FS01:0x22:*********************** Log Started 2020-04-08T01:16:38Z ***********************
01:16:39:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
01:16:39:WU01:FS01:0x22:       Type: 0x22
01:16:39:WU01:FS01:0x22:       Core: Core22
01:16:39:WU01:FS01:0x22:    Website: https://foldingathome.org/
01:16:39:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
01:16:39:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
01:16:39:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
01:16:39:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 10060 -checkpoint 15
01:16:39:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
01:16:39:WU01:FS01:0x22:             0 -gpu 0
01:16:39:WU01:FS01:0x22:     Config: <none>
01:16:39:WU01:FS01:0x22:************************************ Build *************************************
01:16:39:WU01:FS01:0x22:    Version: 0.0.2
01:16:39:WU01:FS01:0x22:       Date: Dec 6 2019
01:16:39:WU01:FS01:0x22:       Time: 21:30:31
01:16:39:WU01:FS01:0x22: Repository: Git
01:16:39:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
01:16:39:WU01:FS01:0x22:     Branch: HEAD
01:16:39:WU01:FS01:0x22:   Compiler: Visual C++ 2008
01:16:39:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:16:39:WU01:FS01:0x22:   Platform: win32 10
01:16:39:WU01:FS01:0x22:       Bits: 64
01:16:39:WU01:FS01:0x22:       Mode: Release
01:16:39:WU01:FS01:0x22:************************************ System ************************************
01:16:39:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
01:16:39:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
01:16:39:WU01:FS01:0x22:       CPUs: 4
01:16:39:WU01:FS01:0x22:     Memory: 31.95GiB
01:16:39:WU01:FS01:0x22:Free Memory: 24.35GiB
01:16:39:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
01:16:39:WU01:FS01:0x22: OS Version: 6.2
01:16:39:WU01:FS01:0x22:Has Battery: false
01:16:39:WU01:FS01:0x22: On Battery: false
01:16:39:WU01:FS01:0x22: UTC Offset: -4
01:16:39:WU01:FS01:0x22:        PID: 15644
01:16:39:WU01:FS01:0x22:        CWD: C:\Users\me\AppData\Roaming\FAHClient\work
01:16:39:WU01:FS01:0x22:         OS: Windows 10 Pro
01:16:39:WU01:FS01:0x22:    OS Arch: AMD64
01:16:39:WU01:FS01:0x22:********************************************************************************
01:16:39:WU01:FS01:0x22:Project: 11751 (Run 0, Clone 5232, Gen 13)
01:16:39:WU01:FS01:0x22:Unit: 0x0000001b8ca304e75e6bbb1a9c0ee701
01:16:39:WU01:FS01:0x22:Reading tar file core.xml
01:16:39:WU01:FS01:0x22:Reading tar file integrator.xml
01:16:39:WU01:FS01:0x22:Reading tar file state.xml
01:16:41:WU01:FS01:0x22:Reading tar file system.xml
01:16:42:WU01:FS01:0x22:Digital signatures verified
01:16:42:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
01:16:42:WU01:FS01:0x22:Version 0.0.2
01:16:56:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
01:16:56:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
01:18:11:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
01:19:24:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
01:20:38:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
01:21:52:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
01:23:06:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
01:24:25:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
01:25:39:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
01:26:53:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
01:28:07:WU01:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
01:29:20:WU01:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
01:30:40:WU01:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
01:31:54:WU01:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
01:33:09:WU01:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
01:34:23:WU01:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
01:35:37:WU01:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
01:36:56:WU01:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
01:38:10:WU01:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
01:39:24:WU01:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
01:40:38:WU01:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
01:41:54:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
01:43:13:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
01:44:28:WU01:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
01:45:43:WU01:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
01:46:57:WU01:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
01:48:10:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
01:49:30:WU01:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
01:50:44:WU01:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
01:51:59:WU01:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
01:53:12:WU01:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
01:54:25:WU01:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
01:55:44:WU01:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
01:56:58:WU01:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
01:58:12:WU01:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
01:59:25:WU01:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
02:00:39:WU01:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
02:01:59:WU01:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
02:03:13:WU01:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
