some issues with the viewer/screen saver
regchan
Post by regchan »
just noticed this issue bug
ok there is nothing populated for the following field inless stated
current work unit
project
fahcore
progress
time left
donor
name
team
status snapshot 1.- of 4 but keeps going up and down
connection says trying
protein says demo
slot is blank
VirtualCtor
Re: some issues with the viewer/screen saver
Post by VirtualCtor »
These are known issues with the viewer. I can't post a link, but issue #1283 in the FoldingAtHome project on GitHub has a workaround for the demo protein issue.
regchan
Post by regchan »
this screen seems to be a bit light on details any way to get the info or is it somthing im blocking url wise
VirtualCtor
It's a bug in the latest version* of the viewer. The workaround is to install the previous version of the viewer.
EDIT: This is a Windows version issue only (as confirmed by Joe_H).
regchan
Post by regchan »
thats @VirtuakCtor now just the screen saver is bugged
Known issue with latest version of FAHViewer on Windows. Does work on Linux and OS X for some, not all WUs.