02:04:26:WU01:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
02:05:40:WU01:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
02:06:55:WU01:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
02:08:26:WU01:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
02:09:44:WU01:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
02:11:03:WU01:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
02:12:18:WU01:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
02:13:33:WU01:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
02:14:53:WU01:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
02:16:07:WU01:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
02:17:20:WU01:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
02:18:33:WU01:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
02:19:47:WU01:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
02:21:06:WU01:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
02:22:22:WU01:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
02:23:36:WU01:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
02:24:50:WU01:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
02:26:03:WU01:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
02:27:24:WU01:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
02:28:43:WU01:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
02:30:01:WU01:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
02:31:21:WU01:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
02:32:38:WU01:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
02:34:00:WU01:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
02:35:15:WU01:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
02:36:35:WU01:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
02:37:53:WU01:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
02:39:08:WU01:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
02:40:26:WU01:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
02:41:40:WU01:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
02:42:53:WU01:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
02:44:07:WU01:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
02:45:21:WU01:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
02:46:39:WU01:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
02:47:53:WU01:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
02:49:06:WU01:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
02:50:20:WU01:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
02:51:33:WU01:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
02:52:52:WU01:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
02:54:06:WU01:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
02:55:20:WU01:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
02:56:34:WU01:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
02:57:49:WU01:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
02:59:10:WU01:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
03:00:23:WU01:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
03:01:37:WU01:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
03:02:50:WU01:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
03:04:04:WU01:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
03:05:22:WU01:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
03:06:36:WU01:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
03:07:50:WU01:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
03:09:04:WU01:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
03:10:17:WU01:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
03:11:37:WU01:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
03:12:51:WU01:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
03:14:04:WU01:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
03:15:17:WU01:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
03:16:31:WU01:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
03:17:52:WU01:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
03:19:05:WU01:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
03:20:19:WU01:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
03:21:33:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
03:21:34:WU00:FS01:Connecting to 65.254.110.245:8080
03:21:34:WU00:FS01:Assigned to work server 40.114.52.201
03:21:34:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 40.114.52.201
03:21:34:WU00:FS01:Connecting to 40.114.52.201:8080
03:21:50:WU00:FS01:Downloading 79.27MiB
03:21:56:WU00:FS01:Download 27.44%
03:22:02:WU00:FS01:Download 56.06%
03:22:08:WU00:FS01:Download 83.81%
03:22:12:WU00:FS01:Download complete
03:22:12:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11776 run:0 clone:26006 gen:0 core:0x22 unit:0x00000003287234c95e774b0b47fb2414
03:22:47:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
03:22:52:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
03:22:52:WU01:FS01:0x22:Saving result file checkpointState.xml
03:22:56:WU01:FS01:0x22:Saving result file checkpt.crc
03:22:56:WU01:FS01:0x22:Saving result file positions.xtc
03:22:58:WU01:FS01:0x22:Saving result file science.log
03:22:58:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
03:22:58:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:22:58:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11751 run:0 clone:5232 gen:13 core:0x22 unit:0x0000001b8ca304e75e6bbb1a9c0ee701
03:22:58:WU01:FS01:Uploading 14.65MiB to 140.163.4.231
03:22:58:WU00:FS01:Starting
03:22:58:WU01:FS01:Connecting to 140.163.4.231:8080
03:22:58:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\me\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 7320 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
03:22:58:WU00:FS01:Started FahCore on PID 14748
03:22:58:WU00:FS01:Core PID:11684
03:22:58:WU00:FS01:FahCore 0x22 started
03:22:59:WU00:FS01:0x22:*********************** Log Started 2020-04-08T03:22:59Z ***********************
03:22:59:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
03:22:59:WU00:FS01:0x22:       Type: 0x22
03:22:59:WU00:FS01:0x22:       Core: Core22
03:22:59:WU00:FS01:0x22:    Website: https://foldingathome.org/
03:22:59:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
03:22:59:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:22:59:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
03:22:59:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 14748 -checkpoint 15
03:22:59:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
03:22:59:WU00:FS01:0x22:             0 -gpu 0
03:22:59:WU00:FS01:0x22:     Config: <none>
03:22:59:WU00:FS01:0x22:************************************ Build *************************************
03:22:59:WU00:FS01:0x22:    Version: 0.0.2
03:22:59:WU00:FS01:0x22:       Date: Dec 6 2019
03:22:59:WU00:FS01:0x22:       Time: 21:30:31
03:22:59:WU00:FS01:0x22: Repository: Git
03:22:59:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
03:22:59:WU00:FS01:0x22:     Branch: HEAD
03:22:59:WU00:FS01:0x22:   Compiler: Visual C++ 2008
03:22:59:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:22:59:WU00:FS01:0x22:   Platform: win32 10
03:22:59:WU00:FS01:0x22:       Bits: 64
03:22:59:WU00:FS01:0x22:       Mode: Release
03:22:59:WU00:FS01:0x22:************************************ System ************************************
03:22:59:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
03:22:59:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
03:22:59:WU00:FS01:0x22:       CPUs: 4
03:22:59:WU00:FS01:0x22:     Memory: 31.95GiB
03:22:59:WU00:FS01:0x22:Free Memory: 25.58GiB
03:22:59:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
03:22:59:WU00:FS01:0x22: OS Version: 6.2
03:22:59:WU00:FS01:0x22:Has Battery: false
03:22:59:WU00:FS01:0x22: On Battery: false
03:22:59:WU00:FS01:0x22: UTC Offset: -4
03:22:59:WU00:FS01:0x22:        PID: 11684
03:22:59:WU00:FS01:0x22:        CWD: C:\Users\me\AppData\Roaming\FAHClient\work
03:22:59:WU00:FS01:0x22:         OS: Windows 10 Pro
03:22:59:WU00:FS01:0x22:    OS Arch: AMD64
03:22:59:WU00:FS01:0x22:********************************************************************************
03:22:59:WU00:FS01:0x22:Project: 11776 (Run 0, Clone 26006, Gen 0)
03:22:59:WU00:FS01:0x22:Unit: 0x00000003287234c95e774b0b47fb2414
03:22:59:WU00:FS01:0x22:Reading tar file core.xml
03:22:59:WU00:FS01:0x22:Reading tar file integrator.xml
03:22:59:WU00:FS01:0x22:Reading tar file state.xml
03:23:00:WU00:FS01:0x22:Reading tar file system.xml
03:23:01:WU00:FS01:0x22:Digital signatures verified
03:23:01:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
03:23:01:WU00:FS01:0x22:Version 0.0.2
03:23:22:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
03:23:22:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:23:59:WU01:FS01:Upload 1.28%
03:24:05:WU01:FS01:Upload 44.36%
03:24:11:WU01:FS01:Upload 62.27%
03:24:15:WU01:FS01:Upload complete
03:24:15:WU01:FS01:Server responded WORK_QUIT (404)
03:24:15:WARNING:WU01:FS01:Server did not like results, dumping
03:24:15:WU01:FS01:Cleaning up
Knish
Post by Knish »
I spotted a similar one here https://apps.foldingathome.org/wu#proje ... 034&gen=12
despite someone posting their log where they got it assigned almost 25 hrs after the first person was assigned it despite it being successfully returned in 5 hrs.
I wonder...? From Linus Tech's server video we saw a glimpse of bandwidth loads and the cross server communication seems to massively outweigh any client to server loads, and from the EOC stats pages showing frequent 0 point updates due to fah points flat-file generation getting paused when they become inundated, makes me wonder what other things become slow to get updated? so maybe duplicate WUs are getting sent out simply because whatever process hasn't had the time to update them yet?
edit> oh, but yeah, 6 days seems like an extreme length of time but 117xx come from the cancer institute's servers and I noticed a few days ago that of the 3 servers they have, one of them has been Down status for many days in a row and finally got taken off the serverstatus page completely, so maybe your WU was lost in that transition?
Knish
Post by Knish »
huh..... 4 success in a row
https://apps.foldingathome.org/wu#proje ... 746&gen=43
Some of this can come from returns to Collection Servers, the WS will not have information that a particular WU has been returned until the results are uploaded from the CS to the WS. Normally this occurs within a relatively short time, but under the high network loads lately there have been substantial delays. That has sometimes resulted in WUs returned within the Timeout to CS, but the WS issuing a WU again because it had not received the WU by the timeout.
